root/radiance/ray/src/gen/mkillum.c
Revision: 1.2
Committed: Tue Jul 23 16:13:28 1991 UTC (33 years, 11 months ago) by greg
Changes since 1.1: +187 -82 lines
*** empty log message ***
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Make illum sources for optimizing rendering process
9 */
10
11 #include "mkillum.h"
12
13 #include <ctype.h>
14
15 /* default parameters */
16 #define SAMPDENS 128 /* points per projected steradian */
17 #define NSAMPS 32 /* samples per point */
18 #define DFLMAT "illum_mat" /* material name */
19 /* selection options */
20 #define S_NONE 0 /* select none */
21 #define S_ELEM 1 /* select specified element */
22 #define S_COMPL 2 /* select all but element */
23 #define S_ALL 3 /* select all */
24
25 /* rtrace command and defaults */
26 char *rtargv[64] = { "rtrace", "-dj", ".25", "-dr", "3", "-ab", "2",
27 "-ad", "256", "-as", "128", "-aa", ".15" };
28 int rtargc = 13;
29 /* overriding rtrace options */
30 char *myrtopts[] = { "-I-", "-i-", "-di+", "-ov", "-h-", "-fff", NULL };
31
32 struct rtproc rt; /* our rtrace process */
33
34 struct illum_args thisillum = { /* our illum and default values */
35 0,
36 DFLMAT,
37 DFLMAT,
38 0,
39 VOIDID,
40 NSAMPS,
41 };
42
43 int sampdens = SAMPDENS; /* sample point density */
44 char matcheck[MAXSTR]; /* current material to include or exclude */
45 int matselect = S_ALL; /* selection criterion */
46
47 FUN ofun[NUMOTYPE] = INIT_OTYPE; /* object types */
48
49 int gargc; /* global argc */
50 char **gargv; /* global argv */
51 #define progname gargv[0]
52
53 int doneheader = 0; /* printed header yet? */
54 #define checkhead() if (!doneheader++) printhead(gargc,gargv)
55
56 int warnings = 1; /* print warnings? */
57
58 extern char *fgetline(), *fgetword(), *sskip(),
59 *atos(), *iskip(), *fskip();
60 extern FILE *popen();
61
62
63 main(argc, argv) /* compute illum distributions using rtrace */
64 int argc;
65 char *argv[];
66 {
67 extern char *getenv(), *getpath();
68 char *rtpath;
69 register int i;
70 /* set global arguments */
71 gargc = argc; gargv = argv;
72 /* set up rtrace command */
73 if (argc < 2)
74 error(USER, "too few arguments");
75 for (i = 1; i < argc-1; i++) {
76 rtargv[rtargc++] = argv[i];
77 if (argv[i][0] == '-' && argv[i][1] == 'w')
78 warnings = !warnings;
79 }
80 for (i = 0; myrtopts[i] != NULL; i++)
81 rtargv[rtargc++] = myrtopts[i];
82 rtargv[rtargc++] = argv[argc-1];
83 rtargv[rtargc] = NULL;
84 /* just asking for defaults? */
85 if (!strcmp(argv[argc-1], "-defaults")) {
86 rtpath = getpath(rtargv[0], getenv("PATH"), X_OK);
87 if (rtpath == NULL) {
88 eputs(rtargv[0]);
89 eputs(": command not found\n");
90 exit(1);
91 }
92 execv(rtpath, rtargv);
93 perror(rtpath);
94 exit(1);
95 }
96 /* else initialize and run our calculation */
97 init();
98 filter(stdin, "standard input");
99 quit(0);
100 }
101
102
103 init() /* start rtrace and set up buffers */
104 {
105 int maxbytes;
106
107 maxbytes = open_process(rt.pd, rtargv);
108 if (maxbytes == 0) {
109 eputs(rtargv[0]);
110 eputs(": command not found\n");
111 exit(1);
112 }
113 if (maxbytes < 0)
114 error(SYSTEM, "cannot start rtrace process");
115 rt.bsiz = maxbytes/(6*sizeof(float));
116 rt.buf = (float *)malloc(rt.bsiz*(6*sizeof(float)));
117 if (rt.buf == NULL)
118 error(SYSTEM, "out of memory in init");
119 rt.bsiz--; /* allow for flush ray */
120 rt.nrays = 0;
121 }
122
123
