--- ray/src/gen/mkillum.c 2007/09/21 05:53:21 2.31 +++ ray/src/gen/mkillum.c 2012/10/13 20:15:43 2.39 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: mkillum.c,v 2.31 2007/09/21 05:53:21 greg Exp $"; +static const char RCSid[] = "$Id: mkillum.c,v 2.39 2012/10/13 20:15:43 greg Exp $"; #endif /* * Make illum sources for optimizing rendering process @@ -8,9 +8,8 @@ static const char RCSid[] = "$Id: mkillum.c,v 2.31 200 #include #include -#include "platform.h" +#include "rtprocess.h" /* win_popen() */ #include "mkillum.h" -#include "random.h" /* default parameters */ #define SAMPDENS 48 /* points per projected steradian */ @@ -25,7 +24,6 @@ static const char RCSid[] = "$Id: mkillum.c,v 2.31 200 struct illum_args thisillum = { /* our illum and default values */ 0, - UDzpos, 0., DFLMAT, DFLDAT, @@ -33,7 +31,6 @@ struct illum_args thisillum = { /* our illum and defa VOIDID, SAMPDENS, NSAMPS, - NULL, 0., }; @@ -70,9 +67,8 @@ main( /* compute illum distributions using rtrace */ gargv = argv; progname = gargv[0]; /* set up rendering defaults */ - dstrsrc = 0.25; + dstrsrc = 0.5; directrelay = 3; - directvis = 0; ambounce = 2; /* get options from command line */ for (i = 1; i < argc; i++) { @@ -178,6 +174,16 @@ char *s; void +quit(ec) /* make sure exit is called */ +int ec; +{ + if (ray_pnprocs > 0) /* close children if any */ + ray_pclose(0); + exit(ec); +} + + +void filter( /* process stream */ register FILE *infp, char *name @@ -299,22 +305,16 @@ xoptions( /* process options in string s */ } cp = sskip(cp); continue; - case 'd': /* sample density / BSDF data */ + case 'd': /* sample density */ if (*++cp != '=') break; - if (thisillum.sd != NULL) { - free_BSDF(thisillum.sd); - thisillum.sd = NULL; - } if (!*++cp || isspace(*cp)) continue; - if (isintd(++cp, " \t\n\r")) { + if (isintd(cp, " \t\n\r")) { thisillum.sampdens = atoi(cp); } else { - atos(buf, sizeof(buf), cp); - thisillum.sd = load_BSDF(buf); - if (thisillum.sd == NULL) - break; + error(WARNING, "direct BSDF input unsupported"); + goto opterr; } cp = sskip(cp); continue; @@ -360,40 +360,6 @@ xoptions( /* process options in string s */ } doneheader = 0; continue; - case 'u': /* up direction */ - if (*++cp != '=') - break; - if (!*++cp || isspace(*cp)) { - thisillum.udir = UDunknown; - continue; - } - negax = 0; - if (*cp == '+') - cp++; - else if (*cp == '-') { - negax++; - cp++; - } - switch (*cp++) { - case 'x': - case 'X': - thisillum.udir = negax ? UDxneg : UDxpos; - break; - case 'y': - case 'Y': - thisillum.udir = negax ? UDyneg : UDypos; - break; - case 'z': - case 'Z': - thisillum.udir = negax ? UDxneg : UDxpos; - break; - default: - thisillum.udir = UDunknown; - break; - } - if (thisillum.udir == UDunknown || !isspace(*cp)) - break; - continue; case 't': /* object thickness */ if (*++cp != '=') break; @@ -446,31 +412,9 @@ printopts(void) /* print out option default values * printf("l+\t\t\t\t# light type on\n"); else printf("l-\t\t\t\t# light type off\n"); - printf("d=%d\t\t\t\t# density of points\n", thisillum.sampdens); - printf("s=%d\t\t\t\t# samples per point\n", thisillum.nsamps); + printf("d=%d\t\t\t\t# density of directions\n", thisillum.sampdens); + printf("s=%d\t\t\t\t# samples per direction\n", thisillum.nsamps); printf("b=%f\t\t\t# minimum average brightness\n", thisillum.minbrt); - switch (thisillum.udir) { - case UDzneg: - fputs("u=-Z\t\t\t\t# up is negative Z\n", stdout); - break; - case UDyneg: - fputs("u=-Y\t\t\t\t# up is negative Y\n", stdout); - break; - case UDxneg: - fputs("u=-X\t\t\t\t# up is negative X\n", stdout); - break; - case UDxpos: - fputs("u=+X\t\t\t\t# up is positive X\n", stdout); - break; - case UDypos: - fputs("u=+Y\t\t\t\t# up is positive Y\n", stdout); - break; - case UDzpos: - fputs("u=+Z\t\t\t\t# up is positive Z\n", stdout); - break; - case UDunknown: - break; - } printf("t=%f\t\t\t# object thickness\n", thisillum.thick); }
