root/radiance/ray/src/gen/mkillum.c
Revision: 2.11
Committed: Sat Feb 22 02:07:24 2003 UTC (21 years, 1 month ago) by greg
Changes since 2.10: +9 -12 lines
5 * Make illum sources for optimizing rendering process
6 */
7
8 #include "mkillum.h"
9
10 #include <signal.h>
11
12 #include <ctype.h>
13
14 /* default parameters */
15 #define SAMPDENS 48 /* points per projected steradian */
16 #define NSAMPS 32 /* samples per point */
17 #define DFLMAT "illum_mat" /* material name */
18 #define DFLDAT "illum" /* data file name */
19 /* selection options */
20 #define S_NONE 0 /* select none */
21 #define S_ELEM 1 /* select specified element */
22 #define S_COMPL 2 /* select all but element */
23 #define S_ALL 3 /* select all */
24
25 /* rtrace command and defaults */
26 char *rtargv[64] = { "rtrace", "-dj", ".25", "-dr", "3", "-dv-",
27 "-ab", "2", "-ad", "256", "-as", "128", "-aa", ".15", };
28 int rtargc = 14;
29 /* overriding rtrace options */
30 char *myrtopts[] = { "-I-", "-i-", "-ld-", "-ov", "-h-",
31 "-fff", "-y", "0", NULL };
32
33 struct rtproc rt; /* our rtrace process */
34
35 struct illum_args thisillum = { /* our illum and default values */
36 0,
37 DFLMAT,
38 DFLDAT,
39 0,
40 VOIDID,
41 SAMPDENS,
42 NSAMPS,
43 0.,
44 };
45
46 char matcheck[MAXSTR]; /* current material to include or exclude */
47 int matselect = S_ALL; /* selection criterion */
48
49 FUN ofun[NUMOTYPE] = INIT_OTYPE; /* object types */
50
51 int gargc; /* global argc */
52 char **gargv; /* global argv */
53 #define progname gargv[0]
54
55 int doneheader = 0; /* printed header yet? */
56 #define checkhead() if (!doneheader++) printhead(gargc,gargv)
57
58 int warnings = 1; /* print warnings? */
59
60
61 main(argc, argv) /* compute illum distributions using rtrace */
62 int argc;
63 char *argv[];
64 {
65 char *rtpath;
66 FILE *fp;
67 register int i;
68 /* set global arguments */
69 gargv = argv;
70 /* set up rtrace command */
71 for (i = 1; i < argc; i++) {
72 if (argv[i][0] == '<' && argv[i][1] == '\0')
73 break;
74 rtargv[rtargc++] = argv[i];
75 if (argv[i][0] == '-' && argv[i][1] == 'w')
76 switch (argv[i][2]) {
77 case '\0':
78 warnings = !warnings;
79 break;
80 case '+':
81 case 'T': case 't':
82 case 'Y': case 'y':
83 case '1':
84 warnings = 1;
85 break;
86 case '-':
87 case 'F': case 'f':
88 case 'N': case 'n':
89 case '0':
90 warnings = 0;
91 break;
92 }
93 }
94 gargc = i;
95 rtargc--;
96 for (i = 0; myrtopts[i] != NULL; i++)
97 rtargv[rtargc++] = myrtopts[i];
98 rtargv[rtargc++] = argv[gargc-1];
99 rtargv[rtargc] = NULL;
100 /* just asking for defaults? */
101 if (!strcmp(argv[gargc-1], "-defaults")) {
102 printopts(); fflush(stdout);
103 rtpath = getpath(rtargv[0], getenv("PATH"), X_OK);
104 if (rtpath == NULL) {
105 eputs(rtargv[0]);
106 eputs(": command not found\n");
