root/radiance/ray/src/gen/mkillum.c
Revision: 2.18
Committed: Wed Oct 22 02:06:34 2003 UTC (21 years, 8 months ago) by greg
2 static const char RCSid[] = "$Id: mkillum.c,v 2.17 2003/09/24 14:55:54 greg Exp $";
5 * Make illum sources for optimizing rendering process
6 */
7
8 #include <signal.h>
9 #include <ctype.h>
10
11 #include "platform.h"
12 #include "mkillum.h"
13
14 /* default parameters */
15 #define SAMPDENS 48 /* points per projected steradian */
16 #define NSAMPS 32 /* samples per point */
17 #define DFLMAT "illum_mat" /* material name */
18 #define DFLDAT "illum" /* data file name */
19 /* selection options */
20 #define S_NONE 0 /* select none */
21 #define S_ELEM 1 /* select specified element */
22 #define S_COMPL 2 /* select all but element */
23 #define S_ALL 3 /* select all */
24
25 /* rtrace command and defaults */
26 char *rtargv[64] = { "rtrace", "-dj", ".25", "-dr", "3", "-dv-",
27 "-ab", "2", "-ad", "1024", "-as", "512", "-aa", ".1", };
28 int rtargc = 14;
29 /* overriding rtrace options */
30 char *myrtopts[] = { "-I-", "-i-", "-ld-", "-ov", "-h-",
31 "-fff", "-y", "0", NULL };
32
33 struct rtproc rt; /* our rtrace process */
34
35 struct illum_args thisillum = { /* our illum and default values */
36 0,
37 DFLMAT,
38 DFLDAT,
39 0,
40 VOIDID,
41 SAMPDENS,
42 NSAMPS,
43 0.,
44 };
45
46 char matcheck[MAXSTR]; /* current material to include or exclude */
47 int matselect = S_ALL; /* selection criterion */
48
49 FUN ofun[NUMOTYPE] = INIT_OTYPE; /* object types */
50
51 int gargc; /* global argc */
52 char **gargv; /* global argv */
53 #define progname gargv[0]
54
55 int doneheader = 0; /* printed header yet? */
56 #define checkhead() if (!doneheader++) printhead(gargc,gargv)
57
58 int warnings = 1; /* print warnings? */
59
60
61 main(argc, argv) /* compute illum distributions using rtrace */
62 int argc;
63 char *argv[];
64 {
65 char *rtpath;
66 FILE *fp;
67 register int i;
68 /* set global arguments */
69 gargv = argv;
70 /* set up rtrace command */
71 for (i = 1; i < argc; i++) {
72 if (argv[i][0] == '<' && argv[i][1] == '\0')
73 break;
74 rtargv[rtargc++] = argv[i];
75 if (argv[i][0] == '-' && argv[i][1] == 'w')
76 switch (argv[i][2]) {
77 case '\0':
78 warnings = !warnings;
79 break;
80 case '+':
81 case 'T': case 't':
82 case 'Y': case 'y':
83 case '1':
84 warnings = 1;
85 break;
86 case '-':
87 case 'F': case 'f':
88 case 'N': case 'n':
89 case '0':
90 warnings = 0;
91 break;
92 }
93 }
94 gargc = i;
95 rtargc--;
96 for (i = 0; myrtopts[i] != NULL; i++)
97 rtargv[rtargc++] = myrtopts[i];
98 rtargv[rtargc++] = argv[gargc-1];
99 rtargv[rtargc] = NULL;
100 /* just asking for defaults? */
101 if (!strcmp(argv[gargc-1], "-defaults")) {
102 printopts(); fflush(stdout);
103 rtpath = getpath(rtargv[0], getenv("PATH"), X_OK);
104 if (rtpath == NULL) {
105 eputs(rtargv[0]);
