--- ray/src/gen/mkillum.c 2003/11/16 10:29:38 2.19 +++ ray/src/gen/mkillum.c 2006/06/07 17:52:04 2.27 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: mkillum.c,v 2.19 2003/11/16 10:29:38 schorsch Exp $"; +static const char RCSid[] = "$Id: mkillum.c,v 2.27 2006/06/07 17:52:04 schorsch Exp $"; #endif /* * Make illum sources for optimizing rendering process @@ -31,7 +31,7 @@ int rtargc = 14; char *myrtopts[] = { "-I-", "-i-", "-ld-", "-ov", "-h-", "-fff", "-y", "0", NULL }; -struct rtproc rt; /* our rtrace process */ +struct rtproc rt0; /* head of rtrace process list */ struct illum_args thisillum = { /* our illum and default values */ 0, @@ -49,6 +49,8 @@ int matselect = S_ALL; /* selection criterion */ FUN ofun[NUMOTYPE] = INIT_OTYPE; /* object types */ +char persistfn[] = "pfXXXXXX"; /* persist file name */ + int gargc; /* global argc */ char **gargv; /* global argv */ #define progname gargv[0] @@ -58,7 +60,8 @@ int doneheader = 0; /* printed header yet? */ int warnings = 1; /* print warnings? */ -void init(void); +int done_rprocs(struct rtproc *rtp); +void init(int np); void filter(register FILE *infp, char *name); void xoptions(char *s, char *nm); void printopts(void); @@ -72,13 +75,22 @@ main( /* compute illum distributions using rtrace */ char *argv[] ) { + int nprocs = 1; char *rtpath; FILE *fp; register int i; /* set global arguments */ gargv = argv; + /* check for -n option */ + if (!strcmp(argv[1], "-n")) { + nprocs = atoi(argv[2]); + if (nprocs <= 0) + error(USER, "illegal number of processes"); + i = 3; + } else + i = 1; /* set up rtrace command */ - for (i = 1; i < argc; i++) { + for ( ; i < argc; i++) { if (argv[i][0] == '<' && argv[i][1] == '\0') break; rtargv[rtargc++] = argv[i]; @@ -102,13 +114,19 @@ main( /* compute illum distributions using rtrace */ } } gargc = i; - rtargc--; + if (!strcmp(rtargv[--rtargc], "-defaults")) + nprocs = 0; + if (nprocs > 1) { /* add persist file if parallel invocation */ + rtargv[rtargc++] = "-PP"; + rtargv[rtargc++] = mktemp(persistfn); + } + /* add "mandatory" rtrace options */ for (i = 0; myrtopts[i] != NULL; i++) rtargv[rtargc++] = myrtopts[i]; + /* finally, put back final argument */ rtargv[rtargc++] = argv[gargc-1]; rtargv[rtargc] = NULL; - /* just asking for defaults? */ - if (!strcmp(argv[gargc-1], "-defaults")) { + if (!nprocs) { /* just asking for defaults? */ printopts(); fflush(stdout); rtpath = getpath(rtargv[0], getenv("PATH"), X_OK); if (rtpath == NULL) { @@ -117,13 +135,13 @@ main( /* compute illum distributions using rtrace */ exit(1); } execv(rtpath, rtargv); - perror(rtpath); + perror(rtpath); /* execv() should not return */ exit(1); } if (gargc < 2 || argv[gargc-1][0] == '-') error(USER, "missing octree argument"); /* else initialize and run our calculation */ - init(); + init(nprocs); if (gargc+1 < argc) for (i = gargc+1; i < argc; i++) { if ((fp = fopen(argv[i], "r")) == NULL) { @@ -136,56 +154,108 @@ main( /* compute illum distributions using rtrace */ } else filter(stdin, "standard input"); - return 0; + quit(0); + return 0; /* pro forma return */ } +#ifndef SIGALRM +#define SIGALRM SIGTERM +#endif +static void +killpersist(void) /* kill persistent rtrace process */ +{ + FILE *fp = fopen(persistfn, "r"); + int pid; + + if (fp == NULL) + return; + if (fscanf(fp, "%*s %d", &pid) != 1 || kill(pid, SIGALRM) < 0) + unlink(persistfn); + fclose(fp); +} + + +int +done_rprocs(struct rtproc *rtp) +{ + int st0, st1 = 0; + + if (rtp->next != NULL) { /* close last opened first! */ + st1 = done_rprocs(rtp->next); + free((void *)rtp->next); + rtp->next = NULL; + } + st0 = close_process(&rtp->pd); + if (st0 < 0) + error(WARNING, "unknown return status from rtrace process"); + else if (st0 > 0) + return(st0); + return(st1); +} + void -quit(status) /* exit with status */ -int status; +quit(int status) /* exit with status */ { int rtstat; - rtstat = close_process(&(rt.pd)); - if (status == 0) { - if (rtstat < 0) - error(WARNING, - "unknown return status from rtrace process"); - else - status = rtstat; - } + if (rt0.next != NULL) /* terminate persistent rtrace */ + killpersist(); + /* clean up rtrace process(es) */ + rtstat = done_rprocs(&rt0); + if (status == 0) + status = rtstat; exit(status); } void -init(void) /* start rtrace and set up buffers */ +init(int np) /* start rtrace and set up buffers */ { - extern int o_face(), o_sphere(), o_ring(); + struct rtproc *rtp; + int i; int maxbytes; /* set up object functions */ ofun[OBJ_FACE].funp = o_face; ofun[OBJ_SPHERE].funp = o_sphere; ofun[OBJ_RING].funp = o_ring; /* set up signal handling */ -#ifdef SIGPIPE /* not present on Windows */ + signal(SIGINT, quit); +#ifdef SIGHUP + signal(SIGHUP, quit); +#endif +#ifdef SIGTERM + signal(SIGTERM, quit); +#endif +#ifdef SIGPIPE signal(SIGPIPE, quit); #endif - /* start rtrace process */ - errno = 0; - maxbytes = open_process(&(rt.pd), rtargv); - if (maxbytes == 0) { - eputs(rtargv[0]); - eputs(": command not found\n"); - exit(1); + rtp = &rt0; /* start rtrace process(es) */ + for (i = 0; i++ < np; ) { + errno = 0; + maxbytes = open_process(&rtp->pd, rtargv); + if (maxbytes == 0) { + eputs(rtargv[0]); + eputs(": command not found\n"); + exit(1); + } + if (maxbytes < 0) + error(SYSTEM, "cannot start rtrace process"); + rtp->bsiz = maxbytes/(6*sizeof(float)); + rtp->buf = (float *)malloc(6*sizeof(float)*rtp->bsiz--); + rtp->dest = (float **)calloc(rtp->bsiz, sizeof(float *)); + if (rtp->buf == NULL || rtp->dest == NULL) + error(SYSTEM, "out of memory in init"); + rtp->nrays = 0; + if (i == np) /* last process? */ + break; + if (np > 1) + sleep(2); /* wait for persist file */ + rtp->next = (struct rtproc *)malloc(sizeof(struct rtproc)); + if (rtp->next == NULL) + error(SYSTEM, "out of memory in init"); + rtp = rtp->next; } - if (maxbytes < 0) - error(SYSTEM, "cannot start rtrace process"); - rt.bsiz = maxbytes/(6*sizeof(float)); - rt.buf = (float *)malloc(6*sizeof(float)*rt.bsiz--); - rt.dest = (float **)malloc(sizeof(float *)*rt.bsiz); - if (rt.buf == NULL || rt.dest == NULL) - error(SYSTEM, "out of memory in init"); - rt.nrays = 0; + rtp->next = NULL; /* set up urand */ initurand(16384); } @@ -506,7 +576,7 @@ xobject( /* translate an object from fp */ checkhead(); /* process object */ if (doit) - (*ofun[thisobj.otype].funp)(&thisobj, &thisillum, &rt, nm); + (*ofun[thisobj.otype].funp)(&thisobj, &thisillum, &rt0, nm); else printobj(thisillum.altmat, &thisobj); /* free arguments */
