root/radiance/ray/src/gen/mkillum.c
Revision: 2.3
Committed: Wed Mar 25 10:55:03 1992 UTC (32 years, 3 months ago) by greg
improved checking for octree argument
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Make illum sources for optimizing rendering process
9 */
10
11 #include "mkillum.h"
12
13 #include <signal.h>
14
15 #include <ctype.h>
16
17 /* default parameters */
18 #define SAMPDENS 48 /* points per projected steradian */
19 #define NSAMPS 32 /* samples per point */
20 #define DFLMAT "illum_mat" /* material name */
21 #define DFLDAT "illum" /* data file name */
22 /* selection options */
23 #define S_NONE 0 /* select none */
24 #define S_ELEM 1 /* select specified element */
25 #define S_COMPL 2 /* select all but element */
26 #define S_ALL 3 /* select all */
27
28 /* rtrace command and defaults */
29 char *rtargv[64] = { "rtrace", "-dj", ".25", "-dr", "3", "-di+",
30 "-ab", "2", "-ad", "256", "-as", "128", "-aa", ".15", };
31 int rtargc = 14;
32 /* overriding rtrace options */
33 char *myrtopts[] = { "-I-", "-i-", "-ov", "-h-", "-fff", NULL };
34
35 struct rtproc rt; /* our rtrace process */
36
37 struct illum_args thisillum = { /* our illum and default values */
38 0,
39 DFLMAT,
40 DFLDAT,
41 0,
42 VOIDID,
43 SAMPDENS,
44 NSAMPS,
45 0.,
46 };
47
48 char matcheck[MAXSTR]; /* current material to include or exclude */
49 int matselect = S_ALL; /* selection criterion */
50
51 FUN ofun[NUMOTYPE] = INIT_OTYPE; /* object types */
52
53 int gargc; /* global argc */
54 char **gargv; /* global argv */
55 #define progname gargv[0]
56
57 int doneheader = 0; /* printed header yet? */
58 #define checkhead() if (!doneheader++) printhead(gargc,gargv)
59
60 int warnings = 1; /* print warnings? */
61
62 extern char *fgetline(), *fgetword(), *sskip(),
63 *atos(), *iskip(), *fskip(), *strcpy();
64 extern FILE *popen();
65
66
67 main(argc, argv) /* compute illum distributions using rtrace */
68 int argc;
69 char *argv[];
70 {
71 extern char *getenv(), *getpath();
72 char *rtpath;
73 FILE *fp;
74 register int i;
75 /* set global arguments */
76 gargv = argv;
77 /* set up rtrace command */
78 for (i = 1; i < argc; i++) {
79 if (argv[i][0] == '<' && !argv[i][1])
80 break;
81 rtargv[rtargc++] = argv[i];
82 if (argv[i][0] == '-' && argv[i][1] == 'w')
83 warnings = !warnings;
84 }
85 gargc = i;
86 rtargc--;
87 for (i = 0; myrtopts[i] != NULL; i++)
88 rtargv[rtargc++] = myrtopts[i];
89 rtargv[rtargc++] = argv[gargc-1];
90 rtargv[rtargc] = NULL;
91 /* just asking for defaults? */
92 if (!strcmp(argv[gargc-1], "-defaults")) {
93 printopts(); fflush(stdout);
94 rtpath = getpath(rtargv[0], getenv("PATH"), X_OK);
95 if (rtpath == NULL) {
96 eputs(rtargv[0]);
97 eputs(": command not found\n");
98 exit(1);
99 }
