--- ray/src/gen/mkillum.c 2003/06/26 00:58:09 2.14 +++ ray/src/gen/mkillum.c 2009/12/12 19:00:59 2.36 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: mkillum.c,v 2.14 2003/06/26 00:58:09 schorsch Exp $"; +static const char RCSid[] = "$Id: mkillum.c,v 2.36 2009/12/12 19:00:59 greg Exp $"; #endif /* * Make illum sources for optimizing rendering process @@ -7,10 +7,7 @@ static const char RCSid[] = "$Id: mkillum.c,v 2.14 200 #include #include -#include -#include "standard.h" -#include "platform.h" #include "mkillum.h" /* default parameters */ @@ -24,99 +21,99 @@ static const char RCSid[] = "$Id: mkillum.c,v 2.14 200 #define S_COMPL 2 /* select all but element */ #define S_ALL 3 /* select all */ - /* rtrace command and defaults */ -char *rtargv[64] = { "rtrace", "-dj", ".25", "-dr", "3", "-dv-", - "-ab", "2", "-ad", "256", "-as", "128", "-aa", ".15", }; -int rtargc = 14; - /* overriding rtrace options */ -char *myrtopts[] = { "-I-", "-i-", "-ld-", "-ov", "-h-", - "-fff", "-y", "0", NULL }; - -struct rtproc rt; /* our rtrace process */ - struct illum_args thisillum = { /* our illum and default values */ 0, + UDzpos, + 0., DFLMAT, DFLDAT, 0, VOIDID, SAMPDENS, NSAMPS, + NULL, 0., }; char matcheck[MAXSTR]; /* current material to include or exclude */ int matselect = S_ALL; /* selection criterion */ -FUN ofun[NUMOTYPE] = INIT_OTYPE; /* object types */ - int gargc; /* global argc */ char **gargv; /* global argv */ -#define progname gargv[0] int doneheader = 0; /* printed header yet? */ #define checkhead() if (!doneheader++) printhead(gargc,gargv) int warnings = 1; /* print warnings? */ +void init(char *octnm, int np); +void filter(register FILE *infp, char *name); +void xoptions(char *s, char *nm); +void printopts(void); +void printhead(register int ac, register char **av); +void xobject(FILE *fp, char *nm); -main(argc, argv) /* compute illum distributions using rtrace */ -int argc; -char *argv[]; + +int +main( /* compute illum distributions using rtrace */ + int argc, + char *argv[] +) { - char *rtpath; + int nprocs = 1; FILE *fp; + int rval; register int i; /* set global arguments */ gargv = argv; - /* set up rtrace command */ + progname = gargv[0]; + /* set up rendering defaults */ + dstrsrc = 0.5; + directrelay = 3; + directvis = 0; + ambounce = 2; + /* get options from command line */ for (i = 1; i < argc; i++) { - if (argv[i][0] == '<' && argv[i][1] == '\0') + while ((rval = expandarg(&argc, &argv, i)) > 0) + ; + if (rval < 0) { + sprintf(errmsg, "cannot expand '%s'", argv[i]); + error(SYSTEM, errmsg); + } + if (argv[i][0] != '-') break; - rtargv[rtargc++] = argv[i]; - if (argv[i][0] == '-' && argv[i][1] == 'w') - switch (argv[i][2]) { - case '\0': - warnings = !warnings; - break; - case '+': - case 'T': case 't': - case 'Y': case 'y': - case '1': - warnings = 1; - break; - case '-': - case 'F': case 'f': - case 'N': case 'n': - case '0': - warnings = 0; - break; - } - } - gargc = i; - rtargc--; - for (i = 0; myrtopts[i] != NULL; i++) - rtargv[rtargc++] = myrtopts[i]; - rtargv[rtargc++] = argv[gargc-1]; - rtargv[rtargc] = NULL; - /* just asking for defaults? */ - if (!strcmp(argv[gargc-1], "-defaults")) { - printopts(); fflush(stdout); - rtpath = getpath(rtargv[0], getenv("PATH"), X_OK); - if (rtpath == NULL) { - eputs(rtargv[0]); - eputs(": command not found\n"); - exit(1); + if (!strcmp(argv[i], "-w")) { + warnings = 0; + continue; } - execv(rtpath, rtargv); - perror(rtpath); - exit(1); + if (!strcmp(argv[i], "-n")) { + nprocs = atoi(argv[++i]); + if (nprocs <= 0) + error(USER, "illegal number of processes"); + continue; + } + if (!strcmp(argv[i], "-defaults")) { + printopts(); + print_rdefaults(); + quit(0); + } + rval = getrenderopt(argc-i, argv+i); + if (rval < 0) { + sprintf(errmsg, "bad render option at '%s'", argv[i]); + error(USER, errmsg); + } + i += rval; } - if (gargc < 2 || argv[gargc-1][0] == '-') + gargc = ++i; + /* add "mandatory" render options */ + do_irrad = 0; + if (gargc > argc || argv[gargc-1][0] == '-') error(USER, "missing octree argument"); /* else initialize and run our calculation */ - init(); - if (gargc+1 < argc) + init(argv[gargc-1], nprocs); + if (gargc < argc) { + if (gargc == argc-1 || argv[gargc][0] != '<' || argv[gargc][1]) + error(USER, "use '< file1 file2 ..' for multiple inputs"); for (i = gargc+1; i < argc; i++) { if ((fp = fopen(argv[i], "r")) == NULL) { sprintf(errmsg, @@ -126,65 +123,36 @@ char *argv[]; filter(fp, argv[i]); fclose(fp); } - else + } else filter(stdin, "standard input"); quit(0); + return 0; /* pro forma return */ } void -quit(status) /* exit with status */ -int status; +init(char *octnm, int np) /* start rendering process(es) */ { - int rtstat; - - rtstat = close_process(&(rt.pd)); - if (status == 0) - if (rtstat < 0) - error(WARNING, - "unknown return status from rtrace process"); - else - status = rtstat; - exit(status); -} - - -init() /* start rtrace and set up buffers */ -{ - extern int o_face(), o_sphere(), o_ring(); - int maxbytes; - /* set up object functions */ - ofun[OBJ_FACE].funp = o_face; - ofun[OBJ_SPHERE].funp = o_sphere; - ofun[OBJ_RING].funp = o_ring; /* set up signal handling */ -#ifdef SIGPIPE /* not present on Windows */ + signal(SIGINT, quit); +#ifdef SIGHUP + signal(SIGHUP, quit); +#endif +#ifdef SIGTERM + signal(SIGTERM, quit); +#endif +#ifdef SIGPIPE signal(SIGPIPE, quit); #endif - /* start rtrace process */ - errno = 0; - maxbytes = open_process(&(rt.pd), rtargv); - if (maxbytes == 0) { - eputs(rtargv[0]); - eputs(": command not found\n"); - exit(1); - } - if (maxbytes < 0) - error(SYSTEM, "cannot start rtrace process"); - rt.bsiz = maxbytes/(6*sizeof(float)); - rt.buf = (float *)malloc(6*sizeof(float)*rt.bsiz--); - rt.dest = (float **)malloc(sizeof(float *)*rt.bsiz); - if (rt.buf == NULL || rt.dest == NULL) - error(SYSTEM, "out of memory in init"); - rt.nrays = 0; - /* set up urand */ - initurand(16384); + /* start rendering process(es) */ + ray_pinit(octnm, np); } void -eputs(s) /* put string to stderr */ -register char *s; +eputs( /* put string to stderr */ + register char *s +) { static int midline = 0; @@ -207,10 +175,22 @@ char *s; } -filter(infp, name) /* process stream */ -register FILE *infp; -char *name; +void +quit(ec) /* make sure exit is called */ +int ec; { + if (ray_pnprocs > 0) /* close children if any */ + ray_pclose(0); + exit(ec); +} + + +void +filter( /* process stream */ + register FILE *infp, + char *name +) +{ char buf[512]; FILE *pfp; register int c; @@ -239,12 +219,15 @@ char *name; } -xoptions(s, nm) /* process options in string s */ -char *s; -char *nm; +void +xoptions( /* process options in string s */ + char *s, + char *nm +) { extern FILE *freopen(); char buf[64]; + int negax; int nerrs = 0; register char *cp; @@ -324,15 +307,26 @@ char *nm; } cp = sskip(cp); continue; - case 'd': /* point sample density */ + case 'd': /* sample density / BSDF data */ if (*++cp != '=') break; - if (!isintd(++cp, " \t\n\r")) - break; - thisillum.sampdens = atoi(cp); + if (thisillum.sd != NULL) { + free_BSDF(thisillum.sd); + thisillum.sd = NULL; + } + if (!