| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: mkillum.c,v 2.20 2004/09/17 21:43:50 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Make illum sources for optimizing rendering process
| 6 |
| 7 |
| 8 |
#include <signal.h>
| 9 |
#include <ctype.h>
| 10 |
| 11 |
#include "platform.h"
| 12 |
#include "mkillum.h"
| 13 |
#include "random.h"
| 14 |
| 15 |
/* default parameters */
| 16 |
#define SAMPDENS 48 /* points per projected steradian */
| 17 |
#define NSAMPS 32 /* samples per point */
| 18 |
#define DFLMAT "illum_mat" /* material name */
| 19 |
#define DFLDAT "illum" /* data file name */
| 20 |
/* selection options */
| 21 |
#define S_NONE 0 /* select none */
| 22 |
#define S_ELEM 1 /* select specified element */
| 23 |
#define S_COMPL 2 /* select all but element */
| 24 |
#define S_ALL 3 /* select all */
| 25 |
| 26 |
/* rtrace command and defaults */
| 27 |
char *rtargv[64] = { "rtrace", "-dj", ".25", "-dr", "3", "-dv-",
| 28 |
"-ab", "2", "-ad", "1024", "-as", "512", "-aa", ".1", };
| 29 |
int rtargc = 14;
| 30 |
/* overriding rtrace options */
| 31 |
char *myrtopts[] = { "-I-", "-i-", "-ld-", "-ov", "-h-",
| 32 |
"-fff", "-y", "0", NULL };
| 33 |
| 34 |
struct rtproc rt0; /* head of rtrace process list */
| 35 |
| 36 |
struct illum_args thisillum = { /* our illum and default values */
| 37 |
0,
| 38 |
DFLMAT,
| 39 |
DFLDAT,
| 40 |
0,
| 41 |
VOIDID,
| 42 |
SAMPDENS,
| 43 |
NSAMPS,
| 44 |
0.,
| 45 |
| 46 |
| 47 |
char matcheck[MAXSTR]; /* current material to include or exclude */
| 48 |
int matselect = S_ALL; /* selection criterion */
| 49 |
| 50 |
FUN ofun[NUMOTYPE] = INIT_OTYPE; /* object types */
| 51 |
| 52 |
char persistfn[] = "pfXXXXXX"; /* persist file name */
| 53 |
| 54 |
int gargc; /* global argc */
| 55 |
char **gargv; /* global argv */
| 56 |
#define progname gargv[0]
| 57 |
| 58 |
int doneheader = 0; /* printed header yet? */
| 59 |
#define checkhead() if (!doneheader++) printhead(gargc,gargv)
| 60 |
| 61 |
int warnings = 1; /* print warnings? */
| 62 |
| 63 |
void init(int np);
| 64 |
void filter(register FILE *infp, char *name);
| 65 |
void xoptions(char *s, char *nm);
| 66 |
void printopts(void);
| 67 |
void printhead(register int ac, register char **av);
| 68 |
void xobject(FILE *fp, char *nm);
| 69 |
| 70 |
| 71 |
int
| 72 |
main( /* compute illum distributions using rtrace */
| 73 |
int argc,
| 74 |
char *argv[]
| 75 |
| 76 |
| 77 |
int nprocs = 1;
| 78 |
char *rtpath;
| 79 |
FILE *fp;
| 80 |
register int i;
| 81 |
/* set global arguments */
| 82 |
gargv = argv;
| 83 |
/* check for -n option */
| 84 |
if (!strcmp(argv[1], "-n")) {
| 85 |
nprocs = atoi(argv[2]);
| 86 |
if (nprocs <= 0)
| 87 |
error(USER, "illegal number of processes");
| 88 |
i = 3;
| 89 |
} else
| 90 |
i = 1;
| 91 |
/* set up rtrace command */
| 92 |
for ( ; i < argc; i++) {
| 93 |
if (argv[i][0] == '<' && argv[i][1] == '\0')
| 94 |
