root/radiance/ray/src/gen/mkillum.c
Revision: 2.24
Committed: Wed May 25 04:44:25 2005 UTC (20 years ago) by greg
Changes since 2.23: +3 -4 lines
2 static const char RCSid[] = "$Id: mkillum.c,v 2.23 2004/10/28 00:50:47 greg Exp $";
5 * Make illum sources for optimizing rendering process
6 */
7
8 #include <signal.h>
9 #include <ctype.h>
10
11 #include "platform.h"
12 #include "mkillum.h"
13 #include "random.h"
14
15 /* default parameters */
16 #define SAMPDENS 48 /* points per projected steradian */
17 #define NSAMPS 32 /* samples per point */
18 #define DFLMAT "illum_mat" /* material name */
19 #define DFLDAT "illum" /* data file name */
20 /* selection options */
21 #define S_NONE 0 /* select none */
22 #define S_ELEM 1 /* select specified element */
23 #define S_COMPL 2 /* select all but element */
24 #define S_ALL 3 /* select all */
25
26 /* rtrace command and defaults */
27 char *rtargv[64] = { "rtrace", "-dj", ".25", "-dr", "3", "-dv-",
28 "-ab", "2", "-ad", "1024", "-as", "512", "-aa", ".1", };
29 int rtargc = 14;
30 /* overriding rtrace options */
31 char *myrtopts[] = { "-I-", "-i-", "-ld-", "-ov", "-h-",
32 "-fff", "-y", "0", NULL };
33
34 struct rtproc rt0; /* head of rtrace process list */
35
36 struct illum_args thisillum = { /* our illum and default values */
37 0,
38 DFLMAT,
39 DFLDAT,
40 0,
41 VOIDID,
42 SAMPDENS,
43 NSAMPS,
44 0.,
45 };
46
47 char matcheck[MAXSTR]; /* current material to include or exclude */
48 int matselect = S_ALL; /* selection criterion */
49
50 FUN ofun[NUMOTYPE] = INIT_OTYPE; /* object types */
51
52 char persistfn[] = "pfXXXXXX"; /* persist file name */
53
54 int gargc; /* global argc */
55 char **gargv; /* global argv */
56 #define progname gargv[0]
57
58 int doneheader = 0; /* printed header yet? */
59 #define checkhead() if (!doneheader++) printhead(gargc,gargv)
60
61 int warnings = 1; /* print warnings? */
62
63 int done_rprocs(struct rtproc *rtp);
64 void init(int np);
65 void filter(register FILE *infp, char *name);
66 void xoptions(char *s, char *nm);
67 void printopts(void);
68 void printhead(register int ac, register char **av);
69 void xobject(FILE *fp, char *nm);
70
71
72 int
73 main( /* compute illum distributions using rtrace */
74 int argc,
75 char *argv[]
76 )
77 {
78 int nprocs = 1;
79 char *rtpath;
80 FILE *fp;
81 register int i;
82 /* set global arguments */
83 gargv = argv;
84 /* check for -n option */
85 if (!strcmp(argv[1], "-n")) {
86 nprocs = atoi(argv[2]);
87 if (nprocs <= 0)
88 error(USER, "illegal number of processes");
89 i = 3;
90 } else
91 i = 1;
92 /* set up rtrace command */
93 for ( ; i < argc; i++) {
94 if (argv[i][0] == '<' && argv[i][1] == '\0')
95 break;
96 rtargv[rtargc++] = argv[i];
97 if (argv[i][0] == '-' && argv[i][1] == 'w')
98 switch (argv[i][2]) {
99 case '\0':
100 warnings = !warnings;
101 break;
102 case '+':
103 case 'T': case 't':
104 case 'Y': case 'y':
105 case '1':
106 warnings = 1;
107 break;
108 case '-':
109 case 'F': case 'f':
110 case 'N': case 'n':
111 case '0':
112 warnings = 0;
113 break;
114 }
115 }
116 gargc = i;
117 if (!strcmp(rtargv[--rtargc], "-defaults"))
118 nprocs = 0;
119 if (nprocs > 1) { /* add persist file if parallel invocation */
120 rtargv[rtargc++] = "-PP";
121 rtargv[rtargc++] = mktemp(persistfn);
122 }
123 /* add "mandatory" rtrace options */
124 for (i = 0; myrtopts[i] != NULL; i++)
125 rtargv[rtargc++] = myrtopts[i];
126 /* finally, put back final argument */
127 rtargv[rtargc++] = argv[gargc-1];
128 rtargv[rtargc] = NULL;
