root/radiance/ray/src/gen/glaze.csh
Revision: 2.4
Committed: Wed Aug 25 01:40:12 2004 UTC (19 years, 9 months ago) by greg
Content type: application/x-csh
Changes since 2.3: +6 -5 lines
Added missing partial boolean (Jack fixed this)
1 #!/bin/csh -f
2 # RCSid: $Id: glaze.csh,v 2.3 2004/08/14 19:36:38 greg Exp $
3 #
4 # Complex glazing model (goes with glaze1.cal and glaze2.cal)
5 #
6 # Oct. 2002 Greg Ward
7 # Aug. 2004 GW (added -f option to read glazings from file)
8 # Funding for this development generously provided by Visarc, Inc.
9 # (http://www.visarc.com)
10 #
11
12 #################################################################
13 #
14 # Supported surface types:
15 #
16 set sn_arr=("clear glass" "VE1-2M low-E coating" "PVB laminated" "V-175 white frit" "V-933 warm gray frit")
17 # Glass-side hemispherical reflectances for each surface type:
18 set rg_r_arr=(0.074 0.065 .11 0.33 0.15)
19 set rg_g_arr=(0.077 0.058 .11 0.33 0.15)
20 set rg_b_arr=(0.079 0.067 .11 0.33 0.15)
21 # Coating-side hemispherical reflectance for each surface type:
22 set rc_r_arr=(0.074 0.042 .11 0.59 0.21)
23 set rc_g_arr=(0.077 0.049 .11 0.59 0.21)
24 set rc_b_arr=(0.079 0.043 .11 0.59 0.21)
25 # Hemispherical (normal) transmittance for each surface type:
26 set tn_r_arr=(0.862 0.756 0.63 0.21 0.09)
27 set tn_g_arr=(0.890 0.808 0.63 0.21 0.09)
28 set tn_b_arr=(0.886 0.744 0.63 0.21 0.09)
29 # Boolean whether coatings can have partial coverage:
30 set part_arr=(0 0 0 1 1)
31
32 while ($#argv > 0)
33 set header="Surface Tr Tg Tb Rcr Rcg Rcb Rgr Rgg Rgb Part"
34 if ($#argv < 2 || "$argv[1]" != '-f') then
35 echo "Usage: $0 [-f glazing.dat ..]"
36 exit 1
37 endif
38 shift argv
39 set gf="$argv[1]"
40 shift argv
41 if ("`sed -n 1p $gf:q`" != "$header") then
42 echo "Bad header in $gf -- Expected: $header"
43 exit 1
44 endif
45 echo "Adding glazing types from file $gf :"
46 set nl=`wc -l < $gf:q`
47 @ i=2
48 while ($i <= $nl)
49 set ln=(`sed -n ${i}p $gf:q`)
50 if ($#ln != 11) then
51 echo "Expected 11 words in line: $ln"
52 exit 1
53 endif
54 echo $ln[1]
55 set sn_arr=($sn_arr:q $ln[1])
56 set tn_r_arr=($tn_r_arr $ln[2])
57 set tn_g_arr=($tn_g_arr $ln[3])
58 set tn_b_arr=($tn_b_arr $ln[4])
59 set rc_r_arr=($rc_r_arr $ln[5])
60 set rc_g_arr=($rc_g_arr $ln[6])
61 set rc_b_arr=($rc_b_arr $ln[7])
62 set rg_r_arr=($rc_r_arr $ln[8])
63 set rg_g_arr=($rc_g_arr $ln[9])
64 set rg_b_arr=($rc_b_arr $ln[10])
65 set part_arr=($part_arr $ln[11])
66 @ i++
67 end
68 end
69
70 #################################################################
71 #
72 # Get user input
73 #
74 echo -n "Enter the number of panes in the system: "
75 set np="$<"
76 if ($np != 1 && $np != 2) then
77 echo "Must be 1 or 2 pane system"
78 exit 1
79 endif
80 echo ""
