1 |
greg |
2.1 |
#!/bin/csh -f |
2 |
greg |
2.5 |
# RCSid: $Id: glaze.csh,v 2.4 2004/08/25 01:40:12 greg Exp $ |
3 |
greg |
2.1 |
4 |
# Complex glazing model (goes with glaze1.cal and glaze2.cal) |
5 |
6 |
# Oct. 2002 Greg Ward |
7 |
greg |
2.3 |
# Aug. 2004 GW (added -f option to read glazings from file) |
8 |
greg |
2.2 |
# Funding for this development generously provided by Visarc, Inc. |
9 |
greg |
2.4 |
# (http://www.visarc.com) |
10 |
greg |
2.1 |
11 |
12 |
13 |
14 |
greg |
2.5 |
# The general assumption is that one surface is uncoated, and |
15 |
# reflectances and transmittances are computed from this fact. |
16 |
# If the user tries to enter two coated surfaces on the same |
17 |
# pane, the script complains and exits. |
18 |
19 |
greg |
2.1 |
# Supported surface types: |
20 |
21 |
set sn_arr=("clear glass" "VE1-2M low-E coating" "PVB laminated" "V-175 white frit" "V-933 warm gray frit") |
22 |
# Glass-side hemispherical reflectances for each surface type: |
23 |
set rg_r_arr=(0.074 0.065 .11 0.33 0.15) |
24 |
set rg_g_arr=(0.077 0.058 .11 0.33 0.15) |
25 |
set rg_b_arr=(0.079 0.067 .11 0.33 0.15) |
26 |
# Coating-side hemispherical reflectance for each surface type: |
27 |
set rc_r_arr=(0.074 0.042 .11 0.59 0.21) |
28 |
set rc_g_arr=(0.077 0.049 .11 0.59 0.21) |
29 |
set rc_b_arr=(0.079 0.043 .11 0.59 0.21) |
30 |
# Hemispherical (normal) transmittance for each surface type: |
31 |
set tn_r_arr=(0.862 0.756 0.63 0.21 0.09) |
32 |
set tn_g_arr=(0.890 0.808 0.63 0.21 0.09) |
33 |
set tn_b_arr=(0.886 0.744 0.63 0.21 0.09) |
34 |
# Boolean whether coatings can have partial coverage: |
35 |
set part_arr=(0 0 0 1 1) |
36 |
37 |
greg |
2.3 |
while ($#argv > 0) |
38 |
greg |
2.4 |
set header="Surface Tr Tg Tb Rcr Rcg Rcb Rgr Rgg Rgb Part" |
39 |
greg |
2.3 |
if ($#argv < 2 || "$argv[1]" != '-f') then |
40 |
echo "Usage: $0 [-f glazing.dat ..]" |
41 |
exit 1 |
42 |
endif |
43 |
shift argv |
44 |
set gf="$argv[1]" |
45 |
shift argv |
46 |
if ("`sed -n 1p $gf:q`" != "$header") then |
47 |
echo "Bad header in $gf -- Expected: $header" |
48 |
exit 1 |
49 |
endif |
50 |
echo "Adding glazing types from file $gf :" |
51 |
set nl=`wc -l < $gf:q` |
52 |
@ i=2 |
53 |
while ($i <= $nl) |
54 |
set ln=(`sed -n ${i}p $gf:q`) |
55 |
greg |
2.4 |
if ($#ln != 11) then |
56 |
echo "Expected 11 words in line: $ln" |
57 |
greg |
2.3 |
exit 1 |
58 |
endif |
59 |
