root/Development/ray/src/gen/mkillum.c
Revision: 2.40
Committed: Sun Aug 11 02:57:49 2013 UTC (12 years, 4 months ago) by greg
CVS Tags: rad5R0, rad4R2P2, rad4R2P1, rad4R2
Changes since 2.39: +1 -13 lines
Removed deprecated thickness setting used for BSDF input
# User Rev Content
1 greg 1.1 #ifndef lint
2 greg 2.40 static const char RCSid[] = "$Id: mkillum.c,v 2.39 2012/10/13 20:15:43 greg Exp $";
3 greg 1.1 #endif
4     /*
5     * Make illum sources for optimizing rendering process
6     */
7
8 greg 1.3 #include <signal.h>
9 schorsch 2.13 #include <ctype.h>
10 greg 1.3
11 greg 2.38 #include "rtprocess.h" /* win_popen() */
12 greg 2.15 #include "mkillum.h"
13 greg 1.1
14     /* default parameters */
15 greg 1.8 #define SAMPDENS 48 /* points per projected steradian */
16 greg 1.1 #define NSAMPS 32 /* samples per point */
17     #define DFLMAT "illum_mat" /* material name */
18 greg 1.10 #define DFLDAT "illum" /* data file name */
19 greg 1.1 /* selection options */
20     #define S_NONE 0 /* select none */
21     #define S_ELEM 1 /* select specified element */
22     #define S_COMPL 2 /* select all but element */
23     #define S_ALL 3 /* select all */
24
25 greg 1.2 struct illum_args thisillum = { /* our illum and default values */
26     0,
27     DFLMAT,
28 greg 1.10 DFLDAT,
29 greg 1.2 0,
30     VOIDID,
31 greg 1.3 SAMPDENS,
32 greg 1.2 NSAMPS,
33 greg 1.12 0.,
34 greg 1.2 };
35 greg 1.1
36     char matcheck[MAXSTR]; /* current material to include or exclude */
37     int matselect = S_ALL; /* selection criterion */
38
39     int gargc; /* global argc */
40     char **gargv; /* global argv */
41
42     int doneheader = 0; /* printed header yet? */
43 greg 1.2 #define checkhead() if (!doneheader++) printhead(gargc,gargv)
44 greg 1.1
45 greg 1.2 int warnings = 1; /* print warnings? */
46
47 greg 2.28 void init(char *octnm, int np);
48 schorsch 2.19 void filter(register FILE *infp, char *name);
49     void xoptions(char *s, char *nm);
50     void printopts(void);
51     void printhead(register int ac, register char **av);
52     void xobject(FILE *fp, char *nm);
53 greg 1.1
54 schorsch 2.19
55     int
56     main( /* compute illum distributions using rtrace */
57     int argc,
58     char *argv[]
59     )
60 greg 1.1 {
61 greg 2.20 int nprocs = 1;
62 greg 1.3 FILE *fp;
63 greg 2.28 int rval;
64 greg 1.1 register int i;
65     /* set global arguments */
66 greg 1.3 gargv = argv;
67 greg 2.28 progname = gargv[0];
68     /* set up rendering defaults */
69 greg 2.35 dstrsrc = 0.5;
70 greg 2.28 directrelay = 3;
71     ambounce = 2;
72     /* get options from command line */
73 greg 2.29 for (i = 1; i < argc; i++) {
74 greg 2.28 while ((rval = expandarg(&argc, &argv, i)) > 0)
75     ;
76     if (rval < 0) {
77     sprintf(errmsg, "cannot expand '%s'", argv[i]);
78     error(SYSTEM, errmsg);
79     }
80     if (argv[i][0] != '-')
81 greg 1.3 break;
82 greg 2.28 if (!strcmp(argv[i], "-w")) {
83     warnings = 0;
84     continue;
85     }
86     if (!strcmp(argv[i], "-n")) {
