1 |
#!/bin/csh -f |
2 |
# RCSid: $Id: glaze.csh,v 2.1 2003/02/22 02:07:23 greg Exp $ |
3 |
4 |
# Complex glazing model (goes with glaze1.cal and glaze2.cal) |
5 |
6 |
# Oct. 2002 Greg Ward |
7 |
# Funding for this development generously provided by Visarc, Inc. |
8 |
# (http://www.vizarc.com) |
9 |
10 |
11 |
12 |
13 |
# Supported surface types: |
14 |
15 |
set sn_arr=("clear glass" "VE1-2M low-E coating" "PVB laminated" "V-175 white frit" "V-933 warm gray frit") |
16 |
# Glass-side hemispherical reflectances for each surface type: |
17 |
set rg_r_arr=(0.074 0.065 .11 0.33 0.15) |
18 |
set rg_g_arr=(0.077 0.058 .11 0.33 0.15) |
19 |
set rg_b_arr=(0.079 0.067 .11 0.33 0.15) |
20 |
# Coating-side hemispherical reflectance for each surface type: |
21 |
set rc_r_arr=(0.074 0.042 .11 0.59 0.21) |
22 |
set rc_g_arr=(0.077 0.049 .11 0.59 0.21) |
23 |
set rc_b_arr=(0.079 0.043 .11 0.59 0.21) |
24 |
# Hemispherical (normal) transmittance for each surface type: |
25 |
set tn_r_arr=(0.862 0.756 0.63 0.21 0.09) |
26 |
set tn_g_arr=(0.890 0.808 0.63 0.21 0.09) |
27 |
set tn_b_arr=(0.886 0.744 0.63 0.21 0.09) |
28 |
# Boolean whether coatings can have partial coverage: |
29 |
set part_arr=(0 0 0 1 1) |
30 |
31 |
32 |
33 |
# Get user input |
34 |
35 |
echo -n "Enter the number of panes in the system: " |
36 |
set np="$<" |
37 |
if ($np != 1 && $np != 2) then |
38 |
echo "Must be 1 or 2 pane system" |
39 |
exit 1 |
40 |
endif |
41 |
echo "" |
42 |
echo "Window normal faces interior" |
43 |
echo "" |
44 |
if ($np == 1) then |
45 |
echo " | |" |
46 |
echo " | |" |
47 |
echo " | |" |
48 |
echo " | |-->" |
49 |
echo " | |" |
50 |
echo " | |" |
51 |
echo " | |" |
52 |
echo " s1 s2" |
53 |
else |
54 |
echo " | | | |" |
55 |
echo " | | | |" |
56 |
echo " | | | |" |
57 |
echo " | | | |-->" |
58 |
echo " | | | |" |
59 |
echo " | | | |" |
60 |
echo " | | | |" |
61 |
echo " s1 s2 s3 s4" |
62 |
endif |
63 |
echo "" |
64 |
echo "Supported surface types are:" |
65 |
set i=1 |
66 |
while ($i <= $#sn_arr) |
67 |
echo " " $i - $sn_arr[$i] |
68 |
@ i++ |
69 |
end |
70 |
echo "" |
71 |
echo -n "What is the type of s1? " |
72 |
set s1t="$<" |
73 |
echo -n "What is the type of s2? " |
74 |
set s2t="$<" |
75 |
if ($s1t != 1 && $s2t != 1) then |
76 |
echo "One surface of each pane must be $sn_arr[1]" |
77 |
exit 1 |
78 |
endif |
79 |
if ($part_arr[$s1t]) then |
80 |
echo -n "Enter fraction coverage for s1 (0-1): " |
81 |
set s1c="$<" |
82 |
endif |
83 |
if ($part_arr[$s2t]) then |
84 |
