1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: mkillum.c,v 2.38 2011/10/05 17:20:55 greg Exp $"; |
3 |
#endif |
4 |
5 |
* Make illum sources for optimizing rendering process |
6 |
7 |
8 |
#include <signal.h> |
9 |
#include <ctype.h> |
10 |
11 |
#include "rtprocess.h" /* win_popen() */ |
12 |
#include "mkillum.h" |
13 |
14 |
/* default parameters */ |
15 |
#define SAMPDENS 48 /* points per projected steradian */ |
16 |
#define NSAMPS 32 /* samples per point */ |
17 |
#define DFLMAT "illum_mat" /* material name */ |
18 |
#define DFLDAT "illum" /* data file name */ |
19 |
/* selection options */ |
20 |
#define S_NONE 0 /* select none */ |
21 |
#define S_ELEM 1 /* select specified element */ |
22 |
#define S_COMPL 2 /* select all but element */ |
23 |
#define S_ALL 3 /* select all */ |
24 |
25 |
struct illum_args thisillum = { /* our illum and default values */ |
26 |
0, |
27 |
0., |
28 |
DFLMAT, |
29 |
DFLDAT, |
30 |
0, |
31 |
VOIDID, |
32 |
SAMPDENS, |
33 |
NSAMPS, |
34 |
0., |
35 |
36 |
37 |
char matcheck[MAXSTR]; /* current material to include or exclude */ |
38 |
int matselect = S_ALL; /* selection criterion */ |
39 |
40 |
int gargc; /* global argc */ |
41 |
char **gargv; /* global argv */ |
42 |
43 |
int doneheader = 0; /* printed header yet? */ |
44 |
#define checkhead() if (!doneheader++) printhead(gargc,gargv) |
45 |
46 |
int warnings = 1; /* print warnings? */ |
47 |
48 |
void init(char *octnm, int np); |
49 |
void filter(register FILE *infp, char *name); |
50 |
void xoptions(char *s, char *nm); |
51 |
void printopts(void); |
52 |
void printhead(register int ac, register char **av); |
53 |
void xobject(FILE *fp, char *nm); |
54 |
55 |
56 |
int |
57 |
main( /* compute illum distributions using rtrace */ |
58 |
int argc, |
59 |
char *argv[] |
60 |
61 |
62 |
int nprocs = 1; |
63 |
FILE *fp; |
64 |
int rval; |
65 |
register int i; |
66 |
/* set global arguments */ |
67 |
gargv = argv; |
68 |
progname = gargv[0]; |
69 |
/* set up rendering defaults */ |
70 |
dstrsrc = 0.5; |
71 |
directrelay = 3; |
72 |
ambounce = 2; |
73 |
/* get options from command line */ |
74 |
for (i = 1; i < argc; i++) { |
75 |
while ((rval = expandarg(&argc, &argv, i)) > 0) |
76 |
77 |
if (rval < 0) { |
78 |
sprintf(errmsg, "cannot expand '%s'", argv[i]); |
79 |
error(SYSTEM, errmsg); |
80 |
81 |
if (argv[i][0] != '-') |
82 |
break; |
83 |
if (!strcmp(argv[i], "-w")) { |
84 |
warnings = 0; |
85 |
continue; |
86 |
87 |
if (!strcmp(argv[i], "-n")) { |
88 |
nprocs = atoi(argv[++i]); |
89 |
if (nprocs <= 0) |
90 |
error(USER, "illegal number of processes"); |
91 |
continue; |
92 |
93 |
if (!strcmp(argv[i], "-defaults")) { |
94 |
printopts(); |
95 |
print_rdefaults(); |
96 |
quit(0); |
97 |
98 |
rval = getrenderopt(argc-i, argv+i); |
99 |
if (rval < 0) { |
100 |
sprintf(errmsg, "bad render option at '%s'", argv[i]); |
101 |
error(USER, errmsg); |
102 |
103 |
i += rval; |
104 |
105 |
gargc = ++i; |
106 |
/* add "mandatory" render options */ |
107 |
do_irrad = 0; |
108 |
if (gargc > argc || argv[gargc-1][0] == '-') |
109 |
error(USER, "missing octree argument"); |
110 |
/* else initialize and run our calculation */ |
111 |
init(argv[gargc-1], nprocs); |
112 |
if (gargc < argc) { |
113 |
if (gargc == argc-1 || argv[gargc][0] != '<' || argv[gargc][1]) |
114 |
error(USER, "use '< file1 file2 ..' for multiple inputs"); |