87     nprocs = atoi(argv[++i]);
88     if (nprocs <= 0)
89     error(USER, "illegal number of processes");
90     continue;
91     }
92     if (!strcmp(argv[i], "-defaults")) {
93     printopts();
94     print_rdefaults();
95     quit(0);
96     }
97     rval = getrenderopt(argc-i, argv+i);
98     if (rval < 0) {
99     sprintf(errmsg, "bad render option at '%s'", argv[i]);
100     error(USER, errmsg);
101 greg 1.1 }
102 greg 2.28 i += rval;
103 greg 1.1 }
104 greg 2.28 gargc = ++i;
105     /* add "mandatory" render options */
106     do_irrad = 0;
107     if (gargc > argc || argv[gargc-1][0] == '-')
108 greg 2.3 error(USER, "missing octree argument");
109 greg 1.1 /* else initialize and run our calculation */
110 greg 2.28 init(argv[gargc-1], nprocs);
111     if (gargc < argc) {
112     if (gargc == argc-1 || argv[gargc][0] != '<' || argv[gargc][1])
113 greg 2.30 error(USER, "use '< file1 file2 ..' for multiple inputs");
114 greg 1.3 for (i = gargc+1; i < argc; i++) {
115 greg 1.5 if ((fp = fopen(argv[i], "r")) == NULL) {
116 greg 1.3 sprintf(errmsg,
117     "cannot open scene file \"%s\"", argv[i]);
118     error(SYSTEM, errmsg);
119     }
120     filter(fp, argv[i]);
121     fclose(fp);
122     }
123 greg 2.28 } else
124 greg 1.3 filter(stdin, "standard input");
125 greg 2.20 quit(0);
126 schorsch 2.27 return 0; /* pro forma return */
127 greg 1.1 }
128
129 schorsch 2.26
130 greg 2.11 void
131 greg 2.28 init(char *octnm, int np) /* start rendering process(es) */
132 greg 1.3 {
133     /* set up signal handling */
134 greg 2.25 signal(SIGINT, quit);
135     #ifdef SIGHUP
136     signal(SIGHUP, quit);
137     #endif
138     #ifdef SIGTERM
139     signal(SIGTERM, quit);
140     #endif
141     #ifdef SIGPIPE
142 greg 1.3 signal(SIGPIPE, quit);
143 schorsch 2.13 #endif
144 greg 2.28 /* start rendering process(es) */
145     ray_pinit(octnm, np);
146 greg 1.1 }
147
148
149 greg 2.11 void
150 schorsch 2.19 eputs( /* put string to stderr */
151     register char *s
152     )
153 greg 1.1 {
154     static int midline = 0;
155
156     if (!*s) return;
157     if (!midline) {
158     fputs(progname, stderr);
159     fputs(": ", stderr);
160     }
161     fputs(s, stderr);
162     midline = s[strlen(s)-1] != '\n';
163     }
164
165
166 greg 2.11 void
167 greg 1.2 wputs(s) /* print warning if enabled */
168     char *s;
169     {
170     if (warnings)
171     eputs(s);
172     }
173
174
175 schorsch 2.19 void
176 greg 2.36 quit(ec) /* make sure exit is called */
177     int ec;
178     {
179     if (ray_pnprocs > 0) /* close children if any */
180     ray_pclose(0);
181     exit(ec);
182     }
183
184
185     void
186 schorsch 2.19 filter( /* process stream */
187     register FILE *infp,
188     char *name
189     )
190 greg 1.1 {
191     char buf[512];
192     FILE *pfp;
193     register int c;
194
195     while ((c = getc(infp)) != EOF) {
196     if (isspace(c))
197     continue;
198     if (c == '#') { /* comment/options */
199     buf[0] = c;