81 echo "Window normal faces interior"
82 echo ""
83 if ($np == 1) then
84 echo " | |"
85 echo " | |"
86 echo " | |"
87 echo " | |-->"
88 echo " | |"
89 echo " | |"
90 echo " | |"
91 echo " s1 s2"
92 else
93 echo " | | | |"
94 echo " | | | |"
95 echo " | | | |"
96 echo " | | | |-->"
97 echo " | | | |"
98 echo " | | | |"
99 echo " | | | |"
100 echo " s1 s2 s3 s4"
101 endif
102 echo ""
103 echo "Supported surface types are:"
104 set i=1
105 while ($i <= $#sn_arr)
106 echo " " $i - $sn_arr[$i]
107 @ i++
108 end
109 echo ""
110 echo -n "What is the type of s1? "
111 set s1t="$<"
112 echo -n "What is the type of s2? "
113 set s2t="$<"
114 if ($s1t != 1 && $s2t != 1) then
115 echo "One surface of each pane must be $sn_arr[1]"
116 exit 1
117 endif
118 if ($part_arr[$s1t]) then
119 echo -n "Enter fraction coverage for s1 (0-1): "
120 set s1c="$<"
121 endif
122 if ($part_arr[$s2t]) then
123 echo -n "Enter fraction coverage for s2 (0-1): "
124 set s2c="$<"
125 endif
126 if ($np == 2) then
127 echo -n "What is the type of s3? "
128 set s3t="$<"
129 echo -n "What is the type of s4? "
130 set s4t="$<"
131 if ($s3t != 1 && $s4t != 1) then
132 echo "One surface of each pane must be $sn_arr[1]"
133 exit 1
134 endif
135 if ($part_arr[$s3t]) then
136 echo -n "Enter fraction coverage for s3 (0-1): "
137 set s3c="$<"
138 endif
139 if ($part_arr[$s4t]) then
140 echo -n "Enter fraction coverage for s4 (0-1): "
141 set s4c="$<"
142 endif
143 endif
144
145 #################################################################
146 #
147 # Begin material comments
148 #
149 echo ""
150 echo "############################################"
151 echo "# Glazing produced by Radiance glaze script"
152 echo "# `date`"
153 echo "# Material surface normal points to interior"
154 echo "# Number of panes in system: $np"
155
156 if ($np == 2) goto glaze2
157 #################################################################
158 #
159 # Compute single glazing
160 #
161 set sc=1
162 echo "# Exterior surface s1 type: $sn_arr[$s1t]"
163 if ($?s1c) then
164 echo "# s1 coating coverage: $s1c"
165 set sc=$s1c
166 endif
167 echo "# Interior surface s2 type: $sn_arr[$s2t]"
168 if ($?s2c) then
169 echo "# s2 coating coverage: $s2c"
170 set sc=$s2c
171 endif
172 if ($s1t != 1) then
173 set ct=$s1t
174 echo -n "# Exterior normal hemispherical reflectance: "
175 ev ".265*($sc*$rc_r_arr[$ct]+(1-$sc)*$rc_r_arr[1])+.670*($sc*$rc_g_arr[$ct]+(1-$sc)*$rc_g_arr[1])+.065*($sc*$rc_b_arr[$ct]+(1-$sc)*$rc_b_arr[1])"
176 echo -n "# Interior normal hemispherical reflectance: "
177 ev ".265*($sc*$rg_r_arr[$ct]+(1-$sc)*$rg_r_arr[1])+.670*($sc*$rg_g_arr[$ct]+(1-$sc)*$rg_g_arr[1])+.065*($sc*$rg_b_arr[$ct]+(1-$sc)*$rg_b_arr[1])"
178 else
179 set ct=$s2t