115 |
for (i = gargc+1; i < argc; i++) { |
116 |
if ((fp = fopen(argv[i], "r")) == NULL) { |
117 |
sprintf(errmsg, |
118 |
"cannot open scene file \"%s\"", argv[i]); |
119 |
120 |
121 |
filter(fp, argv[i]); |
122 |
fclose(fp); |
123 |
124 |
} else |
125 |
filter(stdin, "standard input"); |
126 |
quit(0); |
127 |
return 0; /* pro forma return */ |
128 |
129 |
130 |
131 |
void |
132 |
init(char *octnm, int np) /* start rendering process(es) */ |
133 |
134 |
/* set up signal handling */ |
135 |
signal(SIGINT, quit); |
136 |
#ifdef SIGHUP |
137 |
signal(SIGHUP, quit); |
138 |
#endif |
139 |
#ifdef SIGTERM |
140 |
signal(SIGTERM, quit); |
141 |
#endif |
142 |
#ifdef SIGPIPE |
143 |
signal(SIGPIPE, quit); |
144 |
#endif |
145 |
146 |
ray_pinit(octnm, np); |
147 |
148 |
149 |
150 |
void |
151 |
eputs( /* put string to stderr */ |
152 |
register char *s |
153 |
154 |
155 |
static int midline = 0; |
156 |
157 |
if (!*s) return; |
158 |
if (!midline) { |
159 |
fputs(progname, stderr); |
160 |
fputs(": ", stderr); |
161 |
162 |
fputs(s, stderr); |
163 |
midline = s[strlen(s)-1] != '\n'; |
164 |
165 |
166 |
167 |
void |
168 |
wputs(s) /* print warning if enabled */ |
169 |
char *s; |
170 |
171 |
if (warnings) |
172 |
eputs(s); |
173 |
174 |
175 |
176 |
void |
177 |
quit(ec) /* make sure exit is called */ |
178 |
int ec; |
179 |
180 |
if (ray_pnprocs > 0) /* close children if any */ |
181 |
ray_pclose(0); |
182 |
exit(ec); |
183 |
184 |
185 |
186 |
void |
187 |
filter( /* process stream */ |
188 |
register FILE *infp, |
189 |
char *name |
190 |
191 |
192 |
char buf[512]; |
193 |
FILE *pfp; |
194 |
register int c; |
195 |
196 |
while ((c = getc(infp)) != EOF) { |
197 |
if (isspace(c)) |
198 |
continue; |
199 |
if (c == '#') { /* comment/options */ |
200 |
buf[0] = c; |
201 |
fgets(buf+1, sizeof(buf)-1, infp); |
202 |
xoptions(buf, name); |
203 |
} else if (c == '!') { /* command */ |
204 |
buf[0] = c; |
205 |
fgetline(buf+1, sizeof(buf)-1, infp); |
206 |
if ((pfp = popen(buf+1, "r")) == NULL) { |
207 |
sprintf(errmsg, "cannot execute \"%s\"", buf); |
208 |
209 |
210 |
filter(pfp, buf); |
211 |
pclose(pfp); |
212 |
} else { /* object */ |
213 |
ungetc(c, infp); |
214 |
xobject(infp, name); |
215 |
216 |
217 |
218 |
219 |
220 |
void |
221 |
xoptions( /* process options in string s */ |
222 |
char *s, |
223 |
char *nm |
224 |
225 |
226 |
extern FILE *freopen(); |
227 |
char buf[64]; |
228 |
int negax; |
229 |
int nerrs = 0; |
230 |
register char *cp; |
231 |
232 |
if (strncmp(s, "#@mkillum", 9) || !isspace(s[9])) { |
233 |
fputs(s, stdout); /* not for us */ |
234 |
return; |
235 |
236 |
cp = s+10; |
237 |
while (*cp) { |
238 |
switch (*cp) { |
239 |
case ' ': |
240 |
case '\t': |
241 |
case '\n': |
242 |
case '\r': |
243 |
case '\f': |
244 |
cp++; |
245 |
continue; |
246 |
case 'm': /* material name */ |
247 |
if (*++cp != '=') |
248 |
break; |
249 |
if (!*++cp || isspace(*cp)) |
250 |
break; |
251 |
atos(thisillum.matname, MAXSTR, cp); |
252 |
cp = sskip(cp); |
253 |
if (!(thisillum.flags & IL_DATCLB)) { |
254 |
strcpy(thisillum.datafile, thisillum.matname); |
255 |
thisillum.dfnum = 0; |
256 |
257 |
continue; |
258 |
case 'f': /* data file name */ |
259 |
if (*++cp != '=') |
260 |
break; |
261 |
if (!*++cp || isspace(*cp)) { |
262 |
strcpy(thisillum.datafile,thisillum.matname); |
263 |
264 |