echo $ln[1] |
60 |
set sn_arr=($sn_arr:q $ln[1]) |
61 |
set tn_r_arr=($tn_r_arr $ln[2]) |
62 |
set tn_g_arr=($tn_g_arr $ln[3]) |
63 |
set tn_b_arr=($tn_b_arr $ln[4]) |
64 |
set rc_r_arr=($rc_r_arr $ln[5]) |
65 |
set rc_g_arr=($rc_g_arr $ln[6]) |
66 |
set rc_b_arr=($rc_b_arr $ln[7]) |
67 |
greg |
2.5 |
set rg_r_arr=($rg_r_arr $ln[8]) |
68 |
set rg_g_arr=($rg_g_arr $ln[9]) |
69 |
set rg_b_arr=($rg_b_arr $ln[10]) |
70 |
greg |
2.4 |
set part_arr=($part_arr $ln[11]) |
71 |
greg |
2.3 |
@ i++ |
72 |
end |
73 |
end |
74 |
75 |
greg |
2.1 |
76 |
77 |
# Get user input |
78 |
79 |
echo -n "Enter the number of panes in the system: " |
80 |
set np="$<" |
81 |
if ($np != 1 && $np != 2) then |
82 |
echo "Must be 1 or 2 pane system" |
83 |
exit 1 |
84 |
endif |
85 |
echo "" |
86 |
echo "Window normal faces interior" |
87 |
echo "" |
88 |
if ($np == 1) then |
89 |
echo " | |" |
90 |
echo " | |" |
91 |
echo " | |" |
92 |
echo " | |-->" |
93 |
echo " | |" |
94 |
echo " | |" |
95 |
echo " | |" |
96 |
echo " s1 s2" |
97 |
else |
98 |
echo " | | | |" |
99 |
echo " | | | |" |
100 |
echo " | | | |" |
101 |
echo " | | | |-->" |
102 |
echo " | | | |" |
103 |
echo " | | | |" |
104 |
echo " | | | |" |
105 |
echo " s1 s2 s3 s4" |
106 |
endif |
107 |
echo "" |
108 |
echo "Supported surface types are:" |
109 |
set i=1 |
110 |
while ($i <= $#sn_arr) |
111 |
echo " " $i - $sn_arr[$i] |
112 |
@ i++ |
113 |
end |
114 |
echo "" |
115 |
echo -n "What is the type of s1? " |
116 |
set s1t="$<" |
117 |
echo -n "What is the type of s2? " |
118 |
set s2t="$<" |
119 |
if ($s1t != 1 && $s2t != 1) then |
120 |
echo "One surface of each pane must be $sn_arr[1]" |
121 |
exit 1 |
122 |
endif |
123 |
if ($part_arr[$s1t]) then |
124 |
echo -n "Enter fraction coverage for s1 (0-1): " |
125 |
set s1c="$<" |
126 |
endif |
127 |
if ($part_arr[$s2t]) then |
128 |
echo -n "Enter fraction coverage for s2 (0-1): " |
129 |
set s2c="$<" |
130 |
endif |
131 |
if ($np == 2) then |
132 |
echo -n "What is the type of s3? " |
133 |
set s3t="$<" |
134 |
echo -n "What is the type of s4? " |
135 |
set s4t="$<" |
136 |
if ($s3t != 1 && $s4t != 1) then |
137 |
138 |
exit 1 |
139 |
endif |
140 |
if ($part_arr[$s3t]) then |
141 |
echo -n "Enter fraction coverage for s3 (0-1): " |
142 |
set s3c="$<" |
143 |
endif |
144 |
if ($part_arr[$s4t]) then |
145 |
echo -n "Enter fraction coverage for s4 (0-1): " |
146 |