129 if (!nprocs) { /* just asking for defaults? */
130 printopts(); fflush(stdout);
131 rtpath = getpath(rtargv[0], getenv("PATH"), X_OK);
132 if (rtpath == NULL) {
133 eputs(rtargv[0]);
134 eputs(": command not found\n");
135 exit(1);
136 }
137 execv(rtpath, rtargv);
138 perror(rtpath); /* execv() should not return */
139 exit(1);
140 }
141 if (gargc < 2 || argv[gargc-1][0] == '-')
142 error(USER, "missing octree argument");
143 /* else initialize and run our calculation */
144 init(nprocs);
145 if (gargc+1 < argc)
146 for (i = gargc+1; i < argc; i++) {
147 if ((fp = fopen(argv[i], "r")) == NULL) {
148 sprintf(errmsg,
149 "cannot open scene file \"%s\"", argv[i]);
150 error(SYSTEM, errmsg);
151 }
152 filter(fp, argv[i]);
153 fclose(fp);
154 }
155 else
156 filter(stdin, "standard input");
157 quit(0);
158 }
159
160 static void
161 killpersist(void) /* kill persistent rtrace process */
162 {
163 FILE *fp = fopen(persistfn, "r");
164 int pid;
165
166 if (fp == NULL)
167 return;
168 if (fscanf(fp, "%*s %d", &pid) != 1 || kill(pid, SIGALRM) < 0)
169 unlink(persistfn);
170 fclose(fp);
171 }
172
173 int
174 done_rprocs(struct rtproc *rtp)
175 {
176 int st0, st1 = 0;
177
178 if (rtp->next != NULL) { /* close last opened first! */
179 st1 = done_rprocs(rtp->next);
180 free((void *)rtp->next);
181 rtp->next = NULL;
182 }
183 st0 = close_process(&rtp->pd);
184 if (st0 < 0)
185 error(WARNING, "unknown return status from rtrace process");
186 else if (st0 > 0)
187 return(st0);
188 return(st1);
189 }
190
191 void
192 quit(int status) /* exit with status */
193 {
194 int rtstat;
195
196 if (rt0.next != NULL) /* terminate persistent rtrace */
197 killpersist();
198 /* clean up rtrace process(es) */
199 rtstat = done_rprocs(&rt0);
200 if (status == 0)
201 status = rtstat;
202 exit(status);
203 }
204
205 void
206 init(int np) /* start rtrace and set up buffers */
207 {
208 struct rtproc *rtp;
209 int i;
210 int maxbytes;
211 /* set up object functions */
212 ofun[OBJ_FACE].funp = o_face;
213 ofun[OBJ_SPHERE].funp = o_sphere;
214 ofun[OBJ_RING].funp = o_ring;
215 /* set up signal handling */
216 #ifdef SIGPIPE /* not present on Windows */
217 signal(SIGPIPE, quit);
218 #endif
219 rtp = &rt0; /* start rtrace process(es) */
220 for (i = 0; i++ < np; ) {
221 errno = 0;
222 maxbytes = open_process(&rtp->pd, rtargv);
223 if (maxbytes == 0) {
224 eputs(rtargv[0]);
225 eputs(": command not found\n");
226 exit(1);
227 }
228 if (maxbytes < 0)
229 error(SYSTEM, "cannot start rtrace process");
230 rtp->bsiz = maxbytes/(6*sizeof(float));
231 rtp->buf = (float *)malloc(6*sizeof(float)*rtp->bsiz--);
232 rtp->dest = (float **)calloc(rtp->bsiz, sizeof(float *));
233 if (rtp->buf == NULL || rtp->dest == NULL)
234 error(SYSTEM, "out of memory in init");
235 rtp->nrays = 0;
236 if (i == np) /* last process? */
237 break;
238 if (np > 1)
239 sleep(2); /* wait for persist file */
240 rtp->next = (struct rtproc *)malloc(sizeof(struct rtproc));
241 if (rtp->next == NULL)
242 error(SYSTEM, "out of memory in init");
243 rtp = rtp->next;
244 }
245 rtp->next = NULL;
246 /* set up urand */
247 initurand(16384);
248 }
249
250
251 void
252 eputs( /* put string to stderr */
253 register char *s
254 )
255 {
256 static int midline = 0;
257
258 if (!*s) return;
259 if (!midline) {
260 fputs(progname, stderr);
261 fputs(": ", stderr);
262 }
263 fputs(s, stderr);
264 midline = s[strlen(s)-1] != '\n';
265 }
266
267
268 void
269 wputs(s) /* print warning if enabled */
270 char *s;
271 {
