--- ray/src/gen/mkillum.c 1991/07/24 12:22:03 1.4 +++ ray/src/gen/mkillum.c 2003/02/22 02:07:24 2.11 @@ -1,9 +1,6 @@ -/* Copyright (c) 1991 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: mkillum.c,v 2.11 2003/02/22 02:07:24 greg Exp $"; #endif - /* * Make illum sources for optimizing rendering process */ @@ -15,9 +12,10 @@ static char SCCSid[] = "$SunId$ LBL"; #include /* default parameters */ -#define SAMPDENS 128 /* points per projected steradian */ +#define SAMPDENS 48 /* points per projected steradian */ #define NSAMPS 32 /* samples per point */ #define DFLMAT "illum_mat" /* material name */ +#define DFLDAT "illum" /* data file name */ /* selection options */ #define S_NONE 0 /* select none */ #define S_ELEM 1 /* select specified element */ @@ -25,22 +23,24 @@ static char SCCSid[] = "$SunId$ LBL"; #define S_ALL 3 /* select all */ /* rtrace command and defaults */ -char *rtargv[64] = { "rtrace", "-dj", ".25", "-dr", "3", "-di+", +char *rtargv[64] = { "rtrace", "-dj", ".25", "-dr", "3", "-dv-", "-ab", "2", "-ad", "256", "-as", "128", "-aa", ".15", }; int rtargc = 14; /* overriding rtrace options */ -char *myrtopts[] = { "-I-", "-i-", "-ov", "-h-", "-fff", NULL }; +char *myrtopts[] = { "-I-", "-i-", "-ld-", "-ov", "-h-", + "-fff", "-y", "0", NULL }; struct rtproc rt; /* our rtrace process */ struct illum_args thisillum = { /* our illum and default values */ 0, DFLMAT, - DFLMAT, + DFLDAT, 0, VOIDID, SAMPDENS, NSAMPS, + 0., }; char matcheck[MAXSTR]; /* current material to include or exclude */ @@ -57,16 +57,11 @@ int doneheader = 0; /* printed header yet? */ int warnings = 1; /* print warnings? */ -extern char *fgetline(), *fgetword(), *sskip(), - *atos(), *iskip(), *fskip(); -extern FILE *popen(); - main(argc, argv) /* compute illum distributions using rtrace */ int argc; char *argv[]; { - extern char *getenv(), *getpath(); char *rtpath; FILE *fp; register int i; @@ -74,14 +69,29 @@ char *argv[]; gargv = argv; /* set up rtrace command */ for (i = 1; i < argc; i++) { - if (argv[i][0] == '<' && !argv[i][1]) + if (argv[i][0] == '<' && argv[i][1] == '\0') break; rtargv[rtargc++] = argv[i]; if (argv[i][0] == '-' && argv[i][1] == 'w') - warnings = !warnings; + switch (argv[i][2]) { + case '\0': + warnings = !warnings; + break; + case '+': + case 'T': case 't': + case 'Y': case 'y': + case '1': + warnings = 1; + break; + case '-': + case 'F': case 'f': + case 'N': case 'n': + case '0': + warnings = 0; + break; + } } - if ((gargc = i) < 2) - error(USER, "too few arguments"); + gargc = i; rtargc--; for (i = 0; myrtopts[i] != NULL; i++) rtargv[rtargc++] = myrtopts[i]; @@ -89,6 +99,7 @@ char *argv[]; rtargv[rtargc] = NULL; /* just asking for defaults? */ if (!strcmp(argv[gargc-1], "-defaults")) { + printopts(); fflush(stdout); rtpath = getpath(rtargv[0], getenv("PATH"), X_OK); if (rtpath == NULL) { eputs(rtargv[0]); @@ -99,11 +110,13 @@ char *argv[]; perror(rtpath); exit(1); } + if (gargc < 2 || argv[gargc-1][0] == '-') + error(USER, "missing octree argument"); /* else initialize and run our calculation */ init(); if (gargc+1 < argc) for (i = gargc+1; i < argc; i++) { - if ((fp = fopen(argv[i], "r")) == NULL { + if ((fp = fopen(argv[i], "r")) == NULL) { sprintf(errmsg, "cannot open scene file \"%s\"", argv[i]); error(SYSTEM, errmsg); @@ -117,6 +130,7 @@ char *argv[]; } +void quit(status) /* exit with status */ int status; { @@ -144,6 +158,7 @@ init() /* start rtrace and set up buffers */ /* set up signal handling */ signal(SIGPIPE, quit); /* start rtrace process */ + errno = 0; maxbytes = open_process(rt.pd, rtargv); if (maxbytes == 0) { eputs(rtargv[0]); @@ -158,9 +173,12 @@ init() /* start rtrace and set up buffers */ if (rt.buf == NULL || rt.dest == NULL) error(SYSTEM, "out of memory in init"); rt.nrays = 0; + /* set up urand */ + initurand(16384); } +void eputs(s) /* put string to stderr */ register char *s; { @@ -176,6 +194,7 @@ register char *s; } +void wputs(s) /* print warning if enabled */ char *s; { @@ -235,12 +254,14 @@ char *nm; case ' ': case '\t': case '\n': + case '\r': + case '\f': cp++; continue; case 'm': /* material name */ if (*++cp != '=') break; - if (!