root/radiance/ray/src/gen/mkillum.c
Revision: 2.40
Committed: Sun Aug 11 02:57:49 2013 UTC (11 years, 8 months ago) by greg
CVS Tags: rad4R2P2, rad5R0, rad4R2, rad4R2P1
Changes since 2.39: +1 -13 lines
Removed deprecated thickness setting used for BSDF input
2 static const char RCSid[] = "$Id: mkillum.c,v 2.39 2012/10/13 20:15:43 greg Exp $";
5 * Make illum sources for optimizing rendering process
6 */
7
8 #include <signal.h>
9 #include <ctype.h>
10
11 #include "rtprocess.h" /* win_popen() */
12 #include "mkillum.h"
13
14 /* default parameters */
15 #define SAMPDENS 48 /* points per projected steradian */
16 #define NSAMPS 32 /* samples per point */
17 #define DFLMAT "illum_mat" /* material name */
18 #define DFLDAT "illum" /* data file name */
19 /* selection options */
20 #define S_NONE 0 /* select none */
21 #define S_ELEM 1 /* select specified element */
22 #define S_COMPL 2 /* select all but element */
23 #define S_ALL 3 /* select all */
24
25 struct illum_args thisillum = { /* our illum and default values */
26 0,
27 DFLMAT,
28 DFLDAT,
29 0,
30 VOIDID,
31 SAMPDENS,
32 NSAMPS,
33 0.,
34 };
35
36 char matcheck[MAXSTR]; /* current material to include or exclude */
37 int matselect = S_ALL; /* selection criterion */
38
39 int gargc; /* global argc */
40 char **gargv; /* global argv */
41
42 int doneheader = 0; /* printed header yet? */
43 #define checkhead() if (!doneheader++) printhead(gargc,gargv)
44
45 int warnings = 1; /* print warnings? */
46
47 void init(char *octnm, int np);
48 void filter(register FILE *infp, char *name);
49 void xoptions(char *s, char *nm);
50 void printopts(void);
51 void printhead(register int ac, register char **av);
52 void xobject(FILE *fp, char *nm);
53
54
55 int
56 main( /* compute illum distributions using rtrace */
57 int argc,
58 char *argv[]
59 )
60 {
61 int nprocs = 1;
62 FILE *fp;
63 int rval;
64 register int i;
65 /* set global arguments */
66 gargv = argv;
67 progname = gargv[0];
68 /* set up rendering defaults */
69 dstrsrc = 0.5;
70 directrelay = 3;
71 ambounce = 2;
72 /* get options from command line */
73 for (i = 1; i < argc; i++) {
74 while ((rval = expandarg(&argc, &argv, i)) > 0)
75 ;
76 if (rval < 0) {
77 sprintf(errmsg, "cannot expand '%s'", argv[i]);
78 error(SYSTEM, errmsg);
79 }
80 if (argv[i][0] != '-')
81 break;
82 if (!strcmp(argv[i], "-w")) {
83 warnings = 0;
84 continue;
85 }
86 if (!strcmp(argv[i], "-n")) {
87 nprocs = atoi(argv[++i]);
88 if (nprocs <= 0)
89 error(USER, "illegal number of processes");
90 continue;
91 }
92 if (!strcmp(argv[i], "-defaults")) {
93 printopts();
94 print_rdefaults();
95 quit(0);
96 }
97 rval = getrenderopt(argc-i, argv+i);
98 if (rval < 0) {
99 sprintf(errmsg, "bad render option at '%s'", argv[i]);
100 error(USER, errmsg);
101 }
102 i += rval;
103 }
104 gargc = ++i;
105 /* add "mandatory" render options */
106 do_irrad = 0;
107 if (gargc > argc || argv[gargc-1][0] == '-')
108 error(USER, "missing octree argument");
109 /* else initialize and run our calculation */
