--- ray/src/gen/mkillum.c 1991/07/23 12:00:29 1.1 +++ ray/src/gen/mkillum.c 1991/07/23 16:13:28 1.2 @@ -8,12 +8,10 @@ static char SCCSid[] = "$SunId$ LBL"; * Make illum sources for optimizing rendering process */ -#include "standard.h" +#include "mkillum.h" -#include "object.h" +#include -#include "otypes.h" - /* default parameters */ #define SAMPDENS 128 /* points per projected steradian */ #define NSAMPS 32 /* samples per point */ @@ -31,46 +29,32 @@ int rtargc = 13; /* overriding rtrace options */ char *myrtopts[] = { "-I-", "-i-", "-di+", "-ov", "-h-", "-fff", NULL }; - /* illum flags */ -#define IL_FLAT 0x1 /* flat surface */ -#define IL_LIGHT 0x2 /* light rather than illum */ -#define IL_COLDST 0x4 /* colored distribution */ -#define IL_COLAVG 0x8 /* compute average color */ -#define IL_DATCLB 0x10 /* OK to clobber data file */ +struct rtproc rt; /* our rtrace process */ -struct illum_args { - int flags; /* flags from list above */ - char matname[MAXSTR]; /* illum material name */ - char datafile[MAXSTR]; /* distribution data file name */ - int dfnum; /* data file number */ - char altmatname[MAXSTR]; /* alternate material name */ - int nsamps; /* # of samples in each direction */ - int nalt, nazi; /* # of altitude and azimuth angles */ - FVECT orient; /* coordinate system orientation */ -} thisillum = { /* default values */ - 0, - DFLMAT, - DFLMAT, - 0, - VOIDID, - NSAMPS, -}; +struct illum_args thisillum = { /* our illum and default values */ + 0, + DFLMAT, + DFLMAT, + 0, + VOIDID, + NSAMPS, + }; int sampdens = SAMPDENS; /* sample point density */ char matcheck[MAXSTR]; /* current material to include or exclude */ int matselect = S_ALL; /* selection criterion */ -int rt_pd[3]; /* rtrace pipe descriptors */ -float *rt_buf; /* rtrace i/o buffer */ -int rt_bsiz; /* maximum rays for rtrace buffer */ -int rt_nrays; /* current length of rtrace buffer */ +FUN ofun[NUMOTYPE] = INIT_OTYPE; /* object types */ int gargc; /* global argc */ char **gargv; /* global argv */ #define progname gargv[0] int doneheader = 0; /* printed header yet? */ +#define checkhead() if (!doneheader++) printhead(gargc,gargv) +int warnings = 1; /* print warnings? */ + extern char *fgetline(), *fgetword(), *sskip(), *atos(), *iskip(), *fskip(); extern FILE *popen(); @@ -88,8 +72,11 @@ char *argv[]; /* set up rtrace command */ if (argc < 2) error(USER, "too few arguments"); - for (i = 1; i < argc-1; i++) + for (i = 1; i < argc-1; i++) { rtargv[rtargc++] = argv[i]; + if (argv[i][0] == '-' && argv[i][1] == 'w') + warnings = !warnings; + } for (i = 0; myrtopts[i] != NULL; i++) rtargv[rtargc++] = myrtopts[i]; rtargv[rtargc++] = argv[argc-1]; @@ -108,8 +95,8 @@ char *argv[]; } /* else initialize and run our calculation */ init(); - mkillum(stdin, "standard input"); - exit(cleanup()); /* cleanup returns rtrace status */ + filter(stdin, "standard input"); + quit(0); } @@ -117,7 +104,7 @@ init() /* start rtrace and set up buffers */ { int maxbytes; - maxbytes = open_process(rt_pd, rtargv); + maxbytes = open_process(rt.pd, rtargv); if (maxbytes == 0) { eputs(rtargv[0]); eputs(": command not found\n"); @@ -125,26 +112,28 @@ init() /* start rtrace and set up buffers */ } if (maxbytes < 