root/radiance/ray/src/gen/mkillum.c
Revision: 1.6
Committed: Thu Jul 25 10:59:05 1991 UTC (33 years, 11 months ago) by greg
Changes since 1.5: +14 -6 lines
visual debugging pass
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Make illum sources for optimizing rendering process
9 */
10
11 #include "mkillum.h"
12
13 #include <signal.h>
14
15 #include <ctype.h>
16
17 /* default parameters */
18 #define SAMPDENS 128 /* points per projected steradian */
19 #define NSAMPS 32 /* samples per point */
20 #define DFLMAT "illum_mat" /* material name */
21 /* selection options */
22 #define S_NONE 0 /* select none */
23 #define S_ELEM 1 /* select specified element */
24 #define S_COMPL 2 /* select all but element */
25 #define S_ALL 3 /* select all */
26
27 /* rtrace command and defaults */
28 char *rtargv[64] = { "rtrace", "-dj", ".25", "-dr", "3", "-di+",
29 "-ab", "2", "-ad", "256", "-as", "128", "-aa", ".15", };
30 int rtargc = 14;
31 /* overriding rtrace options */
32 char *myrtopts[] = { "-I-", "-i-", "-ov", "-h-", "-fff", NULL };
33
34 struct rtproc rt; /* our rtrace process */
35
36 struct illum_args thisillum = { /* our illum and default values */
37 0,
38 DFLMAT,
39 DFLMAT,
40 0,
41 VOIDID,
42 SAMPDENS,
43 NSAMPS,
44 };
45
46 char matcheck[MAXSTR]; /* current material to include or exclude */
47 int matselect = S_ALL; /* selection criterion */
48
49 FUN ofun[NUMOTYPE] = INIT_OTYPE; /* object types */
50
51 int gargc; /* global argc */
52 char **gargv; /* global argv */
53 #define progname gargv[0]
54
55 int doneheader = 0; /* printed header yet? */
56 #define checkhead() if (!doneheader++) printhead(gargc,gargv)
57
58 int warnings = 1; /* print warnings? */
59
60 extern char *fgetline(), *fgetword(), *sskip(),
61 *atos(), *iskip(), *fskip(), *strcpy();
62 extern FILE *popen();
63
64
65 main(argc, argv) /* compute illum distributions using rtrace */
66 int argc;
67 char *argv[];
68 {
69 extern char *getenv(), *getpath();
70 char *rtpath;
71 FILE *fp;
72 register int i;
73 /* set global arguments */
74 gargv = argv;
75 /* set up rtrace command */
76 for (i = 1; i < argc; i++) {
77 if (argv[i][0] == '<' && !argv[i][1])
78 break;
79 rtargv[rtargc++] = argv[i];
80 if (argv[i][0] == '-' && argv[i][1] == 'w')
81 warnings = !warnings;
82 }
83 if ((gargc = i) < 2)
84 error(USER, "too few arguments");
85 rtargc--;
86 for (i = 0; myrtopts[i] != NULL; i++)
87 rtargv[rtargc++] = myrtopts[i];
88 rtargv[rtargc++] = argv[gargc-1];
89 rtargv[rtargc] = NULL;
90 /* just asking for defaults? */
91 if (!strcmp(argv[gargc-1], "-defaults")) {
92 rtpath = getpath(rtargv[0], getenv("PATH"), X_OK);
93 if (rtpath == NULL) {
94 eputs(rtargv[0]);
95 eputs(": command not found\n");
96 exit(1);
97 }
98 execv(rtpath, rtargv);
99 perror(rtpath);
100 exit(1);
101 }
102 /* else initialize and run our calculation */
103 init();
104 if (gargc+1 < argc)
105 for (i = gargc+1; i < argc; i++) {
106 if ((fp = fopen(argv[i], "r")) == NULL) {
107 sprintf(errmsg,
108 "cannot open scene file \"%s\"", argv[i]);
109 error(SYSTEM, errmsg);
110 }
111 filter(fp, argv[i]);
112 fclose(fp);
113 }
114 else
115 filter(stdin, "standard input");
116 quit(0);
117 }
118
119
120 quit(status) /* exit with status */
121 int status;
122 {
123 int rtstat;
124
125 rtstat = close_process(rt.pd);
126 if (status == 0)
127 if (rtstat < 0)
128 error(WARNING,
129 "unknown return status from rtrace process");
130 else
131 status = rtstat;
132 exit(status);
133 }
134
135
136 init() /* start rtrace and set up buffers */
137 {
138 extern int o_face(), o_sphere(), o_ring();