180 echo -n "# Exterior normal hemispherical reflectance: "
181 ev ".265*($sc*$rg_r_arr[$ct]+(1-$sc)*$rg_r_arr[1])+.670*($sc*$rg_g_arr[$ct]+(1-$sc)*$rg_g_arr[1])+.065*($sc*$rg_b_arr[$ct]+(1-$sc)*$rg_b_arr[1])"
182 echo -n "# Interior normal hemispherical reflectance: "
183 ev ".265*($sc*$rc_r_arr[$ct]+(1-$sc)*$rc_r_arr[1])+.670*($sc*$rc_g_arr[$ct]+(1-$sc)*$rc_g_arr[1])+.065*($sc*$rc_b_arr[$ct]+(1-$sc)*$rc_b_arr[1])"
184 endif
185 echo -n "# Normal hemispherical transmittance: "
186 ev ".265*($sc*$tn_r_arr[$ct]+(1-$sc)*$tn_r_arr[1])+.670*($sc*$tn_g_arr[$ct]+(1-$sc)*$tn_g_arr[1])+.065*($sc*$tn_b_arr[$ct]+(1-$sc)*$tn_b_arr[1])"
187 echo "#"
188 echo "void BRTDfunc glaze1_unnamed"
189 if ($part_arr[$s1t] || $part_arr[$s2t]) then
190 ### Frit glazing
191 echo "10"
192 echo " sr_frit_r sr_frit_g sr_frit_b"
193 echo " st_frit_r st_frit_g st_frit_b"
194 echo " 0 0 0"
195 echo " glaze1.cal"
196 echo "0"
197 echo "11"
198 if ($s2t == 1) then
199 ev "$s1c*($rg_r_arr[$s1t]-$rg_r_arr[1])" \
200 "$s1c*($rg_g_arr[$s1t]-$rg_g_arr[1])" \
201 "$s1c*($rg_b_arr[$s1t]-$rg_b_arr[1])"
202 ev "$s1c*$rc_r_arr[$s1t]" "$s1c*$rc_g_arr[$s1t]" "$s1c*$rc_b_arr[$s1t]"
203 ev "$s1c*$tn_r_arr[$s1t]" "$s1c*$tn_g_arr[$s1t]" "$s1c*$tn_b_arr[$s1t]"
204 echo " 1 $s1c"
205 else
206 ev "$s2c*$rc_r_arr[$s2t]" "$s2c*$rc_g_arr[$s2t]" "$s2c*$rc_b_arr[$s2t]"
207 ev "$s2c*($rg_r_arr[$s2t]-$rg_r_arr[1])" \
208 "$s2c*($rg_g_arr[$s2t]-$rg_g_arr[1])" \
209 "$s2c*($rg_b_arr[$s2t]-$rg_b_arr[1])"
210 ev "$s2c*$tn_r_arr[$s2t]" "$s2c*$tn_g_arr[$s2t]" "$s2c*$tn_b_arr[$s2t]"
211 echo " -1 $s2c"
212 endif
213 else
214 ### Low-E glazing
215 echo "10"
216 echo " sr_lowE_r sr_lowE_g sr_lowE_b"
217 echo " st_lowE_r st_lowE_g st_lowE_b"
218 echo " 0 0 0"
219 echo " glaze1.cal"
220 echo "0"
221 echo "19"
222 echo " 0 0 0"
223 echo " 0 0 0"
224 echo " 0 0 0"
225 if ($s2t == 1) then
226 echo " 1"
227 set st=$s1t
228 else
229 echo " -1"
230 set st=$s2t
231 endif
232 echo " $rg_r_arr[$st] $rg_g_arr[$st] $rg_b_arr[$st]"
233 echo " $rc_r_arr[$st] $rc_g_arr[$st] $rc_b_arr[$st]"
234 echo " $tn_r_arr[$st] $tn_g_arr[$st] $tn_b_arr[$st]"
235 endif
236 echo ""
237 exit 0
238
239 glaze2:
240 #################################################################
241 #
242 # Compute double glazing
243 #
244 if ($s2t != 1) then
245 set s2r_rgb=($rc_r_arr[$s2t] $rc_g_arr[$s2t] $rc_b_arr[$s2t])
246 set s1r_rgb=($rg_r_arr[$s2t] $rg_g_arr[$s2t] $rg_b_arr[$s2t])
247 set s12t_rgb=($tn_r_arr[$s2t] $tn_g_arr[$s2t] $tn_b_arr[$s2t])
248 else
249 set s2r_rgb=($rg_r_arr[$s1t] $rg_g_arr[$s1t] $rg_b_arr[$s1t])
250 set s1r_rgb=($rc_r_arr[$s1t] $rc_g_arr[$s1t] $rc_b_arr[$s1t])
251 set s12t_rgb=($tn_r_arr[$s1t] $tn_g_arr[$s1t] $tn_b_arr[$s1t])
252 endif
253 if ($s4t != 1) then
254 set s4r_rgb=($rc_r_arr[$s4t] $rc_g_arr[$s4t] $rc_b_arr[$s4t])
