root/radiance/ray/src/gen/glaze.csh
Revision: 2.1
Committed: Sat Feb 22 02:07:23 2003 UTC (22 years, 4 months ago) by greg
Content type: application/x-csh
1 #!/bin/csh -f
2 # RCSid: $Id$
3 #
4 # Complex glazing model (goes with glaze1.cal and glaze2.cal)
5 #
6 # Oct. 2002 Greg Ward
7 #
8
9 #################################################################
10 #
11 # Supported surface types:
12 #
13 set sn_arr=("clear glass" "VE1-2M low-E coating" "PVB laminated" "V-175 white frit" "V-933 warm gray frit")
14 # Glass-side hemispherical reflectances for each surface type:
15 set rg_r_arr=(0.074 0.065 .11 0.33 0.15)
16 set rg_g_arr=(0.077 0.058 .11 0.33 0.15)
17 set rg_b_arr=(0.079 0.067 .11 0.33 0.15)
18 # Coating-side hemispherical reflectance for each surface type:
19 set rc_r_arr=(0.074 0.042 .11 0.59 0.21)
20 set rc_g_arr=(0.077 0.049 .11 0.59 0.21)
21 set rc_b_arr=(0.079 0.043 .11 0.59 0.21)
22 # Hemispherical (normal) transmittance for each surface type:
23 set tn_r_arr=(0.862 0.756 0.63 0.21 0.09)
24 set tn_g_arr=(0.890 0.808 0.63 0.21 0.09)
25 set tn_b_arr=(0.886 0.744 0.63 0.21 0.09)
26 # Boolean whether coatings can have partial coverage:
27 set part_arr=(0 0 0 1 1)
28
29 #################################################################
30 #
31 # Get user input
32 #
33 echo -n "Enter the number of panes in the system: "
34 set np="$<"
35 if ($np != 1 && $np != 2) then
36 echo "Must be 1 or 2 pane system"
37 exit 1
38 endif
39 echo ""
40 echo "Window normal faces interior"
41 echo ""
42 if ($np == 1) then
43 echo " | |"
44 echo " | |"
45 echo " | |"
46 echo " | |-->"
47 echo " | |"
48 echo " | |"
49 echo " | |"
50 echo " s1 s2"
51 else
52 echo " | | | |"
53 echo " | | | |"
54 echo " | | | |"
55 echo " | | | |-->"
56 echo " | | | |"
57 echo " | | | |"
58 echo " | | | |"
59 echo " s1 s2 s3 s4"
60 endif
61 echo ""
62 echo "Supported surface types are:"
63 set i=1
64 while ($i <= $#sn_arr)
65 echo " " $i - $sn_arr[$i]
66 @ i++
67 end
68 echo ""
69 echo -n "What is the type of s1? "
70 set s1t="$<"
71 echo -n "What is the type of s2? "
72 set s2t="$<"
73 if ($s1t != 1 && $s2t != 1) then
74 echo "One surface of each pane must be $sn_arr[1]"
75 exit 1
76 endif
77 if ($part_arr[$s1t]) then
78 echo -n "Enter fraction coverage for s1 (0-1): "
79 set s1c="$<"
80 endif
81 if ($part_arr[$s2t]) then
82 echo -n "Enter fraction coverage for s2 (0-1): "
83 set s2c="$<"
84 endif
85 if ($np == 2) then
86 echo -n "What is the type of s3? "
87 set s3t="$<"
88 echo -n "What is the type of s4? "
89 set s4t="$<"
90 if ($s3t != 1 && $s4t != 1) then
91 echo "One surface of each pane must be $sn_arr[1]"
92 exit 1
93 endif
94 if ($part_arr[$s3t]) then
95 echo -n "Enter fraction coverage for s3 (0-1): "
96 set s3c="$<"
97 endif
98 if ($part_arr[$s4t]) then
99 echo -n "Enter fraction coverage for s4 (0-1): "
100 set s4c="$<"
101 endif
102 endif
103
104 #################################################################
105 #
106 # Begin material comments