echo -n "Enter fraction coverage for s2 (0-1): " |
85 |
set s2c="$<" |
86 |
endif |
87 |
if ($np == 2) then |
88 |
echo -n "What is the type of s3? " |
89 |
set s3t="$<" |
90 |
echo -n "What is the type of s4? " |
91 |
set s4t="$<" |
92 |
if ($s3t != 1 && $s4t != 1) then |
93 |
94 |
exit 1 |
95 |
endif |
96 |
if ($part_arr[$s3t]) then |
97 |
echo -n "Enter fraction coverage for s3 (0-1): " |
98 |
set s3c="$<" |
99 |
endif |
100 |
if ($part_arr[$s4t]) then |
101 |
echo -n "Enter fraction coverage for s4 (0-1): " |
102 |
set s4c="$<" |
103 |
endif |
104 |
endif |
105 |
106 |
107 |
108 |
# Begin material comments |
109 |
110 |
echo "" |
111 |
echo "############################################" |
112 |
echo "# Glazing produced by Radiance glaze script" |
113 |
echo "# `date`" |
114 |
echo "# Material surface normal points to interior" |
115 |
echo "# Number of panes in system: $np" |
116 |
117 |
if ($np == 2) goto glaze2 |
118 |
119 |
120 |
# Compute single glazing |
121 |
122 |
set sc=1 |
123 |
echo "# Exterior surface s1 type: $sn_arr[$s1t]" |
124 |
if ($?s1c) then |
125 |
echo "# s1 coating coverage: $s1c" |
126 |
set sc=$s1c |
127 |
endif |
128 |
echo "# Interior surface s2 type: $sn_arr[$s2t]" |
129 |
if ($?s2c) then |
130 |
echo "# s2 coating coverage: $s2c" |
131 |
set sc=$s2c |
132 |
endif |
133 |
if ($s1t != 1) then |
134 |
set ct=$s1t |
135 |
echo -n "# Exterior normal hemispherical reflectance: " |
136 |
ev ".265*($sc*$rc_r_arr[$ct]+(1-$sc)*$rc_r_arr[1])+.670*($sc*$rc_g_arr[$ct]+(1-$sc)*$rc_g_arr[1])+.065*($sc*$rc_b_arr[$ct]+(1-$sc)*$rc_b_arr[1])" |
137 |
echo -n "# Interior normal hemispherical reflectance: " |
138 |
ev ".265*($sc*$rg_r_arr[$ct]+(1-$sc)*$rg_r_arr[1])+.670*($sc*$rg_g_arr[$ct]+(1-$sc)*$rg_g_arr[1])+.065*($sc*$rg_b_arr[$ct]+(1-$sc)*$rg_b_arr[1])" |
139 |
else |
140 |
set ct=$s2t |
141 |
142 |
143 |
144 |
145 |
endif |
146 |
echo -n "# Normal hemispherical transmittance: " |
147 |
ev ".265*($sc*$tn_r_arr[$ct]+(1-$sc)*$tn_r_arr[1])+.670*($sc*$tn_g_arr[$ct]+(1-$sc)*$tn_g_arr[1])+.065*($sc*$tn_b_arr[$ct]+(1-$sc)*$tn_b_arr[1])" |
148 |
echo "#" |
149 |
echo "void BRTDfunc glaze1_unnamed" |
150 |
if ($part_arr[$s1t] || $part_arr[$s2t]) then |
151 |
### Frit glazing |
152 |
echo "10" |
153 |
echo " sr_frit_r sr_frit_g sr_frit_b" |
154 |
echo " st_frit_r st_frit_g st_frit_b" |
155 |
echo " 0 0 0" |
156 |
echo " glaze1.cal" |
157 |
echo "0" |
158 |
echo "11" |
159 |
if ($s2t == 1) then |
160 |
ev "$s1c*($rg_r_arr[$s1t]-$rg_r_arr[1])" \ |
161 |
"$s1c*($rg_g_arr[$s1t]-$rg_g_arr[1])" \ |