*++cp) + if (!*++cp || isspace(*cp)) break; atos(thisillum.matname, MAXSTR, cp); cp = sskip(cp); @@ -252,7 +273,9 @@ char *nm; case 'f': /* data file name */ if (*++cp != '=') break; - if (!*++cp) { + if (!*++cp || isspace(*cp)) { + strcpy(thisillum.datafile,thisillum.matname); + thisillum.dfnum = 0; thisillum.flags &= ~IL_DATCLB; continue; } @@ -263,10 +286,11 @@ char *nm; continue; case 'i': /* include material */ case 'e': /* exclude material */ - matselect = (*cp == 'i') ? S_ELEM : S_COMPL; - if (*++cp != '=') + if (cp[1] != '=') break; - atos(matcheck, MAXSTR, ++cp); + matselect = (*cp == 'i') ? S_ELEM : S_COMPL; + cp += 2; + atos(matcheck, MAXSTR, cp); cp = sskip(cp); continue; case 'a': /* use everything */ @@ -282,12 +306,11 @@ char *nm; break; switch (*++cp) { case 'a': /* average */ - thisillum.flags |= IL_COLAVG; - thisillum.flags &= ~IL_COLDST; + thisillum.flags = (thisillum.flags|IL_COLAVG) + & ~IL_COLDST; break; case 'd': /* distribution */ - thisillum.flags |= IL_COLDST; - thisillum.flags &= ~IL_COLAVG; + thisillum.flags |= (IL_COLDST|IL_COLAVG); break; case 'n': /* none */ thisillum.flags &= ~(IL_COLAVG|IL_COLDST); @@ -300,7 +323,7 @@ char *nm; case 'd': /* point sample density */ if (*++cp != '=') break; - if (!isintd(++cp, " \t\n")) + if (!isintd(++cp, " \t\n\r")) break; thisillum.sampdens = atoi(cp); cp = sskip(cp); @@ -308,7 +331,7 @@ char *nm; case 's': /* point super-samples */ if (*++cp != '=') break; - if (!isintd(++cp, " \t\n")) + if (!isintd(++cp, " \t\n\r")) break; thisillum.nsamps = atoi(cp); cp = sskip(cp); @@ -323,10 +346,20 @@ char *nm; break; cp++; continue; + case 'b': /* brightness */ + if (*++cp != '=') + break; + if (!isfltd(++cp, " \t\n\r")) + break; + thisillum.minbrt = atof(cp); + if (thisillum.minbrt < 0.) + thisillum.minbrt = 0.; + cp = sskip(cp); + continue; case 'o': /* output file */ if (*++cp != '=') break; - if (!*++cp) + if (!*++cp || isspace(*cp)) break; atos(buf, sizeof(buf), cp); cp = sskip(cp); @@ -337,9 +370,15 @@ char *nm; } doneheader = 0; continue; + case '!': /* processed file! */ + sprintf(errmsg, "(%s): already processed!", nm); + error(WARNING, errmsg); + matselect = S_NONE; + return; } opterr: /* skip faulty option */ - cp = sskip(cp); + while (*cp && !isspace(*cp)) + cp++; nerrs++; } /* print header? */ @@ -358,6 +397,27 @@ char *nm; } +printopts() /* print out option default values */ +{ + printf("m=%-15s\t\t# material name\n", thisillum.matname); + printf("f=%-15s\t\t# data file name\n", thisillum.datafile); + if (thisillum.flags & IL_COLAVG) + if (thisillum.flags & IL_COLDST) + printf("c=d\t\t\t\t# color distribution\n"); + else + printf("c=a\t\t\t\t# color average\n"); + else + printf("c=n\t\t\t\t# color none\n"); + if (thisillum.flags & IL_LIGHT) + printf("l+\t\t\t\t# light type on\n"); + else + printf("l-\t\t\t\t# light type off\n"); + printf("d=%d\t\t\t\t# density of points\n", thisillum.sampdens); + printf("s=%d\t\t\t\t# samples per point\n", thisillum.nsamps); + printf("b=%f\t\t\t# minimum average brightness\n", thisillum.minbrt); +} + + printhead(ac, av) /* print out header */ register int ac; register char **av; @@ -367,7 +427,7 @@ register char **av; putchar(' '); fputs(*av++, stdout); } - putchar('\n'); + fputs("\n#@mkillum !\n", stdout); }