255 set s3r_rgb=($rg_r_arr[$s4t] $rg_g_arr[$s4t] $rg_b_arr[$s4t])
256 set s34t_rgb=($tn_r_arr[$s4t] $tn_g_arr[$s4t] $tn_b_arr[$s4t])
257 else
258 set s4r_rgb=($rg_r_arr[$s3t] $rg_g_arr[$s3t] $rg_b_arr[$s3t])
259 set s3r_rgb=($rc_r_arr[$s3t] $rc_g_arr[$s3t] $rc_b_arr[$s3t])
260 set s34t_rgb=($tn_r_arr[$s3t] $tn_g_arr[$s3t] $tn_b_arr[$s3t])
261 endif
262 set s12c=1
263 echo "# Exterior surface s1 type: $sn_arr[$s1t]"
264 if ($?s1c) then
265 echo "# s1 coating coverage: $s1c"
266 set s12c=$s1c
267 endif
268 echo "# Inner surface s2 type: $sn_arr[$s2t]"
269 if ($?s2c) then
270 echo "# s2 coating coverage: $s2c"
271 set s12c=$s2c
272 endif
273 set s34c=1
274 echo "# Inner surface s3 type: $sn_arr[$s3t]"
275 if ($?s3c) then
276 echo "# s3 coating coverage: $s3c"
277 set s34c=$s3c
278 endif
279 echo "# Interior surface s4 type: $sn_arr[$s4t]"
280 if ($?s4c) then
281 echo "# s4 coating coverage: $s4c"
282 set s34c=$s4c
283 endif
284 # Approximate reflectance and transmittance for comment using gray values
285 set rglass=`ev ".265*$rg_r_arr[1]+.670*$rg_g_arr[1]+.065*$rg_b_arr[1]"`
286 set tglass=`ev ".265*$tn_r_arr[1]+.670*$tn_g_arr[1]+.065*$tn_b_arr[1]"`
287 set s1r_gry=`ev "$s12c*(.265*$s1r_rgb[1]+.670*$s1r_rgb[2]+.065*$s1r_rgb[3])+(1-$s12c)*$rglass"`
288 set s2r_gry=`ev "$s12c*(.265*$s2r_rgb[1]+.670*$s2r_rgb[2]+.065*$s2r_rgb[3])+(1-$s12c)*$rglass"`
289 set s12t_gry=`ev "$s12c*(.265*$s12t_rgb[1]+.670*$s12t_rgb[2]+.065*$s12t_rgb[3])+(1-$s12c)*$tglass"`
290 set s3r_gry=`ev "$s34c*(.265*$s3r_rgb[1]+.670*$s3r_rgb[2]+.065*$s3r_rgb[3])+(1-$s34c)*$rglass"`
291 set s4r_gry=`ev "$s34c*(.265*$s4r_rgb[1]+.670*$s4r_rgb[2]+.065*$s4r_rgb[3])+(1-$s34c)*$rglass"`
292 set s34t_gry=`ev "$s34c*(.265*$s34t_rgb[1]+.670*$s34t_rgb[2]+.065*$s34t_rgb[3])+(1-$s34c)*$tglass"`
293 echo -n "# Exterior normal hemispherical reflectance: "
294 ev "$s1r_gry + $s12t_gry^2*$s3r_gry"
295 echo -n "# Interior normal hemispherical reflectance: "
296 ev "$s4r_gry + $s34t_gry^2*$s2r_gry"
297 echo -n "# Normal hemispherical transmittance: "
298 ev "$s12t_gry*$s34t_gry"
299 echo "#"
300 echo "void BRTDfunc glaze2_unnamed"
301
302 if ($part_arr[$s3t] || $part_arr[$s4t]) then
303 ### Front pane has frit
304 if ($part_arr[$s1t] || $part_arr[$s2t]) then
305 echo "Only one pane can have frit"
306 exit 1
307 endif
308 if ($?s3c) then
309 set sc=$s3c
310 set s3g=`ev "1-$s3c"`
311 else
312 set s3c=0
313 set s3g=1
314 endif
315 if ($?s4c) then
316 set sc=$s4c
317 set s4g=`ev "1-$s4c"`
318 else
319 set s4c=0
320 set s4g=1
321 endif
322 echo "10"
323 echo "if(Rdot,cr($s4g*rclr,$s3g*$s4g*tclr,fr($s2r_rgb[1])),cr(fr($s1r_rgb[1]),ft($s12t_rgb[1]),$s3g*rclr))"
324 echo "if(Rdot,cr($s4g*rclr,$s3g*$s4g*tclr,fr($s2r_rgb[2])),cr(fr($s1r_rgb[2]),ft($s12t_rgb[2]),$s3g*rclr))"
