root/Development/ray/src/gen/mkillum.c
Revision: 1.13
Committed: Mon Aug 26 10:16:54 1991 UTC (34 years, 2 months ago) by greg
fixed distribution pattern discontinuity
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Make illum sources for optimizing rendering process
9 */
10
11 #include "mkillum.h"
12
13 #include <signal.h>
14
15 #include <ctype.h>
16
17 /* default parameters */
18 #define SAMPDENS 48 /* points per projected steradian */
19 #define NSAMPS 32 /* samples per point */
20 #define DFLMAT "illum_mat" /* material name */
21 #define DFLDAT "illum" /* data file name */
22 /* selection options */
23 #define S_NONE 0 /* select none */
24 #define S_ELEM 1 /* select specified element */
25 #define S_COMPL 2 /* select all but element */
26 #define S_ALL 3 /* select all */
27
28 /* rtrace command and defaults */
29 char *rtargv[64] = { "rtrace", "-dj", ".25", "-dr", "3", "-di+",
30 "-ab", "2", "-ad", "256", "-as", "128", "-aa", ".15", };
31 int rtargc = 14;
32 /* overriding rtrace options */
33 char *myrtopts[] = { "-I-", "-i-", "-ov", "-h-", "-fff", NULL };
34
35 struct rtproc rt; /* our rtrace process */
36
37 struct illum_args thisillum = { /* our illum and default values */
38 0,
39 DFLMAT,
40 DFLDAT,
41 0,
42 VOIDID,
43 SAMPDENS,
44 NSAMPS,
45 0.,
46 };
47
48 char matcheck[MAXSTR]; /* current material to include or exclude */
49 int matselect = S_ALL; /* selection criterion */
50
51 FUN ofun[NUMOTYPE] = INIT_OTYPE; /* object types */
52
53 int gargc; /* global argc */
54 char **gargv; /* global argv */
55 #define progname gargv[0]
56
57 int doneheader = 0; /* printed header yet? */
58 #define checkhead() if (!doneheader++) printhead(gargc,gargv)
59
60 int warnings = 1; /* print warnings? */
61
62 extern char *fgetline(), *fgetword(), *sskip(),
63 *atos(), *iskip(), *fskip(), *strcpy();
64 extern FILE *popen();
65
66
67 main(argc, argv) /* compute illum distributions using rtrace */
68 int argc;
69 char *argv[];
70 {
71 extern char *getenv(), *getpath();
72 char *rtpath;
73 FILE *fp;
74 register int i;
75 /* set global arguments */
76 gargv = argv;
77 /* set up rtrace command */
78 for (i = 1; i < argc; i++) {
79 if (argv[i][0] == '<' && !argv[i][1])
80 break;
81 rtargv[rtargc++] = argv[i];
82 if (argv[i][0] == '-' && argv[i][1] == 'w')
83 warnings = !warnings;
84 }
85 if ((gargc = i) < 2)
86 error(USER, "too few arguments");
87 rtargc--;
88 for (i = 0; myrtopts[i] != NULL; i++)
89 rtargv[rtargc++] = myrtopts[i];
90 rtargv[rtargc++] = argv[gargc-1];
91 rtargv[rtargc] = NULL;
92 /* just asking for defaults? */
93 if (!strcmp(argv[gargc-1], "-defaults")) {
94 printopts(); fflush(stdout);
95 rtpath = getpath(rtargv[0], getenv("PATH"), X_OK);
96 if (rtpath == NULL) {
97 eputs(rtargv[0]);
98 eputs(": command not found\n");
99 exit(1);
100 }
101 execv(rtpath, rtargv);
102 perror(rtpath);
103 exit(1);
104 }
105 /* else initialize and run our calculation */
106 init();
107 if (gargc+1 < argc)
108 for (i = gargc+1; i < argc; i++) {
109 if ((fp = fopen(argv[i], "r")) == NULL) {
110 sprintf(errmsg,
111 "cannot open scene file \"%s\"", argv[i]);
112 error(SYSTEM, errmsg);
113 }
114 filter(fp, argv[i]);
115 fclose(fp);
116 }
117 else
118 filter(stdin, "standard input");
119 quit(0);
120 }
121
122
123 quit(status) /* exit with status */
124 int status;
125 {
126 int rtstat;
127
128 rtstat = close_process(rt.pd);
129 if (status == 0)
130 if (rtstat < 0)
131 error(WARNING,
132 "unknown return status from rtrace process");
133 else
134 status = rtstat;
135 exit(status);
136 }
137
138
139 init() /* start rtrace and set up buffers */
140 {
141 extern int o_face(), o_sphere(), o_ring();
142 int maxbytes;
143 /* set up object functions */
144 ofun[OBJ_FACE].funp = o_face;
145 ofun[OBJ_SPHERE].funp = o_sphere;
146 ofun[OBJ_RING].funp = o_ring;
147 /* set up signal handling */
148 signal(SIGPIPE, quit);
149 /* start rtrace process */
150 maxbytes = open_process(rt.pd, rtargv);
151 if (maxbytes == 0) {
152 eputs(rtargv[0]);
153 eputs(": command not found\n");
154 exit(1);
155 }
156 if (maxbytes < 0)
157 error(SYSTEM, "cannot start rtrace process");