thisillum.flags &= ~IL_DATCLB; |
265 |
continue; |
266 |
267 |
atos(thisillum.datafile, MAXSTR, cp); |
268 |
cp = sskip(cp); |
269 |
270 |
thisillum.flags |= IL_DATCLB; |
271 |
continue; |
272 |
case 'i': /* include material */ |
273 |
case 'e': /* exclude material */ |
274 |
if (cp[1] != '=') |
275 |
break; |
276 |
matselect = (*cp == 'i') ? S_ELEM : S_COMPL; |
277 |
cp += 2; |
278 |
atos(matcheck, MAXSTR, cp); |
279 |
cp = sskip(cp); |
280 |
continue; |
281 |
case 'a': /* use everything */ |
282 |
cp = sskip(cp); |
283 |
matselect = S_ALL; |
284 |
continue; |
285 |
case 'n': /* use nothing (passive) */ |
286 |
cp = sskip(cp); |
287 |
matselect = S_NONE; |
288 |
continue; |
289 |
case 'c': /* color calculation */ |
290 |
if (*++cp != '=') |
291 |
break; |
292 |
switch (*++cp) { |
293 |
case 'a': /* average */ |
294 |
thisillum.flags = (thisillum.flags|IL_COLAVG) |
295 |
& ~IL_COLDST; |
296 |
break; |
297 |
case 'd': /* distribution */ |
298 |
thisillum.flags |= (IL_COLDST|IL_COLAVG); |
299 |
break; |
300 |
case 'n': /* none */ |
301 |
thisillum.flags &= ~(IL_COLAVG|IL_COLDST); |
302 |
break; |
303 |
default: |
304 |
goto opterr; |
305 |
306 |
cp = sskip(cp); |
307 |
continue; |
308 |
case 'd': /* sample density */ |
309 |
if (*++cp != '=') |
310 |
break; |
311 |
312 |
continue; |
313 |
if (isintd(cp, " \t\n\r")) { |
314 |
thisillum.sampdens = atoi(cp); |
315 |
} else { |
316 |
error(WARNING, "direct BSDF input unsupported"); |
317 |
goto opterr; |
318 |
319 |
cp = sskip(cp); |
320 |
continue; |
321 |
case 's': /* surface super-samples */ |
322 |
if (*++cp != '=') |
323 |
break; |
324 |
if (!isintd(++cp, " \t\n\r")) |
325 |
break; |
326 |
thisillum.nsamps = atoi(cp); |
327 |
cp = sskip(cp); |
328 |
continue; |
329 |
case 'l': /* light sources */ |
330 |
cp++; |
331 |
if (*cp == '+') |
332 |
thisillum.flags |= IL_LIGHT; |
333 |
else if (*cp == '-') |
334 |
thisillum.flags &= ~IL_LIGHT; |
335 |
else |
336 |
break; |
337 |
cp++; |
338 |
continue; |
339 |
case 'b': /* brightness */ |
340 |
if (*++cp != '=') |
341 |
break; |
342 |
if (!isfltd(++cp, " \t\n\r")) |
343 |
break; |
344 |
thisillum.minbrt = atof(cp); |
345 |
if (thisillum.minbrt < 0.) |
346 |
thisillum.minbrt = 0.; |
347 |
cp = sskip(cp); |
348 |
continue; |
349 |
case 'o': /* output file */ |
350 |
if (*++cp != '=') |
351 |
break; |
352 |
353 |
break; |
354 |
atos(buf, sizeof(buf), cp); |
355 |
cp = sskip(cp); |
356 |
if (freopen(buf, "w", stdout) == NULL) { |
357 |
sprintf(errmsg, |
358 |
"cannot open output file \"%s\"", buf); |
359 |
360 |
361 |
doneheader = 0; |
362 |
continue; |
363 |
case 't': /* object thickness */ |
364 |
if (*++cp != '=') |
365 |
break; |
366 |
367 |
break; |
368 |
thisillum.thick = atof(cp); |
369 |
if (thisillum.thick < .0) |
370 |
thisillum.thick = .0; |
371 |
cp = sskip(cp); |
372 |
continue; |
373 |
case '!': /* processed file! */ |
374 |
sprintf(errmsg, "(%s): already processed!", nm); |
375 |
error(WARNING, errmsg); |
376 |
377 |
return; |
378 |
379 |
opterr: /* skip faulty option */ |
380 |
while (*cp && !isspace(*cp)) |
381 |
cp++; |
382 |
nerrs++; |
383 |
384 |
/* print header? */ |
385 |
checkhead(); |
386 |
/* issue warnings? */ |
387 |
if (nerrs) { |
388 |
sprintf(errmsg, "(%s): %d error(s) in option line:", |
389 |
nm, nerrs); |
390 |
391 |
wputs(s); |
392 |
printf("# %s: the following option line has %d error(s):\n", |