200     fgets(buf+1, sizeof(buf)-1, infp);
201 greg 1.2 xoptions(buf, name);
202 greg 1.1 } else if (c == '!') { /* command */
203     buf[0] = c;
204     fgetline(buf+1, sizeof(buf)-1, infp);
205     if ((pfp = popen(buf+1, "r")) == NULL) {
206     sprintf(errmsg, "cannot execute \"%s\"", buf);
207     error(SYSTEM, errmsg);
208     }
209 greg 1.2 filter(pfp, buf);
210 greg 1.1 pclose(pfp);
211     } else { /* object */
212     ungetc(c, infp);
213     xobject(infp, name);
214     }
215     }
216     }
217
218
219 schorsch 2.19 void
220     xoptions( /* process options in string s */
221     char *s,
222     char *nm
223     )
224 greg 1.1 {
225     extern FILE *freopen();
226     char buf[64];
227 greg 2.30 int negax;
228 greg 1.1 int nerrs = 0;
229     register char *cp;
230
231 greg 1.2 if (strncmp(s, "#@mkillum", 9) || !isspace(s[9])) {
232     fputs(s, stdout); /* not for us */
233 greg 1.1 return;
234 greg 1.2 }
235 greg 1.1 cp = s+10;
236     while (*cp) {
237     switch (*cp) {
238     case ' ':
239     case '\t':
240     case '\n':
241 greg 2.11 case '\r':
242     case '\f':
243 greg 1.1 cp++;
244     continue;
245     case 'm': /* material name */
246 greg 1.2 if (*++cp != '=')
247 greg 1.1 break;
248 greg 2.8 if (!*++cp || isspace(*cp))
249 greg 1.2 break;
250 greg 1.1 atos(thisillum.matname, MAXSTR, cp);
251     cp = sskip(cp);
252     if (!(thisillum.flags & IL_DATCLB)) {
253     strcpy(thisillum.datafile, thisillum.matname);
254     thisillum.dfnum = 0;
255     }
256     continue;
257     case 'f': /* data file name */
258 greg 1.2 if (*++cp != '=')
259 greg 1.1 break;
260 greg 2.8 if (!*++cp || isspace(*cp)) {
261 greg 1.6 strcpy(thisillum.datafile,thisillum.matname);
262 greg 1.10 thisillum.dfnum = 0;
263 greg 1.1 thisillum.flags &= ~IL_DATCLB;
264     continue;
265     }
266     atos(thisillum.datafile, MAXSTR, cp);
267     cp = sskip(cp);
268     thisillum.dfnum = 0;
269     thisillum.flags |= IL_DATCLB;
270     continue;
271     case 'i': /* include material */
272     case 'e': /* exclude material */
273 greg 1.6 if (cp[1] != '=')
274 greg 1.1 break;
275 greg 1.7 matselect = (*cp == 'i') ? S_ELEM : S_COMPL;
276     cp += 2;
277     atos(matcheck, MAXSTR, cp);
278 greg 1.1 cp = sskip(cp);
279     continue;
280     case 'a': /* use everything */
281     cp = sskip(cp);
282     matselect = S_ALL;
283     continue;
284     case 'n': /* use nothing (passive) */
285     cp = sskip(cp);
286     matselect = S_NONE;
287     continue;
288     case 'c': /* color calculation */
289 greg 1.2 if (*++cp != '=')
290 greg 1.1 break;
291 greg 1.2 switch (*++cp) {
292 greg 1.1 case 'a': /* average */
293 greg 1.6 thisillum.flags = (thisillum.flags|IL_COLAVG)
294     & ~IL_COLDST;
295 greg 1.1 break;
296     case 'd': /* distribution */
297 greg 1.5 thisillum.flags |= (IL_COLDST|IL_COLAVG);
298 greg 1.1 break;
299     case 'n': /* none */
300     thisillum.flags &= ~(IL_COLAVG|IL_COLDST);
301     break;
302     default:
303     goto opterr;
304     }
305     cp = sskip(cp);