set s4c="$<" |
147 |
endif |
148 |
endif |
149 |
150 |
151 |
152 |
# Begin material comments |
153 |
154 |
echo "" |
155 |
echo "############################################" |
156 |
echo "# Glazing produced by Radiance glaze script" |
157 |
echo "# `date`" |
158 |
echo "# Material surface normal points to interior" |
159 |
echo "# Number of panes in system: $np" |
160 |
161 |
if ($np == 2) goto glaze2 |
162 |
163 |
164 |
# Compute single glazing |
165 |
166 |
set sc=1 |
167 |
echo "# Exterior surface s1 type: $sn_arr[$s1t]" |
168 |
if ($?s1c) then |
169 |
echo "# s1 coating coverage: $s1c" |
170 |
set sc=$s1c |
171 |
endif |
172 |
echo "# Interior surface s2 type: $sn_arr[$s2t]" |
173 |
if ($?s2c) then |
174 |
echo "# s2 coating coverage: $s2c" |
175 |
set sc=$s2c |
176 |
endif |
177 |
if ($s1t != 1) then |
178 |
set ct=$s1t |
179 |
echo -n "# Exterior normal hemispherical reflectance: " |
180 |
ev ".265*($sc*$rc_r_arr[$ct]+(1-$sc)*$rc_r_arr[1])+.670*($sc*$rc_g_arr[$ct]+(1-$sc)*$rc_g_arr[1])+.065*($sc*$rc_b_arr[$ct]+(1-$sc)*$rc_b_arr[1])" |
181 |
echo -n "# Interior normal hemispherical reflectance: " |
182 |
ev ".265*($sc*$rg_r_arr[$ct]+(1-$sc)*$rg_r_arr[1])+.670*($sc*$rg_g_arr[$ct]+(1-$sc)*$rg_g_arr[1])+.065*($sc*$rg_b_arr[$ct]+(1-$sc)*$rg_b_arr[1])" |
183 |
else |
184 |
set ct=$s2t |
185 |
186 |
187 |
188 |
189 |
endif |
190 |
echo -n "# Normal hemispherical transmittance: " |
191 |
ev ".265*($sc*$tn_r_arr[$ct]+(1-$sc)*$tn_r_arr[1])+.670*($sc*$tn_g_arr[$ct]+(1-$sc)*$tn_g_arr[1])+.065*($sc*$tn_b_arr[$ct]+(1-$sc)*$tn_b_arr[1])" |
192 |
echo "#" |
193 |
echo "void BRTDfunc glaze1_unnamed" |
194 |
if ($part_arr[$s1t] || $part_arr[$s2t]) then |
195 |
### Frit glazing |
196 |
echo "10" |
197 |
echo " sr_frit_r sr_frit_g sr_frit_b" |
198 |
echo " st_frit_r st_frit_g st_frit_b" |
199 |
echo " 0 0 0" |
200 |
echo " glaze1.cal" |
201 |
echo "0" |
202 |
echo "11" |
203 |
if ($s2t == 1) then |
204 |
ev "$s1c*($rg_r_arr[$s1t]-$rg_r_arr[1])" \ |
205 |
"$s1c*($rg_g_arr[$s1t]-$rg_g_arr[1])" \ |
206 |
"$s1c*($rg_b_arr[$s1t]-$rg_b_arr[1])" |
207 |
ev "$s1c*$rc_r_arr[$s1t]" "$s1c*$rc_g_arr[$s1t]" "$s1c*$rc_b_arr[$s1t]" |
208 |
ev "$s1c*$tn_r_arr[$s1t]" "$s1c*$tn_g_arr[$s1t]" "$s1c*$tn_b_arr[$s1t]" |
209 |
echo " 1 $s1c" |
210 |
else |
211 |
ev "$s2c*$rc_r_arr[$s2t]" "$s2c*$rc_g_arr[$s2t]" "$s2c*$rc_b_arr[$s2t]" |
212 |
ev "$s2c*($rg_r_arr[$s2t]-$rg_r_arr[1])" \ |