107 #
108 echo ""
109 echo "############################################"
110 echo "# Glazing produced by Radiance glaze script"
111 echo "# `date`"
112 echo "# Material surface normal points to interior"
113 echo "# Number of panes in system: $np"
114
115 if ($np == 2) goto glaze2
116 #################################################################
117 #
118 # Compute single glazing
119 #
120 set sc=1
121 echo "# Exterior surface s1 type: $sn_arr[$s1t]"
122 if ($?s1c) then
123 echo "# s1 coating coverage: $s1c"
124 set sc=$s1c
125 endif
126 echo "# Interior surface s2 type: $sn_arr[$s2t]"
127 if ($?s2c) then
128 echo "# s2 coating coverage: $s2c"
129 set sc=$s2c
130 endif
131 if ($s1t != 1) then
132 set ct=$s1t
133 echo -n "# Exterior normal hemispherical reflectance: "
134 ev ".265*($sc*$rc_r_arr[$ct]+(1-$sc)*$rc_r_arr[1])+.670*($sc*$rc_g_arr[$ct]+(1-$sc)*$rc_g_arr[1])+.065*($sc*$rc_b_arr[$ct]+(1-$sc)*$rc_b_arr[1])"
135 echo -n "# Interior normal hemispherical reflectance: "
136 ev ".265*($sc*$rg_r_arr[$ct]+(1-$sc)*$rg_r_arr[1])+.670*($sc*$rg_g_arr[$ct]+(1-$sc)*$rg_g_arr[1])+.065*($sc*$rg_b_arr[$ct]+(1-$sc)*$rg_b_arr[1])"
137 else
138 set ct=$s2t
139 echo -n "# Exterior normal hemispherical reflectance: "
140 ev ".265*($sc*$rg_r_arr[$ct]+(1-$sc)*$rg_r_arr[1])+.670*($sc*$rg_g_arr[$ct]+(1-$sc)*$rg_g_arr[1])+.065*($sc*$rg_b_arr[$ct]+(1-$sc)*$rg_b_arr[1])"
141 echo -n "# Interior normal hemispherical reflectance: "
142 ev ".265*($sc*$rc_r_arr[$ct]+(1-$sc)*$rc_r_arr[1])+.670*($sc*$rc_g_arr[$ct]+(1-$sc)*$rc_g_arr[1])+.065*($sc*$rc_b_arr[$ct]+(1-$sc)*$rc_b_arr[1])"
143 endif
144 echo -n "# Normal hemispherical transmittance: "
145 ev ".265*($sc*$tn_r_arr[$ct]+(1-$sc)*$tn_r_arr[1])+.670*($sc*$tn_g_arr[$ct]+(1-$sc)*$tn_g_arr[1])+.065*($sc*$tn_b_arr[$ct]+(1-$sc)*$tn_b_arr[1])"
146 echo "#"
147 echo "void BRTDfunc glaze1_unnamed"
148 if ($part_arr[$s1t] || $part_arr[$s2t]) then
149 ### Frit glazing
150 echo "10"
151 echo " sr_frit_r sr_frit_g sr_frit_b"
152 echo " st_frit_r st_frit_g st_frit_b"
153 echo " 0 0 0"
154 echo " glaze1.cal"
155 echo "0"
156 echo "11"
157 if ($s2t == 1) then
158 ev "$s1c*($rg_r_arr[$s1t]-$rg_r_arr[1])" \
159 "$s1c*($rg_g_arr[$s1t]-$rg_g_arr[1])" \
160 "$s1c*($rg_b_arr[$s1t]-$rg_b_arr[1])"
161 ev "$s1c*$rc_r_arr[$s1t]" "$s1c*$rc_g_arr[$s1t]" "$s1c*$rc_b_arr[$s1t]"
162 ev "$s1c*$tn_r_arr[$s1t]" "$s1c*$tn_g_arr[$s1t]" "$s1c*$tn_b_arr[$s1t]"
163 echo " 1 $s1c"
164 else
165 ev "$s2c*$rc_r_arr[$s2t]" "$s2c*$rc_g_arr[$s2t]" "$s2c*$rc_b_arr[$s2t]"
166 ev "$s2c*($rg_r_arr[$s2t]-$rg_r_arr[1])" \
167 "$s2c*($rg_g_arr[$s2t]-$rg_g_arr[1])" \
168 "$s2c*($rg_b_arr[$s2t]-$rg_b_arr[1])"
169 ev "$s2c*$tn_r_arr[$s2t]" "$s2c*$tn_g_arr[$s2t]" "$s2c*$tn_b_arr[$s2t]"
170 echo " -1 $s2c"
171 endif
172 else
173 ### Low-E glazing
174 echo "10"
175 echo " sr_lowE_r sr_lowE_g sr_lowE_b"
176 echo " st_lowE_r st_lowE_g st_lowE_b"
177 echo " 0 0 0"
178 echo " glaze1.cal"
179 echo "0"
180 echo "19"
181 echo " 0 0 0"
182 echo " 0 0 0"