107 exit(1);
108 }
109 execv(rtpath, rtargv);
110 perror(rtpath);
111 exit(1);
112 }
113 if (gargc < 2 || argv[gargc-1][0] == '-')
114 error(USER, "missing octree argument");
115 /* else initialize and run our calculation */
116 init();
117 if (gargc+1 < argc)
118 for (i = gargc+1; i < argc; i++) {
119 if ((fp = fopen(argv[i], "r")) == NULL) {
120 sprintf(errmsg,
121 "cannot open scene file \"%s\"", argv[i]);
122 error(SYSTEM, errmsg);
123 }
124 filter(fp, argv[i]);
125 fclose(fp);
126 }
127 else
128 filter(stdin, "standard input");
129 quit(0);
130 }
131
132
133 void
134 quit(status) /* exit with status */
135 int status;
136 {
137 int rtstat;
138
139 rtstat = close_process(rt.pd);
140 if (status == 0)
141 if (rtstat < 0)
142 error(WARNING,
143 "unknown return status from rtrace process");
144 else
145 status = rtstat;
146 exit(status);
147 }
148
149
150 init() /* start rtrace and set up buffers */
151 {
152 extern int o_face(), o_sphere(), o_ring();
153 int maxbytes;
154 /* set up object functions */
155 ofun[OBJ_FACE].funp = o_face;
156 ofun[OBJ_SPHERE].funp = o_sphere;
157 ofun[OBJ_RING].funp = o_ring;
158 /* set up signal handling */
159 signal(SIGPIPE, quit);
160 /* start rtrace process */
161 errno = 0;
162 maxbytes = open_process(rt.pd, rtargv);
163 if (maxbytes == 0) {
164 eputs(rtargv[0]);
165 eputs(": command not found\n");
166 exit(1);
167 }
168 if (maxbytes < 0)
169 error(SYSTEM, "cannot start rtrace process");
170 rt.bsiz = maxbytes/(6*sizeof(float));
171 rt.buf = (float *)malloc(6*sizeof(float)*rt.bsiz--);
172 rt.dest = (float **)malloc(sizeof(float *)*rt.bsiz);
173 if (rt.buf == NULL || rt.dest == NULL)
174 error(SYSTEM, "out of memory in init");
175 rt.nrays = 0;
176 /* set up urand */
177 initurand(16384);
178 }
179
180
181 void
182 eputs(s) /* put string to stderr */
183 register char *s;
184 {
185 static int midline = 0;
186
187 if (!*s) return;
188 if (!midline) {
189 fputs(progname, stderr);
190 fputs(": ", stderr);
191 }
192 fputs(s, stderr);
193 midline = s[strlen(s)-1] != '\n';
194 }
195
196
197 void
198 wputs(s) /* print warning if enabled */
199 char *s;
200 {
201 if (warnings)
202 eputs(s);
203 }
204
205
206 filter(infp, name) /* process stream */
207 register FILE *infp;
208 char *name;
209 {
210 char buf[512];
211 FILE *pfp;
212 register int c;
213
214 while ((c = getc(infp)) != EOF) {
215 if (isspace(c))
216 continue;
217 if (c == '#') { /* comment/options */
218 buf[0] = c;
219 fgets(buf+1, sizeof(buf)-1, infp);
220 xoptions(buf, name);
221 } else if (c == '!') { /* command */
222 buf[0] = c;
223 fgetline(buf+1, sizeof(buf)-1, infp);
224 if ((pfp = popen(buf+1, "r")) == NULL) {
225 sprintf(errmsg, "cannot execute \"%s\"", buf);
226 error(SYSTEM, errmsg);
227 }
228 filter(pfp, buf);
229 pclose(pfp);
230 } else { /* object */