158 rt.bsiz = maxbytes/(6*sizeof(float));
159 rt.buf = (float *)malloc(6*sizeof(float)*rt.bsiz--);
160 rt.dest = (float **)malloc(sizeof(float *)*rt.bsiz);
161 if (rt.buf == NULL || rt.dest == NULL)
162 error(SYSTEM, "out of memory in init");
163 rt.nrays = 0;
164 /* set up urand */
165 initurand(2048);
166 }
167
168
169 eputs(s) /* put string to stderr */
170 register char *s;
171 {
172 static int midline = 0;
173
174 if (!*s) return;
175 if (!midline) {
176 fputs(progname, stderr);
177 fputs(": ", stderr);
178 }
179 fputs(s, stderr);
180 midline = s[strlen(s)-1] != '\n';
181 }
182
183
184 wputs(s) /* print warning if enabled */
185 char *s;
186 {
187 if (warnings)
188 eputs(s);
189 }
190
191
192 filter(infp, name) /* process stream */
193 register FILE *infp;
194 char *name;
195 {
196 char buf[512];
197 FILE *pfp;
198 register int c;
199
200 while ((c = getc(infp)) != EOF) {
201 if (isspace(c))
202 continue;
203 if (c == '#') { /* comment/options */
204 buf[0] = c;
205 fgets(buf+1, sizeof(buf)-1, infp);
206 xoptions(buf, name);
207 } else if (c == '!') { /* command */
208 buf[0] = c;
209 fgetline(buf+1, sizeof(buf)-1, infp);
210 if ((pfp = popen(buf+1, "r")) == NULL) {
211 sprintf(errmsg, "cannot execute \"%s\"", buf);
212 error(SYSTEM, errmsg);
213 }
214 filter(pfp, buf);
215 pclose(pfp);
216 } else { /* object */
217 ungetc(c, infp);
218 xobject(infp, name);
219 }
220 }
221 }
222
223
224 xoptions(s, nm) /* process options in string s */
225 char *s;
226 char *nm;
227 {
228 extern FILE *freopen();
229 char buf[64];
230 int nerrs = 0;
231 register char *cp;
232
233 if (strncmp(s, "#@mkillum", 9) || !isspace(s[9])) {
234 fputs(s, stdout); /* not for us */
235 return;
236 }
237 cp = s+10;
238 while (*cp) {
239 switch (*cp) {
240 case ' ':
241 case '\t':
242 case '\n':
243 cp++;
244 continue;
245 case 'm': /* material name */
246 if (*++cp != '=')
247 break;
248 if (!*++cp)
249 break;
250 atos(thisillum.matname, MAXSTR, cp);
251 cp = sskip(cp);
252 if (!(thisillum.flags & IL_DATCLB)) {
253 strcpy(thisillum.datafile, thisillum.matname);
254 thisillum.dfnum = 0;
255 }
256 continue;
257 case 'f': /* data file name */
258 if (*++cp != '=')
259 break;
260 if (!*++cp) {
261 strcpy(thisillum.datafile,thisillum.matname);
262 thisillum.dfnum = 0;
263 thisillum.flags &= ~IL_DATCLB;
264 continue;
265 }
266 atos(thisillum.datafile, MAXSTR, cp);
267 cp = sskip(cp);
268 thisillum.dfnum = 0;
269 thisillum.flags |= IL_DATCLB;
270 continue;
271 case 'i': /* include material */
272 case 'e': /* exclude material */
273 if (cp[1] != '=')
274 break;
275 matselect = (*cp == 'i') ? S_ELEM : S_COMPL;
276 cp += 2;
277 atos(matcheck, MAXSTR, cp);
278 cp = sskip(cp);
279 continue;
280 case 'a': /* use everything */
281 cp = sskip(cp);
282 matselect = S_ALL;
283 continue;
284 case 'n': /* use nothing (passive) */
285 cp = sskip(cp);
286 matselect = S_NONE;
287 continue;
288 case 'c': /* color calculation */
289 if (*++cp != '=')
290 break;
291 switch (*++cp) {
292 case 'a': /* average */
293 thisillum.flags = (thisillum.flags|IL_COLAVG)
294 & ~IL_COLDST;
295 break;
296 case 'd': /* distribution */
297 thisillum.flags |= (IL_COLDST|IL_COLAVG);
298 break;
299 case 'n': /* none */
300 thisillum.flags &= ~(IL_COLAVG|IL_COLDST);
301 break;
302 default:
303 goto opterr;
304 }
305 cp = sskip(cp);
306 continue;
307 case 'd': /* point sample density */
308 if (*++cp != '=')
309 break;
310 if (!isintd(++cp, " \t\n"))
311 break;
312 thisillum.sampdens = atoi(cp);
313 cp = sskip(cp);
314 continue;
315 case 's': /* point super-samples */
316 if (*++cp != '=')
317 break;
318 if (!isintd(++cp, " \t\n"))
319 break;
320 thisillum.nsamps = atoi(cp);
321 cp = sskip(cp);
322 continue;
323 case 'l': /* light sources */
324 cp++;
325 if (*cp == '+')
326 thisillum.flags |= IL_LIGHT;
327 else if (*cp == '-')
328 thisillum.flags &= ~IL_LIGHT;
329 else
330 break;
331 cp++;
332 continue;
333 case 'b': /* brightness */
334 if (*++cp != '=')
335 break;
336 if (!isfltd(++cp, " \t\n"))
337 break;
338 thisillum.minbrt = atof(cp);
339 if (thisillum.minbrt < 0.)
