root/Development/ray/src/gen/mkillum.c
Sun Aug 11 02:57:49 2013 UTC (12 years, 4 months ago) by greg
Changes since 2.39: +1 -13 lines
Diff to previous 2.39 , to selected 1.6
Removed deprecated thickness setting used for BSDF input
Sat Oct 13 20:15:43 2012 UTC (13 years, 2 months ago) by greg
Changes since 2.38: +4 -68 lines
Diff to previous 2.38 , to selected 1.6
Wed Oct 5 17:20:55 2011 UTC (14 years, 2 months ago) by greg
Changes since 2.37: +2 -1 lines
Diff to previous 2.37 , to selected 1.6
Windows compatibility changes from Bill Hoffman
Mon Aug 15 19:48:06 2011 UTC (14 years, 4 months ago) by greg
Changes since 2.36: +1 -2 lines
Diff to previous 2.36 , to selected 1.6
Sat Dec 12 19:00:59 2009 UTC (16 years ago) by greg
Changes since 2.35: +11 -1 lines
Diff to previous 2.35 , to selected 1.6
Sat Jun 6 05:03:47 2009 UTC (16 years, 6 months ago) by greg
Diff to previous 2.34 , to selected 1.6
Improved redistribute() sampling algorithm
Sat Apr 18 16:14:26 2009 UTC (16 years, 8 months ago) by greg
Diff to previous 2.33 , to selected 1.6
Corrected wording on default value
Thu Dec 13 07:03:37 2007 UTC (18 years ago) by greg
Changes since 2.32: +3 -3 lines
Diff to previous 2.32 , to selected 1.6
Sat Dec 8 01:43:09 2007 UTC (18 years ago) by greg
Changes since 2.31: +1 -3 lines
Diff to previous 2.31 , to selected 1.6
Fri Sep 21 05:53:21 2007 UTC (18 years, 3 months ago) by greg
Changes since 2.30: +13 -1 lines
Diff to previous 2.30 , to selected 1.6
Tue Sep 18 19:51:07 2007 UTC (18 years, 3 months ago) by greg
Changes since 2.29: +77 -7 lines
Diff to previous 2.29 , to selected 1.6
Fri Sep 14 21:29:08 2007 UTC (18 years, 3 months ago) by greg
Diff to previous 2.28 , to selected 1.6
Fixed -defaults option
Thu Sep 13 06:31:21 2007 UTC (18 years, 3 months ago) by greg
Changes since 2.27: +65 -165 lines
Diff to previous 2.27 , to selected 1.6
Changed mkillum from calling rtrace to calling Radiance library (raypcalls.o)
Wed Jun 7 17:52:04 2006 UTC (19 years, 6 months ago) by schorsch
Changes since 2.26: +2 -1 lines
Diff to previous 2.26 , to selected 1.6
Mon Sep 19 11:30:10 2005 UTC (20 years, 3 months ago) by schorsch
Changes since 2.25: +6 -1 lines
Diff to previous 2.25 , to selected 1.6
Thu May 26 14:46:21 2005 UTC (20 years, 7 months ago) by greg
Changes since 2.24: +9 -2 lines
Diff to previous 2.24 , to selected 1.6
Additional signal handling
Wed May 25 04:44:25 2005 UTC (20 years, 7 months ago) by greg
Changes since 2.23: +3 -4 lines
Diff to previous 2.23 , to selected 1.6
Thu Oct 28 00:50:47 2004 UTC (21 years, 2 months ago) by greg
CVS Tags: rad3R6P1
Changes since 2.22: +23 -12 lines
Diff to previous 2.22 , to selected 1.6
Reversed order of rtrace close processes, apparently to no effect
Sat Oct 23 18:55:52 2004 UTC (21 years, 2 months ago) by schorsch
Diff to previous 2.21 , to selected 1.6
Sun Sep 19 08:42:22 2004 UTC (21 years, 3 months ago) by greg
Diff to previous 2.20 , to selected 1.6
Fri Sep 17 21:43:50 2004 UTC (21 years, 3 months ago) by greg
Changes since 2.19: +83 -37 lines
Diff to previous 2.19 , to selected 1.6
Sun Nov 16 10:29:38 2003 UTC (22 years, 1 month ago) by schorsch
Changes since 2.18: +42 -23 lines
Diff to previous 2.18 , to selected 1.6
Wed Oct 22 02:06:34 2003 UTC (22 years, 2 months ago) by greg
Diff to previous 2.17 , to selected 1.6
Wed Sep 24 14:55:54 2003 UTC (22 years, 3 months ago) by greg
Diff to previous 2.16 , to selected 1.6
Mon Jul 21 22:30:18 2003 UTC (22 years, 5 months ago) by schorsch
Diff to previous 2.15 , to selected 1.6
Fri Jun 27 22:27:45 2003 UTC (22 years, 6 months ago) by greg
Diff to previous 2.14 , to selected 1.6
Thu Jun 26 00:58:09 2003 UTC (22 years, 6 months ago) by schorsch
Changes since 2.13: +5 -4 lines
Diff to previous 2.13 , to selected 1.6
Sun Jun 8 12:03:10 2003 UTC (22 years, 6 months ago) by schorsch
Changes since 2.12: +7 -4 lines
Diff to previous 2.12 , to selected 1.6
Tue Mar 11 19:29:05 2003 UTC (22 years, 9 months ago) by greg
Diff to previous 2.11 , to selected 1.6
Sat Feb 22 02:07:24 2003 UTC (22 years, 10 months ago) by greg
Changes since 2.10: +9 -12 lines
Diff to previous 2.10 , to selected 1.6
Mon Oct 20 16:37:14 1997 UTC (28 years, 2 months ago) by gregl
Diff to previous 2.9 , to selected 1.6
Tue Nov 14 16:03:46 1995 UTC (30 years, 1 month ago) by greg
Diff to previous 2.8 , to selected 1.6
fixed bug in skipping s=%d option faults where integer is missing
Tue Oct 17 20:34:55 1995 UTC (30 years, 2 months ago) by greg
Diff to previous 2.7 , to selected 1.6
fixed bug in f= and other space-terminated null specifications
Fri Jan 7 14:51:28 1994 UTC (31 years, 11 months ago) by greg
Diff to previous 2.6 , to selected 1.6
increased size of urand() table
Tue Sep 21 17:09:59 1993 UTC (32 years, 3 months ago) by greg
Changes since 2.5: +18 -2 lines
Diff to previous 2.5 , to selected 1.6
fixed detection of -w+, etc.
