root/radiance/ray/src/gen/mkillum.c
Revision: 2.19
Committed: Sun Nov 16 10:29:38 2003 UTC (21 years, 8 months ago) by schorsch
Changes since 2.18: +42 -23 lines
2 static const char RCSid[] = "$Id: mkillum.c,v 2.18 2003/10/22 02:06:34 greg Exp $";
5 * Make illum sources for optimizing rendering process
6 */
7
8 #include <signal.h>
9 #include <ctype.h>
10
11 #include "platform.h"
12 #include "mkillum.h"
13 #include "random.h"
14
15 /* default parameters */
16 #define SAMPDENS 48 /* points per projected steradian */
17 #define NSAMPS 32 /* samples per point */
18 #define DFLMAT "illum_mat" /* material name */
19 #define DFLDAT "illum" /* data file name */
20 /* selection options */
21 #define S_NONE 0 /* select none */
22 #define S_ELEM 1 /* select specified element */
23 #define S_COMPL 2 /* select all but element */
24 #define S_ALL 3 /* select all */
25
26 /* rtrace command and defaults */
27 char *rtargv[64] = { "rtrace", "-dj", ".25", "-dr", "3", "-dv-",
28 "-ab", "2", "-ad", "1024", "-as", "512", "-aa", ".1", };
29 int rtargc = 14;
30 /* overriding rtrace options */
31 char *myrtopts[] = { "-I-", "-i-", "-ld-", "-ov", "-h-",
32 "-fff", "-y", "0", NULL };
33
34 struct rtproc rt; /* our rtrace process */
35
36 struct illum_args thisillum = { /* our illum and default values */
37 0,
38 DFLMAT,
39 DFLDAT,
40 0,
41 VOIDID,
42 SAMPDENS,
43 NSAMPS,
44 0.,
45 };
46
47 char matcheck[MAXSTR]; /* current material to include or exclude */
48 int matselect = S_ALL; /* selection criterion */
49
50 FUN ofun[NUMOTYPE] = INIT_OTYPE; /* object types */
51
52 int gargc; /* global argc */
53 char **gargv; /* global argv */
54 #define progname gargv[0]
55
56 int doneheader = 0; /* printed header yet? */
57 #define checkhead() if (!doneheader++) printhead(gargc,gargv)
58
59 int warnings = 1; /* print warnings? */
60
61 void init(void);
62 void filter(register FILE *infp, char *name);
63 void xoptions(char *s, char *nm);
64 void printopts(void);
65 void printhead(register int ac, register char **av);
66 void xobject(FILE *fp, char *nm);
67
68
69 int
70 main( /* compute illum distributions using rtrace */
71 int argc,
72 char *argv[]
73 )
74 {
75 char *rtpath;
76 FILE *fp;
77 register int i;
78 /* set global arguments */
79 gargv = argv;
80 /* set up rtrace command */
81 for (i = 1; i < argc; i++) {
82 if (argv[i][0] == '<' && argv[i][1] == '\0')
83 break;
84 rtargv[rtargc++] = argv[i];
85 if (argv[i][0] == '-' && argv[i][1] == 'w')
86 switch (argv[i][2]) {
87 case '\0':
88 warnings = !warnings;
89 break;
90 case '+':
91 case 'T': case 't':
92 case 'Y': case 'y':
93 case '1':
94 warnings = 1;
95 break;
96 case '-':
97 case 'F': case 'f':
98 case 'N': case 'n':
99 case '0':
100 warnings = 0;
101 break;
102 }
103 }
104 gargc = i;
105 rtargc--;
106 for (i = 0; myrtopts[i] != NULL; i++)
107 rtargv[rtargc++] = myrtopts[i];
108 rtargv[rtargc++] = argv[gargc-1];
109 rtargv[rtargc] = NULL;
110 /* just asking for defaults? */
