--- ray/src/gen/mkillum.c 1991/07/24 16:48:22 1.5 +++ ray/src/gen/mkillum.c 1992/03/25 10:55:03 2.3 @@ -15,9 +15,10 @@ static char SCCSid[] = "$SunId$ LBL"; #include /* default parameters */ -#define SAMPDENS 128 /* points per projected steradian */ +#define SAMPDENS 48 /* points per projected steradian */ #define NSAMPS 32 /* samples per point */ #define DFLMAT "illum_mat" /* material name */ +#define DFLDAT "illum" /* data file name */ /* selection options */ #define S_NONE 0 /* select none */ #define S_ELEM 1 /* select specified element */ @@ -36,11 +37,12 @@ struct rtproc rt; /* our rtrace process */ struct illum_args thisillum = { /* our illum and default values */ 0, DFLMAT, - DFLMAT, + DFLDAT, 0, VOIDID, SAMPDENS, NSAMPS, + 0., }; char matcheck[MAXSTR]; /* current material to include or exclude */ @@ -58,7 +60,7 @@ int doneheader = 0; /* printed header yet? */ int warnings = 1; /* print warnings? */ extern char *fgetline(), *fgetword(), *sskip(), - *atos(), *iskip(), *fskip(); + *atos(), *iskip(), *fskip(), *strcpy(); extern FILE *popen(); @@ -80,8 +82,7 @@ char *argv[]; if (argv[i][0] == '-' && argv[i][1] == 'w') warnings = !warnings; } - if ((gargc = i) < 2) - error(USER, "too few arguments"); + gargc = i; rtargc--; for (i = 0; myrtopts[i] != NULL; i++) rtargv[rtargc++] = myrtopts[i]; @@ -89,6 +90,7 @@ char *argv[]; rtargv[rtargc] = NULL; /* just asking for defaults? */ if (!strcmp(argv[gargc-1], "-defaults")) { + printopts(); fflush(stdout); rtpath = getpath(rtargv[0], getenv("PATH"), X_OK); if (rtpath == NULL) { eputs(rtargv[0]); @@ -99,6 +101,8 @@ char *argv[]; perror(rtpath); exit(1); } + if (gargc < 2 || argv[gargc-1][0] == '-') + error(USER, "missing octree argument"); /* else initialize and run our calculation */ init(); if (gargc+1 < argc) @@ -144,6 +148,7 @@ init() /* start rtrace and set up buffers */ /* set up signal handling */ signal(SIGPIPE, quit); /* start rtrace process */ + errno = 0; maxbytes = open_process(rt.pd, rtargv); if (maxbytes == 0) { eputs(rtargv[0]); @@ -158,6 +163,8 @@ init() /* start rtrace and set up buffers */ if (rt.buf == NULL || rt.dest == NULL) error(SYSTEM, "out of memory in init"); rt.nrays = 0; + /* set up urand */ + initurand(2048); } @@ -253,6 +260,8 @@ char *nm; if (*++cp != '=') break; if (!*++cp) { + strcpy(thisillum.datafile,thisillum.matname); + thisillum.dfnum = 0; thisillum.flags &= ~IL_DATCLB; continue; } @@ -263,10 +272,11 @@ char *nm; continue; case 'i': /* include material */ case 'e': /* exclude material */ - matselect = (*cp == 'i') ? S_ELEM : S_COMPL; - if (*++cp != '=') + if (cp[1] != '=') break; - atos(matcheck, MAXSTR, ++cp); + matselect = (*cp == 'i') ? S_ELEM : S_COMPL; + cp += 2; + atos(matcheck, MAXSTR, cp); cp = sskip(cp); continue; case 'a': /* use everything */ @@ -282,8 +292,8 @@ char *nm; break; switch (*++cp) { case 'a': /* average */ - thisillum.flags |= IL_COLAVG; - thisillum.flags &= ~IL_COLDST; + thisillum.flags = (thisillum.flags|IL_COLAVG) + & ~IL_COLDST; break; case 'd': /* distribution */ thisillum.flags |= (IL_COLDST|IL_COLAVG); @@ -322,6 +332,16 @@ char *nm; break; cp++; continue; + case 'b': /* brightness */ + if (*++cp != '=') + break; + if (!isfltd(++cp, " \t\n")) + break; + thisillum.minbrt = atof(cp); + if (thisillum.minbrt < 0.) + thisillum.minbrt = 0.; + cp = sskip(cp); + continue; case 'o': /* output file */ if (*++cp != '=') break; @@ -336,6 +356,11 @@ char *nm; } doneheader = 0; continue; + case '!': /* processed file! */ + sprintf(errmsg, "(%s): already processed!", nm); + error(WARNING, errmsg); + matselect = S_NONE; + return; } opterr: /* skip faulty option */ cp = sskip(cp); @@ -357,6 +382,27 @@ char *nm; } +printopts() /* print out option default values */ +{ + printf("m=%-15s\t\t# material name\n", thisillum.matname); + printf("f=%-15s\t\t# data file name\n", thisillum.datafile); + if (thisillum.flags & IL_COLAVG) + if (thisillum.flags & IL_COLDST) + printf("c=d\t\t\t\t# color distribution\n"); + else + printf("c=a\t\t\t\t# color average\n"); + else + printf("c=n\t\t\t\t# color none\n"); + if (thisillum.flags & IL_LIGHT) + printf("l+\t\t\t\t# light type on\n"); + else + printf("l-\t\t\t\t# light type off\n"); + printf("d=%d\t\t\t\t# density of points\n", thisillum.sampdens); + printf("s=%d\t\t\t\t# samples per point\n", thisillum.nsamps); + printf("b=%f\t\t\t# minimum average brightness\n", thisillum.minbrt); +} + + printhead(ac, av) /* print out header */ register int ac; register char **av; @@ -366,7 +412,7 @@ register char **av; putchar(' '); fputs(*av++, stdout); } - putchar('\n'); + fputs("\n#@mkillum !\n", stdout); }