213 |
"$s2c*($rg_g_arr[$s2t]-$rg_g_arr[1])" \ |
214 |
"$s2c*($rg_b_arr[$s2t]-$rg_b_arr[1])" |
215 |
ev "$s2c*$tn_r_arr[$s2t]" "$s2c*$tn_g_arr[$s2t]" "$s2c*$tn_b_arr[$s2t]" |
216 |
echo " -1 $s2c" |
217 |
endif |
218 |
else |
219 |
### Low-E glazing |
220 |
echo "10" |
221 |
echo " sr_lowE_r sr_lowE_g sr_lowE_b" |
222 |
echo " st_lowE_r st_lowE_g st_lowE_b" |
223 |
echo " 0 0 0" |
224 |
225 |
echo "0" |
226 |
echo "19" |
227 |
echo " 0 0 0" |
228 |
echo " 0 0 0" |
229 |
echo " 0 0 0" |
230 |
231 |
echo " 1" |
232 |
set st=$s1t |
233 |
else |
234 |
echo " -1" |
235 |
set st=$s2t |
236 |
endif |
237 |
echo " $rg_r_arr[$st] $rg_g_arr[$st] $rg_b_arr[$st]" |
238 |
echo " $rc_r_arr[$st] $rc_g_arr[$st] $rc_b_arr[$st]" |
239 |
echo " $tn_r_arr[$st] $tn_g_arr[$st] $tn_b_arr[$st]" |
240 |
endif |
241 |
echo "" |
242 |
exit 0 |
243 |
244 |
glaze2: |
245 |
246 |
247 |
# Compute double glazing |
248 |
249 |
if ($s2t != 1) then |
250 |
set s2r_rgb=($rc_r_arr[$s2t] $rc_g_arr[$s2t] $rc_b_arr[$s2t]) |
251 |
set s1r_rgb=($rg_r_arr[$s2t] $rg_g_arr[$s2t] $rg_b_arr[$s2t]) |
252 |
set s12t_rgb=($tn_r_arr[$s2t] $tn_g_arr[$s2t] $tn_b_arr[$s2t]) |
253 |
else |
254 |
set s2r_rgb=($rg_r_arr[$s1t] $rg_g_arr[$s1t] $rg_b_arr[$s1t]) |
255 |
set s1r_rgb=($rc_r_arr[$s1t] $rc_g_arr[$s1t] $rc_b_arr[$s1t]) |
256 |
set s12t_rgb=($tn_r_arr[$s1t] $tn_g_arr[$s1t] $tn_b_arr[$s1t]) |
257 |
endif |
258 |
if ($s4t != 1) then |
259 |
set s4r_rgb=($rc_r_arr[$s4t] $rc_g_arr[$s4t] $rc_b_arr[$s4t]) |
260 |
set s3r_rgb=($rg_r_arr[$s4t] $rg_g_arr[$s4t] $rg_b_arr[$s4t]) |
261 |
set s34t_rgb=($tn_r_arr[$s4t] $tn_g_arr[$s4t] $tn_b_arr[$s4t]) |
262 |
else |
263 |
set s4r_rgb=($rg_r_arr[$s3t] $rg_g_arr[$s3t] $rg_b_arr[$s3t]) |
264 |
set s3r_rgb=($rc_r_arr[$s3t] $rc_g_arr[$s3t] $rc_b_arr[$s3t]) |
265 |
set s34t_rgb=($tn_r_arr[$s3t] $tn_g_arr[$s3t] $tn_b_arr[$s3t]) |
266 |
endif |
267 |
set s12c=1 |
268 |
269 |
if ($?s1c) then |
270 |
271 |
set s12c=$s1c |
272 |
endif |
273 |
echo "# Inner surface s2 type: $sn_arr[$s2t]" |
274 |
if ($?s2c) then |
275 |
276 |
set s12c=$s2c |
277 |
endif |
278 |
set s34c=1 |
279 |
echo "# Inner surface s3 type: $sn_arr[$s3t]" |
280 |
if ($?s3c) then |
281 |
echo "# s3 coating coverage: $s3c" |
282 |
set s34c=$s3c |
283 |
endif |
284 |
echo "# Interior surface s4 type: $sn_arr[$s4t]" |
285 |
if ($?s4c) then |
286 |
echo "# s4 coating coverage: $s4c" |
287 |
