root/radiance/ray/src/gen/mkillum.c
Revision: 2.23
Committed: Thu Oct 28 00:50:47 2004 UTC (19 years, 7 months ago) by greg
CVS Tags: rad3R6P1
Changes since 2.22: +23 -12 lines
Reversed order of rtrace close processes, apparently to no effect
2 static const char RCSid[] = "$Id: mkillum.c,v 2.22 2004/10/23 18:55:52 schorsch Exp $";
5 * Make illum sources for optimizing rendering process
6 */
7
8 #include <signal.h>
9 #include <ctype.h>
10
11 #include "platform.h"
12 #include "rtprocess.h"
13 #include "mkillum.h"
14 #include "random.h"
15
16 /* default parameters */
17 #define SAMPDENS 48 /* points per projected steradian */
18 #define NSAMPS 32 /* samples per point */
19 #define DFLMAT "illum_mat" /* material name */
20 #define DFLDAT "illum" /* data file name */
21 /* selection options */
22 #define S_NONE 0 /* select none */
23 #define S_ELEM 1 /* select specified element */
24 #define S_COMPL 2 /* select all but element */
25 #define S_ALL 3 /* select all */
26
27 /* rtrace command and defaults */
28 char *rtargv[64] = { "rtrace", "-dj", ".25", "-dr", "3", "-dv-",
29 "-ab", "2", "-ad", "1024", "-as", "512", "-aa", ".1", };
30 int rtargc = 14;
31 /* overriding rtrace options */
32 char *myrtopts[] = { "-I-", "-i-", "-ld-", "-ov", "-h-",
33 "-fff", "-y", "0", NULL };
34
35 struct rtproc rt0; /* head of rtrace process list */
36
37 struct illum_args thisillum = { /* our illum and default values */
38 0,
39 DFLMAT,
40 DFLDAT,
41 0,
42 VOIDID,
43 SAMPDENS,
44 NSAMPS,
45 0.,
46 };
47
48 char matcheck[MAXSTR]; /* current material to include or exclude */
49 int matselect = S_ALL; /* selection criterion */
50
51 FUN ofun[NUMOTYPE] = INIT_OTYPE; /* object types */
52
53 char persistfn[] = "pfXXXXXX"; /* persist file name */
54
55 int gargc; /* global argc */
56 char **gargv; /* global argv */
57 #define progname gargv[0]
58
59 int doneheader = 0; /* printed header yet? */
60 #define checkhead() if (!doneheader++) printhead(gargc,gargv)
61
62 int warnings = 1; /* print warnings? */
63
64 int done_rprocs(struct rtproc *rtp);
65 void init(int np);
66 void filter(register FILE *infp, char *name);
67 void xoptions(char *s, char *nm);
68 void printopts(void);
69 void printhead(register int ac, register char **av);
70 void xobject(FILE *fp, char *nm);
71
72
73 int
74 main( /* compute illum distributions using rtrace */
75 int argc,
76 char *argv[]
77 )
78 {
79 int nprocs = 1;
80 char *rtpath;
81 FILE *fp;
82 register int i;
83 /* set global arguments */
84 gargv = argv;
85 /* check for -n option */
86 if (!strcmp(argv[1], "-n")) {
87 nprocs = atoi(argv[2]);
88 if (nprocs <= 0)
89 error(USER, "illegal number of processes");
90 i = 3;
91 } else
92 i = 1;
93 /* set up rtrace command */
94 for ( ; i < argc; i++) {
95 if (argv[i][0] == '<' && argv[i][1] == '\0')
96 break;
97 rtargv[rtargc++] = argv[i];
98 if (argv[i][0] == '-' && argv[i][1] == 'w')
99 switch (argv[i][2]) {
100 case '\0':
101 warnings = !warnings;
102 break;
103 case '+':
104 case 'T': case 't':
105 case 'Y': case 'y':
106 case '1':
107 warnings = 1;
108 break;
109 case '-':
110 case 'F': case 'f':
111 case 'N': case 'n':
112 case '0':
113 warnings = 0;
114 break;
115 }
116 }
117 gargc = i;
118 if (!strcmp(rtargv[--rtargc], "-defaults"))
119 nprocs = 0;
120 if (nprocs > 1) { /* add persist file if parallel invocation */
121 rtargv[rtargc++] = "-PP";
122 rtargv[rtargc++] = mktemp(persistfn);
123 }
124 /* add "mandatory" rtrace options */
125 for (i = 0; myrtopts[i] != NULL; i++)
126 rtargv[rtargc++] = myrtopts[i];
