root/radiance/ray/src/gen/mkillum.c
Revision: 2.30
Committed: Tue Sep 18 19:51:07 2007 UTC (16 years, 9 months ago) by greg
Changes since 2.29: +77 -7 lines
2 static const char RCSid[] = "$Id: mkillum.c,v 2.29 2007/09/14 21:29:08 greg Exp $";
5 * Make illum sources for optimizing rendering process
6 */
7
8 #include <signal.h>
9 #include <ctype.h>
10
11 #include "platform.h"
12 #include "mkillum.h"
13 #include "random.h"
14
15 /* default parameters */
16 #define SAMPDENS 48 /* points per projected steradian */
17 #define NSAMPS 32 /* samples per point */
18 #define DFLMAT "illum_mat" /* material name */
19 #define DFLDAT "illum" /* data file name */
20 /* selection options */
21 #define S_NONE 0 /* select none */
22 #define S_ELEM 1 /* select specified element */
23 #define S_COMPL 2 /* select all but element */
24 #define S_ALL 3 /* select all */
25
26 struct illum_args thisillum = { /* our illum and default values */
27 0,
28 UDzpos,
29 DFLMAT,
30 DFLDAT,
31 0,
32 VOIDID,
33 SAMPDENS,
34 NSAMPS,
35 NULL,
36 0.,
37 };
38
39 char matcheck[MAXSTR]; /* current material to include or exclude */
40 int matselect = S_ALL; /* selection criterion */
41
42 int gargc; /* global argc */
43 char **gargv; /* global argv */
44
45 int doneheader = 0; /* printed header yet? */
46 #define checkhead() if (!doneheader++) printhead(gargc,gargv)
47
48 int warnings = 1; /* print warnings? */
49
50 void init(char *octnm, int np);
51 void filter(register FILE *infp, char *name);
52 void xoptions(char *s, char *nm);
53 void printopts(void);
54 void printhead(register int ac, register char **av);
55 void xobject(FILE *fp, char *nm);
56
57
58 int
59 main( /* compute illum distributions using rtrace */
60 int argc,
61 char *argv[]
62 )
63 {
64 int nprocs = 1;
65 FILE *fp;
66 int rval;
67 register int i;
68 /* set global arguments */
69 gargv = argv;
70 progname = gargv[0];
71 /* set up rendering defaults */
72 dstrsrc = 0.25;
73 directrelay = 3;
74 directvis = 0;
75 ambounce = 2;
76 /* get options from command line */
77 for (i = 1; i < argc; i++) {
78 while ((rval = expandarg(&argc, &argv, i)) > 0)
79 ;
80 if (rval < 0) {
81 sprintf(errmsg, "cannot expand '%s'", argv[i]);
82 error(SYSTEM, errmsg);
83 }
84 if (argv[i][0] != '-')
85 break;
86 if (!strcmp(argv[i], "-w")) {
87 warnings = 0;
88 continue;
89 }
90 if (!strcmp(argv[i], "-n")) {
91 nprocs = atoi(argv[++i]);
92 if (nprocs <= 0)
93 error(USER, "illegal number of processes");
94 continue;
95 }
96 if (!strcmp(argv[i], "-defaults")) {
97 printopts();
98 print_rdefaults();
99 quit(0);
100 }
101 rval = getrenderopt(argc-i, argv+i);
102 if (rval < 0) {
103 sprintf(errmsg, "bad render option at '%s'", argv[i]);
104 error(USER, errmsg);
105 }
106 i += rval;
107 }
108 gargc = ++i;
109 /* add "mandatory" render options */
110 do_irrad = 0;
111 if (gargc > argc || argv[gargc-1][0] == '-')
112 error(USER, "missing octree argument");
113 /* else initialize and run our calculation */
114 init(argv[gargc-1], nprocs);
115 if (gargc < argc) {
116 if (gargc == argc-1 || argv[gargc][0] != '<' || argv[gargc][1])
117 error(USER, "use '< file1 file2 ..' for multiple inputs");
118 for (i = gargc+1; i < argc; i++) {
119 if ((fp = fopen(argv[i], "r")) == NULL) {
120 sprintf(errmsg,
121 "cannot open scene file \"%s\"", argv[i]);