break;
| 95 |
rtargv[rtargc++] = argv[i];
| 96 |
if (argv[i][0] == '-' && argv[i][1] == 'w')
| 97 |
switch (argv[i][2]) {
| 98 |
case '\0':
| 99 |
warnings = !warnings;
| 100 |
break;
| 101 |
case '+':
| 102 |
case 'T': case 't':
| 103 |
case 'Y': case 'y':
| 104 |
case '1':
| 105 |
warnings = 1;
| 106 |
break;
| 107 |
case '-':
| 108 |
case 'F': case 'f':
| 109 |
case 'N': case 'n':
| 110 |
case '0':
| 111 |
warnings = 0;
| 112 |
break;
| 113 |
| 114 |
| 115 |
gargc = i;
| 116 |
if (!strcmp(rtargv[--rtargc], "-defaults"))
| 117 |
nprocs = 0;
| 118 |
if (nprocs > 1) { /* add persist file if parallel invocation */
| 119 |
rtargv[rtargc++] = "-PP";
| 120 |
rtargv[rtargc++] = mktemp(persistfn);
| 121 |
| 122 |
/* add "mandatory" rtrace options */
| 123 |
for (i = 0; myrtopts[i] != NULL; i++)
| 124 |
rtargv[rtargc++] = myrtopts[i];
| 125 |
/* finally, put back final argument */
| 126 |
rtargv[rtargc++] = argv[gargc-1];
| 127 |
rtargv[rtargc] = NULL;
| 128 |
if (!nprocs) { /* just asking for defaults? */
| 129 |
printopts(); fflush(stdout);
| 130 |
rtpath = getpath(rtargv[0], getenv("PATH"), X_OK);
| 131 |
if (rtpath == NULL) {
| 132 |
eputs(rtargv[0]);
| 133 |
eputs(": command not found\n");
| 134 |
exit(1);
| 135 |
| 136 |
execv(rtpath, rtargv);
| 137 |
perror(rtpath); /* execv() should not return */
| 138 |
exit(1);
| 139 |
| 140 |
if (gargc < 2 || argv[gargc-1][0] == '-')
| 141 |
error(USER, "missing octree argument");
| 142 |
/* else initialize and run our calculation */
| 143 |
init(nprocs);
| 144 |
if (gargc+1 < argc)
| 145 |
for (i = gargc+1; i < argc; i++) {
| 146 |
if ((fp = fopen(argv[i], "r")) == NULL) {
| 147 |
sprintf(errmsg,
| 148 |
"cannot open scene file \"%s\"", argv[i]);
| 149 |
error(SYSTEM, errmsg);
| 150 |
| 151 |
filter(fp, argv[i]);
| 152 |
fclose(fp);
| 153 |
| 154 |
else
| 155 |
filter(stdin, "standard input");
| 156 |
quit(0);
| 157 |
| 158 |
| 159 |
static void
| 160 |
killpersist(void) /* kill persistent rtrace process */
| 161 |
| 162 |
FILE *fp = fopen(persistfn, "r");
| 163 |
int pid;
| 164 |
| 165 |
if (fp == NULL)
| 166 |
return;
| 167 |
if (fscanf(fp, "%*s %d", &pid) != 1 || kill(pid, SIGALRM) < 0)
| 168 |
unlink(persistfn);
| 169 |
fclose(fp);
| 170 |
| 171 |
| 172 |
void
| 173 |
quit(int status) /* exit with status */
| 174 |
| 175 |
struct rtproc *rtp;
| 176 |
int rtstat;
| 177 |
| 178 |
if (rt0.next != NULL) /* terminate persistent rtrace */
| 179 |
killpersist();
| 180 |
/* clean up rtrace process(es) */
| 181 |
for (rtp = &rt0; rtp != NULL; rtp = rtp->next) {
| 182 |
rtstat = close_process(&rtp->pd);
| 183 |
if (status == 0) {
| 184 |
if (rtstat < 0)
| 185 |
error(WARNING,
| 186 |
"unknown return status from rtrace process");
| 187 |
else
| 188 |
status = rtstat;
| 189 |
| 190 |
| 191 |
exit(status);
| 192 |
| 193 |
| 194 |
void
| 195 |
init(int np) /* start rtrace and set up buffers */
| 196 |
| 197 |