111 if (!strcmp(argv[gargc-1], "-defaults")) {
112 printopts(); fflush(stdout);
113 rtpath = getpath(rtargv[0], getenv("PATH"), X_OK);
114 if (rtpath == NULL) {
115 eputs(rtargv[0]);
116 eputs(": command not found\n");
117 exit(1);
118 }
119 execv(rtpath, rtargv);
120 perror(rtpath);
121 exit(1);
122 }
123 if (gargc < 2 || argv[gargc-1][0] == '-')
124 error(USER, "missing octree argument");
125 /* else initialize and run our calculation */
126 init();
127 if (gargc+1 < argc)
128 for (i = gargc+1; i < argc; i++) {
129 if ((fp = fopen(argv[i], "r")) == NULL) {
130 sprintf(errmsg,
131 "cannot open scene file \"%s\"", argv[i]);
132 error(SYSTEM, errmsg);
133 }
134 filter(fp, argv[i]);
135 fclose(fp);
136 }
137 else
138 filter(stdin, "standard input");
139 return 0;
140 }
141
142
143 void
144 quit(status) /* exit with status */
145 int status;
146 {
147 int rtstat;
148
149 rtstat = close_process(&(rt.pd));
150 if (status == 0) {
151 if (rtstat < 0)
152 error(WARNING,
153 "unknown return status from rtrace process");
154 else
155 status = rtstat;
156 }
157 exit(status);
158 }
159
160 void
161 init(void) /* start rtrace and set up buffers */
162 {
163 extern int o_face(), o_sphere(), o_ring();
164 int maxbytes;
165 /* set up object functions */
166 ofun[OBJ_FACE].funp = o_face;
167 ofun[OBJ_SPHERE].funp = o_sphere;
168 ofun[OBJ_RING].funp = o_ring;
169 /* set up signal handling */
170 #ifdef SIGPIPE /* not present on Windows */
171 signal(SIGPIPE, quit);
172 #endif
173 /* start rtrace process */
174 errno = 0;
175 maxbytes = open_process(&(rt.pd), rtargv);
176 if (maxbytes == 0) {
177 eputs(rtargv[0]);
178 eputs(": command not found\n");
179 exit(1);
180 }
181 if (maxbytes < 0)
182 error(SYSTEM, "cannot start rtrace process");
183 rt.bsiz = maxbytes/(6*sizeof(float));
184 rt.buf = (float *)malloc(6*sizeof(float)*rt.bsiz--);
185 rt.dest = (float **)malloc(sizeof(float *)*rt.bsiz);
186 if (rt.buf == NULL || rt.dest == NULL)
187 error(SYSTEM, "out of memory in init");
188 rt.nrays = 0;
189 /* set up urand */
190 initurand(16384);
191 }
192
193
194 void
195 eputs( /* put string to stderr */
196 register char *s
197 )
198 {
199 static int midline = 0;
200
201 if (!*s) return;
202 if (!midline) {
203 fputs(progname, stderr);
204 fputs(": ", stderr);
205 }
206 fputs(s, stderr);
207 midline = s[strlen(s)-1] != '\n';
208 }
209
210
211 void
212 wputs(s) /* print warning if enabled */
213 char *s;
214 {
215 if (warnings)
216 eputs(s);
217 }
218
219
220 void
221 filter( /* process stream */
222 register FILE *infp,
223 char *name
224 )
225 {
226 char buf[512];
227 FILE *pfp;
228 register int c;
229
230 while ((c = getc(infp)) != EOF) {
231 if (isspace(c))
232 continue;
233 if (c == '#') { /* comment/options */
234 buf[0] = c;
235 fgets(buf+1, sizeof(buf)-1, infp);
236 xoptions(buf, name);
237 } else if (c == '!') { /* command */
238 buf[0] = c;
239 fgetline(buf+1, sizeof(buf)-1, infp);
240 if ((pfp = popen(buf+1, "r")) == NULL) {
