root/radiance/ray/src/gen/loadEPW.h
Revision: 2.2
Committed: Tue Mar 4 17:45:41 2025 UTC (4 months, 4 weeks ago) by greg
CVS Tags: rad6R0, HEAD
fix(gendaymtx): Somehow missed "May" in month list!
# User Rev Content
1 greg 2.2 /* RCSid $Id: loadEPW.h,v 2.1 2025/02/26 20:39:28 greg Exp $ */
2 greg 2.1 /*
3     * Header for EPW (or WEA) file loader
4     *
5     * G. Ward, Feb 2025
6     */
7
8     #ifndef _RAD_LOADEPW_H_
9     #define _RAD_LOADEPW_H_
10
11     #ifdef __cplusplus
12     extern "C" {
13     #endif
14
15     enum {Sunday, Monday, Tuesday, Wednesday,
16     Thursday, Friday, Saturday};
17
18     extern const char WDname[7][10];
19
20 greg 2.2 enum {January, February, March, April, May, June, July,
21 greg 2.1 August, September, October, November, December};
22
23     extern const char MOname[12][10];
24
25     enum {WEAnot=0, WEAradnorm=1, WEAradhoriz=2, WEAphotnorm=3};
26
27     /* EPW date and time */
28     typedef struct {
29     float hour; /* decimal hour (0-24) */
30     short day; /* day of the month (1-31) */
31     short month; /* month of the year (0-11) */
32     short year; /* year (or 0) */
33     } EPWdate;
34
35     /* EPW file header info. */
36     typedef struct {
37     FILE *fp; /* open file pointer */
38     int lino; /* current line in file */
39     int dstart; /* starting data position in file */
40     short lin0; /* # lines in header */
41     short isWEA; /* input is WEA data type? */
42     EPWdate dtpos; /* date and time of current record */
43     struct Location {
44     char city[64]; /* location city */
45     char state[64]; /* location state/province */
46     char country[64]; /* country */
47     char source[64]; /* data source */
48     char wmo[16]; /* WMO (EnergyPlus alpha?) */
49     double latitude; /* site latitude (deg north) */
50     double longitude; /* site longitude (deg east) */
51     float timezone; /* time zone (hours from GMT) */
52     float elevation; /* site altitude in meters */
53     } loc; /* location data */
54     /* struct DesConditions XXX unsupported */
55     /* struct VarPeriods XXX unsupported */
56     /* struct GroundTemps XXX unsupported */
57     /* struct SpecialDays XXX unsupported */
58     char *comments1; /* first set of additional comments */
59     char *comments2; /* second set of comments */
60     int nperiods; /* # of data periods */
61     struct DataPeriod {
62     char name[64]; /* data period name */
63     short nperhour; /* # records/hour */
64     short startday; /* starting day of the week */
65     EPWdate firstdate; /* starting date */
66     EPWdate lastdate; /* ending date */
67     } period[1]; /* periods covered in EPW file */
68     } EPWheader;
69
70     /* EPW record holder (NOTE: all lengths in meters, contrary to spec!) */
71     typedef struct {
72     EPWdate date; /* measurement date and time */
73     char uncert[64]; /* uncertainty flags */
74     float dbtemp; /* dry bulb temperature (deg-C) */
75     float dptemp; /* dew point temperature (deg-C) */
76     float humidity; /* relative humidity (0-110 %) */
77     float atmospressure; /* atmospheric pressure (31000 - 120000) */
78     float exthorizirrad; /* extraterrestrial horizontal irradiance */
79     float extdirirrad; /* extraterrestrial direct normal irradiance */
80     float horizirrad_ir; /* infrared horizontal normal irradiance */
81     float globhorizirrad; /* global horizontal irradiance */
82     float dirirrad; /* direct normal irradiance */
83     float horizdiffirrad; /* horizontal diffuse irradiance */
84     float globhorizillum; /* global horizontal illuminance (lux) */
85     float diffillum; /* diffuse horizontal illuminance (lux) */
86     float dirillum; /* direct normal illuminance (lux) */
87     float zenlum; /* zenith luminance (cd/m2) */
88     float windirection; /* wind direction (deg E of N) */
89     float windspeed; /* wind speed in m/s */
90     float skycover; /* total sky coverage (fraction) */
91     float opskycover; /* opaque sky coverage (fraction) */
92     float visibility; /* visibility (meters!) */
93     float ceilheight; /* cloud ceiling height (meters) */
94     /* char weather[32]; XXX unsupported */
95     float precip; /* precipital water in meters(!) */
96     float optdepth; /* aerosol optical depth (fraction!) */
97     float snowdepth; /* snow depth (meters!) */
98     int nosnowdays; /* # days since last snow */
99     float albedo; /* ratio of reflected to global horiz. irrad */
100     float liqpdepth; /* liquid precipitation depth (meters!) */
101     float liqhours; /* liquid precipitation quantity (hours) */
102     } EPWrecord;
103
104     extern const EPWrecord EPWrecInit;
105
106     #define EPWisset(rp,field) ((rp)->field != EPWrecInit.field)
107
108     /* specify NULL for stdin */
109     extern EPWheader * EPWopen(const char *fname);
110
111     extern int EPWseek(EPWheader *epw, const EPWdate *dt);
112
113     extern int EPWread(EPWheader *epw, EPWrecord *rp);
114
115     extern void EPWclose(EPWheader *epw);
116
117     #ifdef __cplusplus
118     }
119     #endif
120     #endif /* ! _RAD_LOADEPW_H_ */