122 error(SYSTEM, errmsg);
123 }
124 filter(fp, argv[i]);
125 fclose(fp);
126 }
127 } else
128 filter(stdin, "standard input");
129 quit(0);
130 return 0; /* pro forma return */
131 }
132
133
134 void
135 init(char *octnm, int np) /* start rendering process(es) */
136 {
137 /* set up signal handling */
138 signal(SIGINT, quit);
139 #ifdef SIGHUP
140 signal(SIGHUP, quit);
141 #endif
142 #ifdef SIGTERM
143 signal(SIGTERM, quit);
144 #endif
145 #ifdef SIGPIPE
146 signal(SIGPIPE, quit);
147 #endif
148 /* start rendering process(es) */
149 ray_pinit(octnm, np);
150 }
151
152
153 void
154 eputs( /* put string to stderr */
155 register char *s
156 )
157 {
158 static int midline = 0;
159
160 if (!*s) return;
161 if (!midline) {
162 fputs(progname, stderr);
163 fputs(": ", stderr);
164 }
165 fputs(s, stderr);
166 midline = s[strlen(s)-1] != '\n';
167 }
168
169
170 void
171 wputs(s) /* print warning if enabled */
172 char *s;
173 {
174 if (warnings)
175 eputs(s);
176 }
177
178
179 void
180 filter( /* process stream */
181 register FILE *infp,
182 char *name
183 )
184 {
185 char buf[512];
186 FILE *pfp;
187 register int c;
188
189 while ((c = getc(infp)) != EOF) {
190 if (isspace(c))
191 continue;
192 if (c == '#') { /* comment/options */
193 buf[0] = c;
194 fgets(buf+1, sizeof(buf)-1, infp);
195 xoptions(buf, name);
196 } else if (c == '!') { /* command */
197 buf[0] = c;
198 fgetline(buf+1, sizeof(buf)-1, infp);
199 if ((pfp = popen(buf+1, "r")) == NULL) {
200 sprintf(errmsg, "cannot execute \"%s\"", buf);
201 error(SYSTEM, errmsg);
202 }
203 filter(pfp, buf);
204 pclose(pfp);
205 } else { /* object */
206 ungetc(c, infp);
207 xobject(infp, name);
208 }
209 }
210 }
211
212
213 void
214 xoptions( /* process options in string s */
215 char *s,
216 char *nm
217 )
218 {
219 extern FILE *freopen();
220 char buf[64];
221 int negax;
222 int nerrs = 0;
223 register char *cp;
224
225 if (strncmp(s, "#@mkillum", 9) || !isspace(s[9])) {
226 fputs(s, stdout); /* not for us */
227 return;
228 }
229 cp = s+10;
230 while (*cp) {
231 switch (*cp) {
232 case ' ':
233 case '\t':
234 case '\n':
235 case '\r':
236 case '\f':
237 cp++;
238 continue;
239 case 'm': /* material name */
240 if (*++cp != '=')
241 break;
242 if (!*++cp || isspace(*cp))
243 break;
244 atos(thisillum.matname, MAXSTR, cp);
245 cp = sskip(cp);
246 if (!(thisillum.flags & IL_DATCLB)) {
247 strcpy(thisillum.datafile, thisillum.matname);
248 thisillum.dfnum = 0;
249 }
250 continue;
251 case 'f': /* data file name */
252 if (*++cp != '=')
253 break;
254 if (!*++cp || isspace(*cp)) {
255 strcpy(thisillum.datafile,thisillum.matname);
256 thisillum.dfnum = 0;
257 thisillum.flags &= ~IL_DATCLB;
258 continue;
259 }
260 atos(thisillum.datafile, MAXSTR, cp);
261 cp = sskip(cp);
262 thisillum.dfnum = 0;
263 thisillum.flags |= IL_DATCLB;
264 continue;
265 case 'i': /* include material */
266 case 'e': /* exclude material */
267 if (cp[1] != '=')
268 break;
269 matselect = (*cp == 'i') ? S_ELEM : S_COMPL;
270 cp += 2;
271 atos(matcheck, MAXSTR, cp);
272 cp = sskip(cp);
273 continue;
274 case 'a': /* use everything */
275 cp = sskip(cp);
276 matselect = S_ALL;
277 continue;
278 case 'n': /* use nothing (passive) */
279 cp = sskip(cp);
280 matselect = S_NONE;
281 continue;
282 case 'c': /* color calculation */
