root/radiance/ray/src/gen/mkillum.c
Revision: 2.27
Committed: Wed Jun 7 17:52:04 2006 UTC (17 years, 11 months ago) by schorsch
Changes since 2.26: +2 -1 lines
2 static const char RCSid[] = "$Id: mkillum.c,v 2.26 2005/09/19 11:30:10 schorsch Exp $";
5 * Make illum sources for optimizing rendering process
6 */
7
8 #include <signal.h>
9 #include <ctype.h>
10
11 #include "platform.h"
12 #include "mkillum.h"
13 #include "random.h"
14
15 /* default parameters */
16 #define SAMPDENS 48 /* points per projected steradian */
17 #define NSAMPS 32 /* samples per point */
18 #define DFLMAT "illum_mat" /* material name */
19 #define DFLDAT "illum" /* data file name */
20 /* selection options */
21 #define S_NONE 0 /* select none */
22 #define S_ELEM 1 /* select specified element */
23 #define S_COMPL 2 /* select all but element */
24 #define S_ALL 3 /* select all */
25
26 /* rtrace command and defaults */
27 char *rtargv[64] = { "rtrace", "-dj", ".25", "-dr", "3", "-dv-",
28 "-ab", "2", "-ad", "1024", "-as", "512", "-aa", ".1", };
29 int rtargc = 14;
30 /* overriding rtrace options */
31 char *myrtopts[] = { "-I-", "-i-", "-ld-", "-ov", "-h-",
32 "-fff", "-y", "0", NULL };
33
34 struct rtproc rt0; /* head of rtrace process list */
35
36 struct illum_args thisillum = { /* our illum and default values */
37 0,
38 DFLMAT,
39 DFLDAT,
40 0,
41 VOIDID,
42 SAMPDENS,
43 NSAMPS,
44 0.,
45 };
46
47 char matcheck[MAXSTR]; /* current material to include or exclude */
48 int matselect = S_ALL; /* selection criterion */
49
50 FUN ofun[NUMOTYPE] = INIT_OTYPE; /* object types */
51
52 char persistfn[] = "pfXXXXXX"; /* persist file name */
53
54 int gargc; /* global argc */
55 char **gargv; /* global argv */
56 #define progname gargv[0]
57
58 int doneheader = 0; /* printed header yet? */
59 #define checkhead() if (!doneheader++) printhead(gargc,gargv)
60
61 int warnings = 1; /* print warnings? */
62
63 int done_rprocs(struct rtproc *rtp);
64 void init(int np);
65 void filter(register FILE *infp, char *name);
66 void xoptions(char *s, char *nm);
67 void printopts(void);
68 void printhead(register int ac, register char **av);
69 void xobject(FILE *fp, char *nm);
70
71
72 int
73 main( /* compute illum distributions using rtrace */
74 int argc,
75 char *argv[]
76 )
77 {
78 int nprocs = 1;
79 char *rtpath;
80 FILE *fp;
81 register int i;
82 /* set global arguments */
83 gargv = argv;
84 /* check for -n option */
85 if (!strcmp(argv[1], "-n")) {
86 nprocs = atoi(argv[2]);
87 if (nprocs <= 0)
88 error(USER, "illegal number of processes");
89 i = 3;
90 } else
91 i = 1;
92 /* set up rtrace command */
93 for ( ; i < argc; i++) {
94 if (argv[i][0] == '<' && argv[i][1] == '\0')
95 break;
96 rtargv[rtargc++] = argv[i];
97 if (argv[i][0] == '-' && argv[i][1] == 'w')
98 switch (argv[i][2]) {
99 case '\0':
100 warnings = !warnings;
101 break;
102 case '+':
103 case 'T': case 't':
104 case 'Y': case 'y':
105 case '1':
106 warnings = 1;
107 break;
108 case '-':
109 case 'F': case 'f':
110 case 'N': case 'n':
111 case '0':
112 warnings = 0;
113 break;
114 }
115 }
116 gargc = i;
117 if (!strcmp(rtargv[--rtargc], "-defaults"))
118 nprocs = 0;
119 if (nprocs > 1) { /* add persist file if parallel invocation */
120 rtargv[rtargc++] = "-PP";
121 rtargv[rtargc++] = mktemp(persistfn);
122 }
123 /* add "mandatory" rtrace options */
124 for (i = 0; myrtopts[i] != NULL; i++)
125 rtargv[rtargc++] = myrtopts[i];
126 /* finally, put back final argument */
127 rtargv[rtargc++] = argv[gargc-1];
128 rtargv[rtargc] = NULL;
129 if (!nprocs) { /* just asking for defaults? */