set s34c=$s4c |
288 |
endif |
289 |
# Approximate reflectance and transmittance for comment using gray values |
290 |
set rglass=`ev ".265*$rg_r_arr[1]+.670*$rg_g_arr[1]+.065*$rg_b_arr[1]"` |
291 |
set tglass=`ev ".265*$tn_r_arr[1]+.670*$tn_g_arr[1]+.065*$tn_b_arr[1]"` |
292 |
set s1r_gry=`ev "$s12c*(.265*$s1r_rgb[1]+.670*$s1r_rgb[2]+.065*$s1r_rgb[3])+(1-$s12c)*$rglass"` |
293 |
set s2r_gry=`ev "$s12c*(.265*$s2r_rgb[1]+.670*$s2r_rgb[2]+.065*$s2r_rgb[3])+(1-$s12c)*$rglass"` |
294 |
set s12t_gry=`ev "$s12c*(.265*$s12t_rgb[1]+.670*$s12t_rgb[2]+.065*$s12t_rgb[3])+(1-$s12c)*$tglass"` |
295 |
set s3r_gry=`ev "$s34c*(.265*$s3r_rgb[1]+.670*$s3r_rgb[2]+.065*$s3r_rgb[3])+(1-$s34c)*$rglass"` |
296 |
set s4r_gry=`ev "$s34c*(.265*$s4r_rgb[1]+.670*$s4r_rgb[2]+.065*$s4r_rgb[3])+(1-$s34c)*$rglass"` |
297 |
set s34t_gry=`ev "$s34c*(.265*$s34t_rgb[1]+.670*$s34t_rgb[2]+.065*$s34t_rgb[3])+(1-$s34c)*$tglass"` |
298 |
299 |
ev "$s1r_gry + $s12t_gry^2*$s3r_gry" |
300 |
301 |
ev "$s4r_gry + $s34t_gry^2*$s2r_gry" |
302 |
303 |
ev "$s12t_gry*$s34t_gry" |
304 |
echo "#" |
305 |
echo "void BRTDfunc glaze2_unnamed" |
306 |
307 |
if ($part_arr[$s3t] || $part_arr[$s4t]) then |
308 |
### Front pane has frit |
309 |
310 |
echo "Only one pane can have frit" |
311 |
exit 1 |
312 |
endif |
313 |
if ($?s3c) then |
314 |
set sc=$s3c |
315 |
set s3g=`ev "1-$s3c"` |
316 |
else |
317 |
set s3c=0 |
318 |
set s3g=1 |
319 |
endif |
320 |
if ($?s4c) then |
321 |
set sc=$s4c |
322 |
set s4g=`ev "1-$s4c"` |
323 |
else |
324 |
set s4c=0 |
325 |
set s4g=1 |
326 |
endif |
327 |
echo "10" |
328 |
echo "if(Rdot,cr($s4g*rclr,$s3g*$s4g*tclr,fr($s2r_rgb[1])),cr(fr($s1r_rgb[1]),ft($s12t_rgb[1]),$s3g*rclr))" |
329 |
echo "if(Rdot,cr($s4g*rclr,$s3g*$s4g*tclr,fr($s2r_rgb[2])),cr(fr($s1r_rgb[2]),ft($s12t_rgb[2]),$s3g*rclr))" |
330 |
echo "if(Rdot,cr($s4g*rclr,$s3g*$s4g*tclr,fr($s2r_rgb[3])),cr(fr($s1r_rgb[3]),ft($s12t_rgb[3]),$s3g*rclr))" |
331 |
echo "$s3g*$s4g*ft($s12t_rgb[1])*tclr" |
332 |
echo "$s3g*$s4g*ft($s12t_rgb[2])*tclr" |
333 |
echo "$s3g*$s4g*ft($s12t_rgb[3])*tclr" |
334 |
echo " 0 0 0" |
335 |
echo " glaze2.cal" |
336 |
echo "0" |
337 |
echo "9" |
338 |
ev "$sc*$s4r_rgb[1]-$s3c*$rg_r_arr[1]" \ |
339 |
"$sc*$s4r_rgb[2]-$s3c*$rg_g_arr[1]" \ |
340 |
"$sc*$s4r_rgb[3]-$s3c*$rg_b_arr[1]" |
341 |
ev "$s12t_rgb[1]^2*($sc*$s3r_rgb[1]-$s4c*$rg_r_arr[1])" \ |
342 |
"$s12t_rgb[2]^2*($sc*$s3r_rgb[2]-$s4c*$rg_g_arr[1])" \ |
