1 |
#!/bin/csh -f |
2 |
# RCSid: $Id: markpath.csh,v 2.1 2003/02/22 02:07:23 greg Exp $ |
3 |
4 |
# Put right trianglar markers down a path at the given intervals. |
5 |
# Use with replmarks to place regular-sized objects along a path. |
6 |
# Shorter (y-side) of triangles is always horizontal (perp. to z). |
7 |
8 |
# Input is an ordered list of 3-D points defining the path. |
9 |
# We interpolate the path and align our markers with it. |
10 |
# Triangles are sized and aligned so tip of one meets butt of next |
11 |
12 |
if ($#argv < 2) then |
13 |
echo "Usage: $0 3d.pts spacing [markmat]" |
14 |
exit 1 |
15 |
endif |
16 |
set pts=$1 |
17 |
set step=$2 |
18 |
set mat=mark |
19 |
if ($#argv > 2) set mat=$3 |
20 |
set npts=`wc -l < $pts` |
21 |
(head -1 $pts ; cat $pts) | rlam - $pts \ |
22 |
| rcalc -e '$1=d($1,$2,$3,$4,$5,$6)' -e "cond=$npts+.5-recno" \ |
23 |
-e 's(x):x*x;d(x0,y0,z0,x1,y1,z1):sqrt(s(x1-x0)+s(y1-y0)+s(z1-z0))' \ |
24 |
| total -1 -r > /tmp/run$$.dat |
25 |
rlam /tmp/run$$.dat $pts | tabfunc -i xp yp zp > /tmp/path$$.cal |
26 |
set tmax=`tail -1 /tmp/run$$.dat` |
27 |
set nsteps=`ev "floor($tmax/$step)"` |
28 |
echo $mat > /tmp/tri$$.fmt |
29 |
cat >> /tmp/tri$$.fmt << '_EOF_' |
30 |
polygon marker.${recno} |
31 |
0 |
32 |
0 |
33 |
9 |
34 |
${ x0 } ${ y0 } ${ z0 } |
35 |
${ x1 } ${ y1 } ${ z1 } |
36 |
${ x2 } ${ y2 } ${ z2 } |
37 |
38 |
'_EOF_' |
39 |
cnt $nsteps | rcalc -o /tmp/tri$$.fmt -f /tmp/path$$.cal -e st=$step \ |
40 |
-e 't=$1*st;x0=xp(t);y0=yp(t);z0=zp(t)' \ |
41 |
-e 'x1=xp(t+st);y1=yp(t+st);z1=zp(t+st)' \ |
42 |
-e 'x2=x0+.5*(y0-y1);y2=y0+.5*(x1-x0);z2=z0' |
43 |
rm /tmp/run$$.dat /tmp/path$$.cal /tmp/tri$$.fmt |