127 /* finally, put back final argument */
128 rtargv[rtargc++] = argv[gargc-1];
129 rtargv[rtargc] = NULL;
130 if (!nprocs) { /* just asking for defaults? */
131 printopts(); fflush(stdout);
132 rtpath = getpath(rtargv[0], getenv("PATH"), X_OK);
133 if (rtpath == NULL) {
134 eputs(rtargv[0]);
135 eputs(": command not found\n");
136 exit(1);
137 }
138 execv(rtpath, rtargv);
139 perror(rtpath); /* execv() should not return */
140 exit(1);
141 }
142 if (gargc < 2 || argv[gargc-1][0] == '-')
143 error(USER, "missing octree argument");
144 /* else initialize and run our calculation */
145 init(nprocs);
146 if (gargc+1 < argc)
147 for (i = gargc+1; i < argc; i++) {
148 if ((fp = fopen(argv[i], "r")) == NULL) {
149 sprintf(errmsg,
150 "cannot open scene file \"%s\"", argv[i]);
151 error(SYSTEM, errmsg);
152 }
153 filter(fp, argv[i]);
154 fclose(fp);
155 }
156 else
157 filter(stdin, "standard input");
158 quit(0);
159 }
160
161 static void
162 killpersist(void) /* kill persistent rtrace process */
163 {
164 FILE *fp = fopen(persistfn, "r");
165 int pid;
166
167 if (fp == NULL)
168 return;
169 if (fscanf(fp, "%*s %d", &pid) != 1 || kill(pid, SIGALRM) < 0)
170 unlink(persistfn);
171 fclose(fp);
172 }
173
174 int
175 done_rprocs(struct rtproc *rtp)
176 {
177 int st0, st1 = 0;
178
179 if (rtp->next != NULL) { /* close last opened first! */
180 st1 = done_rprocs(rtp->next);
181 free((void *)rtp->next);
182 rtp->next = NULL;
183 }
184 st0 = close_process(&rtp->pd);
185 if (st0 < 0)
186 error(WARNING, "unknown return status from rtrace process");
187 else if (st0 > 0)
188 return(st0);
189 return(st1);
190 }
191
192 void
193 quit(int status) /* exit with status */
194 {
195 int rtstat;
196
197 if (rt0.next != NULL) /* terminate persistent rtrace */
198 killpersist();
199 /* clean up rtrace process(es) */
200 rtstat = done_rprocs(&rt0);
201 if (status == 0)
202 status = rtstat;
203 exit(status);
204 }
205
206 void
207 init(int np) /* start rtrace and set up buffers */
208 {
209 struct rtproc *rtp;
210 int i;
211 int maxbytes;
212 /* set up object functions */
213 ofun[OBJ_FACE].funp = o_face;
214 ofun[OBJ_SPHERE].funp = o_sphere;
215 ofun[OBJ_RING].funp = o_ring;
216 /* set up signal handling */
217 #ifdef SIGPIPE /* not present on Windows */
218 signal(SIGPIPE, quit);
219 #endif
220 rtp = &rt0; /* start rtrace process(es) */
221 for (i = 0; i++ < np; ) {
222 errno = 0;
223 maxbytes = open_process(&rtp->pd, rtargv);
224 if (maxbytes == 0) {
225 eputs(rtargv[0]);
226 eputs(": command not found\n");
227 exit(1);
228 }
229 if (maxbytes < 0)
230 error(SYSTEM, "cannot start rtrace process");
231 if (!i && np > 1)
232 sleep(2); /* wait for persist file */
233 rtp->bsiz = maxbytes/(6*sizeof(float));
234 rtp->buf = (float *)malloc(6*sizeof(float)*rtp->bsiz--);
235 rtp->dest = (float **)calloc(rtp->bsiz, sizeof(float *));
236 if (rtp->buf == NULL || rtp->dest == NULL)
237 error(SYSTEM, "out of memory in init");
238 rtp->nrays = 0;
239 if (i == np) /* last process? */
240 break;
241 rtp->next = (struct rtproc *)malloc(sizeof(struct rtproc));
242 if (rtp->next == NULL)
243 error(SYSTEM, "out of memory in init");
244 rtp = rtp->next;
245 }
246 rtp->next = NULL;
247 /* set up urand */
248 initurand(16384);
249 }
250
251
252 void
253 eputs( /* put string to stderr */
254 register char *s
255 )
256 {
257 static int midline = 0;
258
259 if (!*s) return;
260 if (!midline) {
261 fputs(progname, stderr);
262 fputs(": ", stderr);
263 }
264 fputs(s, stderr);
265 midline = s[strlen(s)-1] != '\n';
266 }
267
268
269 void