162 |
"$s1c*($rg_b_arr[$s1t]-$rg_b_arr[1])" |
163 |
ev "$s1c*$rc_r_arr[$s1t]" "$s1c*$rc_g_arr[$s1t]" "$s1c*$rc_b_arr[$s1t]" |
164 |
ev "$s1c*$tn_r_arr[$s1t]" "$s1c*$tn_g_arr[$s1t]" "$s1c*$tn_b_arr[$s1t]" |
165 |
echo " 1 $s1c" |
166 |
else |
167 |
ev "$s2c*$rc_r_arr[$s2t]" "$s2c*$rc_g_arr[$s2t]" "$s2c*$rc_b_arr[$s2t]" |
168 |
ev "$s2c*($rg_r_arr[$s2t]-$rg_r_arr[1])" \ |
169 |
"$s2c*($rg_g_arr[$s2t]-$rg_g_arr[1])" \ |
170 |
"$s2c*($rg_b_arr[$s2t]-$rg_b_arr[1])" |
171 |
ev "$s2c*$tn_r_arr[$s2t]" "$s2c*$tn_g_arr[$s2t]" "$s2c*$tn_b_arr[$s2t]" |
172 |
echo " -1 $s2c" |
173 |
endif |
174 |
else |
175 |
### Low-E glazing |
176 |
echo "10" |
177 |
echo " sr_lowE_r sr_lowE_g sr_lowE_b" |
178 |
echo " st_lowE_r st_lowE_g st_lowE_b" |
179 |
echo " 0 0 0" |
180 |
181 |
echo "0" |
182 |
echo "19" |
183 |
echo " 0 0 0" |
184 |
echo " 0 0 0" |
185 |
echo " 0 0 0" |
186 |
187 |
echo " 1" |
188 |
set st=$s1t |
189 |
else |
190 |
echo " -1" |
191 |
set st=$s2t |
192 |
endif |
193 |
echo " $rg_r_arr[$st] $rg_g_arr[$st] $rg_b_arr[$st]" |
194 |
echo " $rc_r_arr[$st] $rc_g_arr[$st] $rc_b_arr[$st]" |
195 |
echo " $tn_r_arr[$st] $tn_g_arr[$st] $tn_b_arr[$st]" |
196 |
endif |
197 |
echo "" |
198 |
exit 0 |
199 |
200 |
glaze2: |
201 |
202 |
203 |
# Compute double glazing |
204 |
205 |
if ($s2t != 1) then |
206 |
set s2r_rgb=($rc_r_arr[$s2t] $rc_g_arr[$s2t] $rc_b_arr[$s2t]) |
207 |
set s1r_rgb=($rg_r_arr[$s2t] $rg_g_arr[$s2t] $rg_b_arr[$s2t]) |
208 |
set s12t_rgb=($tn_r_arr[$s2t] $tn_g_arr[$s2t] $tn_b_arr[$s2t]) |
209 |
else |
210 |
set s2r_rgb=($rg_r_arr[$s1t] $rg_g_arr[$s1t] $rg_b_arr[$s1t]) |
211 |
set s1r_rgb=($rc_r_arr[$s1t] $rc_g_arr[$s1t] $rc_b_arr[$s1t]) |
212 |
set s12t_rgb=($tn_r_arr[$s1t] $tn_g_arr[$s1t] $tn_b_arr[$s1t]) |
213 |
endif |
214 |
if ($s4t != 1) then |
215 |
set s4r_rgb=($rc_r_arr[$s4t] $rc_g_arr[$s4t] $rc_b_arr[$s4t]) |
216 |
set s3r_rgb=($rg_r_arr[$s4t] $rg_g_arr[$s4t] $rg_b_arr[$s4t]) |
217 |
set s34t_rgb=($tn_r_arr[$s4t] $tn_g_arr[$s4t] $tn_b_arr[$s4t]) |
218 |
else |
219 |
set s4r_rgb=($rg_r_arr[$s3t] $rg_g_arr[$s3t] $rg_b_arr[$s3t]) |
220 |
set s3r_rgb=($rc_r_arr[$s3t] $rc_g_arr[$s3t] $rc_b_arr[$s3t]) |
221 |
set s34t_rgb=($tn_r_arr[$s3t] $tn_g_arr[$s3t] $tn_b_arr[$s3t]) |
222 |
endif |
223 |
set s12c=1 |
224 |
225 |
if ($?s1c) then |
226 |
227 |
set s12c=$s1c |
228 |
endif |
229 |
echo "# Inner surface s2 type: $sn_arr[$s2t]" |
230 |
if ($?s2c) then |
231 |
232 |
set s12c=$s2c |
233 |
endif |
234 |
set s34c=1 |
235 |
echo "# Inner surface s3 type: $sn_arr[$s3t]" |