struct rtproc *rtp;
| 198 |
int i;
| 199 |
int maxbytes;
| 200 |
/* set up object functions */
| 201 |
ofun[OBJ_FACE].funp = o_face;
| 202 |
ofun[OBJ_SPHERE].funp = o_sphere;
| 203 |
ofun[OBJ_RING].funp = o_ring;
| 204 |
/* set up signal handling */
| 205 |
#ifdef SIGPIPE /* not present on Windows */
| 206 |
signal(SIGPIPE, quit);
| 207 |
#endif
| 208 |
rtp = &rt0; /* start rtrace process(es) */
| 209 |
for (i = 0; i++ < np; ) {
| 210 |
errno = 0;
| 211 |
maxbytes = open_process(&rtp->pd, rtargv);
| 212 |
if (maxbytes == 0) {
| 213 |
eputs(rtargv[0]);
| 214 |
| 215 |
exit(1);
| 216 |
| 217 |
if (maxbytes < 0)
| 218 |
error(SYSTEM, "cannot start rtrace process");
| 219 |
if (!i && np > 1)
| 220 |
sleep(2); /* wait for persist file */
| 221 |
rtp->bsiz = maxbytes/(6*sizeof(float));
| 222 |
rtp->buf = (float *)malloc(6*sizeof(float)*rtp->bsiz--);
| 223 |
rtp->dest = (float **)calloc(rtp->bsiz, sizeof(float *));
| 224 |
if (rtp->buf == NULL || rtp->dest == NULL)
| 225 |
error(SYSTEM, "out of memory in init");
| 226 |
rtp->nrays = 0;
| 227 |
if (i == np) /* last process? */
| 228 |
break;
| 229 |
rtp->next = (struct rtproc *)malloc(sizeof(struct rtproc));
| 230 |
if (rtp->next == NULL)
| 231 |
| 232 |
rtp = rtp->next;
| 233 |
| 234 |
rtp->next = NULL;
| 235 |
/* set up urand */
| 236 |
initurand(16384);
| 237 |
| 238 |
| 239 |
| 240 |
void
| 241 |
eputs( /* put string to stderr */
| 242 |
register char *s
| 243 |
| 244 |
| 245 |
static int midline = 0;
| 246 |
| 247 |
if (!*s) return;
| 248 |
if (!midline) {
| 249 |
fputs(progname, stderr);
| 250 |
fputs(": ", stderr);
| 251 |
| 252 |
fputs(s, stderr);
| 253 |
midline = s[strlen(s)-1] != '\n';
| 254 |
| 255 |
| 256 |
| 257 |
void
| 258 |
wputs(s) /* print warning if enabled */
| 259 |
char *s;
| 260 |
| 261 |
if (warnings)
| 262 |
eputs(s);
| 263 |
| 264 |
| 265 |
| 266 |
void
| 267 |
filter( /* process stream */
| 268 |
| 269 |
char *name
| 270 |
| 271 |
| 272 |
char buf[512];
| 273 |
FILE *pfp;
| 274 |
register int c;
| 275 |
| 276 |
while ((c = getc(infp)) != EOF) {
| 277 |
if (isspace(c))
| 278 |
continue;
| 279 |
if (c == '#') { /* comment/options */
| 280 |
buf[0] = c;
| 281 |
fgets(buf+1, sizeof(buf)-1, infp);
| 282 |
xoptions(buf, name);
| 283 |
} else if (c == '!') { /* command */
| 284 |
buf[0] = c;
| 285 |
fgetline(buf+1, sizeof(buf)-1, infp);
| 286 |
if ((pfp = popen(buf+1, "r")) == NULL) {
| 287 |
sprintf(errmsg, "cannot execute \"%s\"", buf);
| 288 |
| 289 |
| 290 |
filter(pfp, buf);
| 291 |
pclose(pfp);
| 292 |
} else { /* object */
| 293 |
ungetc(c, infp);
| 294 |
xobject(infp, name);
| 295 |
| 296 |
| 297 |
| 298 |
| 299 |
| 300 |
void
| 301 |
xoptions( /* process options in string s */
| 302 |
char *s,
| 303 |
char *nm
| 304 |
| 305 |
| 306 |
extern FILE *freopen();
| 307 |
char buf[64];
| 308 |
int nerrs = 0;
| 309 |
register char *cp;
| 310 |
| 311 |