272 if (warnings)
273 eputs(s);
274 }
275
276
277 void
278 filter( /* process stream */
279 register FILE *infp,
280 char *name
281 )
282 {
283 char buf[512];
284 FILE *pfp;
285 register int c;
286
287 while ((c = getc(infp)) != EOF) {
288 if (isspace(c))
289 continue;
290 if (c == '#') { /* comment/options */
291 buf[0] = c;
292 fgets(buf+1, sizeof(buf)-1, infp);
293 xoptions(buf, name);
294 } else if (c == '!') { /* command */
295 buf[0] = c;
296 fgetline(buf+1, sizeof(buf)-1, infp);
297 if ((pfp = popen(buf+1, "r")) == NULL) {
298 sprintf(errmsg, "cannot execute \"%s\"", buf);
299 error(SYSTEM, errmsg);
300 }
301 filter(pfp, buf);
302 pclose(pfp);
303 } else { /* object */
304 ungetc(c, infp);
305 xobject(infp, name);
306 }
307 }
308 }
309
310
311 void
312 xoptions( /* process options in string s */
313 char *s,
314 char *nm
315 )
316 {
317 extern FILE *freopen();
318 char buf[64];
319 int nerrs = 0;
320 register char *cp;
321
322 if (strncmp(s, "#@mkillum", 9) || !isspace(s[9])) {
323 fputs(s, stdout); /* not for us */
324 return;
325 }
326 cp = s+10;
327 while (*cp) {
328 switch (*cp) {
329 case ' ':
330 case '\t':
331 case '\n':
332 case '\r':
333 case '\f':
334 cp++;
335 continue;
336 case 'm': /* material name */
337 if (*++cp != '=')
338 break;
339 if (!*++cp || isspace(*cp))
340 break;
341 atos(thisillum.matname, MAXSTR, cp);
342 cp = sskip(cp);
343 if (!(thisillum.flags & IL_DATCLB)) {
344 strcpy(thisillum.datafile, thisillum.matname);
345 thisillum.dfnum = 0;
346 }
347 continue;
348 case 'f': /* data file name */
349 if (*++cp != '=')
350 break;
351 if (!*++cp || isspace(*cp)) {
352 strcpy(thisillum.datafile,thisillum.matname);
353 thisillum.dfnum = 0;
354 thisillum.flags &= ~IL_DATCLB;
355 continue;
356 }
357 atos(thisillum.datafile, MAXSTR, cp);
358 cp = sskip(cp);
359 thisillum.dfnum = 0;
360 thisillum.flags |= IL_DATCLB;
361 continue;
362 case 'i': /* include material */
363 case 'e': /* exclude material */
364 if (cp[1] != '=')
365 break;
366 matselect = (*cp == 'i') ? S_ELEM : S_COMPL;
367 cp += 2;
368 atos(matcheck, MAXSTR, cp);
369 cp = sskip(cp);
370 continue;
371 case 'a': /* use everything */
372 cp = sskip(cp);
373 matselect = S_ALL;
374 continue;
375 case 'n': /* use nothing (passive) */
376 cp = sskip(cp);
377 matselect = S_NONE;
378 continue;
379 case 'c': /* color calculation */
380 if (*++cp != '=')
381 break;
382 switch (*++cp) {
383 case 'a': /* average */
384 thisillum.flags = (thisillum.flags|IL_COLAVG)
385 & ~IL_COLDST;
386 break;
387 case 'd': /* distribution */
388 thisillum.flags |= (IL_COLDST|IL_COLAVG);
389 break;
390 case 'n': /* none */
391 thisillum.flags &= ~(IL_COLAVG|IL_COLDST);
392 break;
393 default:
394 goto opterr;
395 }
396 cp = sskip(cp);
397 continue;
398 case 'd': /* point sample density */
399 if (*++cp != '=')
400 break;
401 if (!isintd(++cp, " \t\n\r"))
402 break;
403 thisillum.sampdens = atoi(cp);
404 cp = sskip(cp);
405 continue;
406 case 's': /* point super-samples */
407 if (*++cp != '=')
408 break;
409 if (!isintd(++cp, " \t\n\r"))
410 break;
411 thisillum.nsamps = atoi(cp);
412 cp = sskip(cp);
413 continue;
414 case 'l': /* light sources */
415 cp++;
416 if (*cp == '+')
417 thisillum.flags |= IL_LIGHT;
418 else if (*cp == '-')
419 thisillum.flags &= ~IL_LIGHT;
420 else
421 break;
422 cp++;
423 continue;
424 case 'b': /* brightness */
425 if (*++cp != '=')
426 break;
427 if (!isfltd(++cp, " \t\n\r"))
428 break;
429 thisillum.minbrt = atof(cp);
430 if (thisillum.minbrt < 0.)