Thu Nov 19 20:27:48 1992 UTC (33 years, 1 month ago) by greg
Diff to previous 2.4 , to selected 1.6
changed -di+ to -dv-
Tue Jul 21 09:45:58 1992 UTC (33 years, 5 months ago) by greg
Diff to previous 2.3 , to selected 1.6
slight change to rtrace option
Wed Mar 25 10:55:03 1992 UTC (33 years, 9 months ago) by greg
Diff to previous 2.2 , to selected 1.6
improved checking for octree argument
Wed Mar 11 11:09:57 1992 UTC (33 years, 9 months ago) by greg
Changes since 2.1: +11 -1 lines
Diff to previous 2.1 , to selected 1.6
made defaults reporting more complete
Tue Nov 12 17:05:04 1991 UTC (34 years, 1 month ago) by greg
Diff to previous 1.14 , to selected 1.6
Fri Nov 8 13:17:44 1991 UTC (34 years, 1 month ago) by greg
Diff to previous 1.13 , to selected 1.6
reset errno at appropriate points
Mon Aug 26 10:16:54 1991 UTC (34 years, 4 months ago) by greg
Diff to previous 1.12 , to selected 1.6
fixed distribution pattern discontinuity
Fri Aug 23 12:30:29 1991 UTC (34 years, 4 months ago) by greg
Changes since 1.11: +10 -0 lines
Diff to previous 1.11 , to selected 1.6
Tue Aug 13 14:43:49 1991 UTC (34 years, 4 months ago) by greg
Diff to previous 1.10 , to selected 1.6
fixed format of defaults printing
Tue Jul 30 16:24:42 1991 UTC (34 years, 5 months ago) by greg
Changes since 1.9: +3 -1 lines
Diff to previous 1.9 , to selected 1.6
small changes in default data file name
Thu Jul 25 15:31:30 1991 UTC (34 years, 5 months ago) by greg
Changes since 1.8: +11 -0 lines
Diff to previous 1.8 , to selected 1.6
added variable settings to -defaults printing
Thu Jul 25 14:50:03 1991 UTC (34 years, 5 months ago) by greg
Diff to previous 1.7 , to selected 1.6
changed default sample density
Thu Jul 25 12:52:16 1991 UTC (34 years, 5 months ago) by greg
Changes since 1.6: +5 -4 lines
Diff to previous 1.6
test debugging
Revision 1.6 - (view) (download) (annotate) - [selected]
Thu Jul 25 10:59:05 1991 UTC (34 years, 5 months ago) by greg
Changes since 1.5: +14 -6 lines
Diff to previous 1.5
visual debugging pass
Wed Jul 24 16:48:22 1991 UTC (34 years, 5 months ago) by greg
Changes since 1.4: +2 -3 lines
Diff to previous 1.4 , to selected 1.6
first version of mkillum
Wed Jul 24 12:22:03 1991 UTC (34 years, 5 months ago) by greg
Changes since 1.3: +21 -40 lines
Diff to previous 1.3 , to selected 1.6
*** empty log message ***
Tue Jul 23 17:18:21 1991 UTC (34 years, 5 months ago) by greg
Changes since 1.2: +64 -42 lines
Diff to previous 1.2 , to selected 1.6
added input file capability
Tue Jul 23 16:13:28 1991 UTC (34 years, 5 months ago) by greg
Changes since 1.1: +187 -82 lines
Diff to previous 1.1 , to selected 1.6
Tue Jul 23 12:00:29 1991 UTC (34 years, 5 months ago) by greg
Diff to selected 1.6