100 execv(rtpath, rtargv);
101 perror(rtpath);
102 exit(1);
103 }
104 if (gargc < 2 || argv[gargc-1][0] == '-')
105 error(USER, "missing octree argument");
106 /* else initialize and run our calculation */
107 init();
108 if (gargc+1 < argc)
109 for (i = gargc+1; i < argc; i++) {
110 if ((fp = fopen(argv[i], "r")) == NULL) {
111 sprintf(errmsg,
112 "cannot open scene file \"%s\"", argv[i]);
113 error(SYSTEM, errmsg);
114 }
115 filter(fp, argv[i]);
116 fclose(fp);
117 }
118 else
119 filter(stdin, "standard input");
120 quit(0);
121 }
122
123
124 quit(status) /* exit with status */
125 int status;
126 {
127 int rtstat;
128
129 rtstat = close_process(rt.pd);
130 if (status == 0)
131 if (rtstat < 0)
132 error(WARNING,
133 "unknown return status from rtrace process");
134 else
135 status = rtstat;
136 exit(status);
137 }
138
139
140 init() /* start rtrace and set up buffers */
141 {
142 extern int o_face(), o_sphere(), o_ring();
143 int maxbytes;
144 /* set up object functions */
145 ofun[OBJ_FACE].funp = o_face;
146 ofun[OBJ_SPHERE].funp = o_sphere;
147 ofun[OBJ_RING].funp = o_ring;
148 /* set up signal handling */
149 signal(SIGPIPE, quit);
150 /* start rtrace process */
151 errno = 0;
152 maxbytes = open_process(rt.pd, rtargv);
153 if (maxbytes == 0) {
154 eputs(rtargv[0]);
155 eputs(": command not found\n");
156 exit(1);
157 }
158 if (maxbytes < 0)
159 error(SYSTEM, "cannot start rtrace process");
160 rt.bsiz = maxbytes/(6*sizeof(float));
161 rt.buf = (float *)malloc(6*sizeof(float)*rt.bsiz--);
162 rt.dest = (float **)malloc(sizeof(float *)*rt.bsiz);
163 if (rt.buf == NULL || rt.dest == NULL)
164 error(SYSTEM, "out of memory in init");
165 rt.nrays = 0;
166 /* set up urand */
167 initurand(2048);
168 }
169
170
171 eputs(s) /* put string to stderr */
172 register char *s;
173 {
174 static int midline = 0;
175
176 if (!*s) return;
177 if (!midline) {
178 fputs(progname, stderr);
179 fputs(": ", stderr);
180 }
181 fputs(s, stderr);
182 midline = s[strlen(s)-1] != '\n';
183 }
184
185
186 wputs(s) /* print warning if enabled */
187 char *s;
188 {
189 if (warnings)
190 eputs(s);
191 }
192
193
194 filter(infp, name) /* process stream */
195 register FILE *infp;
196 char *name;
197 {
198 char buf[512];
199 FILE *pfp;
200 register int c;
201
202 while ((c = getc(infp)) != EOF) {
203 if (isspace(c))
204 continue;
205 if (c == '#') { /* comment/options */
206 buf[0] = c;
207 fgets(buf+1, sizeof(buf)-1, infp);
208 xoptions(buf, name);
209 } else if (c == '!') { /* command */
210 buf[0] = c;
211 fgetline(buf+1, sizeof(buf)-1, infp);
212 if ((pfp = popen(buf+1, "r")) == NULL) {
213 sprintf(errmsg, "cannot execute \"%s\"", buf);
214 error(SYSTEM, errmsg);
215 }
216 filter(pfp, buf);
217 pclose(pfp);
218 } else { /* object */
