--- ray/src/gen/mkillum.c 1995/11/14 16:03:46 2.9 +++ ray/src/gen/mkillum.c 2003/03/11 19:29:05 2.12 @@ -1,9 +1,6 @@ -/* Copyright (c) 1995 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: mkillum.c,v 2.12 2003/03/11 19:29:05 greg Exp $"; #endif - /* * Make illum sources for optimizing rendering process */ @@ -30,7 +27,8 @@ char *rtargv[64] = { "rtrace", "-dj", ".25", "-dr", " "-ab", "2", "-ad", "256", "-as", "128", "-aa", ".15", }; int rtargc = 14; /* overriding rtrace options */ -char *myrtopts[] = { "-I-", "-i-", "-ov", "-h-", "-fff", "-y", "0", NULL }; +char *myrtopts[] = { "-I-", "-i-", "-ld-", "-ov", "-h-", + "-fff", "-y", "0", NULL }; struct rtproc rt; /* our rtrace process */ @@ -59,16 +57,11 @@ int doneheader = 0; /* printed header yet? */ int warnings = 1; /* print warnings? */ -extern char *fgetline(), *fgetword(), *sskip(), - *atos(), *iskip(), *fskip(), *strcpy(); -extern FILE *popen(); - main(argc, argv) /* compute illum distributions using rtrace */ int argc; char *argv[]; { - extern char *getenv(), *getpath(); char *rtpath; FILE *fp; register int i; @@ -137,6 +130,7 @@ char *argv[]; } +void quit(status) /* exit with status */ int status; { @@ -184,6 +178,7 @@ init() /* start rtrace and set up buffers */ } +void eputs(s) /* put string to stderr */ register char *s; { @@ -199,6 +194,7 @@ register char *s; } +void wputs(s) /* print warning if enabled */ char *s; { @@ -258,6 +254,8 @@ char *nm; case ' ': case '\t': case '\n': + case '\r': + case '\f': cp++; continue; case 'm': /* material name */ @@ -325,7 +323,7 @@ char *nm; case 'd': /* point sample density */ if (*++cp != '=') break; - if (!isintd(++cp, " \t\n")) + if (!isintd(++cp, " \t\n\r")) break; thisillum.sampdens = atoi(cp); cp = sskip(cp); @@ -333,7 +331,7 @@ char *nm; case 's': /* point super-samples */ if (*++cp != '=') break; - if (!isintd(++cp, " \t\n")) + if (!isintd(++cp, " \t\n\r")) break; thisillum.nsamps = atoi(cp); cp = sskip(cp); @@ -351,7 +349,7 @@ char *nm; case 'b': /* brightness */ if (*++cp != '=') break; - if (!isfltd(++cp, " \t\n")) + if (!isfltd(++cp, " \t\n\r")) break; thisillum.minbrt = atof(cp); if (thisillum.minbrt < 0.) @@ -446,10 +444,10 @@ char *nm; if (fgetword(str, MAXSTR, fp) == NULL) goto readerr; /* is it an alias? */ - if (!strcmp(str, ALIASID)) { + if (!strcmp(str, ALIASKEY)) { if (fgetword(str, MAXSTR, fp) == NULL) goto readerr; - printf("\n%s %s %s", thisillum.altmat, ALIASID, str); + printf("\n%s %s %s", thisillum.altmat, ALIASKEY, str); if (fgetword(str, MAXSTR, fp) == NULL) goto readerr; printf("\t%s\n", str);