241 sprintf(errmsg, "cannot execute \"%s\"", buf);
242 error(SYSTEM, errmsg);
243 }
244 filter(pfp, buf);
245 pclose(pfp);
246 } else { /* object */
247 ungetc(c, infp);
248 xobject(infp, name);
249 }
250 }
251 }
252
253
254 void
255 xoptions( /* process options in string s */
256 char *s,
257 char *nm
258 )
259 {
260 extern FILE *freopen();
261 char buf[64];
262 int nerrs = 0;
263 register char *cp;
264
265 if (strncmp(s, "#@mkillum", 9) || !isspace(s[9])) {
266 fputs(s, stdout); /* not for us */
267 return;
268 }
269 cp = s+10;
270 while (*cp) {
271 switch (*cp) {
272 case ' ':
273 case '\t':
274 case '\n':
275 case '\r':
276 case '\f':
277 cp++;
278 continue;
279 case 'm': /* material name */
280 if (*++cp != '=')
281 break;
282 if (!*++cp || isspace(*cp))
283 break;
284 atos(thisillum.matname, MAXSTR, cp);
285 cp = sskip(cp);
286 if (!(thisillum.flags & IL_DATCLB)) {
287 strcpy(thisillum.datafile, thisillum.matname);
288 thisillum.dfnum = 0;
289 }
290 continue;
291 case 'f': /* data file name */
292 if (*++cp != '=')
293 break;
294 if (!*++cp || isspace(*cp)) {
295 strcpy(thisillum.datafile,thisillum.matname);
296 thisillum.dfnum = 0;
297 thisillum.flags &= ~IL_DATCLB;
298 continue;
299 }
300 atos(thisillum.datafile, MAXSTR, cp);
301 cp = sskip(cp);
302 thisillum.dfnum = 0;
303 thisillum.flags |= IL_DATCLB;
304 continue;
305 case 'i': /* include material */
306 case 'e': /* exclude material */
307 if (cp[1] != '=')
308 break;
309 matselect = (*cp == 'i') ? S_ELEM : S_COMPL;
310 cp += 2;
311 atos(matcheck, MAXSTR, cp);
312 cp = sskip(cp);
313 continue;
314 case 'a': /* use everything */
315 cp = sskip(cp);
316 matselect = S_ALL;
317 continue;
318 case 'n': /* use nothing (passive) */
319 cp = sskip(cp);
320 matselect = S_NONE;
321 continue;
322 case 'c': /* color calculation */
323 if (*++cp != '=')
324 break;
325 switch (*++cp) {
326 case 'a': /* average */
327 thisillum.flags = (thisillum.flags|IL_COLAVG)
328 & ~IL_COLDST;
329 break;
330 case 'd': /* distribution */
331 thisillum.flags |= (IL_COLDST|IL_COLAVG);
332 break;
333 case 'n': /* none */
334 thisillum.flags &= ~(IL_COLAVG|IL_COLDST);
335 break;
336 default:
337 goto opterr;
338 }
339 cp = sskip(cp);
340 continue;
341 case 'd': /* point sample density */
342 if (*++cp != '=')
343 break;
344 if (!isintd(++cp, " \t\n\r"))
345 break;
346 thisillum.sampdens = atoi(cp);
347 cp = sskip(cp);
348 continue;
349 case 's': /* point super-samples */
350 if (*++cp != '=')
351 break;
352 if (!isintd(++cp, " \t\n\r"))
353 break;
354 thisillum.nsamps = atoi(cp);
355 cp = sskip(cp);
356 continue;
357 case 'l': /* light sources */
358 cp++;
359 if (*cp == '+')
360 thisillum.flags |= IL_LIGHT;
361 else if (*cp == '-')
362 thisillum.flags &= ~IL_LIGHT;
363 else
364 break;
365 cp++;
366 continue;
367 case 'b': /* brightness */
368 if (*++cp != '=')
369 break;
370 if (!isfltd(++cp, " \t\n\r"))
371 break;
372 thisillum.minbrt = atof(cp);
373 if (thisillum.minbrt < 0.)