219 ungetc(c, infp);
220 xobject(infp, name);
221 }
222 }
223 }
224
225
226 xoptions(s, nm) /* process options in string s */
227 char *s;
228 char *nm;
229 {
230 extern FILE *freopen();
231 char buf[64];
232 int nerrs = 0;
233 register char *cp;
234
235 if (strncmp(s, "#@mkillum", 9) || !isspace(s[9])) {
236 fputs(s, stdout); /* not for us */
237 return;
238 }
239 cp = s+10;
240 while (*cp) {
241 switch (*cp) {
242 case ' ':
243 case '\t':
244 case '\n':
245 cp++;
246 continue;
247 case 'm': /* material name */
248 if (*++cp != '=')
249 break;
250 if (!*++cp)
251 break;
252 atos(thisillum.matname, MAXSTR, cp);
253 cp = sskip(cp);
254 if (!(thisillum.flags & IL_DATCLB)) {
255 strcpy(thisillum.datafile, thisillum.matname);
256 thisillum.dfnum = 0;
257 }
258 continue;
259 case 'f': /* data file name */
260 if (*++cp != '=')
261 break;
262 if (!*++cp) {
263 strcpy(thisillum.datafile,thisillum.matname);
264 thisillum.dfnum = 0;
265 thisillum.flags &= ~IL_DATCLB;
266 continue;
267 }
268 atos(thisillum.datafile, MAXSTR, cp);
269 cp = sskip(cp);
270 thisillum.dfnum = 0;
271 thisillum.flags |= IL_DATCLB;
272 continue;
273 case 'i': /* include material */
274 case 'e': /* exclude material */
275 if (cp[1] != '=')
276 break;
277 matselect = (*cp == 'i') ? S_ELEM : S_COMPL;
278 cp += 2;
279 atos(matcheck, MAXSTR, cp);
280 cp = sskip(cp);
281 continue;
282 case 'a': /* use everything */
283 cp = sskip(cp);
284 matselect = S_ALL;
285 continue;
286 case 'n': /* use nothing (passive) */
287 cp = sskip(cp);
288 matselect = S_NONE;
289 continue;
290 case 'c': /* color calculation */
291 if (*++cp != '=')
292 break;
293 switch (*++cp) {
294 case 'a': /* average */
295 thisillum.flags = (thisillum.flags|IL_COLAVG)
296 & ~IL_COLDST;
297 break;
298 case 'd': /* distribution */
299 thisillum.flags |= (IL_COLDST|IL_COLAVG);
300 break;
301 case 'n': /* none */
302 thisillum.flags &= ~(IL_COLAVG|IL_COLDST);
303 break;
304 default:
305 goto opterr;
306 }
307 cp = sskip(cp);
308 continue;
309 case 'd': /* point sample density */
310 if (*++cp != '=')
311 break;
312 if (!isintd(++cp, " \t\n"))
313 break;
314 thisillum.sampdens = atoi(cp);
315 cp = sskip(cp);
316 continue;
317 case 's': /* point super-samples */
318 if (*++cp != '=')
319 break;
320 if (!isintd(++cp, " \t\n"))
321 break;
322 thisillum.nsamps = atoi(cp);
323 cp = sskip(cp);
324 continue;
325 case 'l': /* light sources */
326 cp++;
327 if (*cp == '+')
328 thisillum.flags |= IL_LIGHT;
329 else if (*cp == '-')
330 thisillum.flags &= ~IL_LIGHT;
331 else
332 break;
333 cp++;
334 continue;
335 case 'b': /* brightness */
336 if (*++cp != '=')
337 break;
338 if (!isfltd(++cp, " \t\n"))
339 break;
340 thisillum.minbrt = atof(cp);
341 if (thisillum.minbrt < 0.)