124 quit(status) /* exit with status */
125 int status;
126 {
127 int rtstat;
128
129 rtstat = close_process(rt.pd);
130 if (status == 0)
131 if (rtstat < 0)
132 error(WARNING,
133 "unknown return status from rtrace process");
134 else
135 status = rtstat;
136 exit(status);
137 }
138
139
140 eputs(s) /* put string to stderr */
141 register char *s;
142 {
143 static int midline = 0;
144
145 if (!*s) return;
146 if (!midline) {
147 fputs(progname, stderr);
148 fputs(": ", stderr);
149 }
150 fputs(s, stderr);
151 midline = s[strlen(s)-1] != '\n';
152 }
153
154
155 wputs(s) /* print warning if enabled */
156 char *s;
157 {
158 if (warnings)
159 eputs(s);
160 }
161
162
163 filter(infp, name) /* process stream */
164 register FILE *infp;
165 char *name;
166 {
167 char buf[512];
168 FILE *pfp;
169 register int c;
170
171 while ((c = getc(infp)) != EOF) {
172 if (isspace(c))
173 continue;
174 if (c == '#') { /* comment/options */
175 buf[0] = c;
176 fgets(buf+1, sizeof(buf)-1, infp);
177 xoptions(buf, name);
178 } else if (c == '!') { /* command */
179 buf[0] = c;
180 fgetline(buf+1, sizeof(buf)-1, infp);
181 if ((pfp = popen(buf+1, "r")) == NULL) {
182 sprintf(errmsg, "cannot execute \"%s\"", buf);
183 error(SYSTEM, errmsg);
184 }
185 filter(pfp, buf);
186 pclose(pfp);
187 } else { /* object */
188 ungetc(c, infp);
189 xobject(infp, name);
190 }
191 }
192 }
193
194
195 xoptions(s, nm) /* process options in string s */
196 char *s;
197 char *nm;
198 {
199 extern FILE *freopen();
200 char buf[64];
201 int nerrs = 0;
202 register char *cp;
203
204 if (strncmp(s, "#@mkillum", 9) || !isspace(s[9])) {
205 fputs(s, stdout); /* not for us */
206 return;
207 }
208 cp = s+10;
209 while (*cp) {
210 switch (*cp) {
211 case ' ':
212 case '\t':
213 case '\n':
214 cp++;
215 continue;
216 case 'm': /* material name */
217 if (*++cp != '=')
218 break;
219 if (!*++cp)
220 break;
221 atos(thisillum.matname, MAXSTR, cp);
222 cp = sskip(cp);
223 if (!(thisillum.flags & IL_DATCLB)) {
224 strcpy(thisillum.datafile, thisillum.matname);
225 thisillum.dfnum = 0;
226 }
227 continue;
228 case 'f': /* data file name */
229 if (*++cp != '=')
230 break;
231 if (!*++cp) {
232 thisillum.flags &= ~IL_DATCLB;
233 continue;
234 }
235 atos(thisillum.datafile, MAXSTR, cp);
236 cp = sskip(cp);
237 thisillum.dfnum = 0;
238 thisillum.flags |= IL_DATCLB;
239 continue;
240 case 'i': /* include material */
241 case 'e': /* exclude material */
242 matselect = (*cp == 'i') ? S_ELEM : S_COMPL;
243 if (*++cp != '=')
244 break;
245 atos(matcheck, MAXSTR, ++cp);
246 cp = sskip(cp);
247 continue;
248 case 'a': /* use everything */
249 cp = sskip(cp);
250 matselect = S_ALL;
251 continue;
252 case 'n': /* use nothing (passive) */
253 cp = sskip(cp);
254 matselect = S_NONE;
255 continue;
256 case 'c': /* color calculation */
257 if (*++cp != '=')
258 break;
259 switch (*++cp) {
260 case 'a': /* average */
261 thisillum.flags |= IL_COLAVG;
262 thisillum.flags &= ~IL_COLDST;
263 break;
264 case 'd': /* distribution */
265 thisillum.flags |= IL_COLDST;
266 thisillum.flags &= ~IL_COLAVG;
267 break;
268 case 'n': /* none */
269 thisillum.flags &= ~(IL_COLAVG|IL_COLDST);
270 break;
271 default:
272 goto opterr;
273 }
274 cp = sskip(cp);
275 continue;
276 case 'd': /* point sample density */
277 if (*++cp != '=')
278 break;
279 if (!isintd(++cp, " \t\n"))
280 break;
281 sampdens = atoi(cp);
282 cp = sskip(cp);
283 continue;