283 if (*++cp != '=')
284 break;
285 switch (*++cp) {
286 case 'a': /* average */
287 thisillum.flags = (thisillum.flags|IL_COLAVG)
288 & ~IL_COLDST;
289 break;
290 case 'd': /* distribution */
291 thisillum.flags |= (IL_COLDST|IL_COLAVG);
292 break;
293 case 'n': /* none */
294 thisillum.flags &= ~(IL_COLAVG|IL_COLDST);
295 break;
296 default:
297 goto opterr;
298 }
299 cp = sskip(cp);
300 continue;
301 case 'd': /* sample density / BSDF data */
302 if (*++cp != '=')
303 break;
304 if (thisillum.sd != NULL) {
305 free_BSDF(thisillum.sd);
306 thisillum.sd = NULL;
307 }
308 if (!*++cp || isspace(*cp))
309 continue;
310 if (isintd(++cp, " \t\n\r")) {
311 thisillum.sampdens = atoi(cp);
312 } else {
313 atos(buf, sizeof(buf), cp);
314 thisillum.sd = load_BSDF(buf);
315 if (thisillum.sd == NULL)
316 break;
317 }
318 cp = sskip(cp);
319 continue;
320 case 's': /* surface super-samples */
321 if (*++cp != '=')
322 break;
323 if (!isintd(++cp, " \t\n\r"))
324 break;
325 thisillum.nsamps = atoi(cp);
326 cp = sskip(cp);
327 continue;
328 case 'l': /* light sources */
329 cp++;
330 if (*cp == '+')
331 thisillum.flags |= IL_LIGHT;
332 else if (*cp == '-')
333 thisillum.flags &= ~IL_LIGHT;
334 else
335 break;
336 cp++;
337 continue;
338 case 'b': /* brightness */
339 if (*++cp != '=')
340 break;
341 if (!isfltd(++cp, " \t\n\r"))
342 break;
343 thisillum.minbrt = atof(cp);
344 if (thisillum.minbrt < 0.)
345 thisillum.minbrt = 0.;
346 cp = sskip(cp);
347 continue;
348 case 'o': /* output file */
349 if (*++cp != '=')
350 break;
351 if (!*++cp || isspace(*cp))
352 break;
353 atos(buf, sizeof(buf), cp);
354 cp = sskip(cp);
355 if (freopen(buf, "w", stdout) == NULL) {
356 sprintf(errmsg,
357 "cannot open output file \"%s\"", buf);
358 error(SYSTEM, errmsg);
359 }
360 doneheader = 0;
361 continue;
362 case 'u': /* up direction */
363 if (*++cp != '=')
364 break;
365 if (!*++cp || isspace(*cp)) {
366 thisillum.udir = UDunknown;
367 continue;
368 }
369 negax = 0;
370 if (*cp == '+')
371 cp++;
372 else if (*cp == '-') {
373 negax++;
374 cp++;
375 }
376 switch (*cp++) {
377 case 'x':
378 case 'X':
379 thisillum.udir = negax ? UDxneg : UDxpos;
380 break;
381 case 'y':
382 case 'Y':
383 thisillum.udir = negax ? UDyneg : UDypos;
384 break;
385 case 'z':
386 case 'Z':
387 thisillum.udir = negax ? UDxneg : UDxpos;
388 break;
389 default:
390 thisillum.udir = UDunknown;
391 break;
392 }
393 if (thisillum.udir == UDunknown || !isspace(*cp))
394 break;
395 continue;
396 case '!': /* processed file! */
397 sprintf(errmsg, "(%s): already processed!", nm);
398 error(WARNING, errmsg);
399 matselect = S_NONE;
400 return;
401 }
402 opterr: /* skip faulty option */
403 while (*cp && !isspace(*cp))
404 cp++;
405 nerrs++;
406 }
407 /* print header? */
408 checkhead();
409 /* issue warnings? */
410 if (nerrs) {
411 sprintf(errmsg, "(%s): %d error(s) in option line:",
412 nm, nerrs);
413 error(WARNING, errmsg);
414 wputs(s);
415 printf("# %s: the following option line has %d error(s):\n",
416 progname, nerrs);
417 }
418 /* print pure comment */
419 printf("# %s", s+2);
420 }
421
422 void
423 printopts(void) /* print out option default values */
424 {
425 printf("m=%-15s\t\t# material name\n", thisillum.matname);
426 printf("f=%-15s\t\t# data file name\n", thisillum.datafile);