342 thisillum.minbrt = 0.;
343 cp = sskip(cp);
344 continue;
345 case 'o': /* output file */
346 if (*++cp != '=')
347 break;
348 if (!*++cp)
349 break;
350 atos(buf, sizeof(buf), cp);
351 cp = sskip(cp);
352 if (freopen(buf, "w", stdout) == NULL) {
353 sprintf(errmsg,
354 "cannot open output file \"%s\"", buf);
355 error(SYSTEM, errmsg);
356 }
357 doneheader = 0;
358 continue;
359 case '!': /* processed file! */
360 sprintf(errmsg, "(%s): already processed!", nm);
361 error(WARNING, errmsg);
362 matselect = S_NONE;
363 return;
364 }
365 opterr: /* skip faulty option */
366 cp = sskip(cp);
367 nerrs++;
368 }
369 /* print header? */
370 checkhead();
371 /* issue warnings? */
372 if (nerrs) {
373 sprintf(errmsg, "(%s): %d error(s) in option line:",
374 nm, nerrs);
375 error(WARNING, errmsg);
376 wputs(s);
377 printf("# %s: the following option line has %d error(s):\n",
378 progname, nerrs);
379 }
380 /* print pure comment */
381 printf("# %s", s+2);
382 }
383
384
385 printopts() /* print out option default values */
386 {
387 printf("m=%-15s\t\t# material name\n", thisillum.matname);
388 printf("f=%-15s\t\t# data file name\n", thisillum.datafile);
389 if (thisillum.flags & IL_COLAVG)
390 if (thisillum.flags & IL_COLDST)
391 printf("c=d\t\t\t\t# color distribution\n");
392 else
393 printf("c=a\t\t\t\t# color average\n");
394 else
395 printf("c=n\t\t\t\t# color none\n");
396 if (thisillum.flags & IL_LIGHT)
397 printf("l+\t\t\t\t# light type on\n");
398 else
399 printf("l-\t\t\t\t# light type off\n");
400 printf("d=%d\t\t\t\t# density of points\n", thisillum.sampdens);
401 printf("s=%d\t\t\t\t# samples per point\n", thisillum.nsamps);
402 printf("b=%f\t\t\t# minimum average brightness\n", thisillum.minbrt);
403 }
404
405
406 printhead(ac, av) /* print out header */
407 register int ac;
408 register char **av;
409 {
410 putchar('#');
411 while (ac-- > 0) {
412 putchar(' ');
413 fputs(*av++, stdout);
414 }
415 fputs("\n#@mkillum !\n", stdout);
416 }
417
418
419 xobject(fp, nm) /* translate an object from fp */
420 FILE *fp;
421 char *nm;
422 {
423 OBJREC thisobj;
424 char str[MAXSTR];
425 int doit;
426 /* read the object */
427 if (fgetword(thisillum.altmat, MAXSTR, fp) == NULL)
428 goto readerr;
429 if (fgetword(str, MAXSTR, fp) == NULL)
430 goto readerr;
431 /* is it an alias? */
432 if (!strcmp(str, ALIASID)) {
433 if (fgetword(str, MAXSTR, fp) == NULL)
434 goto readerr;
435 printf("\n%s %s %s", thisillum.altmat, ALIASID, str);
436 if (fgetword(str, MAXSTR, fp) == NULL)
437 goto readerr;
438 printf("\t%s\n", str);
439 return;
440 }
441 thisobj.omod = OVOID; /* unused field */
442 if ((thisobj.otype = otype(str)) < 0) {
443 sprintf(errmsg, "(%s): unknown type \"%s\"", nm, str);
444 error(USER, errmsg);
445 }
446 if (fgetword(str, MAXSTR, fp) == NULL)
447 goto readerr;
448 thisobj.oname = str;
449 if (readfargs(&thisobj.oargs, fp) != 1)
450 goto readerr;
451 thisobj.os = NULL;
452 /* check for translation */
453 switch (matselect) {
454 case S_NONE:
455 doit = 0;
456 break;
457 case S_ALL:
458 doit = 1;
459 break;
460 case S_ELEM:
461 doit = !strcmp(thisillum.altmat, matcheck);
462 break;
463 case S_COMPL:
464 doit = strcmp(thisillum.altmat, matcheck);
465 break;
466 }
467 doit = doit && issurface(thisobj.otype);
468 /* print header? */
469 checkhead();
470 /* process object */
471 if (doit)
472 (*ofun[thisobj.otype].funp)(&thisobj, &thisillum, &rt, nm);
473 else
474 printobj(thisillum.altmat, &thisobj);
475 /* free arguments */
476 freefargs(&thisobj.oargs);
477 return;
478 readerr:
479 sprintf(errmsg, "(%s): error reading scene", nm);
480 error(USER, errmsg);
481 }