0) error(SYSTEM, "cannot start rtrace process"); - rt_bsiz = maxbytes/(6*sizeof(float)); - rt_buf = (float *)malloc(rt_bsiz*(6*sizeof(float))); - if (rt_buf == NULL) + rt.bsiz = maxbytes/(6*sizeof(float)); + rt.buf = (float *)malloc(rt.bsiz*(6*sizeof(float))); + if (rt.buf == NULL) error(SYSTEM, "out of memory in init"); - rt_bsiz--; /* allow for flush ray */ - rt_nrays = 0; + rt.bsiz--; /* allow for flush ray */ + rt.nrays = 0; } -int -cleanup() /* close rtrace process and return status */ +quit(status) /* exit with status */ +int status; { - int status; + int rtstat; - free((char *)rt_buf); - rt_bsiz = 0; - status = close_process(rt_pd); - if (status < 0) - return(0); /* unknown status */ - return(status); + rtstat = close_process(rt.pd); + if (status == 0) + if (rtstat < 0) + error(WARNING, + "unknown return status from rtrace process"); + else + status = rtstat; + exit(status); } @@ -163,7 +152,15 @@ register char *s; } -mkillum(infp, name) /* process stream */ +wputs(s) /* print warning if enabled */ +char *s; +{ + if (warnings) + eputs(s); +} + + +filter(infp, name) /* process stream */ register FILE *infp; char *name; { @@ -177,8 +174,7 @@ char *name; if (c == '#') { /* comment/options */ buf[0] = c; fgets(buf+1, sizeof(buf)-1, infp); - fputs(buf, stdout); - getoptions(buf, name); + xoptions(buf, name); } else if (c == '!') { /* command */ buf[0] = c; fgetline(buf+1, sizeof(buf)-1, infp); @@ -186,7 +182,7 @@ char *name; sprintf(errmsg, "cannot execute \"%s\"", buf); error(SYSTEM, errmsg); } - mkillum(pfp, buf); + filter(pfp, buf); pclose(pfp); } else { /* object */ ungetc(c, infp); @@ -196,7 +192,7 @@ char *name; } -getoptions(s, nm) /* get options from string s */ +xoptions(s, nm) /* process options in string s */ char *s; char *nm; { @@ -205,8 +201,10 @@ char *nm; int nerrs = 0; register char *cp; - if (strncmp(s, "#@mkillum", 9) || !isspace(s[9])) + if (strncmp(s, "#@mkillum", 9) || !isspace(s[9])) { + fputs(s, stdout); /* not for us */ return; + } cp = s+10; while (*cp) { switch (*cp) { @@ -216,10 +214,10 @@ char *nm; cp++; continue; case 'm': /* material name */ - cp++; - if (*cp != '=') + if (*++cp != '=') break; - cp++; + if (!*++cp) + break; atos(thisillum.matname, MAXSTR, cp); cp = sskip(cp); if (!(thisillum.flags & IL_DATCLB)) { @@ -228,11 +226,9 @@ char *nm; } continue; case 'f': /* data file name */ - cp++; - if (*cp != '=') + if (*++cp != '=') break; - cp++; - if (*cp == '\0') { + if (!*++cp) { thisillum.flags &= ~IL_DATCLB; continue; } @@ -243,11 +239,10 @@ char *nm; continue; case 'i': /* include material */ case 'e': /* exclude material */ - matselect = (*cp++ == 'i') ? S_ELEM : S_COMPL; - if (*cp != '=') + matselect = (*cp == 'i') ? S_ELEM : S_COMPL; + if (*++cp != '=') break; - cp++; - atos(matcheck, MAXSTR, cp); + atos(matcheck, MAXSTR, ++cp); cp = sskip(cp); continue; case 'a': /* use everything */ @@ -259,11 +254,9 @@ char *nm; matselect = S_NONE; continue; case 'c': /* color calculation */ - cp++; - if (*cp != '=') + if (*++cp != '=') break; - cp++; - switch (*cp) { + switch (*++cp) { case 'a': /* average */ thisillum.flags |= IL_COLAVG; thisillum.flags &= ~IL_COLDST; @@ -281,30 +274,26 @@ char *nm; cp = sskip(cp); continue; case 'd': /* point