236 |
if ($?s3c) then |
237 |
echo "# s3 coating coverage: $s3c" |
238 |
set s34c=$s3c |
239 |
endif |
240 |
echo "# Interior surface s4 type: $sn_arr[$s4t]" |
241 |
if ($?s4c) then |
242 |
echo "# s4 coating coverage: $s4c" |
243 |
set s34c=$s4c |
244 |
endif |
245 |
# Approximate reflectance and transmittance for comment using gray values |
246 |
set rglass=`ev ".265*$rg_r_arr[1]+.670*$rg_g_arr[1]+.065*$rg_b_arr[1]"` |
247 |
set tglass=`ev ".265*$tn_r_arr[1]+.670*$tn_g_arr[1]+.065*$tn_b_arr[1]"` |
248 |
set s1r_gry=`ev "$s12c*(.265*$s1r_rgb[1]+.670*$s1r_rgb[2]+.065*$s1r_rgb[3])+(1-$s12c)*$rglass"` |
249 |
set s2r_gry=`ev "$s12c*(.265*$s2r_rgb[1]+.670*$s2r_rgb[2]+.065*$s2r_rgb[3])+(1-$s12c)*$rglass"` |
250 |
set s12t_gry=`ev "$s12c*(.265*$s12t_rgb[1]+.670*$s12t_rgb[2]+.065*$s12t_rgb[3])+(1-$s12c)*$tglass"` |
251 |
set s3r_gry=`ev "$s34c*(.265*$s3r_rgb[1]+.670*$s3r_rgb[2]+.065*$s3r_rgb[3])+(1-$s34c)*$rglass"` |
252 |
set s4r_gry=`ev "$s34c*(.265*$s4r_rgb[1]+.670*$s4r_rgb[2]+.065*$s4r_rgb[3])+(1-$s34c)*$rglass"` |
253 |
set s34t_gry=`ev "$s34c*(.265*$s34t_rgb[1]+.670*$s34t_rgb[2]+.065*$s34t_rgb[3])+(1-$s34c)*$tglass"` |
254 |
255 |
ev "$s1r_gry + $s12t_gry^2*$s3r_gry" |
256 |
257 |
ev "$s4r_gry + $s34t_gry^2*$s2r_gry" |
258 |
259 |
ev "$s12t_gry*$s34t_gry" |
260 |
echo "#" |
261 |
echo "void BRTDfunc glaze2_unnamed" |
262 |
263 |
if ($part_arr[$s3t] || $part_arr[$s4t]) then |
264 |
### Front pane has frit |
265 |
266 |
echo "Only one pane can have frit" |
267 |
exit 1 |
268 |
endif |
269 |
if ($?s3c) then |
270 |
set sc=$s3c |
271 |
set s3g=`ev "1-$s3c"` |
272 |
else |
273 |
set s3c=0 |
274 |
set s3g=1 |
275 |
endif |
276 |
if ($?s4c) then |
277 |
set sc=$s4c |
278 |
set s4g=`ev "1-$s4c"` |
279 |
else |
280 |
set s4c=0 |
281 |
set s4g=1 |
282 |
endif |
283 |
echo "10" |
284 |
echo "if(Rdot,cr($s4g*rclr,$s3g*$s4g*tclr,fr($s2r_rgb[1])),cr(fr($s1r_rgb[1]),ft($s12t_rgb[1]),$s3g*rclr))" |
285 |
echo "if(Rdot,cr($s4g*rclr,$s3g*$s4g*tclr,fr($s2r_rgb[2])),cr(fr($s1r_rgb[2]),ft($s12t_rgb[2]),$s3g*rclr))" |
286 |
echo "if(Rdot,cr($s4g*rclr,$s3g*$s4g*tclr,fr($s2r_rgb[3])),cr(fr($s1r_rgb[3]),ft($s12t_rgb[3]),$s3g*rclr))" |
287 |
echo "$s3g*$s4g*ft($s12t_rgb[1])*tclr" |
288 |
echo "$s3g*$s4g*ft($s12t_rgb[2])*tclr" |
289 |
echo "$s3g*$s4g*ft($s12t_rgb[3])*tclr" |
290 |
echo " 0 0 0" |
291 |
echo " glaze2.cal" |
292 |
echo "0" |
293 |
echo "9" |
294 |
ev "$sc*$s4r_rgb[1]-$s3c*$rg_r_arr[1]" \ |
295 |
"$sc*$s4r_rgb[2]-$s3c*$rg_g_arr[1]" \ |
296 |
