root/radiance/ray/src/gen/mkillum.c
Revision: 1.9
Committed: Thu Jul 25 15:31:30 1991 UTC (33 years, 11 months ago) by greg
Changes since 1.8: +11 -0 lines
added variable settings to -defaults printing
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Make illum sources for optimizing rendering process
9 */
10
11 #include "mkillum.h"
12
13 #include <signal.h>
14
15 #include <ctype.h>
16
17 /* default parameters */
18 #define SAMPDENS 48 /* points per projected steradian */
19 #define NSAMPS 32 /* samples per point */
20 #define DFLMAT "illum_mat" /* material name */
21 /* selection options */
22 #define S_NONE 0 /* select none */
23 #define S_ELEM 1 /* select specified element */
24 #define S_COMPL 2 /* select all but element */
25 #define S_ALL 3 /* select all */
26
27 /* rtrace command and defaults */
28 char *rtargv[64] = { "rtrace", "-dj", ".25", "-dr", "3", "-di+",
29 "-ab", "2", "-ad", "256", "-as", "128", "-aa", ".15", };
30 int rtargc = 14;
31 /* overriding rtrace options */
32 char *myrtopts[] = { "-I-", "-i-", "-ov", "-h-", "-fff", NULL };
33
34 struct rtproc rt; /* our rtrace process */
35
36 struct illum_args thisillum = { /* our illum and default values */
37 0,
38 DFLMAT,
39 DFLMAT,
40 0,
41 VOIDID,
42 SAMPDENS,
43 NSAMPS,
44 };
45
46 char matcheck[MAXSTR]; /* current material to include or exclude */
47 int matselect = S_ALL; /* selection criterion */
48
49 FUN ofun[NUMOTYPE] = INIT_OTYPE; /* object types */
50
51 int gargc; /* global argc */
52 char **gargv; /* global argv */
53 #define progname gargv[0]
54
55 int doneheader = 0; /* printed header yet? */
56 #define checkhead() if (!doneheader++) printhead(gargc,gargv)
57
58 int warnings = 1; /* print warnings? */
59
60 extern char *fgetline(), *fgetword(), *sskip(),
61 *atos(), *iskip(), *fskip(), *strcpy();
62 extern FILE *popen();
63
64
65 main(argc, argv) /* compute illum distributions using rtrace */
66 int argc;
67 char *argv[];
68 {
69 extern char *getenv(), *getpath();
70 char *rtpath;
71 FILE *fp;
72 register int i;
73 /* set global arguments */
74 gargv = argv;
75 /* set up rtrace command */
76 for (i = 1; i < argc; i++) {
77 if (argv[i][0] == '<' && !argv[i][1])
78 break;
79 rtargv[rtargc++] = argv[i];
80 if (argv[i][0] == '-' && argv[i][1] == 'w')
81 warnings = !warnings;
82 }
83 if ((gargc = i) < 2)
84 error(USER, "too few arguments");
85 rtargc--;
86 for (i = 0; myrtopts[i] != NULL; i++)
87 rtargv[rtargc++] = myrtopts[i];
88 rtargv[rtargc++] = argv[gargc-1];
89 rtargv[rtargc] = NULL;
90 /* just asking for defaults? */
91 if (!strcmp(argv[gargc-1], "-defaults")) {
92 printopts(); fflush(stdout);
93 rtpath = getpath(rtargv[0], getenv("PATH"), X_OK);
94 if (rtpath == NULL) {
95 eputs(rtargv[0]);
96 eputs(": command not found\n");
97 exit(1);
98 }
99 execv(rtpath, rtargv);
100 perror(rtpath);
101 exit(1);
102 }
103 /* else initialize and run our calculation */
104 init();
105 if (gargc+1 < argc)
106 for (i = gargc+1; i < argc; i++) {
107 if ((fp = fopen(argv[i], "r")) == NULL) {
108 sprintf(errmsg,
109 "cannot open scene file \"%s\"", argv[i]);
110 error(SYSTEM, errmsg);
111 }
112 filter(fp, argv[i]);
113 fclose(fp);
114 }
115 else
116 filter(stdin, "standard input");
117 quit(0);
118 }
119
120
121 quit(status) /* exit with status */
122 int status;
123 {
124 int rtstat;
125
126 rtstat = close_process(rt.pd);
127 if (status == 0)
128 if (rtstat < 0)
129 error(WARNING,
130 "unknown return status from rtrace process");
131 else
132 status = rtstat;
133 exit(status);
134 }
135
136
137 init() /* start rtrace and set up buffers */
138 {
139 extern int o_face(), o_sphere(), o_ring();
140 int maxbytes;
141 /* set up object functions */
142 ofun[OBJ_FACE].funp = o_face;