431 thisillum.minbrt = 0.;
432 cp = sskip(cp);
433 continue;
434 case 'o': /* output file */
435 if (*++cp != '=')
436 break;
437 if (!*++cp || isspace(*cp))
438 break;
439 atos(buf, sizeof(buf), cp);
440 cp = sskip(cp);
441 if (freopen(buf, "w", stdout) == NULL) {
442 sprintf(errmsg,
443 "cannot open output file \"%s\"", buf);
444 error(SYSTEM, errmsg);
445 }
446 doneheader = 0;
447 continue;
448 case '!': /* processed file! */
449 sprintf(errmsg, "(%s): already processed!", nm);
450 error(WARNING, errmsg);
451 matselect = S_NONE;
452 return;
453 }
454 opterr: /* skip faulty option */
455 while (*cp && !isspace(*cp))
456 cp++;
457 nerrs++;
458 }
459 /* print header? */
460 checkhead();
461 /* issue warnings? */
462 if (nerrs) {
463 sprintf(errmsg, "(%s): %d error(s) in option line:",
464 nm, nerrs);
465 error(WARNING, errmsg);
466 wputs(s);
467 printf("# %s: the following option line has %d error(s):\n",
468 progname, nerrs);
469 }
470 /* print pure comment */
471 printf("# %s", s+2);
472 }
473
474 void
475 printopts(void) /* print out option default values */
476 {
477 printf("m=%-15s\t\t# material name\n", thisillum.matname);
478 printf("f=%-15s\t\t# data file name\n", thisillum.datafile);
479 if (thisillum.flags & IL_COLAVG)
480 if (thisillum.flags & IL_COLDST)
481 printf("c=d\t\t\t\t# color distribution\n");
482 else
483 printf("c=a\t\t\t\t# color average\n");
484 else
485 printf("c=n\t\t\t\t# color none\n");
486 if (thisillum.flags & IL_LIGHT)
487 printf("l+\t\t\t\t# light type on\n");
488 else
489 printf("l-\t\t\t\t# light type off\n");
490 printf("d=%d\t\t\t\t# density of points\n", thisillum.sampdens);
491 printf("s=%d\t\t\t\t# samples per point\n", thisillum.nsamps);
492 printf("b=%f\t\t\t# minimum average brightness\n", thisillum.minbrt);
493 }
494
495
496 void
497 printhead( /* print out header */
498 register int ac,
499 register char **av
500 )
501 {
502 putchar('#');
503 while (ac-- > 0) {
504 putchar(' ');
505 fputs(*av++, stdout);
506 }
507 fputs("\n#@mkillum !\n", stdout);
508 }
509
510
511 void
512 xobject( /* translate an object from fp */
513 FILE *fp,
514 char *nm
515 )
516 {
517 OBJREC thisobj;
518 char str[MAXSTR];
519 int doit;
520 /* read the object */
521 if (fgetword(thisillum.altmat, MAXSTR, fp) == NULL)
522 goto readerr;
523 if (fgetword(str, MAXSTR, fp) == NULL)
524 goto readerr;
525 /* is it an alias? */
526 if (!strcmp(str, ALIASKEY)) {
527 if (fgetword(str, MAXSTR, fp) == NULL)
528 goto readerr;
529 printf("\n%s %s %s", thisillum.altmat, ALIASKEY, str);
530 if (fgetword(str, MAXSTR, fp) == NULL)
531 goto readerr;
532 printf("\t%s\n", str);
533 return;
534 }
535 thisobj.omod = OVOID; /* unused field */
536 if ((thisobj.otype = otype(str)) < 0) {
537 sprintf(errmsg, "(%s): unknown type \"%s\"", nm, str);
538 error(USER, errmsg);
539 }
540 if (fgetword(str, MAXSTR, fp) == NULL)
541 goto readerr;
542 thisobj.oname = str;
543 if (readfargs(&thisobj.oargs, fp) != 1)
544 goto readerr;
545 thisobj.os = NULL;
546 /* check for translation */
547 switch (matselect) {
548 case S_NONE:
549 doit = 0;
550 break;
551 case S_ALL:
552 doit = 1;
553 break;
554 case S_ELEM:
555 doit = !strcmp(thisillum.altmat, matcheck);
556 break;
557 case S_COMPL:
558 doit = strcmp(thisillum.altmat, matcheck);
559 break;
560 }
561 doit = doit && issurface(thisobj.otype);
562 /* print header? */
563 checkhead();
564 /* process object */
565 if (doit)
566 (*ofun[thisobj.otype].funp)(&thisobj, &thisillum, &rt0, nm);
567 else
568 printobj(thisillum.altmat, &thisobj);
569 /* free arguments */
570 freefargs(&thisobj.oargs);
571 return;
572 readerr:
573 sprintf(errmsg, "(%s): error reading scene", nm);
574 error(USER, errmsg);
575 }
