--- ray/src/gen/mkillum.c 2005/09/19 11:30:10 2.26 +++ ray/src/gen/mkillum.c 2013/08/11 02:57:49 2.40 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: mkillum.c,v 2.26 2005/09/19 11:30:10 schorsch Exp $"; +static const char RCSid[] = "$Id: mkillum.c,v 2.40 2013/08/11 02:57:49 greg Exp $"; #endif /* * Make illum sources for optimizing rendering process @@ -8,9 +8,8 @@ static const char RCSid[] = "$Id: mkillum.c,v 2.26 200 #include #include -#include "platform.h" +#include "rtprocess.h" /* win_popen() */ #include "mkillum.h" -#include "random.h" /* default parameters */ #define SAMPDENS 48 /* points per projected steradian */ @@ -23,16 +22,6 @@ static const char RCSid[] = "$Id: mkillum.c,v 2.26 200 #define S_COMPL 2 /* select all but element */ #define S_ALL 3 /* select all */ - /* rtrace command and defaults */ -char *rtargv[64] = { "rtrace", "-dj", ".25", "-dr", "3", "-dv-", - "-ab", "2", "-ad", "1024", "-as", "512", "-aa", ".1", }; -int rtargc = 14; - /* overriding rtrace options */ -char *myrtopts[] = { "-I-", "-i-", "-ld-", "-ov", "-h-", - "-fff", "-y", "0", NULL }; - -struct rtproc rt0; /* head of rtrace process list */ - struct illum_args thisillum = { /* our illum and default values */ 0, DFLMAT, @@ -47,21 +36,15 @@ struct illum_args thisillum = { /* our illum and defa char matcheck[MAXSTR]; /* current material to include or exclude */ int matselect = S_ALL; /* selection criterion */ -FUN ofun[NUMOTYPE] = INIT_OTYPE; /* object types */ - -char persistfn[] = "pfXXXXXX"; /* persist file name */ - int gargc; /* global argc */ char **gargv; /* global argv */ -#define progname gargv[0] int doneheader = 0; /* printed header yet? */ #define checkhead() if (!doneheader++) printhead(gargc,gargv) int warnings = 1; /* print warnings? */ -int done_rprocs(struct rtproc *rtp); -void init(int np); +void init(char *octnm, int np); void filter(register FILE *infp, char *name); void xoptions(char *s, char *nm); void printopts(void); @@ -76,73 +59,58 @@ main( /* compute illum distributions using rtrace */ ) { int nprocs = 1; - char *rtpath; FILE *fp; + int rval; register int i; /* set global arguments */ gargv = argv; - /* check for -n option */ - if (!strcmp(argv[1], "-n")) { - nprocs = atoi(argv[2]); - if (nprocs <= 0) - error(USER, "illegal number of processes"); - i = 3; - } else - i = 1; - /* set up rtrace command */ - for ( ; i < argc; i++) { - if (argv[i][0] == '<' && argv[i][1] == '\0') + progname = gargv[0]; + /* set up rendering defaults */ + dstrsrc = 0.5; + directrelay = 3; + ambounce = 2; + /* get options from command line */ + for (i = 1; i < argc; i++) { + while ((rval = expandarg(&argc, &argv, i)) > 0) + ; + if (rval < 0) { + sprintf(errmsg, "cannot expand '%s'", argv[i]); + error(SYSTEM, errmsg); + } + if (argv[i][0] != '-') break; - rtargv[rtargc++] = argv[i]; - if (argv[i][0] == '-' && argv[i][1] == 'w') - switch (argv[i][2]) { - case '\0': - warnings = !warnings; - break; - case '+': - case 'T': case 't': - case 'Y': case 'y': - case '1': - warnings = 1; - break; - case '-': - case 'F': case 'f': - case 'N': case 'n': - case '0': - warnings = 0; - break; - } - } - gargc = i; - if (!strcmp(rtargv[--rtargc], "-defaults")) - nprocs = 0; - if (nprocs > 1) { /* add persist file if parallel invocation */ - rtargv[rtargc++] = "-PP"; - rtargv[rtargc++] = mktemp(persistfn); - } - /* add "mandatory" rtrace options */ - for (i = 0; myrtopts[i] != NULL; i++) - rtargv[rtargc++] = myrtopts[i]; - /* finally, put back final argument */ - rtargv[rtargc++] = argv[gargc-1]; - rtargv[rtargc] = NULL; - if (!nprocs) { /* just asking for defaults? */ - printopts(); fflush(stdout); - rtpath = getpath(rtargv[0], getenv("PATH"), X_OK); - if (rtpath == NULL) { - eputs(rtargv[0]); - eputs(": command not found\n"); - exit(1); + if (!strcmp(argv[i], "-w")) { + warnings = 0; + continue; } - execv(rtpath, rtargv); - perror(rtpath); /* execv() should not return */ - exit(1); + if (!strcmp(argv[i], "-n")) { + nprocs = atoi(argv[++i]); + if (nprocs <= 0) + error(USER, "illegal number of processes"); + continue; + } + if (!strcmp(argv[i], "-defaults")) { + printopts(); + print_rdefaults(); + quit(0); + } + rval = getrenderopt(argc-i, argv+i); + if (rval < 0) { + sprintf(errmsg, "bad render option at '%s'", argv[i]); + error(USER, errmsg); + } + i += rval; } - if (gargc < 2 || argv[gargc-1][0] == '-') + gargc = ++i; + /* add "mandatory" render options */ + do_irrad = 0; + if (gargc > argc || argv[gargc-1][0] == '-') error(USER, "missing octree argument"); /* else initialize and run our calculation */ - init(nprocs); - if (gargc+1 < argc) + init(argv[gargc-1], nprocs); + if (gargc < argc) { + if (gargc == argc-1 || argv[gargc][0] != '<' || argv[gargc][1]) + error(USER, "use '< file1 file2 ..' for multiple inputs"); for (i = gargc+1; i < argc; i++) { if ((fp = fopen(argv[i], "r")) == NULL) { sprintf(errmsg, @@ -152,71 +120,16 @@ main( /* compute illum distributions using rtrace */ filter(fp, argv[i]); fclose(fp); } - else + } else filter(stdin, "standard input"); quit(0); + return 0; /* pro forma return */ } -#ifndef SIGALRM -#define SIGALRM SIGTERM -#endif -static void -killpersist(void) /* kill persistent rtrace process */ -{ - FILE *fp = fopen(persistfn, "r"); - int pid; - - if (fp == NULL) - return; - if (fscanf(fp, "%*s %d", &pid) != 1 || kill(pid, SIGALRM) < 0) - unlink(persistfn); - fclose(fp); -} - - -int -done_rprocs(struct rtproc *rtp) -{ - int st0, st1 = 0; - - if (rtp->next != NULL) { /* close last opened first! */ - st1 = done_rprocs(rtp->next); - free((void *)rtp->next); - rtp->next = NULL; - } - st0 = close_process(&rtp->pd); - if (st0 < 0) - error(WARNING, "unknown return status from rtrace process"); - else if (st0 > 0) - return(st0); - return(st1); -} - void -quit(int status) /* exit with status */ +init(char *octnm, int np) /* start rendering process(es) */ { - int rtstat; - - if (rt0.next != NULL) /* terminate persistent rtrace */ - killpersist(); - /* clean up rtrace process(es) */ - rtstat = done_rprocs(&rt0); - if (status == 0) - status = rtstat; - exit(status); -} - -void -init(int np) /* start rtrace and set up buffers */ -{ - struct rtproc *rtp; - int i; - int maxbytes; - /* set up object functions */ - ofun[OBJ_FACE].funp = o_face; - ofun[OBJ_SPHERE].funp = o_sphere; - ofun[OBJ_RING].funp = o_ring; /* set up signal handling */ signal(SIGINT, quit); #ifdef SIGHUP @@ -228,35 +141,8 @@ init(int