306     continue;
307 greg 2.39 case 'd': /* sample density */
308 greg 1.2 if (*++cp != '=')
309 greg 1.1 break;
310 greg 2.30 if (!*++cp || isspace(*cp))
311     continue;
312 greg 2.33 if (isintd(cp, " \t\n\r")) {
313 greg 2.30 thisillum.sampdens = atoi(cp);
314     } else {
315 greg 2.39 error(WARNING, "direct BSDF input unsupported");
316     goto opterr;
317 greg 2.30 }
318 greg 1.1 cp = sskip(cp);
319     continue;
320 greg 2.30 case 's': /* surface super-samples */
321 greg 1.2 if (*++cp != '=')
322 greg 1.1 break;
323 greg 2.11 if (!isintd(++cp, " \t\n\r"))
324 greg 1.1 break;
325     thisillum.nsamps = atoi(cp);
326     cp = sskip(cp);
327     continue;
328 greg 1.3 case 'l': /* light sources */
329 greg 1.4 cp++;
330     if (*cp == '+')
331 greg 1.3 thisillum.flags |= IL_LIGHT;
332 greg 1.4 else if (*cp == '-')
333     thisillum.flags &= ~IL_LIGHT;
334 greg 1.3 else
335 greg 1.4 break;
336     cp++;
337 greg 1.3 continue;
338 greg 1.12 case 'b': /* brightness */
339     if (*++cp != '=')
340     break;
341 greg 2.11 if (!isfltd(++cp, " \t\n\r"))
342 greg 1.12 break;
343     thisillum.minbrt = atof(cp);
344 greg 1.13 if (thisillum.minbrt < 0.)
345     thisillum.minbrt = 0.;
346 greg 1.12 cp = sskip(cp);
347     continue;
348 greg 1.1 case 'o': /* output file */
349 greg 1.2 if (*++cp != '=')
350 greg 1.1 break;
351 greg 2.8 if (!*++cp || isspace(*cp))
352 greg 1.2 break;
353 greg 1.1 atos(buf, sizeof(buf), cp);
354     cp = sskip(cp);
355     if (freopen(buf, "w", stdout) == NULL) {
356     sprintf(errmsg,
357     "cannot open output file \"%s\"", buf);
358     error(SYSTEM, errmsg);
359     }
360     doneheader = 0;
361     continue;
362 greg 1.6 case '!': /* processed file! */
363 greg 1.7 sprintf(errmsg, "(%s): already processed!", nm);
364 greg 1.6 error(WARNING, errmsg);
365 greg 1.7 matselect = S_NONE;
366 greg 1.6 return;
367 greg 1.1 }
368     opterr: /* skip faulty option */
369 greg 2.9 while (*cp && !isspace(*cp))
370     cp++;
371 greg 1.1 nerrs++;
372     }
373 greg 1.2 /* print header? */
374     checkhead();
375     /* issue warnings? */
376 greg 1.1 if (nerrs) {
377     sprintf(errmsg, "(%s): %d error(s) in option line:",
378     nm, nerrs);
379     error(WARNING, errmsg);
380 greg 1.2 wputs(s);
381     printf("# %s: the following option line has %d error(s):\n",
382     progname, nerrs);
383 greg 1.1 }
384 greg 1.2 /* print pure comment */
385 greg 1.4 printf("# %s", s+2);
386 greg 1.9 }
387
388 schorsch 2.19 void
389     printopts(void) /* print out option default values */
390 greg 1.9 {
391 greg 1.11 printf("m=%-15s\t\t# material name\n", thisillum.matname);
392     printf("f=%-15s\t\t# data file name\n", thisillum.datafile);
393 greg 2.2 if (thisillum.flags & IL_COLAVG)
394     if (thisillum.flags & IL_COLDST)
395     printf("c=d\t\t\t\t# color distribution\n");
396     else
397     printf("c=a\t\t\t\t# color average\n");
398     else
399     printf("c=n\t\t\t\t# color none\n");
400     if (thisillum.flags & IL_LIGHT)