393 |
progname, nerrs); |
394 |
395 |
/* print pure comment */ |
396 |
printf("# %s", s+2); |
397 |
398 |
399 |
void |
400 |
printopts(void) /* print out option default values */ |
401 |
402 |
printf("m=%-15s\t\t# material name\n", thisillum.matname); |
403 |
printf("f=%-15s\t\t# data file name\n", thisillum.datafile); |
404 |
if (thisillum.flags & IL_COLAVG) |
405 |
if (thisillum.flags & IL_COLDST) |
406 |
printf("c=d\t\t\t\t# color distribution\n"); |
407 |
else |
408 |
printf("c=a\t\t\t\t# color average\n"); |
409 |
else |
410 |
printf("c=n\t\t\t\t# color none\n"); |
411 |
if (thisillum.flags & IL_LIGHT) |
412 |
printf("l+\t\t\t\t# light type on\n"); |
413 |
else |
414 |
printf("l-\t\t\t\t# light type off\n"); |
415 |
printf("d=%d\t\t\t\t# density of directions\n", thisillum.sampdens); |
416 |
printf("s=%d\t\t\t\t# samples per direction\n", thisillum.nsamps); |
417 |
printf("b=%f\t\t\t# minimum average brightness\n", thisillum.minbrt); |
418 |
printf("t=%f\t\t\t# object thickness\n", thisillum.thick); |
419 |
420 |
421 |
422 |
void |
423 |
printhead( /* print out header */ |
424 |
register int ac, |
425 |
register char **av |
426 |
427 |
428 |
putchar('#'); |
429 |
while (ac-- > 0) { |
430 |
putchar(' '); |
431 |
fputs(*av++, stdout); |
432 |
433 |
fputs("\n#@mkillum !\n", stdout); |
434 |
435 |
436 |
437 |
void |
438 |
xobject( /* translate an object from fp */ |
439 |
FILE *fp, |
440 |
char *nm |
441 |
442 |
443 |
OBJREC thisobj; |
444 |
char str[MAXSTR]; |
445 |
int doit; |
446 |
/* read the object */ |
447 |
if (fgetword(thisillum.altmat, MAXSTR, fp) == NULL) |
448 |
goto readerr; |
449 |
if (fgetword(str, MAXSTR, fp) == NULL) |
450 |
goto readerr; |
451 |
/* is it an alias? */ |
452 |
if (!strcmp(str, ALIASKEY)) { |
453 |
454 |
goto readerr; |
455 |
printf("\n%s %s %s", thisillum.altmat, ALIASKEY, str); |
456 |
457 |
goto readerr; |
458 |
printf("\t%s\n", str); |
459 |
return; |
460 |
461 |
thisobj.omod = OVOID; /* unused field */ |
462 |
if ((thisobj.otype = otype(str)) < 0) { |
463 |
sprintf(errmsg, "(%s): unknown type \"%s\"", nm, str); |
464 |
465 |
466 |
467 |
goto readerr; |
468 |
thisobj.oname = str; |
469 |
if (readfargs(&thisobj.oargs, fp) != 1) |
470 |
goto readerr; |
471 |
thisobj.os = NULL; |
472 |
/* check for translation */ |
473 |
switch (matselect) { |
474 |
case S_NONE: |
475 |
doit = 0; |
476 |
break; |
477 |
case S_ALL: |
478 |
doit = 1; |
479 |
break; |
480 |
case S_ELEM: |
481 |
doit = !strcmp(thisillum.altmat, matcheck); |
482 |
break; |
483 |
case S_COMPL: |
484 |
doit = strcmp(thisillum.altmat, matcheck); |
485 |
break; |
486 |
487 |
doit = doit && issurface(thisobj.otype); |
488 |
489 |
checkhead(); |
490 |
/* process object */ |
491 |
if (doit) |
492 |
switch (thisobj.otype) { |
493 |
case OBJ_FACE: |
494 |
my_face(&thisobj, &thisillum, nm); |
495 |
break; |
496 |
case OBJ_SPHERE: |
497 |
my_sphere(&thisobj, &thisillum, nm); |
498 |
break; |
499 |
case OBJ_RING: |
500 |
my_ring(&thisobj, &thisillum, nm); |
501 |
break; |
502 |
default: |
503 |
my_default(&thisobj, &thisillum, nm); |
504 |
break; |
505 |
506 |
else |
507 |
printobj(thisillum.altmat, &thisobj); |
508 |
/* free arguments */ |
509 |
freefargs(&thisobj.oargs); |
510 |
return; |
511 |
readerr: |
512 |
sprintf(errmsg, "(%s): error reading input", nm); |
513 |
514 |