130 printopts(); fflush(stdout);
131 rtpath = getpath(rtargv[0], getenv("PATH"), X_OK);
132 if (rtpath == NULL) {
133 eputs(rtargv[0]);
134 eputs(": command not found\n");
135 exit(1);
136 }
137 execv(rtpath, rtargv);
138 perror(rtpath); /* execv() should not return */
139 exit(1);
140 }
141 if (gargc < 2 || argv[gargc-1][0] == '-')
142 error(USER, "missing octree argument");
143 /* else initialize and run our calculation */
144 init(nprocs);
145 if (gargc+1 < argc)
146 for (i = gargc+1; i < argc; i++) {
147 if ((fp = fopen(argv[i], "r")) == NULL) {
148 sprintf(errmsg,
149 "cannot open scene file \"%s\"", argv[i]);
150 error(SYSTEM, errmsg);
151 }
152 filter(fp, argv[i]);
153 fclose(fp);
154 }
155 else
156 filter(stdin, "standard input");
157 quit(0);
158 return 0; /* pro forma return */
159 }
160
161
162 #ifndef SIGALRM
163 #define SIGALRM SIGTERM
164 #endif
165 static void
166 killpersist(void) /* kill persistent rtrace process */
167 {
168 FILE *fp = fopen(persistfn, "r");
169 int pid;
170
171 if (fp == NULL)
172 return;
173 if (fscanf(fp, "%*s %d", &pid) != 1 || kill(pid, SIGALRM) < 0)
174 unlink(persistfn);
175 fclose(fp);
176 }
177
178
179 int
180 done_rprocs(struct rtproc *rtp)
181 {
182 int st0, st1 = 0;
183
184 if (rtp->next != NULL) { /* close last opened first! */
185 st1 = done_rprocs(rtp->next);
186 free((void *)rtp->next);
187 rtp->next = NULL;
188 }
189 st0 = close_process(&rtp->pd);
190 if (st0 < 0)
191 error(WARNING, "unknown return status from rtrace process");
192 else if (st0 > 0)
193 return(st0);
194 return(st1);
195 }
196
197 void
198 quit(int status) /* exit with status */
199 {
200 int rtstat;
201
202 if (rt0.next != NULL) /* terminate persistent rtrace */
203 killpersist();
204 /* clean up rtrace process(es) */
205 rtstat = done_rprocs(&rt0);
206 if (status == 0)
207 status = rtstat;
208 exit(status);
209 }
210
211 void
212 init(int np) /* start rtrace and set up buffers */
213 {
214 struct rtproc *rtp;
215 int i;
216 int maxbytes;
217 /* set up object functions */
218 ofun[OBJ_FACE].funp = o_face;
219 ofun[OBJ_SPHERE].funp = o_sphere;
220 ofun[OBJ_RING].funp = o_ring;
221 /* set up signal handling */
222 signal(SIGINT, quit);
223 #ifdef SIGHUP
224 signal(SIGHUP, quit);
225 #endif
226 #ifdef SIGTERM
227 signal(SIGTERM, quit);
228 #endif
229 #ifdef SIGPIPE
230 signal(SIGPIPE, quit);
231 #endif
232 rtp = &rt0; /* start rtrace process(es) */
233 for (i = 0; i++ < np; ) {
234 errno = 0;
235 maxbytes = open_process(&rtp->pd, rtargv);
236 if (maxbytes == 0) {
237 eputs(rtargv[0]);
238 eputs(": command not found\n");
239 exit(1);
240 }
241 if (maxbytes < 0)
242 error(SYSTEM, "cannot start rtrace process");
243 rtp->bsiz = maxbytes/(6*sizeof(float));
244 rtp->buf = (float *)malloc(6*sizeof(float)*rtp->bsiz--);
245 rtp->dest = (float **)calloc(rtp->bsiz, sizeof(float *));
246 if (rtp->buf == NULL || rtp->dest == NULL)
247 error(SYSTEM, "out of memory in init");
248 rtp->nrays = 0;
249 if (i == np) /* last process? */
250 break;
251 if (np > 1)
252 sleep(2); /* wait for persist file */
253 rtp->next = (struct rtproc *)malloc(sizeof(struct rtproc));
254 if (rtp->next == NULL)
255 error(SYSTEM, "out of memory in init");
256 rtp = rtp->next;
257 }
258 rtp->next = NULL;
259 /* set up urand */
260 initurand(16384);
261 }
262
263
264 void
265 eputs( /* put string to stderr */
266 register char *s
267 )
268 {
269 static int midline = 0;
270
271 if (!*s) return;
272 if (!midline) {
273 fputs(progname, stderr);
274 fputs(": ", stderr);
275 }
276 fputs(s, stderr);
277 midline = s[strlen(s)-1] != '\n';
278 }