110 init(argv[gargc-1], nprocs);
111 if (gargc < argc) {
112 if (gargc == argc-1 || argv[gargc][0] != '<' || argv[gargc][1])
113 error(USER, "use '< file1 file2 ..' for multiple inputs");
114 for (i = gargc+1; i < argc; i++) {
115 if ((fp = fopen(argv[i], "r")) == NULL) {
116 sprintf(errmsg,
117 "cannot open scene file \"%s\"", argv[i]);
118 error(SYSTEM, errmsg);
119 }
120 filter(fp, argv[i]);
121 fclose(fp);
122 }
123 } else
124 filter(stdin, "standard input");
125 quit(0);
126 return 0; /* pro forma return */
127 }
128
129
130 void
131 init(char *octnm, int np) /* start rendering process(es) */
132 {
133 /* set up signal handling */
134 signal(SIGINT, quit);
135 #ifdef SIGHUP
136 signal(SIGHUP, quit);
137 #endif
138 #ifdef SIGTERM
139 signal(SIGTERM, quit);
140 #endif
141 #ifdef SIGPIPE
142 signal(SIGPIPE, quit);
143 #endif
144 /* start rendering process(es) */
145 ray_pinit(octnm, np);
146 }
147
148
149 void
150 eputs( /* put string to stderr */
151 register char *s
152 )
153 {
154 static int midline = 0;
155
156 if (!*s) return;
157 if (!midline) {
158 fputs(progname, stderr);
159 fputs(": ", stderr);
160 }
161 fputs(s, stderr);
162 midline = s[strlen(s)-1] != '\n';
163 }
164
165
166 void
167 wputs(s) /* print warning if enabled */
168 char *s;
169 {
170 if (warnings)
171 eputs(s);
172 }
173
174
175 void
176 quit(ec) /* make sure exit is called */
177 int ec;
178 {
179 if (ray_pnprocs > 0) /* close children if any */
180 ray_pclose(0);
181 exit(ec);
182 }
183
184
185 void
186 filter( /* process stream */
187 register FILE *infp,
188 char *name
189 )
190 {
191 char buf[512];
192 FILE *pfp;
193 register int c;
194
195 while ((c = getc(infp)) != EOF) {
196 if (isspace(c))
197 continue;
198 if (c == '#') { /* comment/options */
199 buf[0] = c;
200 fgets(buf+1, sizeof(buf)-1, infp);
201 xoptions(buf, name);
202 } else if (c == '!') { /* command */
203 buf[0] = c;
204 fgetline(buf+1, sizeof(buf)-1, infp);
205 if ((pfp = popen(buf+1, "r")) == NULL) {
206 sprintf(errmsg, "cannot execute \"%s\"", buf);
207 error(SYSTEM, errmsg);
208 }
209 filter(pfp, buf);
210 pclose(pfp);
211 } else { /* object */
212 ungetc(c, infp);
213 xobject(infp, name);
214 }
215 }
216 }
217
218
219 void
220 xoptions( /* process options in string s */
221 char *s,
222 char *nm
223 )
224 {
225 extern FILE *freopen();
226 char buf[64];
227 int negax;
228 int nerrs = 0;
229 register char *cp;
230
231 if (strncmp(s, "#@mkillum", 9) || !isspace(s[9])) {
232 fputs(s, stdout); /* not for us */
233 return;
234 }
235 cp = s+10;
236 while (*cp) {
237 switch (*cp) {
238 case ' ':
239 case '\t':
240 case '\n':
241 case '\r':
242 case '\f':
243 cp++;
244 continue;
245 case 'm': /* material name */
246 if (*++cp != '=')
247 break;
248 if (!*++cp || isspace(*cp))
249 break;
250 atos(thisillum.matname, MAXSTR, cp);
251 cp = sskip(cp);
252 if (!(thisillum.flags & IL_DATCLB)) {
253 strcpy(thisillum.datafile, thisillum.matname);
254 thisillum.dfnum = 0;
255 }
256 continue;
257 case 'f': /* data file name */