284 case 's': /* point super-samples */
285 if (*++cp != '=')
286 break;
287 if (!isintd(++cp, " \t\n"))
288 break;
289 thisillum.nsamps = atoi(cp);
290 cp = sskip(cp);
291 continue;
292 case 'o': /* output file */
293 if (*++cp != '=')
294 break;
295 if (!*++cp)
296 break;
297 atos(buf, sizeof(buf), cp);
298 cp = sskip(cp);
299 if (freopen(buf, "w", stdout) == NULL) {
300 sprintf(errmsg,
301 "cannot open output file \"%s\"", buf);
302 error(SYSTEM, errmsg);
303 }
304 doneheader = 0;
305 continue;
306 }
307 opterr: /* skip faulty option */
308 cp = sskip(cp);
309 nerrs++;
310 }
311 /* print header? */
312 checkhead();
313 /* issue warnings? */
314 if (nerrs) {
315 sprintf(errmsg, "(%s): %d error(s) in option line:",
316 nm, nerrs);
317 error(WARNING, errmsg);
318 wputs(s);
319 printf("# %s: the following option line has %d error(s):\n",
320 progname, nerrs);
321 }
322 /* print pure comment */
323 putchar('#'); putchar(' '); fputs(s+2, stdout);
324 }
325
326
327 printhead(ac, av) /* print out header */
328 register int ac;
329 register char **av;
330 {
331 putchar('#');
332 while (ac-- > 0) {
333 putchar(' ');
334 fputs(*av++, stdout);
335 }
336 putchar('\n');
337 }
338
339
340 xobject(fp, nm) /* translate an object from fp */
341 FILE *fp;
342 char *nm;
343 {
344 OBJREC thisobj;
345 char str[MAXSTR];
346 int doit;
347 /* read the object */
348 if (fgetword(thisillum.altmat, MAXSTR, fp) == NULL)
349 goto readerr;
350 if (fgetword(str, MAXSTR, fp) == NULL)
351 goto readerr;
352 /* is it an alias? */
353 if (!strcmp(str, ALIASID)) {
354 if (fgetword(str, MAXSTR, fp) == NULL)
355 goto readerr;
356 printf("\n%s %s %s", thisillum.altmat, ALIASID, str);
357 if (fgetword(str, MAXSTR, fp) == NULL)
358 goto readerr;
359 printf(" %s\n", str);
360 return;
361 }
362 thisobj.omod = OVOID;
363 if ((thisobj.otype = otype(str)) < 0) {
364 sprintf(errmsg, "(%s): unknown type \"%s\"", nm, str);
365 error(USER, errmsg);
366 }
367 if (fgetword(str, MAXSTR, fp) == NULL)
368 goto readerr;
369 thisobj.oname = str;
370 if (readfargs(&thisobj.oargs, fp) != 1)
371 goto readerr;
372 thisobj.os = NULL;
373 /* check for translation */
374 switch (matselect) {
375 case S_NONE:
376 doit = 0;
377 break;
378 case S_ALL:
379 doit = issurface(thisobj.otype);
380 break;
381 case S_ELEM:
382 doit = !strcmp(thisillum.altmat, matcheck);
383 break;
384 case S_COMPL:
385 doit = strcmp(thisillum.altmat, matcheck);
386 break;
387 }
388 if (doit) /* make sure we can do it */
389 switch (thisobj.otype) {
390 case OBJ_SPHERE:
391 case OBJ_FACE:
392 case OBJ_RING:
393 break;
394 default:
395 sprintf(errmsg,
396 "(%s): cannot make illum for %s \"%s\"",
397 nm, ofun[thisobj.otype].funame,
398 thisobj.oname);
399 error(WARNING, errmsg);
400 doit = 0;
401 break;
402 }
403 /* print header? */
404 checkhead();
405 /* process object */
406 if (doit)
407 mkillum(&thisobj, &thisillum, &rt);
408 else
409 printobj(thisillum.altmat, &thisobj);
410 /* free arguments */
411 freefargs(&thisobj.oargs);
412 return;
413 readerr:
414 sprintf(errmsg, "(%s): error reading scene", nm);
415 error(USER, errmsg);
416 }
417
418
419 int
420 otype(ofname) /* get object function number from its name */
421 char *ofname;
422 {
423 register int i;
424
425 for (i = 0; i < NUMOTYPE; i++)
426 if (!strcmp(ofun[i].funame, ofname))
427 return(i);
428
429 return(-1); /* not found */
430 }
431
432
433 o_default() {}