"$sc*$s4r_rgb[3]-$s3c*$rg_b_arr[1]" |
297 |
ev "$s12t_rgb[1]^2*($sc*$s3r_rgb[1]-$s4c*$rg_r_arr[1])" \ |
298 |
"$s12t_rgb[2]^2*($sc*$s3r_rgb[2]-$s4c*$rg_g_arr[1])" \ |
299 |
"$s12t_rgb[3]^2*($sc*$s3r_rgb[3]-$s4c*$rg_b_arr[1])" |
300 |
ev "$sc*$s12t_rgb[1]*$s34t_rgb[1]" \ |
301 |
"$sc*$s12t_rgb[2]*$s34t_rgb[2]" \ |
302 |
"$sc*$s12t_rgb[3]*$s34t_rgb[3]" |
303 |
else if ($part_arr[$s1t] || $part_arr[$s2t]) then |
304 |
### Back pane has frit |
305 |
if ($?s1c) then |
306 |
set sc=$s1c |
307 |
set s1g=`ev "1-$s1c"` |
308 |
else |
309 |
set s1c=0 |
310 |
set s1g=1 |
311 |
endif |
312 |
if ($?s2c) then |
313 |
set sc=$s2c |
314 |
set s2g=`ev "1-$s2c"` |
315 |
else |
316 |
set s2c=0 |
317 |
set s2g=1 |
318 |
endif |
319 |
echo "10" |
320 |
echo "if(Rdot,cr(fr($s4r_rgb[1]),ft($s34t_rgb[1]),$s2g*rclr),cr($s1g*rclr,$s1g*$s2g*tclr,fr($s3r_rgb[1])))" |
321 |
echo "if(Rdot,cr(fr($s4r_rgb[2]),ft($s34t_rgb[2]),$s2g*rclr),cr($s1g*rclr,$s1g*$s2g*tclr,fr($s3r_rgb[2])))" |
322 |
echo "if(Rdot,cr(fr($s4r_rgb[3]),ft($s34t_rgb[3]),$s2g*rclr),cr($s1g*rclr,$s1g*$s2g*tclr,fr($s3r_rgb[3])))" |
323 |
echo "$s1g*$s2g*ft($s34t_rgb[1])*tclr" |
324 |
echo "$s1g*$s2g*ft($s34t_rgb[2])*tclr" |
325 |
echo "$s1g*$s2g*ft($s34t_rgb[3])*tclr" |
326 |
echo " 0 0 0" |
327 |
328 |
echo "0" |
329 |
echo "9" |
330 |
ev "$s34t_rgb[1]^2*($sc*$s2r_rgb[1]-$s1c*$rg_r_arr[1])" \ |
331 |
"$s34t_rgb[2]^2*($sc*$s2r_rgb[2]-$s1c*$rg_g_arr[1])" \ |
332 |
"$s34t_rgb[3]^2*($sc*$s2r_rgb[3]-$s1c*$rg_b_arr[1])" |
333 |
ev "$sc*$s1r_rgb[1]-$s2c*$rg_r_arr[1]" \ |
334 |
"$sc*$s1r_rgb[2]-$s2c*$rg_g_arr[1]" \ |
335 |
"$sc*$s1r_rgb[3]-$s2c*$rg_b_arr[1]" |
336 |
ev "$sc*$s34t_rgb[1]*$s12t_rgb[1]" \ |
337 |
"$sc*$s34t_rgb[2]*$s12t_rgb[2]" \ |
338 |
"$sc*$s34t_rgb[3]*$s12t_rgb[3]" |
339 |
else |
340 |
### Low-E and regular glazing only |
341 |
echo "10" |
342 |
echo "if(Rdot,cr(fr($s4r_rgb[1]),ft($s34t_rgb[1]),fr($s2r_rgb[1])),cr(fr($s1r_rgb[1]),ft($s12t_rgb[1]),fr($s3r_rgb[1])))" |
343 |
echo "if(Rdot,cr(fr($s4r_rgb[2]),ft($s34t_rgb[2]),fr($s2r_rgb[2])),cr(fr($s1r_rgb[2]),ft($s12t_rgb[2]),fr($s3r_rgb[2])))" |
344 |
echo "if(Rdot,cr(fr($s4r_rgb[3]),ft($s34t_rgb[3]),fr($s2r_rgb[3])),cr(fr($s1r_rgb[3]),ft($s12t_rgb[3]),fr($s3r_rgb[3])))" |
345 |
echo "ft($s34t_rgb[1])*ft($s12t_rgb[1])" |
346 |
echo "ft($s34t_rgb[2])*ft($s12t_rgb[2])" |
347 |
echo "ft($s34t_rgb[3])*ft($s12t_rgb[3])" |
348 |
echo " 0 0 0" |
349 |
350 |
echo "0" |
351 |
echo "9" |
352 |
echo " 0 0 0" |
353 |
echo " 0 0 0" |
354 |
echo " 0 0 0" |
355 |
endif |
356 |
echo "" |
357 |
exit 0 |
