root/radiance/ray/src/gen/mkillum.c
Revision: 2.28
Committed: Thu Sep 13 06:31:21 2007 UTC (17 years, 9 months ago) by greg
Changes since 2.27: +65 -165 lines
Changed mkillum from calling rtrace to calling Radiance library (raypcalls.o)
2 static const char RCSid[] = "$Id: mkillum.c,v 2.27 2006/06/07 17:52:04 schorsch Exp $";
5 * Make illum sources for optimizing rendering process
6 */
7
8 #include <signal.h>
9 #include <ctype.h>
10
11 #include "platform.h"
12 #include "mkillum.h"
13 #include "random.h"
14
15 /* default parameters */
16 #define SAMPDENS 48 /* points per projected steradian */
17 #define NSAMPS 32 /* samples per point */
18 #define DFLMAT "illum_mat" /* material name */
19 #define DFLDAT "illum" /* data file name */
20 /* selection options */
21 #define S_NONE 0 /* select none */
22 #define S_ELEM 1 /* select specified element */
23 #define S_COMPL 2 /* select all but element */
24 #define S_ALL 3 /* select all */
25
26 struct illum_args thisillum = { /* our illum and default values */
27 0,
28 DFLMAT,
29 DFLDAT,
30 0,
31 VOIDID,
32 SAMPDENS,
33 NSAMPS,
34 0.,
35 };
36
37 char matcheck[MAXSTR]; /* current material to include or exclude */
38 int matselect = S_ALL; /* selection criterion */
39
40 int gargc; /* global argc */
41 char **gargv; /* global argv */
42
43 int doneheader = 0; /* printed header yet? */
44 #define checkhead() if (!doneheader++) printhead(gargc,gargv)
45
46 int warnings = 1; /* print warnings? */
47
48 void init(char *octnm, int np);
49 void filter(register FILE *infp, char *name);
50 void xoptions(char *s, char *nm);
51 void printopts(void);
52 void printhead(register int ac, register char **av);
53 void xobject(FILE *fp, char *nm);
54
55
56 int
57 main( /* compute illum distributions using rtrace */
58 int argc,
59 char *argv[]
60 )
61 {
62 int nprocs = 1;
63 FILE *fp;
64 int rval;
65 register int i;
66 /* set global arguments */
67 gargv = argv;
68 progname = gargv[0];
69 /* set up rendering defaults */
70 dstrsrc = 0.25;
71 directrelay = 3;
72 directvis = 0;
73 ambounce = 2;
74 /* get options from command line */
75 for (i = 1; i < argc-1; i++) {
76 while ((rval = expandarg(&argc, &argv, i)) > 0)
77 ;
78 if (rval < 0) {
79 sprintf(errmsg, "cannot expand '%s'", argv[i]);
80 error(SYSTEM, errmsg);
81 }
82 if (argv[i][0] != '-')
83 break;
84 if (!strcmp(argv[i], "-w")) {
85 warnings = 0;
86 continue;
87 }
88 if (!strcmp(argv[i], "-n")) {
89 nprocs = atoi(argv[++i]);
90 if (nprocs <= 0)
91 error(USER, "illegal number of processes");
92 continue;
93 }
94 if (!strcmp(argv[i], "-defaults")) {
95 printopts();
96 print_rdefaults();
97 quit(0);
98 }
99 rval = getrenderopt(argc-i, argv+i);
100 if (rval < 0) {
101 sprintf(errmsg, "bad render option at '%s'", argv[i]);
102 error(USER, errmsg);
103 }
104 i += rval;
105 }
106 gargc = ++i;
107 /* add "mandatory" render options */
108 do_irrad = 0;
109 if (gargc > argc || argv[gargc-1][0] == '-')
110 error(USER, "missing octree argument");
111 /* else initialize and run our calculation */
112 init(argv[gargc-1], nprocs);
113 if (gargc < argc) {
114 if (gargc == argc-1 || argv[gargc][0] != '<' || argv[gargc][1])
115 error(USER, "Use '< file1 file2 ..' for multiple inputs");
116 for (i = gargc+1; i < argc; i++) {
117 if ((fp = fopen(argv[i], "r")) == NULL) {
118 sprintf(errmsg,
119 "cannot open scene file \"%s\"", argv[i]);
120 error(SYSTEM, errmsg);
121 }
122 filter(fp, argv[i]);
123 fclose(fp);
124 }
125 } else
126 filter(stdin, "standard input");
127 quit(0);
128 return 0; /* pro forma return */
129 }
130
131
132 void
133 init(char *octnm, int np) /* start rendering process(es) */
134 {
135 /* set up signal handling */
136 signal(SIGINT, quit);
137 #ifdef SIGHUP
138 signal(SIGHUP, quit);
139 #endif
140 #ifdef SIGTERM
141 signal(SIGTERM, quit);
142 #endif
143 #ifdef SIGPIPE
144 signal(SIGPIPE, quit);
145 #endif
146 /* start rendering process(es) */