270 wputs(s) /* print warning if enabled */
271 char *s;
272 {
273 if (warnings)
274 eputs(s);
275 }
276
277
278 void
279 filter( /* process stream */
280 register FILE *infp,
281 char *name
282 )
283 {
284 char buf[512];
285 FILE *pfp;
286 register int c;
287
288 while ((c = getc(infp)) != EOF) {
289 if (isspace(c))
290 continue;
291 if (c == '#') { /* comment/options */
292 buf[0] = c;
293 fgets(buf+1, sizeof(buf)-1, infp);
294 xoptions(buf, name);
295 } else if (c == '!') { /* command */
296 buf[0] = c;
297 fgetline(buf+1, sizeof(buf)-1, infp);
298 if ((pfp = popen(buf+1, "r")) == NULL) {
299 sprintf(errmsg, "cannot execute \"%s\"", buf);
300 error(SYSTEM, errmsg);
301 }
302 filter(pfp, buf);
303 pclose(pfp);
304 } else { /* object */
305 ungetc(c, infp);
306 xobject(infp, name);
307 }
308 }
309 }
310
311
312 void
313 xoptions( /* process options in string s */
314 char *s,
315 char *nm
316 )
317 {
318 extern FILE *freopen();
319 char buf[64];
320 int nerrs = 0;
321 register char *cp;
322
323 if (strncmp(s, "#@mkillum", 9) || !isspace(s[9])) {
324 fputs(s, stdout); /* not for us */
325 return;
326 }
327 cp = s+10;
328 while (*cp) {
329 switch (*cp) {
330 case ' ':
331 case '\t':
332 case '\n':
333 case '\r':
334 case '\f':
335 cp++;
336 continue;
337 case 'm': /* material name */
338 if (*++cp != '=')
339 break;
340 if (!*++cp || isspace(*cp))
341 break;
342 atos(thisillum.matname, MAXSTR, cp);
343 cp = sskip(cp);
344 if (!(thisillum.flags & IL_DATCLB)) {
345 strcpy(thisillum.datafile, thisillum.matname);
346 thisillum.dfnum = 0;
347 }
348 continue;
349 case 'f': /* data file name */
350 if (*++cp != '=')
351 break;
352 if (!*++cp || isspace(*cp)) {
353 strcpy(thisillum.datafile,thisillum.matname);
354 thisillum.dfnum = 0;
355 thisillum.flags &= ~IL_DATCLB;
356 continue;
357 }
358 atos(thisillum.datafile, MAXSTR, cp);
359 cp = sskip(cp);
360 thisillum.dfnum = 0;
361 thisillum.flags |= IL_DATCLB;
362 continue;
363 case 'i': /* include material */
364 case 'e': /* exclude material */
365 if (cp[1] != '=')
366 break;
367 matselect = (*cp == 'i') ? S_ELEM : S_COMPL;
368 cp += 2;
369 atos(matcheck, MAXSTR, cp);
370 cp = sskip(cp);
371 continue;
372 case 'a': /* use everything */
373 cp = sskip(cp);
374 matselect = S_ALL;
375 continue;
376 case 'n': /* use nothing (passive) */
377 cp = sskip(cp);
378 matselect = S_NONE;
379 continue;
380 case 'c': /* color calculation */
381 if (*++cp != '=')
382 break;
383 switch (*++cp) {
384 case 'a': /* average */
385 thisillum.flags = (thisillum.flags|IL_COLAVG)
386 & ~IL_COLDST;
387 break;
388 case 'd': /* distribution */
389 thisillum.flags |= (IL_COLDST|IL_COLAVG);
390 break;
391 case 'n': /* none */
392 thisillum.flags &= ~(IL_COLAVG|IL_COLDST);
393 break;
394 default:
395 goto opterr;
396 }
397 cp = sskip(cp);
398 continue;
399 case 'd': /* point sample density */
400 if (*++cp != '=')
401 break;
402 if (!isintd(++cp, " \t\n\r"))
403 break;
404 thisillum.sampdens = atoi(cp);
405 cp = sskip(cp);
406 continue;
407 case 's': /* point super-samples */
408 if (*++cp != '=')
409 break;
410 if (!isintd(++cp, " \t\n\r"))
411 break;
412 thisillum.nsamps = atoi(cp);
413 cp = sskip(cp);
414 continue;
415 case 'l': /* light sources */
416 cp++;
417 if (*cp == '+')
418 thisillum.flags |= IL_LIGHT;
419 else if (*cp == '-')
420 thisillum.flags &= ~IL_LIGHT;
421 else
422 break;
423 cp++;
424 continue;
425 case 'b': /* brightness */
426 if (*++cp != '=')
427 break;
428 if (!isfltd(++cp, " \t\n\r"))
429 break;
430 thisillum.minbrt = atof(cp);
431 if (thisillum.minbrt < 0.)