143 ofun[OBJ_SPHERE].funp = o_sphere;
144 ofun[OBJ_RING].funp = o_ring;
145 /* set up signal handling */
146 signal(SIGPIPE, quit);
147 /* start rtrace process */
148 maxbytes = open_process(rt.pd, rtargv);
149 if (maxbytes == 0) {
150 eputs(rtargv[0]);
151 eputs(": command not found\n");
152 exit(1);
153 }
154 if (maxbytes < 0)
155 error(SYSTEM, "cannot start rtrace process");
156 rt.bsiz = maxbytes/(6*sizeof(float));
157 rt.buf = (float *)malloc(6*sizeof(float)*rt.bsiz--);
158 rt.dest = (float **)malloc(sizeof(float *)*rt.bsiz);
159 if (rt.buf == NULL || rt.dest == NULL)
160 error(SYSTEM, "out of memory in init");
161 rt.nrays = 0;
162 /* set up urand */
163 initurand(2048);
164 }
165
166
167 eputs(s) /* put string to stderr */
168 register char *s;
169 {
170 static int midline = 0;
171
172 if (!*s) return;
173 if (!midline) {
174 fputs(progname, stderr);
175 fputs(": ", stderr);
176 }
177 fputs(s, stderr);
178 midline = s[strlen(s)-1] != '\n';
179 }
180
181
182 wputs(s) /* print warning if enabled */
183 char *s;
184 {
185 if (warnings)
186 eputs(s);
187 }
188
189
190 filter(infp, name) /* process stream */
191 register FILE *infp;
192 char *name;
193 {
194 char buf[512];
195 FILE *pfp;
196 register int c;
197
198 while ((c = getc(infp)) != EOF) {
199 if (isspace(c))
200 continue;
201 if (c == '#') { /* comment/options */
202 buf[0] = c;
203 fgets(buf+1, sizeof(buf)-1, infp);
204 xoptions(buf, name);
205 } else if (c == '!') { /* command */
206 buf[0] = c;
207 fgetline(buf+1, sizeof(buf)-1, infp);
208 if ((pfp = popen(buf+1, "r")) == NULL) {
209 sprintf(errmsg, "cannot execute \"%s\"", buf);
210 error(SYSTEM, errmsg);
211 }
212 filter(pfp, buf);
213 pclose(pfp);
214 } else { /* object */
215 ungetc(c, infp);
216 xobject(infp, name);
217 }
218 }
219 }
220
221
222 xoptions(s, nm) /* process options in string s */
223 char *s;
224 char *nm;
225 {
226 extern FILE *freopen();
227 char buf[64];
228 int nerrs = 0;
229 register char *cp;
230
231 if (strncmp(s, "#@mkillum", 9) || !isspace(s[9])) {
232 fputs(s, stdout); /* not for us */
233 return;
234 }
235 cp = s+10;
236 while (*cp) {
237 switch (*cp) {
238 case ' ':
239 case '\t':
240 case '\n':
241 cp++;
242 continue;
243 case 'm': /* material name */
244 if (*++cp != '=')
245 break;
246 if (!*++cp)
247 break;
248 atos(thisillum.matname, MAXSTR, cp);
249 cp = sskip(cp);
250 if (!(thisillum.flags & IL_DATCLB)) {
251 strcpy(thisillum.datafile, thisillum.matname);
252 thisillum.dfnum = 0;
253 }
254 continue;
255 case 'f': /* data file name */
256 if (*++cp != '=')
257 break;
258 if (!*++cp) {
259 strcpy(thisillum.datafile,thisillum.matname);
260 thisillum.flags &= ~IL_DATCLB;
261 continue;
262 }
263 atos(thisillum.datafile, MAXSTR, cp);
264 cp = sskip(cp);
265 thisillum.dfnum = 0;
266 thisillum.flags |= IL_DATCLB;
267 continue;
268 case 'i': /* include material */
269 case 'e': /* exclude material */
270 if (cp[1] != '=')
271 break;
272 matselect = (*cp == 'i') ? S_ELEM : S_COMPL;
273 cp += 2;
274 atos(matcheck, MAXSTR, cp);
275 cp = sskip(cp);
276 continue;
277 case 'a': /* use everything */
278 cp = sskip(cp);
279 matselect = S_ALL;
280 continue;
281 case 'n': /* use nothing (passive) */
282 cp = sskip(cp);
283 matselect = S_NONE;
284 continue;
285 case 'c': /* color calculation */
286 if (*++cp != '=')
287 break;
288 switch (*++cp) {
289 case 'a': /* average */
290 thisillum.flags = (thisillum.flags|IL_COLAVG)
291 & ~IL_COLDST;
292 break;
293 case 'd': /* distribution */
294 thisillum.flags |= (IL_COLDST|IL_COLAVG);
295 break;
296 case 'n': /* none */
297 thisillum.flags &= ~(IL_COLAVG|IL_COLDST);
298 break;
299 default:
300 goto opterr;
301 }
302 cp = sskip(cp);
303 continue;
304 case 'd': /* point sample density */