*++cp || isspace(*cp)) + continue; + if (isintd(cp, " \t\n\r")) { + thisillum.sampdens = atoi(cp); + } else { + atos(buf, sizeof(buf), cp); + thisillum.sd = load_BSDF(buf); + if (thisillum.sd == NULL) + break; + } cp = sskip(cp); continue; - case 's': /* point super-samples */ + case 's': /* surface super-samples */ if (*++cp != '=') break; if (!isintd(++cp, " \t\n\r")) @@ -374,6 +368,50 @@ char *nm; } doneheader = 0; continue; + case 'u': /* up direction */ + if (*++cp != '=') + break; + if (!*++cp || isspace(*cp)) { + thisillum.udir = UDunknown; + continue; + } + negax = 0; + if (*cp == '+') + cp++; + else if (*cp == '-') { + negax++; + cp++; + } + switch (*cp++) { + case 'x': + case 'X': + thisillum.udir = negax ? UDxneg : UDxpos; + break; + case 'y': + case 'Y': + thisillum.udir = negax ? UDyneg : UDypos; + break; + case 'z': + case 'Z': + thisillum.udir = negax ? UDzneg : UDzpos; + break; + default: + thisillum.udir = UDunknown; + break; + } + if (thisillum.udir == UDunknown || !isspace(*cp)) + break; + continue; + case 't': /* object thickness */ + if (*++cp != '=') + break; + if (!isfltd(++cp, " \t\n\r")) + break; + thisillum.thick = atof(cp); + if (thisillum.thick < .0) + thisillum.thick = .0; + cp = sskip(cp); + continue; case '!': /* processed file! */ sprintf(errmsg, "(%s): already processed!", nm); error(WARNING, errmsg); @@ -400,8 +438,8 @@ char *nm; printf("# %s", s+2); } - -printopts() /* print out option default values */ +void +printopts(void) /* print out option default values */ { printf("m=%-15s\t\t# material name\n", thisillum.matname); printf("f=%-15s\t\t# data file name\n", thisillum.datafile); @@ -416,15 +454,40 @@ printopts() /* print out option default values */ printf("l+\t\t\t\t# light type on\n"); else printf("l-\t\t\t\t# light type off\n"); - printf("d=%d\t\t\t\t# density of points\n", thisillum.sampdens); - printf("s=%d\t\t\t\t# samples per point\n", thisillum.nsamps); + printf("d=%d\t\t\t\t# density of directions\n", thisillum.sampdens); + printf("s=%d\t\t\t\t# samples per direction\n", thisillum.nsamps); printf("b=%f\t\t\t# minimum average brightness\n", thisillum.minbrt); + switch (thisillum.udir) { + case UDzneg: + fputs("u=-Z\t\t\t\t# up is negative Z\n", stdout); + break; + case UDyneg: + fputs("u=-Y\t\t\t\t# up is negative Y\n", stdout); + break; + case UDxneg: + fputs("u=-X\t\t\t\t# up is negative X\n", stdout); + break; + case UDxpos: + fputs("u=+X\t\t\t\t# up is positive X\n", stdout); + break; + case UDypos: + fputs("u=+Y\t\t\t\t# up is positive Y\n", stdout); + break; + case UDzpos: + fputs("u=+Z\t\t\t\t# up is positive Z\n", stdout); + break; + case UDunknown: + break; + } + printf("t=%f\t\t\t# object thickness\n", thisillum.thick); } -printhead(ac, av) /* print out header */ -register int ac; -register char **av; +void +printhead( /* print out header */ + register int ac, + register char **av +) { putchar('#'); while (ac-- > 0) { @@ -435,9 +498,11 @@ register char **av; } -xobject(fp, nm) /* translate an object from fp */ -FILE *fp; -char *nm; +void +xobject( /* translate an object from fp */ + FILE *fp, + char *nm +) { OBJREC thisobj; char str[MAXSTR]; @@ -488,13 +553,26 @@ char *nm; checkhead(); /* process object */ if (doit) - (*ofun[thisobj.otype].funp)(&thisobj, &thisillum, &rt, nm); + switch (thisobj.otype) { + case OBJ_FACE: + my_face(&thisobj, &thisillum, nm); + break; + case OBJ_SPHERE: + my_sphere(&thisobj, &thisillum, nm); + break; + case OBJ_RING: + my_ring(&thisobj, &thisillum, nm); + break; + default: + my_default(&thisobj, &thisillum, nm); + break; + } else printobj(thisillum.altmat, &thisobj); /* free arguments */ freefargs(&thisobj.oargs); return; readerr: - sprintf(errmsg, "(%s): error reading scene", nm); + sprintf(errmsg, "(%s): error reading input", nm); error(USER, errmsg); }