258 if (*++cp != '=')
259 break;
260 if (!*++cp || isspace(*cp)) {
261 strcpy(thisillum.datafile,thisillum.matname);
262 thisillum.dfnum = 0;
263 thisillum.flags &= ~IL_DATCLB;
264 continue;
265 }
266 atos(thisillum.datafile, MAXSTR, cp);
267 cp = sskip(cp);
268 thisillum.dfnum = 0;
269 thisillum.flags |= IL_DATCLB;
270 continue;
271 case 'i': /* include material */
272 case 'e': /* exclude material */
273 if (cp[1] != '=')
274 break;
275 matselect = (*cp == 'i') ? S_ELEM : S_COMPL;
276 cp += 2;
277 atos(matcheck, MAXSTR, cp);
278 cp = sskip(cp);
279 continue;
280 case 'a': /* use everything */
281 cp = sskip(cp);
282 matselect = S_ALL;
283 continue;
284 case 'n': /* use nothing (passive) */
285 cp = sskip(cp);
286 matselect = S_NONE;
287 continue;
288 case 'c': /* color calculation */
289 if (*++cp != '=')
290 break;
291 switch (*++cp) {
292 case 'a': /* average */
293 thisillum.flags = (thisillum.flags|IL_COLAVG)
294 & ~IL_COLDST;
295 break;
296 case 'd': /* distribution */
297 thisillum.flags |= (IL_COLDST|IL_COLAVG);
298 break;
299 case 'n': /* none */
300 thisillum.flags &= ~(IL_COLAVG|IL_COLDST);
301 break;
302 default:
303 goto opterr;
304 }
305 cp = sskip(cp);
306 continue;
307 case 'd': /* sample density */
308 if (*++cp != '=')
309 break;
310 if (!*++cp || isspace(*cp))
311 continue;
312 if (isintd(cp, " \t\n\r")) {
313 thisillum.sampdens = atoi(cp);
314 } else {
315 error(WARNING, "direct BSDF input unsupported");
316 goto opterr;
317 }
318 cp = sskip(cp);
319 continue;
320 case 's': /* surface super-samples */
321 if (*++cp != '=')
322 break;
323 if (!isintd(++cp, " \t\n\r"))
324 break;
325 thisillum.nsamps = atoi(cp);
326 cp = sskip(cp);
327 continue;
328 case 'l': /* light sources */
329 cp++;
330 if (*cp == '+')
331 thisillum.flags |= IL_LIGHT;
332 else if (*cp == '-')
333 thisillum.flags &= ~IL_LIGHT;
334 else
335 break;
336 cp++;
337 continue;
338 case 'b': /* brightness */
339 if (*++cp != '=')
340 break;
341 if (!isfltd(++cp, " \t\n\r"))
342 break;
343 thisillum.minbrt = atof(cp);
344 if (thisillum.minbrt < 0.)
345 thisillum.minbrt = 0.;
346 cp = sskip(cp);
347 continue;
348 case 'o': /* output file */
349 if (*++cp != '=')
350 break;
351 if (!*++cp || isspace(*cp))
352 break;
353 atos(buf, sizeof(buf), cp);
354 cp = sskip(cp);
355 if (freopen(buf, "w", stdout) == NULL) {
356 sprintf(errmsg,
357 "cannot open output file \"%s\"", buf);
358 error(SYSTEM, errmsg);
359 }
360 doneheader = 0;
361 continue;
362 case '!': /* processed file! */
363 sprintf(errmsg, "(%s): already processed!", nm);
364 error(WARNING, errmsg);
365 matselect = S_NONE;
366 return;
367 }
368 opterr: /* skip faulty option */
369 while (*cp && !isspace(*cp))
370 cp++;
371 nerrs++;
372 }
373 /* print header? */
374 checkhead();
375 /* issue warnings? */
376 if (nerrs) {
377 sprintf(errmsg, "(%s): %d error(s) in option line:",
378 nm, nerrs);
379 error(WARNING, errmsg);
380 wputs(s);
381 printf("# %s: the following option line has %d error(s):\n",
382 progname, nerrs);