231 ungetc(c, infp);
232 xobject(infp, name);
233 }
234 }
235 }
236
237
238 xoptions(s, nm) /* process options in string s */
239 char *s;
240 char *nm;
241 {
242 extern FILE *freopen();
243 char buf[64];
244 int nerrs = 0;
245 register char *cp;
246
247 if (strncmp(s, "#@mkillum", 9) || !isspace(s[9])) {
248 fputs(s, stdout); /* not for us */
249 return;
250 }
251 cp = s+10;
252 while (*cp) {
253 switch (*cp) {
254 case ' ':
255 case '\t':
256 case '\n':
257 case '\r':
258 case '\f':
259 cp++;
260 continue;
261 case 'm': /* material name */
262 if (*++cp != '=')
263 break;
264 if (!*++cp || isspace(*cp))
265 break;
266 atos(thisillum.matname, MAXSTR, cp);
267 cp = sskip(cp);
268 if (!(thisillum.flags & IL_DATCLB)) {
269 strcpy(thisillum.datafile, thisillum.matname);
270 thisillum.dfnum = 0;
271 }
272 continue;
273 case 'f': /* data file name */
274 if (*++cp != '=')
275 break;
276 if (!*++cp || isspace(*cp)) {
277 strcpy(thisillum.datafile,thisillum.matname);
278 thisillum.dfnum = 0;
279 thisillum.flags &= ~IL_DATCLB;
280 continue;
281 }
282 atos(thisillum.datafile, MAXSTR, cp);
283 cp = sskip(cp);
284 thisillum.dfnum = 0;
285 thisillum.flags |= IL_DATCLB;
286 continue;
287 case 'i': /* include material */
288 case 'e': /* exclude material */
289 if (cp[1] != '=')
290 break;
291 matselect = (*cp == 'i') ? S_ELEM : S_COMPL;
292 cp += 2;
293 atos(matcheck, MAXSTR, cp);
294 cp = sskip(cp);
295 continue;
296 case 'a': /* use everything */
297 cp = sskip(cp);
298 matselect = S_ALL;
299 continue;
300 case 'n': /* use nothing (passive) */
301 cp = sskip(cp);
302 matselect = S_NONE;
303 continue;
304 case 'c': /* color calculation */
305 if (*++cp != '=')
306 break;
307 switch (*++cp) {
308 case 'a': /* average */
309 thisillum.flags = (thisillum.flags|IL_COLAVG)
310 & ~IL_COLDST;
311 break;
312 case 'd': /* distribution */
313 thisillum.flags |= (IL_COLDST|IL_COLAVG);
314 break;
315 case 'n': /* none */
316 thisillum.flags &= ~(IL_COLAVG|IL_COLDST);
317 break;
318 default:
319 goto opterr;
320 }
321 cp = sskip(cp);
322 continue;
323 case 'd': /* point sample density */
324 if (*++cp != '=')
325 break;
326 if (!isintd(++cp, " \t\n\r"))
327 break;
328 thisillum.sampdens = atoi(cp);
329 cp = sskip(cp);
330 continue;
331 case 's': /* point super-samples */
332 if (*++cp != '=')
333 break;
334 if (!isintd(++cp, " \t\n\r"))
335 break;
336 thisillum.nsamps = atoi(cp);
337 cp = sskip(cp);
338 continue;
339 case 'l': /* light sources */
340 cp++;
341 if (*cp == '+')
342 thisillum.flags |= IL_LIGHT;
343 else if (*cp == '-')
344 thisillum.flags &= ~IL_LIGHT;
345 else
346 break;
347 cp++;
348 continue;
349 case 'b': /* brightness */
350 if (*++cp != '=')
351 break;
352 if (!isfltd(++cp, " \t\n\r"))
353 break;
354 thisillum.minbrt = atof(cp);
355 if (thisillum.minbrt < 0.)