sample density */ - cp++; - if (*cp != '=') + if (*++cp != '=') break; - cp++; - if (!isintd(cp, " \t\n")) + if (!isintd(++cp, " \t\n")) break; sampdens = atoi(cp); cp = sskip(cp); continue; case 's': /* point super-samples */ - cp++; - if (*cp != '=') + if (*++cp != '=') break; - cp++; - if (!isintd(cp, " \t\n")) + if (!isintd(++cp, " \t\n")) break; thisillum.nsamps = atoi(cp); cp = sskip(cp); continue; case 'o': /* output file */ - cp++; - if (*cp != '=') + if (*++cp != '=') break; - cp++; + if (!*++cp) + break; atos(buf, sizeof(buf), cp); cp = sskip(cp); if (freopen(buf, "w", stdout) == NULL) { @@ -319,10 +308,126 @@ char *nm; cp = sskip(cp); nerrs++; } + /* print header? */ + checkhead(); + /* issue warnings? */ if (nerrs) { sprintf(errmsg, "(%s): %d error(s) in option line:", nm, nerrs); error(WARNING, errmsg); - eputs(s); + wputs(s); + printf("# %s: the following option line has %d error(s):\n", + progname, nerrs); } + /* print pure comment */ + putchar('#'); putchar(' '); fputs(s+2, stdout); } + + +printhead(ac, av) /* print out header */ +register int ac; +register char **av; +{ + putchar('#'); + while (ac-- > 0) { + putchar(' '); + fputs(*av++, stdout); + } + putchar('\n'); +} + + +xobject(fp, nm) /* translate an object from fp */ +FILE *fp; +char *nm; +{ + OBJREC thisobj; + char str[MAXSTR]; + int doit; + /* read the object */ + if (fgetword(thisillum.altmat, MAXSTR, fp) == NULL) + goto readerr; + if (fgetword(str, MAXSTR, fp) == NULL) + goto readerr; + /* is it an alias? */ + if (!strcmp(str, ALIASID)) { + if (fgetword(str, MAXSTR, fp) == NULL) + goto readerr; + printf("\n%s %s %s", thisillum.altmat, ALIASID, str); + if (fgetword(str, MAXSTR, fp) == NULL) + goto readerr; + printf(" %s\n", str); + return; + } + thisobj.omod = OVOID; + if ((thisobj.otype = otype(str)) < 0) { + sprintf(errmsg, "(%s): unknown type \"%s\"", nm, str); + error(USER, errmsg); + } + if (fgetword(str, MAXSTR, fp) == NULL) + goto readerr; + thisobj.oname = str; + if (readfargs(&thisobj.oargs, fp) != 1) + goto readerr; + thisobj.os = NULL; + /* check for translation */ + switch (matselect) { + case S_NONE: + doit = 0; + break; + case S_ALL: + doit = issurface(thisobj.otype); + break; + case S_ELEM: + doit = !strcmp(thisillum.altmat, matcheck); + break; + case S_COMPL: + doit = strcmp(thisillum.altmat, matcheck); + break; + } + if (doit) /* make sure we can do it */ + switch (thisobj.otype) { + case OBJ_SPHERE: + case OBJ_FACE: + case OBJ_RING: + break; + default: + sprintf(errmsg, + "(%s): cannot make illum for %s \"%s\"", + nm, ofun[thisobj.otype].funame, + thisobj.oname); + error(WARNING, errmsg); + doit = 0; + break; + } + /* print header? */ + checkhead(); + /* process object */ + if (doit) + mkillum(&thisobj, &thisillum, &rt); + else + printobj(thisillum.altmat, &thisobj); + /* free arguments */ + freefargs(&thisobj.oargs); + return; +readerr: + sprintf(errmsg, "(%s): error reading scene", nm); + error(USER, errmsg); +} + + +int +otype(ofname) /* get object function number from its name */ +char *ofname; +{ + register int i; + + for (i = 0; i < NUMOTYPE; i++) + if (!strcmp(ofun[i].funame, ofname)) + return(i); + + return(-1); /* not found */ +} + + +o_default() {}