np) /* start rtrace and set up buffers */ #ifdef SIGPIPE signal(SIGPIPE, quit); #endif - rtp = &rt0; /* start rtrace process(es) */ - for (i = 0; i++ < np; ) { - errno = 0; - maxbytes = open_process(&rtp->pd, rtargv); - if (maxbytes == 0) { - eputs(rtargv[0]); - eputs(": command not found\n"); - exit(1); - } - if (maxbytes < 0) - error(SYSTEM, "cannot start rtrace process"); - rtp->bsiz = maxbytes/(6*sizeof(float)); - rtp->buf = (float *)malloc(6*sizeof(float)*rtp->bsiz--); - rtp->dest = (float **)calloc(rtp->bsiz, sizeof(float *)); - if (rtp->buf == NULL || rtp->dest == NULL) - error(SYSTEM, "out of memory in init"); - rtp->nrays = 0; - if (i == np) /* last process? */ - break; - if (np > 1) - sleep(2); /* wait for persist file */ - rtp->next = (struct rtproc *)malloc(sizeof(struct rtproc)); - if (rtp->next == NULL) - error(SYSTEM, "out of memory in init"); - rtp = rtp->next; - } - rtp->next = NULL; - /* set up urand */ - initurand(16384); + /* start rendering process(es) */ + ray_pinit(octnm, np); } @@ -287,6 +173,16 @@ char *s; void +quit(ec) /* make sure exit is called */ +int ec; +{ + if (ray_pnprocs > 0) /* close children if any */ + ray_pclose(0); + exit(ec); +} + + +void filter( /* process stream */ register FILE *infp, char *name @@ -328,6 +224,7 @@ xoptions( /* process options in string s */ { extern FILE *freopen(); char buf[64]; + int negax; int nerrs = 0; register char *cp; @@ -407,15 +304,20 @@ xoptions( /* process options in string s */ } cp = sskip(cp); continue; - case 'd': /* point sample density */ + case 'd': /* sample density */ if (*++cp != '=') break; - if (!isintd(++cp, " \t\n\r")) - break; - thisillum.sampdens = atoi(cp); + if (!*++cp || isspace(*cp)) + continue; + if (isintd(cp, " \t\n\r")) { + thisillum.sampdens = atoi(cp); + } else { + error(WARNING, "direct BSDF input unsupported"); + goto opterr; + } cp = sskip(cp); continue; - case 's': /* point super-samples */ + case 's': /* surface super-samples */ if (*++cp != '=') break; if (!isintd(++cp, " \t\n\r")) @@ -499,8 +401,8 @@ printopts(void) /* print out option default values * printf("l+\t\t\t\t# light type on\n"); else printf("l-\t\t\t\t# light type off\n"); - printf("d=%d\t\t\t\t# density of points\n", thisillum.sampdens); - printf("s=%d\t\t\t\t# samples per point\n", thisillum.nsamps); + printf("d=%d\t\t\t\t# density of directions\n", thisillum.sampdens); + printf("s=%d\t\t\t\t# samples per direction\n", thisillum.nsamps); printf("b=%f\t\t\t# minimum average brightness\n", thisillum.minbrt); } @@ -575,13 +477,26 @@ xobject( /* translate an object from fp */ checkhead(); /* process object */ if (doit) - (*ofun[thisobj.otype].funp)(&thisobj, &thisillum, &rt0, nm); + switch (thisobj.otype) { + case OBJ_FACE: + my_face(&thisobj, &thisillum, nm); + break; + case OBJ_SPHERE: + my_sphere(&thisobj, &thisillum, nm); + break; + case OBJ_RING: + my_ring(&thisobj, &thisillum, nm); + break; + default: + my_default(&thisobj, &thisillum, nm); + break; + } else printobj(thisillum.altmat, &thisobj); /* free arguments */ freefargs(&thisobj.oargs); return; readerr: - sprintf(errmsg, "(%s): error reading scene", nm); + sprintf(errmsg, "(%s): error reading input", nm); error(USER, errmsg); }
