root/radiance/ray/src/gen/loadEPW.h
Revision: 2.2
Committed: Tue Mar 4 17:45:41 2025 UTC (5 months ago) by greg
CVS Tags: rad6R0, HEAD
fix(gendaymtx): Somehow missed "May" in month list!
1 /* RCSid $Id: loadEPW.h,v 2.1 2025/02/26 20:39:28 greg Exp $ */
2 /*
3 * Header for EPW (or WEA) file loader
4 *
5 * G. Ward, Feb 2025
6 */
7
8 #ifndef _RAD_LOADEPW_H_
9 #define _RAD_LOADEPW_H_
10
11 #ifdef __cplusplus
12 extern "C" {
13 #endif
14
15 enum {Sunday, Monday, Tuesday, Wednesday,
16 Thursday, Friday, Saturday};
17
18 extern const char WDname[7][10];
19
20 enum {January, February, March, April, May, June, July,
21 August, September, October, November, December};
22
23 extern const char MOname[12][10];
24
25 enum {WEAnot=0, WEAradnorm=1, WEAradhoriz=2, WEAphotnorm=3};
26
27 /* EPW date and time */
28 typedef struct {
29 float hour; /* decimal hour (0-24) */
30 short day; /* day of the month (1-31) */
31 short month; /* month of the year (0-11) */
32 short year; /* year (or 0) */
33 } EPWdate;
34
35 /* EPW file header info. */
36 typedef struct {
37 FILE *fp; /* open file pointer */
38 int lino; /* current line in file */
39 int dstart; /* starting data position in file */
40 short lin0; /* # lines in header */
41 short isWEA; /* input is WEA data type? */
42 EPWdate dtpos; /* date and time of current record */
43 struct Location {
44 char city[64]; /* location city */
45 char state[64]; /* location state/province */
46 char country[64]; /* country */
47 char source[64]; /* data source */
48 char wmo[16]; /* WMO (EnergyPlus alpha?) */
49 double latitude; /* site latitude (deg north) */
50 double longitude; /* site longitude (deg east) */
51 float timezone; /* time zone (hours from GMT) */
52 float elevation; /* site altitude in meters */
53 } loc; /* location data */
54 /* struct DesConditions XXX unsupported */
55 /* struct VarPeriods XXX unsupported */
56 /* struct GroundTemps XXX unsupported */
57 /* struct SpecialDays XXX unsupported */
58 char *comments1; /* first set of additional comments */
59 char *comments2; /* second set of comments */
60 int nperiods; /* # of data periods */
61 struct DataPeriod {
62 char name[64]; /* data period name */
63 short nperhour; /* # records/hour */
64 short startday; /* starting day of the week */
65 EPWdate firstdate; /* starting date */
66 EPWdate lastdate; /* ending date */
67 } period[1]; /* periods covered in EPW file */
68 } EPWheader;
69
70 /* EPW record holder (NOTE: all lengths in meters, contrary to spec!) */
71 typedef struct {
72 EPWdate date; /* measurement date and time */
73 char uncert[64]; /* uncertainty flags */
74 float dbtemp; /* dry bulb temperature (deg-C) */
75 float dptemp; /* dew point temperature (deg-C) */
76 float humidity; /* relative humidity (0-110 %) */
77 float atmospressure; /* atmospheric pressure (31000 - 120000) */
78 float exthorizirrad; /* extraterrestrial horizontal irradiance */
79 float extdirirrad; /* extraterrestrial direct normal irradiance */
80 float horizirrad_ir; /* infrared horizontal normal irradiance */
81 float globhorizirrad; /* global horizontal irradiance */
82 float dirirrad; /* direct normal irradiance */
83 float horizdiffirrad; /* horizontal diffuse irradiance */
84 float globhorizillum; /* global horizontal illuminance (lux) */
85 float diffillum; /* diffuse horizontal illuminance (lux) */
86 float dirillum; /* direct normal illuminance (lux) */
87 float zenlum; /* zenith luminance (cd/m2) */
88 float windirection; /* wind direction (deg E of N) */
89 float windspeed; /* wind speed in m/s */
90 float skycover; /* total sky coverage (fraction) */
91 float opskycover; /* opaque sky coverage (fraction) */
92 float visibility; /* visibility (meters!) */
93 float ceilheight; /* cloud ceiling height (meters) */
94 /* char weather[32]; XXX unsupported */
95 float precip; /* precipital water in meters(!) */
96 float optdepth; /* aerosol optical depth (fraction!) */
97 float snowdepth; /* snow depth (meters!) */
98 int nosnowdays; /* # days since last snow */
99 float albedo; /* ratio of reflected to global horiz. irrad */
100 float liqpdepth; /* liquid precipitation depth (meters!) */
101 float liqhours; /* liquid precipitation quantity (hours) */
102 } EPWrecord;
103
104 extern const EPWrecord EPWrecInit;
105
106 #define EPWisset(rp,field) ((rp)->field != EPWrecInit.field)
107
108 /* specify NULL for stdin */
109 extern EPWheader * EPWopen(const char *fname);
110
111 extern int EPWseek(EPWheader *epw, const EPWdate *dt);
112
113 extern int EPWread(EPWheader *epw, EPWrecord *rp);
114
115 extern void EPWclose(EPWheader *epw);
116
117 #ifdef __cplusplus
118 }
119 #endif
120 #endif /* ! _RAD_LOADEPW_H_ */