147 ray_pinit(octnm, np);
148 }
149
150
151 void
152 eputs( /* put string to stderr */
153 register char *s
154 )
155 {
156 static int midline = 0;
157
158 if (!*s) return;
159 if (!midline) {
160 fputs(progname, stderr);
161 fputs(": ", stderr);
162 }
163 fputs(s, stderr);
164 midline = s[strlen(s)-1] != '\n';
165 }
166
167
168 void
169 wputs(s) /* print warning if enabled */
170 char *s;
171 {
172 if (warnings)
173 eputs(s);
174 }
175
176
177 void
178 filter( /* process stream */
179 register FILE *infp,
180 char *name
181 )
182 {
183 char buf[512];
184 FILE *pfp;
185 register int c;
186
187 while ((c = getc(infp)) != EOF) {
188 if (isspace(c))
189 continue;
190 if (c == '#') { /* comment/options */
191 buf[0] = c;
192 fgets(buf+1, sizeof(buf)-1, infp);
193 xoptions(buf, name);
194 } else if (c == '!') { /* command */
195 buf[0] = c;
196 fgetline(buf+1, sizeof(buf)-1, infp);
197 if ((pfp = popen(buf+1, "r")) == NULL) {
198 sprintf(errmsg, "cannot execute \"%s\"", buf);
199 error(SYSTEM, errmsg);
200 }
201 filter(pfp, buf);
202 pclose(pfp);
203 } else { /* object */
204 ungetc(c, infp);
205 xobject(infp, name);
206 }
207 }
208 }
209
210
211 void
212 xoptions( /* process options in string s */
213 char *s,
214 char *nm
215 )
216 {
217 extern FILE *freopen();
218 char buf[64];
219 int nerrs = 0;
220 register char *cp;
221
222 if (strncmp(s, "#@mkillum", 9) || !isspace(s[9])) {
223 fputs(s, stdout); /* not for us */
224 return;
225 }
226 cp = s+10;
227 while (*cp) {
228 switch (*cp) {
229 case ' ':
230 case '\t':
231 case '\n':
232 case '\r':
233 case '\f':
234 cp++;
235 continue;
236 case 'm': /* material name */
237 if (*++cp != '=')
238 break;
239 if (!*++cp || isspace(*cp))
240 break;
241 atos(thisillum.matname, MAXSTR, cp);
242 cp = sskip(cp);
243 if (!(thisillum.flags & IL_DATCLB)) {
244 strcpy(thisillum.datafile, thisillum.matname);
245 thisillum.dfnum = 0;
246 }
247 continue;
248 case 'f': /* data file name */
249 if (*++cp != '=')
250 break;
251 if (!*++cp || isspace(*cp)) {
252 strcpy(thisillum.datafile,thisillum.matname);
253 thisillum.dfnum = 0;
254 thisillum.flags &= ~IL_DATCLB;
255 continue;
256 }
257 atos(thisillum.datafile, MAXSTR, cp);
258 cp = sskip(cp);
259 thisillum.dfnum = 0;
260 thisillum.flags |= IL_DATCLB;
261 continue;
262 case 'i': /* include material */
263 case 'e': /* exclude material */
264 if (cp[1] != '=')
265 break;
266 matselect = (*cp == 'i') ? S_ELEM : S_COMPL;
267 cp += 2;
268 atos(matcheck, MAXSTR, cp);
269 cp = sskip(cp);
270 continue;
271 case 'a': /* use everything */
272 cp = sskip(cp);
273 matselect = S_ALL;
274 continue;
275 case 'n': /* use nothing (passive) */
276 cp = sskip(cp);
277 matselect = S_NONE;
278 continue;
279 case 'c': /* color calculation */
280 if (*++cp != '=')
281 break;
282 switch (*++cp) {
283 case 'a': /* average */
284 thisillum.flags = (thisillum.flags|IL_COLAVG)
285 & ~IL_COLDST;
286 break;
287 case 'd': /* distribution */
288 thisillum.flags |= (IL_COLDST|IL_COLAVG);
289 break;
290 case 'n': /* none */
291 thisillum.flags &= ~(IL_COLAVG|IL_COLDST);
292 break;
293 default:
294 goto opterr;
295 }
296 cp = sskip(cp);
297 continue;
298 case 'd': /* point sample density */
299 if (*++cp != '=')
300 break;
301 if (!isintd(++cp, " \t\n\r"))
302 break;
303 thisillum.sampdens = atoi(cp);
304 cp = sskip(cp);
305 continue;
306 case 's': /* point super-samples */
307 if (*++cp != '=')
308 break;
309 if (!isintd(++cp, " \t\n\r"))
310 break;
311 thisillum.nsamps = atoi(cp);
312 cp = sskip(cp);
313 continue;
314 case 'l': /* light sources */
315 cp++;
316 if (*cp == '+')
317 thisillum.flags |= IL_LIGHT;
318 else if (*cp == '-')
319 thisillum.flags &= ~IL_LIGHT;
320 else
321 break;
322 cp++;
323 continue;
324 case 'b': /* brightness */
325 if (*++cp != '=')
326 break;
327 if (!isfltd(++cp, " \t\n\r"))
328 break;
329 thisillum.minbrt = atof(cp);
330 if (thisillum.minbrt < 0.)