374 thisillum.minbrt = 0.;
375 cp = sskip(cp);
376 continue;
377 case 'o': /* output file */
378 if (*++cp != '=')
379 break;
380 if (!*++cp || isspace(*cp))
381 break;
382 atos(buf, sizeof(buf), cp);
383 cp = sskip(cp);
384 if (freopen(buf, "w", stdout) == NULL) {
385 sprintf(errmsg,
386 "cannot open output file \"%s\"", buf);
387 error(SYSTEM, errmsg);
388 }
389 doneheader = 0;
390 continue;
391 case '!': /* processed file! */
392 sprintf(errmsg, "(%s): already processed!", nm);
393 error(WARNING, errmsg);
394 matselect = S_NONE;
395 return;
396 }
397 opterr: /* skip faulty option */
398 while (*cp && !isspace(*cp))
399 cp++;
400 nerrs++;
401 }
402 /* print header? */
403 checkhead();
404 /* issue warnings? */
405 if (nerrs) {
406 sprintf(errmsg, "(%s): %d error(s) in option line:",
407 nm, nerrs);
408 error(WARNING, errmsg);
409 wputs(s);
410 printf("# %s: the following option line has %d error(s):\n",
411 progname, nerrs);
412 }
413 /* print pure comment */
414 printf("# %s", s+2);
415 }
416
417 void
418 printopts(void) /* print out option default values */
419 {
420 printf("m=%-15s\t\t# material name\n", thisillum.matname);
421 printf("f=%-15s\t\t# data file name\n", thisillum.datafile);
422 if (thisillum.flags & IL_COLAVG)
423 if (thisillum.flags & IL_COLDST)
424 printf("c=d\t\t\t\t# color distribution\n");
425 else
426 printf("c=a\t\t\t\t# color average\n");
427 else
428 printf("c=n\t\t\t\t# color none\n");
429 if (thisillum.flags & IL_LIGHT)
430 printf("l+\t\t\t\t# light type on\n");
431 else
432 printf("l-\t\t\t\t# light type off\n");
433 printf("d=%d\t\t\t\t# density of points\n", thisillum.sampdens);
434 printf("s=%d\t\t\t\t# samples per point\n", thisillum.nsamps);
435 printf("b=%f\t\t\t# minimum average brightness\n", thisillum.minbrt);
436 }
437
438
439 void
440 printhead( /* print out header */
441 register int ac,
442 register char **av
443 )
444 {
445 putchar('#');
446 while (ac-- > 0) {
447 putchar(' ');
448 fputs(*av++, stdout);
449 }
450 fputs("\n#@mkillum !\n", stdout);
451 }
452
453
454 void
455 xobject( /* translate an object from fp */
456 FILE *fp,
457 char *nm
458 )
459 {
460 OBJREC thisobj;
461 char str[MAXSTR];
462 int doit;
463 /* read the object */
464 if (fgetword(thisillum.altmat, MAXSTR, fp) == NULL)
465 goto readerr;
466 if (fgetword(str, MAXSTR, fp) == NULL)
467 goto readerr;
468 /* is it an alias? */
469 if (!strcmp(str, ALIASKEY)) {
470 if (fgetword(str, MAXSTR, fp) == NULL)
471 goto readerr;
472 printf("\n%s %s %s", thisillum.altmat, ALIASKEY, str);
473 if (fgetword(str, MAXSTR, fp) == NULL)
474 goto readerr;
475 printf("\t%s\n", str);
476 return;
477 }
478 thisobj.omod = OVOID; /* unused field */
479 if ((thisobj.otype = otype(str)) < 0) {
480 sprintf(errmsg, "(%s): unknown type \"%s\"", nm, str);
481 error(USER, errmsg);
482 }
483 if (fgetword(str, MAXSTR, fp) == NULL)
484 goto readerr;
485 thisobj.oname = str;
486 if (readfargs(&thisobj.oargs, fp) != 1)
487 goto readerr;
488 thisobj.os = NULL;
489 /* check for translation */
490 switch (matselect) {
491 case S_NONE:
492 doit = 0;
493 break;
494 case S_ALL:
495 doit = 1;
496 break;
497 case S_ELEM:
498 doit = !strcmp(thisillum.altmat, matcheck);
499 break;
500 case S_COMPL:
501 doit = strcmp(thisillum.altmat, matcheck);
502 break;
503 }
504 doit = doit && issurface(thisobj.otype);
505 /* print header? */
506 checkhead();
507 /* process object */
508 if (doit)
509 (*ofun[thisobj.otype].funp)(&thisobj, &thisillum, &rt, nm);
510 else
511 printobj(thisillum.altmat, &thisobj);
512 /* free arguments */
513 freefargs(&thisobj.oargs);
514 return;
515 readerr:
516 sprintf(errmsg, "(%s): error reading scene", nm);
517 error(USER, errmsg);
518 }