325 echo "if(Rdot,cr($s4g*rclr,$s3g*$s4g*tclr,fr($s2r_rgb[3])),cr(fr($s1r_rgb[3]),ft($s12t_rgb[3]),$s3g*rclr))"
326 echo "$s3g*$s4g*ft($s12t_rgb[1])*tclr"
327 echo "$s3g*$s4g*ft($s12t_rgb[2])*tclr"
328 echo "$s3g*$s4g*ft($s12t_rgb[3])*tclr"
329 echo " 0 0 0"
330 echo " glaze2.cal"
331 echo "0"
332 echo "9"
333 ev "$sc*$s4r_rgb[1]-$s3c*$rg_r_arr[1]" \
334 "$sc*$s4r_rgb[2]-$s3c*$rg_g_arr[1]" \
335 "$sc*$s4r_rgb[3]-$s3c*$rg_b_arr[1]"
336 ev "$s12t_rgb[1]^2*($sc*$s3r_rgb[1]-$s4c*$rg_r_arr[1])" \
337 "$s12t_rgb[2]^2*($sc*$s3r_rgb[2]-$s4c*$rg_g_arr[1])" \
338 "$s12t_rgb[3]^2*($sc*$s3r_rgb[3]-$s4c*$rg_b_arr[1])"
339 ev "$sc*$s12t_rgb[1]*$s34t_rgb[1]" \
340 "$sc*$s12t_rgb[2]*$s34t_rgb[2]" \
341 "$sc*$s12t_rgb[3]*$s34t_rgb[3]"
342 else if ($part_arr[$s1t] || $part_arr[$s2t]) then
343 ### Back pane has frit
344 if ($?s1c) then
345 set sc=$s1c
346 set s1g=`ev "1-$s1c"`
347 else
348 set s1c=0
349 set s1g=1
350 endif
351 if ($?s2c) then
352 set sc=$s2c
353 set s2g=`ev "1-$s2c"`
354 else
355 set s2c=0
356 set s2g=1
357 endif
358 echo "10"
359 echo "if(Rdot,cr(fr($s4r_rgb[1]),ft($s34t_rgb[1]),$s2g*rclr),cr($s1g*rclr,$s1g*$s2g*tclr,fr($s3r_rgb[1])))"
360 echo "if(Rdot,cr(fr($s4r_rgb[2]),ft($s34t_rgb[2]),$s2g*rclr),cr($s1g*rclr,$s1g*$s2g*tclr,fr($s3r_rgb[2])))"
361 echo "if(Rdot,cr(fr($s4r_rgb[3]),ft($s34t_rgb[3]),$s2g*rclr),cr($s1g*rclr,$s1g*$s2g*tclr,fr($s3r_rgb[3])))"
362 echo "$s1g*$s2g*ft($s34t_rgb[1])*tclr"
363 echo "$s1g*$s2g*ft($s34t_rgb[2])*tclr"
364 echo "$s1g*$s2g*ft($s34t_rgb[3])*tclr"
365 echo " 0 0 0"
366 echo " glaze2.cal"
367 echo "0"
368 echo "9"
369 ev "$s34t_rgb[1]^2*($sc*$s2r_rgb[1]-$s1c*$rg_r_arr[1])" \
370 "$s34t_rgb[2]^2*($sc*$s2r_rgb[2]-$s1c*$rg_g_arr[1])" \
371 "$s34t_rgb[3]^2*($sc*$s2r_rgb[3]-$s1c*$rg_b_arr[1])"
372 ev "$sc*$s1r_rgb[1]-$s2c*$rg_r_arr[1]" \
373 "$sc*$s1r_rgb[2]-$s2c*$rg_g_arr[1]" \
374 "$sc*$s1r_rgb[3]-$s2c*$rg_b_arr[1]"
375 ev "$sc*$s34t_rgb[1]*$s12t_rgb[1]" \
376 "$sc*$s34t_rgb[2]*$s12t_rgb[2]" \
377 "$sc*$s34t_rgb[3]*$s12t_rgb[3]"
378 else
379 ### Low-E and regular glazing only
380 echo "10"
381 echo "if(Rdot,cr(fr($s4r_rgb[1]),ft($s34t_rgb[1]),fr($s2r_rgb[1])),cr(fr($s1r_rgb[1]),ft($s12t_rgb[1]),fr($s3r_rgb[1])))"
382 echo "if(Rdot,cr(fr($s4r_rgb[2]),ft($s34t_rgb[2]),fr($s2r_rgb[2])),cr(fr($s1r_rgb[2]),ft($s12t_rgb[2]),fr($s3r_rgb[2])))"
383 echo "if(Rdot,cr(fr($s4r_rgb[3]),ft($s34t_rgb[3]),fr($s2r_rgb[3])),cr(fr($s1r_rgb[3]),ft($s12t_rgb[3]),fr($s3r_rgb[3])))"
384 echo "ft($s34t_rgb[1])*ft($s12t_rgb[1])"
385 echo "ft($s34t_rgb[2])*ft($s12t_rgb[2])"
386 echo "ft($s34t_rgb[3])*ft($s12t_rgb[3])"
387 echo " 0 0 0"
388 echo " glaze2.cal"
389 echo "0"
390 echo "9"
391 echo " 0 0 0"
392 echo " 0 0 0"
393 echo " 0 0 0"
394 endif
395 echo ""
396 exit 0