106 eputs(": command not found\n");
107 exit(1);
108 }
109 execv(rtpath, rtargv);
110 perror(rtpath);
111 exit(1);
112 }
113 if (gargc < 2 || argv[gargc-1][0] == '-')
114 error(USER, "missing octree argument");
115 /* else initialize and run our calculation */
116 init();
117 if (gargc+1 < argc)
118 for (i = gargc+1; i < argc; i++) {
119 if ((fp = fopen(argv[i], "r")) == NULL) {
120 sprintf(errmsg,
121 "cannot open scene file \"%s\"", argv[i]);
122 error(SYSTEM, errmsg);
123 }
124 filter(fp, argv[i]);
125 fclose(fp);
126 }
127 else
128 filter(stdin, "standard input");
129 quit(0);
130 }
131
132
133 void
134 quit(status) /* exit with status */
135 int status;
136 {
137 int rtstat;
138
139 rtstat = close_process(&(rt.pd));
140 if (status == 0) {
141 if (rtstat < 0)
142 error(WARNING,
143 "unknown return status from rtrace process");
144 else
145 status = rtstat;
146 }
147 exit(status);
148 }
149
150
151 init() /* start rtrace and set up buffers */
152 {
153 extern int o_face(), o_sphere(), o_ring();
154 int maxbytes;
155 /* set up object functions */
156 ofun[OBJ_FACE].funp = o_face;
157 ofun[OBJ_SPHERE].funp = o_sphere;
158 ofun[OBJ_RING].funp = o_ring;
159 /* set up signal handling */
160 #ifdef SIGPIPE /* not present on Windows */
161 signal(SIGPIPE, quit);
162 #endif
163 /* start rtrace process */
164 errno = 0;
165 maxbytes = open_process(&(rt.pd), rtargv);
166 if (maxbytes == 0) {
167 eputs(rtargv[0]);
168 eputs(": command not found\n");
169 exit(1);
170 }
171 if (maxbytes < 0)
172 error(SYSTEM, "cannot start rtrace process");
173 rt.bsiz = maxbytes/(6*sizeof(float));
174 rt.buf = (float *)malloc(6*sizeof(float)*rt.bsiz--);
175 rt.dest = (float **)malloc(sizeof(float *)*rt.bsiz);
176 if (rt.buf == NULL || rt.dest == NULL)
177 error(SYSTEM, "out of memory in init");
178 rt.nrays = 0;
179 /* set up urand */
180 initurand(16384);
181 }
182
183
184 void
185 eputs(s) /* put string to stderr */
186 register char *s;
187 {
188 static int midline = 0;
189
190 if (!*s) return;
191 if (!midline) {
192 fputs(progname, stderr);
193 fputs(": ", stderr);
194 }
195 fputs(s, stderr);
196 midline = s[strlen(s)-1] != '\n';
197 }
198
199
200 void
201 wputs(s) /* print warning if enabled */
202 char *s;
203 {
204 if (warnings)
205 eputs(s);
206 }
207
208
209 filter(infp, name) /* process stream */
210 register FILE *infp;
211 char *name;
212 {
213 char buf[512];
214 FILE *pfp;
215 register int c;
216
217 while ((c = getc(infp)) != EOF) {
218 if (isspace(c))
219 continue;
220 if (c == '#') { /* comment/options */
221 buf[0] = c;
222 fgets(buf+1, sizeof(buf)-1, infp);
223 xoptions(buf, name);
224 } else if (c == '!') { /* command */
225 buf[0] = c;
226 fgetline(buf+1, sizeof(buf)-1, infp);
227 if ((pfp = popen(buf+1, "r")) == NULL) {
228 sprintf(errmsg, "cannot execute \"%s\"", buf);
229 error(SYSTEM, errmsg);
230 }
231 filter(pfp, buf);