340 thisillum.minbrt = 0.;
341 cp = sskip(cp);
342 continue;
343 case 'o': /* output file */
344 if (*++cp != '=')
345 break;
346 if (!*++cp)
347 break;
348 atos(buf, sizeof(buf), cp);
349 cp = sskip(cp);
350 if (freopen(buf, "w", stdout) == NULL) {
351 sprintf(errmsg,
352 "cannot open output file \"%s\"", buf);
353 error(SYSTEM, errmsg);
354 }
355 doneheader = 0;
356 continue;
357 case '!': /* processed file! */
358 sprintf(errmsg, "(%s): already processed!", nm);
359 error(WARNING, errmsg);
360 matselect = S_NONE;
361 return;
362 }
363 opterr: /* skip faulty option */
364 cp = sskip(cp);
365 nerrs++;
366 }
367 /* print header? */
368 checkhead();
369 /* issue warnings? */
370 if (nerrs) {
371 sprintf(errmsg, "(%s): %d error(s) in option line:",
372 nm, nerrs);
373 error(WARNING, errmsg);
374 wputs(s);
375 printf("# %s: the following option line has %d error(s):\n",
376 progname, nerrs);
377 }
378 /* print pure comment */
379 printf("# %s", s+2);
380 }
381
382
383 printopts() /* print out option default values */
384 {
385 printf("m=%-15s\t\t# material name\n", thisillum.matname);
386 printf("f=%-15s\t\t# data file name\n", thisillum.datafile);
387 printf("c=n\t\t\t\t# color none\n");
388 printf("d=%d\t\t\t\t# density of points\n", thisillum.sampdens);
389 printf("s=%d\t\t\t\t# samples per point\n", thisillum.nsamps);
390 printf("b=%f\t\t\t# minimum average brightness\n", thisillum.minbrt);
391 }
392
393
394 printhead(ac, av) /* print out header */
395 register int ac;
396 register char **av;
397 {
398 putchar('#');
399 while (ac-- > 0) {
400 putchar(' ');
401 fputs(*av++, stdout);
402 }
403 fputs("\n#@mkillum !\n", stdout);
404 }
405
406
407 xobject(fp, nm) /* translate an object from fp */
408 FILE *fp;
409 char *nm;
410 {
411 OBJREC thisobj;
412 char str[MAXSTR];
413 int doit;
414 /* read the object */
415 if (fgetword(thisillum.altmat, MAXSTR, fp) == NULL)
416 goto readerr;
417 if (fgetword(str, MAXSTR, fp) == NULL)
418 goto readerr;
419 /* is it an alias? */
420 if (!strcmp(str, ALIASID)) {
421 if (fgetword(str, MAXSTR, fp) == NULL)
422 goto readerr;
423 printf("\n%s %s %s", thisillum.altmat, ALIASID, str);
424 if (fgetword(str, MAXSTR, fp) == NULL)
425 goto readerr;
426 printf("\t%s\n", str);
427 return;
428 }
429 thisobj.omod = OVOID; /* unused field */
430 if ((thisobj.otype = otype(str)) < 0) {
431 sprintf(errmsg, "(%s): unknown type \"%s\"", nm, str);
432 error(USER, errmsg);
433 }
434 if (fgetword(str, MAXSTR, fp) == NULL)
435 goto readerr;
436 thisobj.oname = str;
437 if (readfargs(&thisobj.oargs, fp) != 1)
438 goto readerr;
439 thisobj.os = NULL;
440 /* check for translation */
441 switch (matselect) {
442 case S_NONE:
443 doit = 0;
444 break;
445 case S_ALL:
446 doit = 1;
447 break;
448 case S_ELEM:
449 doit = !strcmp(thisillum.altmat, matcheck);
450 break;
451 case S_COMPL:
452 doit = strcmp(thisillum.altmat, matcheck);
453 break;
454 }
455 doit = doit && issurface(thisobj.otype);
456 /* print header? */
457 checkhead();
458 /* process object */
459 if (doit)
460 (*ofun[thisobj.otype].funp)(&thisobj, &thisillum, &rt, nm);
461 else
462 printobj(thisillum.altmat, &thisobj);
463 /* free arguments */
464 freefargs(&thisobj.oargs);
465 return;
466 readerr:
467 sprintf(errmsg, "(%s): error reading scene", nm);
468 error(USER, errmsg);
469 }