343 |
"$s12t_rgb[3]^2*($sc*$s3r_rgb[3]-$s4c*$rg_b_arr[1])" |
344 |
ev "$sc*$s12t_rgb[1]*$s34t_rgb[1]" \ |
345 |
"$sc*$s12t_rgb[2]*$s34t_rgb[2]" \ |
346 |
"$sc*$s12t_rgb[3]*$s34t_rgb[3]" |
347 |
else if ($part_arr[$s1t] || $part_arr[$s2t]) then |
348 |
### Back pane has frit |
349 |
if ($?s1c) then |
350 |
set sc=$s1c |
351 |
set s1g=`ev "1-$s1c"` |
352 |
else |
353 |
set s1c=0 |
354 |
set s1g=1 |
355 |
endif |
356 |
if ($?s2c) then |
357 |
set sc=$s2c |
358 |
set s2g=`ev "1-$s2c"` |
359 |
else |
360 |
set s2c=0 |
361 |
set s2g=1 |
362 |
endif |
363 |
echo "10" |
364 |
echo "if(Rdot,cr(fr($s4r_rgb[1]),ft($s34t_rgb[1]),$s2g*rclr),cr($s1g*rclr,$s1g*$s2g*tclr,fr($s3r_rgb[1])))" |
365 |
echo "if(Rdot,cr(fr($s4r_rgb[2]),ft($s34t_rgb[2]),$s2g*rclr),cr($s1g*rclr,$s1g*$s2g*tclr,fr($s3r_rgb[2])))" |
366 |
echo "if(Rdot,cr(fr($s4r_rgb[3]),ft($s34t_rgb[3]),$s2g*rclr),cr($s1g*rclr,$s1g*$s2g*tclr,fr($s3r_rgb[3])))" |
367 |
echo "$s1g*$s2g*ft($s34t_rgb[1])*tclr" |
368 |
echo "$s1g*$s2g*ft($s34t_rgb[2])*tclr" |
369 |
echo "$s1g*$s2g*ft($s34t_rgb[3])*tclr" |
370 |
echo " 0 0 0" |
371 |
372 |
echo "0" |
373 |
echo "9" |
374 |
ev "$s34t_rgb[1]^2*($sc*$s2r_rgb[1]-$s1c*$rg_r_arr[1])" \ |
375 |
"$s34t_rgb[2]^2*($sc*$s2r_rgb[2]-$s1c*$rg_g_arr[1])" \ |
376 |
"$s34t_rgb[3]^2*($sc*$s2r_rgb[3]-$s1c*$rg_b_arr[1])" |
377 |
ev "$sc*$s1r_rgb[1]-$s2c*$rg_r_arr[1]" \ |
378 |
"$sc*$s1r_rgb[2]-$s2c*$rg_g_arr[1]" \ |
379 |
"$sc*$s1r_rgb[3]-$s2c*$rg_b_arr[1]" |
380 |
ev "$sc*$s34t_rgb[1]*$s12t_rgb[1]" \ |
381 |
"$sc*$s34t_rgb[2]*$s12t_rgb[2]" \ |
382 |
"$sc*$s34t_rgb[3]*$s12t_rgb[3]" |
383 |
else |
384 |
### Low-E and regular glazing only |
385 |
echo "10" |
386 |
echo "if(Rdot,cr(fr($s4r_rgb[1]),ft($s34t_rgb[1]),fr($s2r_rgb[1])),cr(fr($s1r_rgb[1]),ft($s12t_rgb[1]),fr($s3r_rgb[1])))" |
387 |
echo "if(Rdot,cr(fr($s4r_rgb[2]),ft($s34t_rgb[2]),fr($s2r_rgb[2])),cr(fr($s1r_rgb[2]),ft($s12t_rgb[2]),fr($s3r_rgb[2])))" |
388 |
echo "if(Rdot,cr(fr($s4r_rgb[3]),ft($s34t_rgb[3]),fr($s2r_rgb[3])),cr(fr($s1r_rgb[3]),ft($s12t_rgb[3]),fr($s3r_rgb[3])))" |
389 |
echo "ft($s34t_rgb[1])*ft($s12t_rgb[1])" |
390 |
echo "ft($s34t_rgb[2])*ft($s12t_rgb[2])" |
391 |
echo "ft($s34t_rgb[3])*ft($s12t_rgb[3])" |
392 |
echo " 0 0 0" |
393 |
394 |
echo "0" |
395 |
echo "9" |
396 |
echo " 0 0 0" |
397 |
echo " 0 0 0" |
398 |
echo " 0 0 0" |
399 |
endif |
400 |
echo "" |
401 |
exit 0 |