232 pclose(pfp);
233 } else { /* object */
234 ungetc(c, infp);
235 xobject(infp, name);
236 }
237 }
238 }
239
240
241 xoptions(s, nm) /* process options in string s */
242 char *s;
243 char *nm;
244 {
245 extern FILE *freopen();
246 char buf[64];
247 int nerrs = 0;
248 register char *cp;
249
250 if (strncmp(s, "#@mkillum", 9) || !isspace(s[9])) {
251 fputs(s, stdout); /* not for us */
252 return;
253 }
254 cp = s+10;
255 while (*cp) {
256 switch (*cp) {
257 case ' ':
258 case '\t':
259 case '\n':
260 case '\r':
261 case '\f':
262 cp++;
263 continue;
264 case 'm': /* material name */
265 if (*++cp != '=')
266 break;
267 if (!*++cp || isspace(*cp))
268 break;
269 atos(thisillum.matname, MAXSTR, cp);
270 cp = sskip(cp);
271 if (!(thisillum.flags & IL_DATCLB)) {
272 strcpy(thisillum.datafile, thisillum.matname);
273 thisillum.dfnum = 0;
274 }
275 continue;
276 case 'f': /* data file name */
277 if (*++cp != '=')
278 break;
279 if (!*++cp || isspace(*cp)) {
280 strcpy(thisillum.datafile,thisillum.matname);
281 thisillum.dfnum = 0;
282 thisillum.flags &= ~IL_DATCLB;
283 continue;
284 }
285 atos(thisillum.datafile, MAXSTR, cp);
286 cp = sskip(cp);
287 thisillum.dfnum = 0;
288 thisillum.flags |= IL_DATCLB;
289 continue;
290 case 'i': /* include material */
291 case 'e': /* exclude material */
292 if (cp[1] != '=')
293 break;
294 matselect = (*cp == 'i') ? S_ELEM : S_COMPL;
295 cp += 2;
296 atos(matcheck, MAXSTR, cp);
297 cp = sskip(cp);
298 continue;
299 case 'a': /* use everything */
300 cp = sskip(cp);
301 matselect = S_ALL;
302 continue;
303 case 'n': /* use nothing (passive) */
304 cp = sskip(cp);
305 matselect = S_NONE;
306 continue;
307 case 'c': /* color calculation */
308 if (*++cp != '=')
309 break;
310 switch (*++cp) {
311 case 'a': /* average */
312 thisillum.flags = (thisillum.flags|IL_COLAVG)
313 & ~IL_COLDST;
314 break;
315 case 'd': /* distribution */
316 thisillum.flags |= (IL_COLDST|IL_COLAVG);
317 break;
318 case 'n': /* none */
319 thisillum.flags &= ~(IL_COLAVG|IL_COLDST);
320 break;
321 default:
322 goto opterr;
323 }
324 cp = sskip(cp);
325 continue;
326 case 'd': /* point sample density */
327 if (*++cp != '=')
328 break;
329 if (!isintd(++cp, " \t\n\r"))
330 break;
331 thisillum.sampdens = atoi(cp);
332 cp = sskip(cp);
333 continue;
334 case 's': /* point super-samples */
335 if (*++cp != '=')
336 break;
337 if (!isintd(++cp, " \t\n\r"))
338 break;
339 thisillum.nsamps = atoi(cp);
340 cp = sskip(cp);
341 continue;
342 case 'l': /* light sources */
343 cp++;
344 if (*cp == '+')
345 thisillum.flags |= IL_LIGHT;
346 else if (*cp == '-')
347 thisillum.flags &= ~IL_LIGHT;
348 else
349 break;
350 cp++;
351 continue;
352 case 'b': /* brightness */
353 if (*++cp != '=')
354 break;
355 if (!isfltd(++cp, " \t\n\r"))
356 break;
357 thisillum.minbrt = atof(cp);
358 if (thisillum.minbrt < 0.)