305 if (*++cp != '=')
306 break;
307 if (!isintd(++cp, " \t\n"))
308 break;
309 thisillum.sampdens = atoi(cp);
310 cp = sskip(cp);
311 continue;
312 case 's': /* point super-samples */
313 if (*++cp != '=')
314 break;
315 if (!isintd(++cp, " \t\n"))
316 break;
317 thisillum.nsamps = atoi(cp);
318 cp = sskip(cp);
319 continue;
320 case 'l': /* light sources */
321 cp++;
322 if (*cp == '+')
323 thisillum.flags |= IL_LIGHT;
324 else if (*cp == '-')
325 thisillum.flags &= ~IL_LIGHT;
326 else
327 break;
328 cp++;
329 continue;
330 case 'o': /* output file */
331 if (*++cp != '=')
332 break;
333 if (!*++cp)
334 break;
335 atos(buf, sizeof(buf), cp);
336 cp = sskip(cp);
337 if (freopen(buf, "w", stdout) == NULL) {
338 sprintf(errmsg,
339 "cannot open output file \"%s\"", buf);
340 error(SYSTEM, errmsg);
341 }
342 doneheader = 0;
343 continue;
344 case '!': /* processed file! */
345 sprintf(errmsg, "(%s): already processed!", nm);
346 error(WARNING, errmsg);
347 matselect = S_NONE;
348 return;
349 }
350 opterr: /* skip faulty option */
351 cp = sskip(cp);
352 nerrs++;
353 }
354 /* print header? */
355 checkhead();
356 /* issue warnings? */
357 if (nerrs) {
358 sprintf(errmsg, "(%s): %d error(s) in option line:",
359 nm, nerrs);
360 error(WARNING, errmsg);
361 wputs(s);
362 printf("# %s: the following option line has %d error(s):\n",
363 progname, nerrs);
364 }
365 /* print pure comment */
366 printf("# %s", s+2);
367 }
368
369
370 printopts() /* print out option default values */
371 {
372 printf("m=%s\t\t\t# material name\n", thisillum.matname);
373 printf("f=%s\t\t\t# data file name\n", thisillum.datafile);
374 printf("c=n\t\t\t\t# color none\n");
375 printf("d=%d\t\t\t\t# density of points\n", thisillum.sampdens);
376 printf("s=%d\t\t\t\t# samples per point\n", thisillum.nsamps);
377 }
378
379
380 printhead(ac, av) /* print out header */
381 register int ac;
382 register char **av;
383 {
384 putchar('#');
385 while (ac-- > 0) {
386 putchar(' ');
387 fputs(*av++, stdout);
388 }
389 fputs("\n#@mkillum !\n", stdout);
390 }
391
392
393 xobject(fp, nm) /* translate an object from fp */
394 FILE *fp;
395 char *nm;
396 {
397 OBJREC thisobj;
398 char str[MAXSTR];
399 int doit;
400 /* read the object */
401 if (fgetword(thisillum.altmat, MAXSTR, fp) == NULL)
402 goto readerr;
403 if (fgetword(str, MAXSTR, fp) == NULL)
404 goto readerr;
405 /* is it an alias? */
406 if (!strcmp(str, ALIASID)) {
407 if (fgetword(str, MAXSTR, fp) == NULL)
408 goto readerr;
409 printf("\n%s %s %s", thisillum.altmat, ALIASID, str);
410 if (fgetword(str, MAXSTR, fp) == NULL)
411 goto readerr;
412 printf("\t%s\n", str);
413 return;
414 }
415 thisobj.omod = OVOID; /* unused field */
416 if ((thisobj.otype = otype(str)) < 0) {
417 sprintf(errmsg, "(%s): unknown type \"%s\"", nm, str);
418 error(USER, errmsg);
419 }
420 if (fgetword(str, MAXSTR, fp) == NULL)
421 goto readerr;
422 thisobj.oname = str;
423 if (readfargs(&thisobj.oargs, fp) != 1)
424 goto readerr;
425 thisobj.os = NULL;
426 /* check for translation */
427 switch (matselect) {
428 case S_NONE:
429 doit = 0;
430 break;
431 case S_ALL:
432 doit = 1;
433 break;
434 case S_ELEM:
435 doit = !strcmp(thisillum.altmat, matcheck);
436 break;
437 case S_COMPL:
438 doit = strcmp(thisillum.altmat, matcheck);
439 break;
440 }
441 doit = doit && issurface(thisobj.otype);
442 /* print header? */
443 checkhead();
444 /* process object */
445 if (doit)
446 (*ofun[thisobj.otype].funp)(&thisobj, &thisillum, &rt, nm);
447 else
448 printobj(thisillum.altmat, &thisobj);
449 /* free arguments */
450 freefargs(&thisobj.oargs);
451 return;
452 readerr:
453 sprintf(errmsg, "(%s): error reading scene", nm);
454 error(USER, errmsg);
455 }