432 thisillum.minbrt = 0.;
433 cp = sskip(cp);
434 continue;
435 case 'o': /* output file */
436 if (*++cp != '=')
437 break;
438 if (!*++cp || isspace(*cp))
439 break;
440 atos(buf, sizeof(buf), cp);
441 cp = sskip(cp);
442 if (freopen(buf, "w", stdout) == NULL) {
443 sprintf(errmsg,
444 "cannot open output file \"%s\"", buf);
445 error(SYSTEM, errmsg);
446 }
447 doneheader = 0;
448 continue;
449 case '!': /* processed file! */
450 sprintf(errmsg, "(%s): already processed!", nm);
451 error(WARNING, errmsg);
452 matselect = S_NONE;
453 return;
454 }
455 opterr: /* skip faulty option */
456 while (*cp && !isspace(*cp))
457 cp++;
458 nerrs++;
459 }
460 /* print header? */
461 checkhead();
462 /* issue warnings? */
463 if (nerrs) {
464 sprintf(errmsg, "(%s): %d error(s) in option line:",
465 nm, nerrs);
466 error(WARNING, errmsg);
467 wputs(s);
468 printf("# %s: the following option line has %d error(s):\n",
469 progname, nerrs);
470 }
471 /* print pure comment */
472 printf("# %s", s+2);
473 }
474
475 void
476 printopts(void) /* print out option default values */
477 {
478 printf("m=%-15s\t\t# material name\n", thisillum.matname);
479 printf("f=%-15s\t\t# data file name\n", thisillum.datafile);
480 if (thisillum.flags & IL_COLAVG)
481 if (thisillum.flags & IL_COLDST)
482 printf("c=d\t\t\t\t# color distribution\n");
483 else
484 printf("c=a\t\t\t\t# color average\n");
485 else
486 printf("c=n\t\t\t\t# color none\n");
487 if (thisillum.flags & IL_LIGHT)
488 printf("l+\t\t\t\t# light type on\n");
489 else
490 printf("l-\t\t\t\t# light type off\n");
491 printf("d=%d\t\t\t\t# density of points\n", thisillum.sampdens);
492 printf("s=%d\t\t\t\t# samples per point\n", thisillum.nsamps);
493 printf("b=%f\t\t\t# minimum average brightness\n", thisillum.minbrt);
494 }
495
496
497 void
498 printhead( /* print out header */
499 register int ac,
500 register char **av
501 )
502 {
503 putchar('#');
504 while (ac-- > 0) {
505 putchar(' ');
506 fputs(*av++, stdout);
507 }
508 fputs("\n#@mkillum !\n", stdout);
509 }
510
511
512 void
513 xobject( /* translate an object from fp */
514 FILE *fp,
515 char *nm
516 )
517 {
518 OBJREC thisobj;
519 char str[MAXSTR];
520 int doit;
521 /* read the object */
522 if (fgetword(thisillum.altmat, MAXSTR, fp) == NULL)
523 goto readerr;
524 if (fgetword(str, MAXSTR, fp) == NULL)
525 goto readerr;
526 /* is it an alias? */
527 if (!strcmp(str, ALIASKEY)) {
528 if (fgetword(str, MAXSTR, fp) == NULL)
529 goto readerr;
530 printf("\n%s %s %s", thisillum.altmat, ALIASKEY, str);
531 if (fgetword(str, MAXSTR, fp) == NULL)
532 goto readerr;
533 printf("\t%s\n", str);
534 return;
535 }
536 thisobj.omod = OVOID; /* unused field */
537 if ((thisobj.otype = otype(str)) < 0) {
538 sprintf(errmsg, "(%s): unknown type \"%s\"", nm, str);
539 error(USER, errmsg);
540 }
541 if (fgetword(str, MAXSTR, fp) == NULL)
542 goto readerr;
543 thisobj.oname = str;
544 if (readfargs(&thisobj.oargs, fp) != 1)
545 goto readerr;
546 thisobj.os = NULL;
547 /* check for translation */
548 switch (matselect) {
549 case S_NONE:
550 doit = 0;
551 break;
552 case S_ALL:
553 doit = 1;
554 break;
555 case S_ELEM:
556 doit = !strcmp(thisillum.altmat, matcheck);
557 break;
558 case S_COMPL:
559 doit = strcmp(thisillum.altmat, matcheck);
560 break;
561 }
562 doit = doit && issurface(thisobj.otype);
563 /* print header? */
564 checkhead();
565 /* process object */
566 if (doit)
567 (*ofun[thisobj.otype].funp)(&thisobj, &thisillum, &rt0, nm);
568 else
569 printobj(thisillum.altmat, &thisobj);
570 /* free arguments */
571 freefargs(&thisobj.oargs);
572 return;
573 readerr:
574 sprintf(errmsg, "(%s): error reading scene", nm);
575 error(USER, errmsg);
576 }