359 thisillum.minbrt = 0.;
360 cp = sskip(cp);
361 continue;
362 case 'o': /* output file */
363 if (*++cp != '=')
364 break;
365 if (!*++cp || isspace(*cp))
366 break;
367 atos(buf, sizeof(buf), cp);
368 cp = sskip(cp);
369 if (freopen(buf, "w", stdout) == NULL) {
370 sprintf(errmsg,
371 "cannot open output file \"%s\"", buf);
372 error(SYSTEM, errmsg);
373 }
374 doneheader = 0;
375 continue;
376 case '!': /* processed file! */
377 sprintf(errmsg, "(%s): already processed!", nm);
378 error(WARNING, errmsg);
379 matselect = S_NONE;
380 return;
381 }
382 opterr: /* skip faulty option */
383 while (*cp && !isspace(*cp))
384 cp++;
385 nerrs++;
386 }
387 /* print header? */
388 checkhead();
389 /* issue warnings? */
390 if (nerrs) {
391 sprintf(errmsg, "(%s): %d error(s) in option line:",
392 nm, nerrs);
393 error(WARNING, errmsg);
394 wputs(s);
395 printf("# %s: the following option line has %d error(s):\n",
396 progname, nerrs);
397 }
398 /* print pure comment */
399 printf("# %s", s+2);
400 }
401
402
403 printopts() /* print out option default values */
404 {
405 printf("m=%-15s\t\t# material name\n", thisillum.matname);
406 printf("f=%-15s\t\t# data file name\n", thisillum.datafile);
407 if (thisillum.flags & IL_COLAVG)
408 if (thisillum.flags & IL_COLDST)
409 printf("c=d\t\t\t\t# color distribution\n");
410 else
411 printf("c=a\t\t\t\t# color average\n");
412 else
413 printf("c=n\t\t\t\t# color none\n");
414 if (thisillum.flags & IL_LIGHT)
415 printf("l+\t\t\t\t# light type on\n");
416 else
417 printf("l-\t\t\t\t# light type off\n");
418 printf("d=%d\t\t\t\t# density of points\n", thisillum.sampdens);
419 printf("s=%d\t\t\t\t# samples per point\n", thisillum.nsamps);
420 printf("b=%f\t\t\t# minimum average brightness\n", thisillum.minbrt);
421 }
422
423
424 printhead(ac, av) /* print out header */
425 register int ac;
426 register char **av;
427 {
428 putchar('#');
429 while (ac-- > 0) {
430 putchar(' ');
431 fputs(*av++, stdout);
432 }
433 fputs("\n#@mkillum !\n", stdout);
434 }
435
436
437 xobject(fp, nm) /* translate an object from fp */
438 FILE *fp;
439 char *nm;
440 {
441 OBJREC thisobj;
442 char str[MAXSTR];
443 int doit;
444 /* read the object */
445 if (fgetword(thisillum.altmat, MAXSTR, fp) == NULL)
446 goto readerr;
447 if (fgetword(str, MAXSTR, fp) == NULL)
448 goto readerr;
449 /* is it an alias? */
450 if (!strcmp(str, ALIASKEY)) {
451 if (fgetword(str, MAXSTR, fp) == NULL)
452 goto readerr;
453 printf("\n%s %s %s", thisillum.altmat, ALIASKEY, str);
454 if (fgetword(str, MAXSTR, fp) == NULL)
455 goto readerr;
456 printf("\t%s\n", str);
457 return;
458 }
459 thisobj.omod = OVOID; /* unused field */
460 if ((thisobj.otype = otype(str)) < 0) {
461 sprintf(errmsg, "(%s): unknown type \"%s\"", nm, str);
462 error(USER, errmsg);
463 }
464 if (fgetword(str, MAXSTR, fp) == NULL)
465 goto readerr;
466 thisobj.oname = str;
467 if (readfargs(&thisobj.oargs, fp) != 1)
468 goto readerr;
469 thisobj.os = NULL;
470 /* check for translation */
471 switch (matselect) {
472 case S_NONE:
473 doit = 0;
474 break;
475 case S_ALL:
476 doit = 1;
477 break;
478 case S_ELEM:
479 doit = !strcmp(thisillum.altmat, matcheck);
480 break;
481 case S_COMPL:
482 doit = strcmp(thisillum.altmat, matcheck);
483 break;
484 }
485 doit = doit && issurface(thisobj.otype);
486 /* print header? */
487 checkhead();
488 /* process object */
489 if (doit)
490 (*ofun[thisobj.otype].funp)(&thisobj, &thisillum, &rt, nm);
491 else
492 printobj(thisillum.altmat, &thisobj);
493 /* free arguments */
494 freefargs(&thisobj.oargs);
495 return;
496 readerr:
497 sprintf(errmsg, "(%s): error reading scene", nm);
498 error(USER, errmsg);
499 }