356 thisillum.minbrt = 0.;
357 cp = sskip(cp);
358 continue;
359 case 'o': /* output file */
360 if (*++cp != '=')
361 break;
362 if (!*++cp || isspace(*cp))
363 break;
364 atos(buf, sizeof(buf), cp);
365 cp = sskip(cp);
366 if (freopen(buf, "w", stdout) == NULL) {
367 sprintf(errmsg,
368 "cannot open output file \"%s\"", buf);
369 error(SYSTEM, errmsg);
370 }
371 doneheader = 0;
372 continue;
373 case '!': /* processed file! */
374 sprintf(errmsg, "(%s): already processed!", nm);
375 error(WARNING, errmsg);
376 matselect = S_NONE;
377 return;
378 }
379 opterr: /* skip faulty option */
380 while (*cp && !isspace(*cp))
381 cp++;
382 nerrs++;
383 }
384 /* print header? */
385 checkhead();
386 /* issue warnings? */
387 if (nerrs) {
388 sprintf(errmsg, "(%s): %d error(s) in option line:",
389 nm, nerrs);
390 error(WARNING, errmsg);
391 wputs(s);
392 printf("# %s: the following option line has %d error(s):\n",
393 progname, nerrs);
394 }
395 /* print pure comment */
396 printf("# %s", s+2);
397 }
398
399
400 printopts() /* print out option default values */
401 {
402 printf("m=%-15s\t\t# material name\n", thisillum.matname);
403 printf("f=%-15s\t\t# data file name\n", thisillum.datafile);
404 if (thisillum.flags & IL_COLAVG)
405 if (thisillum.flags & IL_COLDST)
406 printf("c=d\t\t\t\t# color distribution\n");
407 else
408 printf("c=a\t\t\t\t# color average\n");
409 else
410 printf("c=n\t\t\t\t# color none\n");
411 if (thisillum.flags & IL_LIGHT)
412 printf("l+\t\t\t\t# light type on\n");
413 else
414 printf("l-\t\t\t\t# light type off\n");
415 printf("d=%d\t\t\t\t# density of points\n", thisillum.sampdens);
416 printf("s=%d\t\t\t\t# samples per point\n", thisillum.nsamps);
417 printf("b=%f\t\t\t# minimum average brightness\n", thisillum.minbrt);
418 }
419
420
421 printhead(ac, av) /* print out header */
422 register int ac;
423 register char **av;
424 {
425 putchar('#');
426 while (ac-- > 0) {
427 putchar(' ');
428 fputs(*av++, stdout);
429 }
430 fputs("\n#@mkillum !\n", stdout);
431 }
432
433
434 xobject(fp, nm) /* translate an object from fp */
435 FILE *fp;
436 char *nm;
437 {
438 OBJREC thisobj;
439 char str[MAXSTR];
440 int doit;
441 /* read the object */
442 if (fgetword(thisillum.altmat, MAXSTR, fp) == NULL)
443 goto readerr;
444 if (fgetword(str, MAXSTR, fp) == NULL)
445 goto readerr;
446 /* is it an alias? */
447 if (!strcmp(str, ALIASID)) {
448 if (fgetword(str, MAXSTR, fp) == NULL)
449 goto readerr;
450 printf("\n%s %s %s", thisillum.altmat, ALIASID, str);
451 if (fgetword(str, MAXSTR, fp) == NULL)
452 goto readerr;
453 printf("\t%s\n", str);
454 return;
455 }
456 thisobj.omod = OVOID; /* unused field */
457 if ((thisobj.otype = otype(str)) < 0) {
458 sprintf(errmsg, "(%s): unknown type \"%s\"", nm, str);
459 error(USER, errmsg);
460 }
461 if (fgetword(str, MAXSTR, fp) == NULL)
462 goto readerr;
463 thisobj.oname = str;
464 if (readfargs(&thisobj.oargs, fp) != 1)
465 goto readerr;
466 thisobj.os = NULL;
467 /* check for translation */
468 switch (matselect) {
469 case S_NONE:
470 doit = 0;
471 break;
472 case S_ALL:
473 doit = 1;
474 break;
475 case S_ELEM:
476 doit = !strcmp(thisillum.altmat, matcheck);
477 break;
478 case S_COMPL:
479 doit = strcmp(thisillum.altmat, matcheck);
480 break;
481 }
482 doit = doit && issurface(thisobj.otype);
483 /* print header? */
484 checkhead();
485 /* process object */
486 if (doit)
487 (*ofun[thisobj.otype].funp)(&thisobj, &thisillum, &rt, nm);
488 else
489 printobj(thisillum.altmat, &thisobj);
490 /* free arguments */
491 freefargs(&thisobj.oargs);
492 return;
493 readerr:
494 sprintf(errmsg, "(%s): error reading scene", nm);
495 error(USER, errmsg);
496 }