139 int maxbytes;
140 /* set up object functions */
141 ofun[OBJ_FACE].funp = o_face;
142 ofun[OBJ_SPHERE].funp = o_sphere;
143 ofun[OBJ_RING].funp = o_ring;
144 /* set up signal handling */
145 signal(SIGPIPE, quit);
146 /* start rtrace process */
147 maxbytes = open_process(rt.pd, rtargv);
148 if (maxbytes == 0) {
149 eputs(rtargv[0]);
150 eputs(": command not found\n");
151 exit(1);
152 }
153 if (maxbytes < 0)
154 error(SYSTEM, "cannot start rtrace process");
155 rt.bsiz = maxbytes/(6*sizeof(float));
156 rt.buf = (float *)malloc(6*sizeof(float)*rt.bsiz--);
157 rt.dest = (float **)malloc(sizeof(float *)*rt.bsiz);
158 if (rt.buf == NULL || rt.dest == NULL)
159 error(SYSTEM, "out of memory in init");
160 rt.nrays = 0;
161 /* set up urand */
162 initurand(2048);
163 }
164
165
166 eputs(s) /* put string to stderr */
167 register char *s;
168 {
169 static int midline = 0;
170
171 if (!*s) return;
172 if (!midline) {
173 fputs(progname, stderr);
174 fputs(": ", stderr);
175 }
176 fputs(s, stderr);
177 midline = s[strlen(s)-1] != '\n';
178 }
179
180
181 wputs(s) /* print warning if enabled */
182 char *s;
183 {
184 if (warnings)
185 eputs(s);
186 }
187
188
189 filter(infp, name) /* process stream */
190 register FILE *infp;
191 char *name;
192 {
193 char buf[512];
194 FILE *pfp;
195 register int c;
196
197 while ((c = getc(infp)) != EOF) {
198 if (isspace(c))
199 continue;
200 if (c == '#') { /* comment/options */
201 buf[0] = c;
202 fgets(buf+1, sizeof(buf)-1, infp);
203 xoptions(buf, name);
204 } else if (c == '!') { /* command */
205 buf[0] = c;
206 fgetline(buf+1, sizeof(buf)-1, infp);
207 if ((pfp = popen(buf+1, "r")) == NULL) {
208 sprintf(errmsg, "cannot execute \"%s\"", buf);
209 error(SYSTEM, errmsg);
210 }
211 filter(pfp, buf);
212 pclose(pfp);
213 } else { /* object */
214 ungetc(c, infp);
215 xobject(infp, name);
216 }
217 }
218 }
219
220
221 xoptions(s, nm) /* process options in string s */
222 char *s;
223 char *nm;
224 {
225 extern FILE *freopen();
226 char buf[64];
227 int nerrs = 0;
228 register char *cp;
229
230 if (strncmp(s, "#@mkillum", 9) || !isspace(s[9])) {
231 fputs(s, stdout); /* not for us */
232 return;
233 }
234 cp = s+10;
235 while (*cp) {
236 switch (*cp) {
237 case ' ':
238 case '\t':
239 case '\n':
240 cp++;
241 continue;
242 case 'm': /* material name */
243 if (*++cp != '=')
244 break;
245 if (!*++cp)
246 break;
247 atos(thisillum.matname, MAXSTR, cp);
248 cp = sskip(cp);
249 if (!(thisillum.flags & IL_DATCLB)) {
250 strcpy(thisillum.datafile, thisillum.matname);
251 thisillum.dfnum = 0;
252 }
253 continue;
254 case 'f': /* data file name */
255 if (*++cp != '=')
256 break;
257 if (!*++cp) {
258 strcpy(thisillum.datafile,thisillum.matname);
259 thisillum.flags &= ~IL_DATCLB;
260 continue;
261 }
262 atos(thisillum.datafile, MAXSTR, cp);
263 cp = sskip(cp);
264 thisillum.dfnum = 0;
265 thisillum.flags |= IL_DATCLB;
266 continue;
267 case 'i': /* include material */
268 case 'e': /* exclude material */
269 if (cp[1] != '=')
270 break;
271 matselect = (*++cp == 'i') ? S_ELEM : S_COMPL;
272 atos(matcheck, MAXSTR, ++cp);
273 cp = sskip(cp);
274 continue;
275 case 'a': /* use everything */
276 cp = sskip(cp);
277 matselect = S_ALL;
278 continue;
279 case 'n': /* use nothing (passive) */
280 cp = sskip(cp);
281 matselect = S_NONE;
282 continue;
283 case 'c': /* color calculation */
284 if (*++cp != '=')
285 break;
286 switch (*++cp) {
287 case 'a': /* average */
288 thisillum.flags = (thisillum.flags|IL_COLAVG)
289 & ~IL_COLDST;
290 break;
291 case 'd': /* distribution */
