--- ray/src/gen/mkillum.c 1991/08/26 10:16:54 1.13 +++ ray/src/gen/mkillum.c 2003/06/08 12:03:10 2.13 @@ -1,19 +1,17 @@ -/* Copyright (c) 1991 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: mkillum.c,v 2.13 2003/06/08 12:03:10 schorsch Exp $"; #endif - /* * Make illum sources for optimizing rendering process */ -#include "mkillum.h" - #include - #include +#include +#include "platform.h" +#include "mkillum.h" + /* default parameters */ #define SAMPDENS 48 /* points per projected steradian */ #define NSAMPS 32 /* samples per point */ @@ -26,11 +24,12 @@ static char SCCSid[] = "$SunId$ LBL"; #define S_ALL 3 /* select all */ /* rtrace command and defaults */ -char *rtargv[64] = { "rtrace", "-dj", ".25", "-dr", "3", "-di+", +char *rtargv[64] = { "rtrace", "-dj", ".25", "-dr", "3", "-dv-", "-ab", "2", "-ad", "256", "-as", "128", "-aa", ".15", }; int rtargc = 14; /* overriding rtrace options */ -char *myrtopts[] = { "-I-", "-i-", "-ov", "-h-", "-fff", NULL }; +char *myrtopts[] = { "-I-", "-i-", "-ld-", "-ov", "-h-", + "-fff", "-y", "0", NULL }; struct rtproc rt; /* our rtrace process */ @@ -59,16 +58,11 @@ int doneheader = 0; /* printed header yet? */ int warnings = 1; /* print warnings? */ -extern char *fgetline(), *fgetword(), *sskip(), - *atos(), *iskip(), *fskip(), *strcpy(); -extern FILE *popen(); - main(argc, argv) /* compute illum distributions using rtrace */ int argc; char *argv[]; { - extern char *getenv(), *getpath(); char *rtpath; FILE *fp; register int i; @@ -76,14 +70,29 @@ char *argv[]; gargv = argv; /* set up rtrace command */ for (i = 1; i < argc; i++) { - if (argv[i][0] == '<' && !argv[i][1]) + if (argv[i][0] == '<' && argv[i][1] == '\0') break; rtargv[rtargc++] = argv[i]; if (argv[i][0] == '-' && argv[i][1] == 'w') - warnings = !warnings; + switch (argv[i][2]) { + case '\0': + warnings = !warnings; + break; + case '+': + case 'T': case 't': + case 'Y': case 'y': + case '1': + warnings = 1; + break; + case '-': + case 'F': case 'f': + case 'N': case 'n': + case '0': + warnings = 0; + break; + } } - if ((gargc = i) < 2) - error(USER, "too few arguments"); + gargc = i; rtargc--; for (i = 0; myrtopts[i] != NULL; i++) rtargv[rtargc++] = myrtopts[i]; @@ -102,6 +111,8 @@ char *argv[]; perror(rtpath); exit(1); } + if (gargc < 2 || argv[gargc-1][0] == '-') + error(USER, "missing octree argument"); /* else initialize and run our calculation */ init(); if (gargc+1 < argc) @@ -120,6 +131,7 @@ char *argv[]; } +void quit(status) /* exit with status */ int status; { @@ -145,8 +157,11 @@ init() /* start rtrace and set up buffers */ ofun[OBJ_SPHERE].funp = o_sphere; ofun[OBJ_RING].funp = o_ring; /* set up signal handling */ +#ifndef _WIN32 /* XXX what do we use instead? */ signal(SIGPIPE, quit); +#endif /* start rtrace process */ + errno = 0; maxbytes = open_process(rt.pd, rtargv); if (maxbytes == 0) { eputs(rtargv[0]); @@ -162,10 +177,11 @@ init() /* start rtrace and set up buffers */ error(SYSTEM, "out of memory in init"); rt.nrays = 0; /* set up urand */ - initurand(2048); + initurand(16384); } +void eputs(s) /* put string to stderr */ register char *s; { @@ -181,6 +197,7 @@ register char *s; } +void wputs(s) /* print warning if enabled */ char *s; { @@ -240,12 +257,14 @@ char *nm; case ' ': case '\t': case '\n': + case '\r': + case '\f': cp++; continue; case 'm': /* material name */ if (*++cp != '=') break; - if (!*++cp) + if (!*++cp || isspace(*cp)) break; atos(thisillum.matname, MAXSTR, cp); cp = sskip(cp); @@ -257,7 +276,7 @@ char *nm; case 'f': /* data file name */ if (*++cp != '=') break; - if (!*++cp) { + if (!*++cp || isspace(*cp)) { strcpy(thisillum.datafile,thisillum.matname); thisillum.dfnum = 0; thisillum.flags &= ~IL_DATCLB; @@ -307,7 +326,7 @@ char *nm; case 'd': /* point sample density */ if (*++cp != '=') break; - if (!isintd(++cp, " \t\n")) + if (!isintd(++cp, " \t\n\r")) break; thisillum.sampdens = atoi(cp); cp = sskip(cp); @@ -315,7 +334,7 @@ char *nm; case 's': /* point super-samples */ if (*++cp != '=') break; - if (!isintd(++cp, " \t\n")) + if (!isintd(++cp, " \t\n\r")) break; thisillum.nsamps = atoi(cp); cp = sskip(cp); @@ -333,7 +352,7 @@ char *nm; case 'b': /* brightness */ if (*++cp != '=') break; - if (!isfltd(++cp, " \t\n")) + if (!isfltd(++cp, " \t\n\r")) break; thisillum.minbrt = atof(cp); if (thisillum.minbrt < 0.) @@ -343,7 +362,7 @@ char *nm; case 'o': /* output file */ if (*++cp != '=') break; - if (!*++cp) + if (!*++cp || isspace(*cp)) break; atos(buf, sizeof(buf), cp); cp = sskip(cp); @@ -361,7 +380,8 @@ char *nm; return; } opterr: /* skip faulty option */ - cp = sskip(cp); + while (*cp && !isspace(*cp)) + cp++; nerrs++; } /* print header? */ @@ -384,7 +404,17 @@ printopts() /* print out option default values */ { printf("m=%-15s\t\t# material name\n", thisillum.matname); printf("f=%-15s\t\t# data file name\n", thisillum.datafile); - printf("c=n\t\t\t\t# color none\n"); + if (thisillum.flags & IL_COLAVG) + if (thisillum.flags & IL_COLDST) + printf("c=d\t\t\t\t# color distribution\n"); + else + printf("c=a\t\t\t\t# color average\n"); + else + printf("c=n\t\t\t\t# color none\n"); + if (thisillum.flags & IL_LIGHT) + printf("l+\t\t\t\t# light type on\n"); + else + printf("l-\t\t\t\t# light type off\n"); printf("d=%d\t\t\t\t# density of points\n", thisillum.sampdens); printf("s=%d\t\t\t\t# samples per point\n", thisillum.nsamps); printf("b=%f\t\t\t# minimum average brightness\n", thisillum.minbrt); @@ -417,10 +447,10 @@ char *nm; if (fgetword(str, MAXSTR, fp) == NULL) goto readerr; /* is it an alias? */ - if (!strcmp(str, ALIASID)) { + if (!strcmp(str, ALIASKEY)) { if (fgetword(str, MAXSTR, fp) == NULL) goto readerr; - printf("\n%s %s %s", thisillum.altmat, ALIASID, str); + printf("\n%s %s %s", thisillum.altmat, ALIASKEY, str); if (fgetword(str, MAXSTR, fp) == NULL) goto readerr; printf("\t%s\n", str);
