Reversed order of rtrace close processes, apparently to no effect
Eliminated copystruct() macro, which is unnecessary in ANSI. Reduced ambiguity warnings for nested if/if/else clauses.
Abstracted process and path handling for Windows. Renamed FLOAT to RREAL because of conflict on Windows. Added conditional compiles for some signal handlers.
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
fixed bug in skipping s=%d option faults where integer is missing
fixed bug in f= and other space-terminated null specifications
increased size of urand() table
fixed detection of -w+, etc.
changed -di+ to -dv-
slight change to rtrace option
improved checking for octree argument
made defaults reporting more complete
reset errno at appropriate points
fixed distribution pattern discontinuity
fixed format of defaults printing
small changes in default data file name
added variable settings to -defaults printing
changed default sample density
test debugging
visual debugging pass
first version of mkillum
*** empty log message ***
added input file capability