292 thisillum.flags |= (IL_COLDST|IL_COLAVG);
293 break;
294 case 'n': /* none */
295 thisillum.flags &= ~(IL_COLAVG|IL_COLDST);
296 break;
297 default:
298 goto opterr;
299 }
300 cp = sskip(cp);
301 continue;
302 case 'd': /* point sample density */
303 if (*++cp != '=')
304 break;
305 if (!isintd(++cp, " \t\n"))
306 break;
307 thisillum.sampdens = atoi(cp);
308 cp = sskip(cp);
309 continue;
310 case 's': /* point super-samples */
311 if (*++cp != '=')
312 break;
313 if (!isintd(++cp, " \t\n"))
314 break;
315 thisillum.nsamps = atoi(cp);
316 cp = sskip(cp);
317 continue;
318 case 'l': /* light sources */
319 cp++;
320 if (*cp == '+')
321 thisillum.flags |= IL_LIGHT;
322 else if (*cp == '-')
323 thisillum.flags &= ~IL_LIGHT;
324 else
325 break;
326 cp++;
327 continue;
328 case 'o': /* output file */
329 if (*++cp != '=')
330 break;
331 if (!*++cp)
332 break;
333 atos(buf, sizeof(buf), cp);
334 cp = sskip(cp);
335 if (freopen(buf, "w", stdout) == NULL) {
336 sprintf(errmsg,
337 "cannot open output file \"%s\"", buf);
338 error(SYSTEM, errmsg);
339 }
340 doneheader = 0;
341 continue;
342 case '!': /* processed file! */
343 sprintf(errmsg, "(%s): processed by mkillum already!",
344 nm);
345 error(WARNING, errmsg);
346 return;
347 }
348 opterr: /* skip faulty option */
349 cp = sskip(cp);
350 nerrs++;
351 }
352 /* print header? */
353 checkhead();
354 /* issue warnings? */
355 if (nerrs) {
356 sprintf(errmsg, "(%s): %d error(s) in option line:",
357 nm, nerrs);
358 error(WARNING, errmsg);
359 wputs(s);
360 printf("# %s: the following option line has %d error(s):\n",
361 progname, nerrs);
362 }
363 /* print pure comment */
364 printf("# %s", s+2);
365 }
366
367
368 printhead(ac, av) /* print out header */
369 register int ac;
370 register char **av;
371 {
372 putchar('#');
373 while (ac-- > 0) {
374 putchar(' ');
375 fputs(*av++, stdout);
376 }
377 fputs("\n#@mkillum !\n", stdout);
378 }
379
380
381 xobject(fp, nm) /* translate an object from fp */
382 FILE *fp;
383 char *nm;
384 {
385 OBJREC thisobj;
386 char str[MAXSTR];
387 int doit;
388 /* read the object */
389 if (fgetword(thisillum.altmat, MAXSTR, fp) == NULL)
390 goto readerr;
391 if (fgetword(str, MAXSTR, fp) == NULL)
392 goto readerr;
393 /* is it an alias? */
394 if (!strcmp(str, ALIASID)) {
395 if (fgetword(str, MAXSTR, fp) == NULL)
396 goto readerr;
397 printf("\n%s %s %s", thisillum.altmat, ALIASID, str);
398 if (fgetword(str, MAXSTR, fp) == NULL)
399 goto readerr;
400 printf("\t%s\n", str);
401 return;
402 }
403 thisobj.omod = OVOID; /* unused field */
404 if ((thisobj.otype = otype(str)) < 0) {
405 sprintf(errmsg, "(%s): unknown type \"%s\"", nm, str);
406 error(USER, errmsg);
407 }
408 if (fgetword(str, MAXSTR, fp) == NULL)
409 goto readerr;
410 thisobj.oname = str;
411 if (readfargs(&thisobj.oargs, fp) != 1)
412 goto readerr;
413 thisobj.os = NULL;
414 /* check for translation */
415 switch (matselect) {
416 case S_NONE:
417 doit = 0;
418 break;
419 case S_ALL:
420 doit = 1;
421 break;
422 case S_ELEM:
423 doit = !strcmp(thisillum.altmat, matcheck);
424 break;
425 case S_COMPL:
426 doit = strcmp(thisillum.altmat, matcheck);
427 break;
428 }
429 doit = doit && issurface(thisobj.otype);
430 /* print header? */
431 checkhead();
432 /* process object */
433 if (doit)
434 (*ofun[thisobj.otype].funp)(&thisobj, &thisillum, &rt, nm);
435 else
436 printobj(thisillum.altmat, &thisobj);
437 /* free arguments */
438 freefargs(&thisobj.oargs);
439 return;
440 readerr:
441 sprintf(errmsg, "(%s): error reading scene", nm);
442 error(USER, errmsg);
443 }