383 }
384 /* print pure comment */
385 printf("# %s", s+2);
386 }
387
388 void
389 printopts(void) /* print out option default values */
390 {
391 printf("m=%-15s\t\t# material name\n", thisillum.matname);
392 printf("f=%-15s\t\t# data file name\n", thisillum.datafile);
393 if (thisillum.flags & IL_COLAVG)
394 if (thisillum.flags & IL_COLDST)
395 printf("c=d\t\t\t\t# color distribution\n");
396 else
397 printf("c=a\t\t\t\t# color average\n");
398 else
399 printf("c=n\t\t\t\t# color none\n");
400 if (thisillum.flags & IL_LIGHT)
401 printf("l+\t\t\t\t# light type on\n");
402 else
403 printf("l-\t\t\t\t# light type off\n");
404 printf("d=%d\t\t\t\t# density of directions\n", thisillum.sampdens);
405 printf("s=%d\t\t\t\t# samples per direction\n", thisillum.nsamps);
406 printf("b=%f\t\t\t# minimum average brightness\n", thisillum.minbrt);
407 }
408
409
410 void
411 printhead( /* print out header */
412 register int ac,
413 register char **av
414 )
415 {
416 putchar('#');
417 while (ac-- > 0) {
418 putchar(' ');
419 fputs(*av++, stdout);
420 }
421 fputs("\n#@mkillum !\n", stdout);
422 }
423
424
425 void
426 xobject( /* translate an object from fp */
427 FILE *fp,
428 char *nm
429 )
430 {
431 OBJREC thisobj;
432 char str[MAXSTR];
433 int doit;
434 /* read the object */
435 if (fgetword(thisillum.altmat, MAXSTR, fp) == NULL)
436 goto readerr;
437 if (fgetword(str, MAXSTR, fp) == NULL)
438 goto readerr;
439 /* is it an alias? */
440 if (!strcmp(str, ALIASKEY)) {
441 if (fgetword(str, MAXSTR, fp) == NULL)
442 goto readerr;
443 printf("\n%s %s %s", thisillum.altmat, ALIASKEY, str);
444 if (fgetword(str, MAXSTR, fp) == NULL)
445 goto readerr;
446 printf("\t%s\n", str);
447 return;
448 }
449 thisobj.omod = OVOID; /* unused field */
450 if ((thisobj.otype = otype(str)) < 0) {
451 sprintf(errmsg, "(%s): unknown type \"%s\"", nm, str);
452 error(USER, errmsg);
453 }
454 if (fgetword(str, MAXSTR, fp) == NULL)
455 goto readerr;
456 thisobj.oname = str;
457 if (readfargs(&thisobj.oargs, fp) != 1)
458 goto readerr;
459 thisobj.os = NULL;
460 /* check for translation */
461 switch (matselect) {
462 case S_NONE:
463 doit = 0;
464 break;
465 case S_ALL:
466 doit = 1;
467 break;
468 case S_ELEM:
469 doit = !strcmp(thisillum.altmat, matcheck);
470 break;
471 case S_COMPL:
472 doit = strcmp(thisillum.altmat, matcheck);
473 break;
474 }
475 doit = doit && issurface(thisobj.otype);
476 /* print header? */
477 checkhead();
478 /* process object */
479 if (doit)
480 switch (thisobj.otype) {
481 case OBJ_FACE:
482 my_face(&thisobj, &thisillum, nm);
483 break;
484 case OBJ_SPHERE:
485 my_sphere(&thisobj, &thisillum, nm);
486 break;
487 case OBJ_RING:
488 my_ring(&thisobj, &thisillum, nm);
489 break;
490 default:
491 my_default(&thisobj, &thisillum, nm);
492 break;
493 }
494 else
495 printobj(thisillum.altmat, &thisobj);
496 /* free arguments */
497 freefargs(&thisobj.oargs);
498 return;
499 readerr:
500 sprintf(errmsg, "(%s): error reading input", nm);
501 error(USER, errmsg);
502 }