401     printf("l+\t\t\t\t# light type on\n");
402     else
403     printf("l-\t\t\t\t# light type off\n");
404 greg 2.34 printf("d=%d\t\t\t\t# density of directions\n", thisillum.sampdens);
405     printf("s=%d\t\t\t\t# samples per direction\n", thisillum.nsamps);
406 greg 1.12 printf("b=%f\t\t\t# minimum average brightness\n", thisillum.minbrt);
407 greg 1.1 }
408 greg 1.2
409
410 schorsch 2.19 void
411     printhead( /* print out header */
412     register int ac,
413     register char **av
414     )
415 greg 1.2 {
416     putchar('#');
417     while (ac-- > 0) {
418     putchar(' ');
419     fputs(*av++, stdout);
420     }
421 greg 1.6 fputs("\n#@mkillum !\n", stdout);
422 greg 1.2 }
423
424
425 schorsch 2.19 void
426     xobject( /* translate an object from fp */
427     FILE *fp,
428     char *nm
429     )
430 greg 1.2 {
431     OBJREC thisobj;
432     char str[MAXSTR];
433     int doit;
434     /* read the object */
435     if (fgetword(thisillum.altmat, MAXSTR, fp) == NULL)
436     goto readerr;
437     if (fgetword(str, MAXSTR, fp) == NULL)
438     goto readerr;
439     /* is it an alias? */
440 greg 2.12 if (!strcmp(str, ALIASKEY)) {
441 greg 1.2 if (fgetword(str, MAXSTR, fp) == NULL)
442     goto readerr;
443 greg 2.12 printf("\n%s %s %s", thisillum.altmat, ALIASKEY, str);
444 greg 1.2 if (fgetword(str, MAXSTR, fp) == NULL)
445     goto readerr;
446 greg 1.4 printf("\t%s\n", str);
447 greg 1.2 return;
448     }
449 greg 1.4 thisobj.omod = OVOID; /* unused field */
450 greg 1.2 if ((thisobj.otype = otype(str)) < 0) {
451     sprintf(errmsg, "(%s): unknown type \"%s\"", nm, str);
452     error(USER, errmsg);
453     }
454     if (fgetword(str, MAXSTR, fp) == NULL)
455     goto readerr;
456     thisobj.oname = str;
457     if (readfargs(&thisobj.oargs, fp) != 1)
458     goto readerr;
459     thisobj.os = NULL;
460     /* check for translation */
461     switch (matselect) {
462     case S_NONE:
463     doit = 0;
464     break;
465     case S_ALL:
466 greg 1.4 doit = 1;
467 greg 1.2 break;
468     case S_ELEM:
469     doit = !strcmp(thisillum.altmat, matcheck);
470     break;
471     case S_COMPL:
472     doit = strcmp(thisillum.altmat, matcheck);
473     break;
474     }
475 greg 1.4 doit = doit && issurface(thisobj.otype);
476 greg 1.2 /* print header? */
477     checkhead();
478     /* process object */
479     if (doit)
480 greg 2.28 switch (thisobj.otype) {
481     case OBJ_FACE:
482     my_face(&thisobj, &thisillum, nm);
483     break;
484     case OBJ_SPHERE:
485     my_sphere(&thisobj, &thisillum, nm);
486     break;
487     case OBJ_RING:
488     my_ring(&thisobj, &thisillum, nm);
489     break;
490     default:
491     my_default(&thisobj, &thisillum, nm);
492     break;
493     }
494 greg 1.2 else
495     printobj(thisillum.altmat, &thisobj);
496     /* free arguments */
497     freefargs(&thisobj.oargs);
498     return;
499     readerr:
500 greg 2.28 sprintf(errmsg, "(%s): error reading input", nm);
501 greg 1.2 error(USER, errmsg);
502     }