331 thisillum.minbrt = 0.;
332 cp = sskip(cp);
333 continue;
334 case 'o': /* output file */
335 if (*++cp != '=')
336 break;
337 if (!*++cp || isspace(*cp))
338 break;
339 atos(buf, sizeof(buf), cp);
340 cp = sskip(cp);
341 if (freopen(buf, "w", stdout) == NULL) {
342 sprintf(errmsg,
343 "cannot open output file \"%s\"", buf);
344 error(SYSTEM, errmsg);
345 }
346 doneheader = 0;
347 continue;
348 case '!': /* processed file! */
349 sprintf(errmsg, "(%s): already processed!", nm);
350 error(WARNING, errmsg);
351 matselect = S_NONE;
352 return;
353 }
354 opterr: /* skip faulty option */
355 while (*cp && !isspace(*cp))
356 cp++;
357 nerrs++;
358 }
359 /* print header? */
360 checkhead();
361 /* issue warnings? */
362 if (nerrs) {
363 sprintf(errmsg, "(%s): %d error(s) in option line:",
364 nm, nerrs);
365 error(WARNING, errmsg);
366 wputs(s);
367 printf("# %s: the following option line has %d error(s):\n",
368 progname, nerrs);
369 }
370 /* print pure comment */
371 printf("# %s", s+2);
372 }
373
374 void
375 printopts(void) /* print out option default values */
376 {
377 printf("m=%-15s\t\t# material name\n", thisillum.matname);
378 printf("f=%-15s\t\t# data file name\n", thisillum.datafile);
379 if (thisillum.flags & IL_COLAVG)
380 if (thisillum.flags & IL_COLDST)
381 printf("c=d\t\t\t\t# color distribution\n");
382 else
383 printf("c=a\t\t\t\t# color average\n");
384 else
385 printf("c=n\t\t\t\t# color none\n");
386 if (thisillum.flags & IL_LIGHT)
387 printf("l+\t\t\t\t# light type on\n");
388 else
389 printf("l-\t\t\t\t# light type off\n");
390 printf("d=%d\t\t\t\t# density of points\n", thisillum.sampdens);
391 printf("s=%d\t\t\t\t# samples per point\n", thisillum.nsamps);
392 printf("b=%f\t\t\t# minimum average brightness\n", thisillum.minbrt);
393 }
394
395
396 void
397 printhead( /* print out header */
398 register int ac,
399 register char **av
400 )
401 {
402 putchar('#');
403 while (ac-- > 0) {
404 putchar(' ');
405 fputs(*av++, stdout);
406 }
407 fputs("\n#@mkillum !\n", stdout);
408 }
409
410
411 void
412 xobject( /* translate an object from fp */
413 FILE *fp,
414 char *nm
415 )
416 {
417 OBJREC thisobj;
418 char str[MAXSTR];
419 int doit;
420 /* read the object */
421 if (fgetword(thisillum.altmat, MAXSTR, fp) == NULL)
422 goto readerr;
423 if (fgetword(str, MAXSTR, fp) == NULL)
424 goto readerr;
425 /* is it an alias? */
426 if (!strcmp(str, ALIASKEY)) {
427 if (fgetword(str, MAXSTR, fp) == NULL)
428 goto readerr;
429 printf("\n%s %s %s", thisillum.altmat, ALIASKEY, str);
430 if (fgetword(str, MAXSTR, fp) == NULL)
431 goto readerr;
432 printf("\t%s\n", str);
433 return;
434 }
435 thisobj.omod = OVOID; /* unused field */
436 if ((thisobj.otype = otype(str)) < 0) {
437 sprintf(errmsg, "(%s): unknown type \"%s\"", nm, str);
438 error(USER, errmsg);
439 }
440 if (fgetword(str, MAXSTR, fp) == NULL)
441 goto readerr;
442 thisobj.oname = str;
443 if (readfargs(&thisobj.oargs, fp) != 1)
444 goto readerr;
445 thisobj.os = NULL;
446 /* check for translation */
447 switch (matselect) {
448 case S_NONE:
449 doit = 0;
450 break;
451 case S_ALL:
452 doit = 1;
453 break;
454 case S_ELEM:
455 doit = !strcmp(thisillum.altmat, matcheck);
456 break;
457 case S_COMPL:
458 doit = strcmp(thisillum.altmat, matcheck);
459 break;
460 }
461 doit = doit && issurface(thisobj.otype);
462 /* print header? */
463 checkhead();
464 /* process object */
465 if (doit)
466 switch (thisobj.otype) {
467 case OBJ_FACE:
468 my_face(&thisobj, &thisillum, nm);
469 break;
470 case OBJ_SPHERE:
471 my_sphere(&thisobj, &thisillum, nm);
472 break;
473 case OBJ_RING:
474 my_ring(&thisobj, &thisillum, nm);
475 break;
476 default:
477 my_default(&thisobj, &thisillum, nm);
478 break;
479 }
480 else
481 printobj(thisillum.altmat, &thisobj);
482 /* free arguments */
483 freefargs(&thisobj.oargs);
484 return;
485 readerr:
486 sprintf(errmsg, "(%s): error reading input", nm);
487 error(USER, errmsg);
488 }