279
280
281 void
282 wputs(s) /* print warning if enabled */
283 char *s;
284 {
285 if (warnings)
286 eputs(s);
287 }
288
289
290 void
291 filter( /* process stream */
292 register FILE *infp,
293 char *name
294 )
295 {
296 char buf[512];
297 FILE *pfp;
298 register int c;
299
300 while ((c = getc(infp)) != EOF) {
301 if (isspace(c))
302 continue;
303 if (c == '#') { /* comment/options */
304 buf[0] = c;
305 fgets(buf+1, sizeof(buf)-1, infp);
306 xoptions(buf, name);
307 } else if (c == '!') { /* command */
308 buf[0] = c;
309 fgetline(buf+1, sizeof(buf)-1, infp);
310 if ((pfp = popen(buf+1, "r")) == NULL) {
311 sprintf(errmsg, "cannot execute \"%s\"", buf);
312 error(SYSTEM, errmsg);
313 }
314 filter(pfp, buf);
315 pclose(pfp);
316 } else { /* object */
317 ungetc(c, infp);
318 xobject(infp, name);
319 }
320 }
321 }
322
323
324 void
325 xoptions( /* process options in string s */
326 char *s,
327 char *nm
328 )
329 {
330 extern FILE *freopen();
331 char buf[64];
332 int nerrs = 0;
333 register char *cp;
334
335 if (strncmp(s, "#@mkillum", 9) || !isspace(s[9])) {
336 fputs(s, stdout); /* not for us */
337 return;
338 }
339 cp = s+10;
340 while (*cp) {
341 switch (*cp) {
342 case ' ':
343 case '\t':
344 case '\n':
345 case '\r':
346 case '\f':
347 cp++;
348 continue;
349 case 'm': /* material name */
350 if (*++cp != '=')
351 break;
352 if (!*++cp || isspace(*cp))
353 break;
354 atos(thisillum.matname, MAXSTR, cp);
355 cp = sskip(cp);
356 if (!(thisillum.flags & IL_DATCLB)) {
357 strcpy(thisillum.datafile, thisillum.matname);
358 thisillum.dfnum = 0;
359 }
360 continue;
361 case 'f': /* data file name */
362 if (*++cp != '=')
363 break;
364 if (!*++cp || isspace(*cp)) {
365 strcpy(thisillum.datafile,thisillum.matname);
366 thisillum.dfnum = 0;
367 thisillum.flags &= ~IL_DATCLB;
368 continue;
369 }
370 atos(thisillum.datafile, MAXSTR, cp);
371 cp = sskip(cp);
372 thisillum.dfnum = 0;
373 thisillum.flags |= IL_DATCLB;
374 continue;
375 case 'i': /* include material */
376 case 'e': /* exclude material */
377 if (cp[1] != '=')
378 break;
379 matselect = (*cp == 'i') ? S_ELEM : S_COMPL;
380 cp += 2;
381 atos(matcheck, MAXSTR, cp);
382 cp = sskip(cp);
383 continue;
384 case 'a': /* use everything */
385 cp = sskip(cp);
386 matselect = S_ALL;
387 continue;
388 case 'n': /* use nothing (passive) */
389 cp = sskip(cp);
390 matselect = S_NONE;
391 continue;
392 case 'c': /* color calculation */
393 if (*++cp != '=')
394 break;
395 switch (*++cp) {
396 case 'a': /* average */
397 thisillum.flags = (thisillum.flags|IL_COLAVG)
398 & ~IL_COLDST;
399 break;
400 case 'd': /* distribution */
401 thisillum.flags |= (IL_COLDST|IL_COLAVG);
402 break;
403 case 'n': /* none */
404 thisillum.flags &= ~(IL_COLAVG|IL_COLDST);
405 break;
406 default:
407 goto opterr;
408 }
409 cp = sskip(cp);
410 continue;
411 case 'd': /* point sample density */
412 if (*++cp != '=')
413 break;
414 if (!isintd(++cp, " \t\n\r"))
415 break;
416 thisillum.sampdens = atoi(cp);
417 cp = sskip(cp);
418 continue;
419 case 's': /* point super-samples */
420 if (*++cp != '=')
421 break;
422 if (!isintd(++cp, " \t\n\r"))
423 break;
424 thisillum.nsamps = atoi(cp);
425 cp = sskip(cp);
426 continue;
427 case 'l': /* light sources */
428 cp++;
429 if (*cp == '+')
430 thisillum.flags |= IL_LIGHT;
431 else if (*cp == '-')
432 thisillum.flags &= ~IL_LIGHT;
433 else
434 break;
435 cp++;
436 continue;
437 case 'b': /* brightness */
438 if (*++cp != '=')
439 break;
440 if (!isfltd(++cp, " \t\n\r"))
441 break;
442 thisillum.minbrt = atof(cp);
443 if (thisillum.minbrt < 0.)