if (strncmp(s, "#@mkillum", 9) || !isspace(s[9])) {
| 312 |
fputs(s, stdout); /* not for us */
| 313 |
return;
| 314 |
| 315 |
cp = s+10;
| 316 |
while (*cp) {
| 317 |
switch (*cp) {
| 318 |
case ' ':
| 319 |
case '\t':
| 320 |
case '\n':
| 321 |
case '\r':
| 322 |
case '\f':
| 323 |
cp++;
| 324 |
continue;
| 325 |
case 'm': /* material name */
| 326 |
if (*++cp != '=')
| 327 |
break;
| 328 |
if (!*++cp || isspace(*cp))
| 329 |
break;
| 330 |
atos(thisillum.matname, MAXSTR, cp);
| 331 |
cp = sskip(cp);
| 332 |
if (!(thisillum.flags & IL_DATCLB)) {
| 333 |
strcpy(thisillum.datafile, thisillum.matname);
| 334 |
thisillum.dfnum = 0;
| 335 |
| 336 |
continue;
| 337 |
case 'f': /* data file name */
| 338 |
if (*++cp != '=')
| 339 |
break;
| 340 |
if (!*++cp || isspace(*cp)) {
| 341 |
strcpy(thisillum.datafile,thisillum.matname);
| 342 |
| 343 |
thisillum.flags &= ~IL_DATCLB;
| 344 |
continue;
| 345 |
| 346 |
atos(thisillum.datafile, MAXSTR, cp);
| 347 |
cp = sskip(cp);
| 348 |
| 349 |
thisillum.flags |= IL_DATCLB;
| 350 |
continue;
| 351 |
case 'i': /* include material */
| 352 |
case 'e': /* exclude material */
| 353 |
if (cp[1] != '=')
| 354 |
break;
| 355 |
matselect = (*cp == 'i') ? S_ELEM : S_COMPL;
| 356 |
cp += 2;
| 357 |
atos(matcheck, MAXSTR, cp);
| 358 |
cp = sskip(cp);
| 359 |
continue;
| 360 |
case 'a': /* use everything */
| 361 |
cp = sskip(cp);
| 362 |
matselect = S_ALL;
| 363 |
continue;
| 364 |
case 'n': /* use nothing (passive) */
| 365 |
cp = sskip(cp);
| 366 |
matselect = S_NONE;
| 367 |
continue;
| 368 |
case 'c': /* color calculation */
| 369 |
if (*++cp != '=')
| 370 |
break;
| 371 |
switch (*++cp) {
| 372 |
case 'a': /* average */
| 373 |
thisillum.flags = (thisillum.flags|IL_COLAVG)
| 374 |
& ~IL_COLDST;
| 375 |
break;
| 376 |
case 'd': /* distribution */
| 377 |
thisillum.flags |= (IL_COLDST|IL_COLAVG);
| 378 |
break;
| 379 |
case 'n': /* none */
| 380 |
thisillum.flags &= ~(IL_COLAVG|IL_COLDST);
| 381 |
break;
| 382 |
default:
| 383 |
goto opterr;
| 384 |
| 385 |
cp = sskip(cp);
| 386 |
continue;
| 387 |
case 'd': /* point sample density */
| 388 |
if (*++cp != '=')
| 389 |
break;
| 390 |
if (!isintd(++cp, " \t\n\r"))
| 391 |
break;
| 392 |
thisillum.sampdens = atoi(cp);
| 393 |
cp = sskip(cp);
| 394 |
continue;
| 395 |
case 's': /* point super-samples */
| 396 |
if (*++cp != '=')
| 397 |
break;
| 398 |
| 399 |
break;
| 400 |
thisillum.nsamps = atoi(cp);
| 401 |
cp = sskip(cp);
| 402 |
continue;
| 403 |
case 'l': /* light sources */
| 404 |
cp++;
| 405 |
if (*cp == '+')
| 406 |
thisillum.flags |= IL_LIGHT;
| 407 |
else if (*cp == '-')
| 408 |
thisillum.flags &= ~IL_LIGHT;
| 409 |
else
| 410 |
break;
| 411 |
cp++;
| 412 |
continue;
| 413 |
case 'b': /* brightness */
| 414 |
if (*++cp != '=')
| 415 |
break;
| 416 |
if (!isfltd(++cp, " \t\n\r"))
| 417 |
break;
| 418 |
thisillum.minbrt = atof(cp);
| 419 |
if (thisillum.minbrt < 0.)