427 if (thisillum.flags & IL_COLAVG)
428 if (thisillum.flags & IL_COLDST)
429 printf("c=d\t\t\t\t# color distribution\n");
430 else
431 printf("c=a\t\t\t\t# color average\n");
432 else
433 printf("c=n\t\t\t\t# color none\n");
434 if (thisillum.flags & IL_LIGHT)
435 printf("l+\t\t\t\t# light type on\n");
436 else
437 printf("l-\t\t\t\t# light type off\n");
438 printf("d=%d\t\t\t\t# density of points\n", thisillum.sampdens);
439 printf("s=%d\t\t\t\t# samples per point\n", thisillum.nsamps);
440 printf("b=%f\t\t\t# minimum average brightness\n", thisillum.minbrt);
441 switch (thisillum.udir) {
442 case UDzneg:
443 fputs("u=-Z\t\t\t\t# up is negative Z\n", stdout);
444 break;
445 case UDyneg:
446 fputs("u=-Y\t\t\t\t# up is negative Y\n", stdout);
447 break;
448 case UDxneg:
449 fputs("u=-X\t\t\t\t# up is negative X\n", stdout);
450 break;
451 case UDxpos:
452 fputs("u=+X\t\t\t\t# up is positive X\n", stdout);
453 break;
454 case UDypos:
455 fputs("u=+Y\t\t\t\t# up is positive Y\n", stdout);
456 break;
457 case UDzpos:
458 fputs("u=+Z\t\t\t\t# up is positive Z\n", stdout);
459 break;
460 case UDunknown:
461 break;
462 }
463 }
464
465
466 void
467 printhead( /* print out header */
468 register int ac,
469 register char **av
470 )
471 {
472 putchar('#');
473 while (ac-- > 0) {
474 putchar(' ');
475 fputs(*av++, stdout);
476 }
477 fputs("\n#@mkillum !\n", stdout);
478 }
479
480
481 void
482 xobject( /* translate an object from fp */
483 FILE *fp,
484 char *nm
485 )
486 {
487 OBJREC thisobj;
488 char str[MAXSTR];
489 int doit;
490 /* read the object */
491 if (fgetword(thisillum.altmat, MAXSTR, fp) == NULL)
492 goto readerr;
493 if (fgetword(str, MAXSTR, fp) == NULL)
494 goto readerr;
495 /* is it an alias? */
496 if (!strcmp(str, ALIASKEY)) {
497 if (fgetword(str, MAXSTR, fp) == NULL)
498 goto readerr;
499 printf("\n%s %s %s", thisillum.altmat, ALIASKEY, str);
500 if (fgetword(str, MAXSTR, fp) == NULL)
501 goto readerr;
502 printf("\t%s\n", str);
503 return;
504 }
505 thisobj.omod = OVOID; /* unused field */
506 if ((thisobj.otype = otype(str)) < 0) {
507 sprintf(errmsg, "(%s): unknown type \"%s\"", nm, str);
508 error(USER, errmsg);
509 }
510 if (fgetword(str, MAXSTR, fp) == NULL)
511 goto readerr;
512 thisobj.oname = str;
513 if (readfargs(&thisobj.oargs, fp) != 1)
514 goto readerr;
515 thisobj.os = NULL;
516 /* check for translation */
517 switch (matselect) {
518 case S_NONE:
519 doit = 0;
520 break;
521 case S_ALL:
522 doit = 1;
523 break;
524 case S_ELEM:
525 doit = !strcmp(thisillum.altmat, matcheck);
526 break;
527 case S_COMPL:
528 doit = strcmp(thisillum.altmat, matcheck);
529 break;
530 }
531 doit = doit && issurface(thisobj.otype);
532 /* print header? */
533 checkhead();
534 /* process object */
535 if (doit)
536 switch (thisobj.otype) {
537 case OBJ_FACE:
538 my_face(&thisobj, &thisillum, nm);
539 break;
540 case OBJ_SPHERE:
541 my_sphere(&thisobj, &thisillum, nm);
542 break;
543 case OBJ_RING:
544 my_ring(&thisobj, &thisillum, nm);
545 break;
546 default:
547 my_default(&thisobj, &thisillum, nm);
548 break;
549 }
550 else
551 printobj(thisillum.altmat, &thisobj);
552 /* free arguments */
553 freefargs(&thisobj.oargs);
554 return;
555 readerr:
556 sprintf(errmsg, "(%s): error reading input", nm);
557 error(USER, errmsg);
558 }