444 thisillum.minbrt = 0.;
445 cp = sskip(cp);
446 continue;
447 case 'o': /* output file */
448 if (*++cp != '=')
449 break;
450 if (!*++cp || isspace(*cp))
451 break;
452 atos(buf, sizeof(buf), cp);
453 cp = sskip(cp);
454 if (freopen(buf, "w", stdout) == NULL) {
455 sprintf(errmsg,
456 "cannot open output file \"%s\"", buf);
457 error(SYSTEM, errmsg);
458 }
459 doneheader = 0;
460 continue;
461 case '!': /* processed file! */
462 sprintf(errmsg, "(%s): already processed!", nm);
463 error(WARNING, errmsg);
464 matselect = S_NONE;
465 return;
466 }
467 opterr: /* skip faulty option */
468 while (*cp && !isspace(*cp))
469 cp++;
470 nerrs++;
471 }
472 /* print header? */
473 checkhead();
474 /* issue warnings? */
475 if (nerrs) {
476 sprintf(errmsg, "(%s): %d error(s) in option line:",
477 nm, nerrs);
478 error(WARNING, errmsg);
479 wputs(s);
480 printf("# %s: the following option line has %d error(s):\n",
481 progname, nerrs);
482 }
483 /* print pure comment */
484 printf("# %s", s+2);
485 }
486
487 void
488 printopts(void) /* print out option default values */
489 {
490 printf("m=%-15s\t\t# material name\n", thisillum.matname);
491 printf("f=%-15s\t\t# data file name\n", thisillum.datafile);
492 if (thisillum.flags & IL_COLAVG)
493 if (thisillum.flags & IL_COLDST)
494 printf("c=d\t\t\t\t# color distribution\n");
495 else
496 printf("c=a\t\t\t\t# color average\n");
497 else
498 printf("c=n\t\t\t\t# color none\n");
499 if (thisillum.flags & IL_LIGHT)
500 printf("l+\t\t\t\t# light type on\n");
501 else
502 printf("l-\t\t\t\t# light type off\n");
503 printf("d=%d\t\t\t\t# density of points\n", thisillum.sampdens);
504 printf("s=%d\t\t\t\t# samples per point\n", thisillum.nsamps);
505 printf("b=%f\t\t\t# minimum average brightness\n", thisillum.minbrt);
506 }
507
508
509 void
510 printhead( /* print out header */
511 register int ac,
512 register char **av
513 )
514 {
515 putchar('#');
516 while (ac-- > 0) {
517 putchar(' ');
518 fputs(*av++, stdout);
519 }
520 fputs("\n#@mkillum !\n", stdout);
521 }
522
523
524 void
525 xobject( /* translate an object from fp */
526 FILE *fp,
527 char *nm
528 )
529 {
530 OBJREC thisobj;
531 char str[MAXSTR];
532 int doit;
533 /* read the object */
534 if (fgetword(thisillum.altmat, MAXSTR, fp) == NULL)
535 goto readerr;
536 if (fgetword(str, MAXSTR, fp) == NULL)
537 goto readerr;
538 /* is it an alias? */
539 if (!strcmp(str, ALIASKEY)) {
540 if (fgetword(str, MAXSTR, fp) == NULL)
541 goto readerr;
542 printf("\n%s %s %s", thisillum.altmat, ALIASKEY, str);
543 if (fgetword(str, MAXSTR, fp) == NULL)
544 goto readerr;
545 printf("\t%s\n", str);
546 return;
547 }
548 thisobj.omod = OVOID; /* unused field */
549 if ((thisobj.otype = otype(str)) < 0) {
550 sprintf(errmsg, "(%s): unknown type \"%s\"", nm, str);
551 error(USER, errmsg);
552 }
553 if (fgetword(str, MAXSTR, fp) == NULL)
554 goto readerr;
555 thisobj.oname = str;
556 if (readfargs(&thisobj.oargs, fp) != 1)
557 goto readerr;
558 thisobj.os = NULL;
559 /* check for translation */
560 switch (matselect) {
561 case S_NONE:
562 doit = 0;
563 break;
564 case S_ALL:
565 doit = 1;
566 break;
567 case S_ELEM:
568 doit = !strcmp(thisillum.altmat, matcheck);
569 break;
570 case S_COMPL:
571 doit = strcmp(thisillum.altmat, matcheck);
572 break;
573 }
574 doit = doit && issurface(thisobj.otype);
575 /* print header? */
576 checkhead();
577 /* process object */
578 if (doit)
579 (*ofun[thisobj.otype].funp)(&thisobj, &thisillum, &rt0, nm);
580 else
581 printobj(thisillum.altmat, &thisobj);
582 /* free arguments */
583 freefargs(&thisobj.oargs);
584 return;
585 readerr:
586 sprintf(errmsg, "(%s): error reading scene", nm);
587 error(USER, errmsg);
588 }