| 420 |
thisillum.minbrt = 0.;
| 421 |
cp = sskip(cp);
| 422 |
continue;
| 423 |
case 'o': /* output file */
| 424 |
if (*++cp != '=')
| 425 |
break;
| 426 |
| 427 |
break;
| 428 |
atos(buf, sizeof(buf), cp);
| 429 |
cp = sskip(cp);
| 430 |
if (freopen(buf, "w", stdout) == NULL) {
| 431 |
sprintf(errmsg,
| 432 |
"cannot open output file \"%s\"", buf);
| 433 |
| 434 |
| 435 |
doneheader = 0;
| 436 |
continue;
| 437 |
case '!': /* processed file! */
| 438 |
sprintf(errmsg, "(%s): already processed!", nm);
| 439 |
error(WARNING, errmsg);
| 440 |
matselect = S_NONE;
| 441 |
return;
| 442 |
| 443 |
opterr: /* skip faulty option */
| 444 |
while (*cp && !isspace(*cp))
| 445 |
cp++;
| 446 |
nerrs++;
| 447 |
| 448 |
/* print header? */
| 449 |
checkhead();
| 450 |
/* issue warnings? */
| 451 |
if (nerrs) {
| 452 |
sprintf(errmsg, "(%s): %d error(s) in option line:",
| 453 |
nm, nerrs);
| 454 |
| 455 |
wputs(s);
| 456 |
printf("# %s: the following option line has %d error(s):\n",
| 457 |
progname, nerrs);
| 458 |
| 459 |
/* print pure comment */
| 460 |
printf("# %s", s+2);
| 461 |
| 462 |
| 463 |
void
| 464 |
printopts(void) /* print out option default values */
| 465 |
| 466 |
printf("m=%-15s\t\t# material name\n", thisillum.matname);
| 467 |
printf("f=%-15s\t\t# data file name\n", thisillum.datafile);
| 468 |
if (thisillum.flags & IL_COLAVG)
| 469 |
if (thisillum.flags & IL_COLDST)
| 470 |
printf("c=d\t\t\t\t# color distribution\n");
| 471 |
else
| 472 |
printf("c=a\t\t\t\t# color average\n");
| 473 |
else
| 474 |
printf("c=n\t\t\t\t# color none\n");
| 475 |
if (thisillum.flags & IL_LIGHT)
| 476 |
printf("l+\t\t\t\t# light type on\n");
| 477 |
else
| 478 |
printf("l-\t\t\t\t# light type off\n");
| 479 |
printf("d=%d\t\t\t\t# density of points\n", thisillum.sampdens);
| 480 |
printf("s=%d\t\t\t\t# samples per point\n", thisillum.nsamps);
| 481 |
printf("b=%f\t\t\t# minimum average brightness\n", thisillum.minbrt);
| 482 |
| 483 |
| 484 |
| 485 |
void
| 486 |
printhead( /* print out header */
| 487 |
register int ac,
| 488 |
register char **av
| 489 |
| 490 |
| 491 |
putchar('#');
| 492 |
while (ac-- > 0) {
| 493 |
putchar(' ');
| 494 |
fputs(*av++, stdout);
| 495 |
| 496 |
fputs("\n#@mkillum !\n", stdout);
| 497 |
| 498 |
| 499 |
| 500 |
void
| 501 |
xobject( /* translate an object from fp */
| 502 |
FILE *fp,
| 503 |
char *nm
| 504 |
| 505 |
| 506 |
OBJREC thisobj;
| 507 |
char str[MAXSTR];
| 508 |
int doit;
| 509 |
/* read the object */
| 510 |
if (fgetword(thisillum.altmat, MAXSTR, fp) == NULL)
| 511 |
goto readerr;
| 512 |
if (fgetword(str, MAXSTR, fp) == NULL)
| 513 |
goto readerr;
| 514 |
/* is it an alias? */
| 515 |
if (!strcmp(str, ALIASKEY)) {
| 516 |
| 517 |
goto readerr;
| 518 |
printf("\n%s %s %s", thisillum.altmat, ALIASKEY, str);
| 519 |
| 520 |
goto readerr;
| 521 |
printf("\t%s\n", str);
| 522 |
return;
| 523 |
| 524 |
thisobj.omod = OVOID; /* unused field */
| 525 |
if ((thisobj.otype = otype(str)) < 0) {
| 526 |
sprintf(errmsg, "(%s): unknown type \"%s\"", nm, str);
| 527 |
error(USER, errmsg);
| 528 |
| 529 |
| 530 |
goto readerr;
| 531 |
thisobj.oname = str;
| 532 |
if (readfargs(&thisobj.oargs, fp) != 1)
| 533 |
goto readerr;
| 534 |
thisobj.os = NULL;
| 535 |
/* check for translation */
| 536 |
switch (matselect) {
| 537 |
case S_NONE:
| 538 |
doit = 0;
| 539 |
break;
| 540 |
case S_ALL:
| 541 |
doit = 1;
| 542 |
break;
| 543 |
case S_ELEM:
| 544 |
doit = !strcmp(thisillum.altmat, matcheck);
| 545 |
break;
| 546 |
case S_COMPL:
| 547 |
doit = strcmp(thisillum.altmat, matcheck);
| 548 |
break;
| 549 |
| 550 |
doit = doit && issurface(thisobj.otype);
| 551 |
/* print header? */
| 552 |
checkhead();
| 553 |
/* process object */
| 554 |
if (doit)
| 555 |
(*ofun[thisobj.otype].funp)(&thisobj, &thisillum, &rt0, nm);
| 556 |
else
| 557 |
printobj(thisillum.altmat, &thisobj);
| 558 |
/* free arguments */
| 559 |
freefargs(&thisobj.oargs);
| 560 |
return;
| 561 |
readerr:
| 562 |
sprintf(errmsg, "(%s): error reading scene", nm);
| 563 |
| 564 |