183 echo " 0 0 0"
184 if ($s2t == 1) then
185 echo " 1"
186 set st=$s1t
187 else
188 echo " -1"
189 set st=$s2t
190 endif
191 echo " $rg_r_arr[$st] $rg_g_arr[$st] $rg_b_arr[$st]"
192 echo " $rc_r_arr[$st] $rc_g_arr[$st] $rc_b_arr[$st]"
193 echo " $tn_r_arr[$st] $tn_g_arr[$st] $tn_b_arr[$st]"
194 endif
195 echo ""
196 exit 0
197
198 glaze2:
199 #################################################################
200 #
201 # Compute double glazing
202 #
203 if ($s2t != 1) then
204 set s2r_rgb=($rc_r_arr[$s2t] $rc_g_arr[$s2t] $rc_b_arr[$s2t])
205 set s1r_rgb=($rg_r_arr[$s2t] $rg_g_arr[$s2t] $rg_b_arr[$s2t])
206 set s12t_rgb=($tn_r_arr[$s2t] $tn_g_arr[$s2t] $tn_b_arr[$s2t])
207 else
208 set s2r_rgb=($rg_r_arr[$s1t] $rg_g_arr[$s1t] $rg_b_arr[$s1t])
209 set s1r_rgb=($rc_r_arr[$s1t] $rc_g_arr[$s1t] $rc_b_arr[$s1t])
210 set s12t_rgb=($tn_r_arr[$s1t] $tn_g_arr[$s1t] $tn_b_arr[$s1t])
211 endif
212 if ($s4t != 1) then
213 set s4r_rgb=($rc_r_arr[$s4t] $rc_g_arr[$s4t] $rc_b_arr[$s4t])
214 set s3r_rgb=($rg_r_arr[$s4t] $rg_g_arr[$s4t] $rg_b_arr[$s4t])
215 set s34t_rgb=($tn_r_arr[$s4t] $tn_g_arr[$s4t] $tn_b_arr[$s4t])
216 else
217 set s4r_rgb=($rg_r_arr[$s3t] $rg_g_arr[$s3t] $rg_b_arr[$s3t])
218 set s3r_rgb=($rc_r_arr[$s3t] $rc_g_arr[$s3t] $rc_b_arr[$s3t])
219 set s34t_rgb=($tn_r_arr[$s3t] $tn_g_arr[$s3t] $tn_b_arr[$s3t])
220 endif
221 set s12c=1
222 echo "# Exterior surface s1 type: $sn_arr[$s1t]"
223 if ($?s1c) then
224 echo "# s1 coating coverage: $s1c"
225 set s12c=$s1c
226 endif
227 echo "# Inner surface s2 type: $sn_arr[$s2t]"
228 if ($?s2c) then
229 echo "# s2 coating coverage: $s2c"
230 set s12c=$s2c
231 endif
232 set s34c=1
233 echo "# Inner surface s3 type: $sn_arr[$s3t]"
234 if ($?s3c) then
235 echo "# s3 coating coverage: $s3c"
236 set s34c=$s3c
237 endif
238 echo "# Interior surface s4 type: $sn_arr[$s4t]"
239 if ($?s4c) then
240 echo "# s4 coating coverage: $s4c"
241 set s34c=$s4c
242 endif
243 # Approximate reflectance and transmittance for comment using gray values
244 set rglass=`ev ".265*$rg_r_arr[1]+.670*$rg_g_arr[1]+.065*$rg_b_arr[1]"`
245 set tglass=`ev ".265*$tn_r_arr[1]+.670*$tn_g_arr[1]+.065*$tn_b_arr[1]"`
246 set s1r_gry=`ev "$s12c*(.265*$s1r_rgb[1]+.670*$s1r_rgb[2]+.065*$s1r_rgb[3])+(1-$s12c)*$rglass"`
247 set s2r_gry=`ev "$s12c*(.265*$s2r_rgb[1]+.670*$s2r_rgb[2]+.065*$s2r_rgb[3])+(1-$s12c)*$rglass"`
248 set s12t_gry=`ev "$s12c*(.265*$s12t_rgb[1]+.670*$s12t_rgb[2]+.065*$s12t_rgb[3])+(1-$s12c)*$tglass"`
249 set s3r_gry=`ev "$s34c*(.265*$s3r_rgb[1]+.670*$s3r_rgb[2]+.065*$s3r_rgb[3])+(1-$s34c)*$rglass"`
250 set s4r_gry=`ev "$s34c*(.265*$s4r_rgb[1]+.670*$s4r_rgb[2]+.065*$s4r_rgb[3])+(1-$s34c)*$rglass"`
251 set s34t_gry=`ev "$s34c*(.265*$s34t_rgb[1]+.670*$s34t_rgb[2]+.065*$s34t_rgb[3])+(1-$s34c)*$tglass"`
252 echo -n "# Exterior normal hemispherical reflectance: "
253 ev "$s1r_gry + $s12t_gry^2*$s3r_gry"
254 echo -n "# Interior normal hemispherical reflectance: "
255 ev "$s4r_gry + $s34t_gry^2*$s2r_gry"
256 echo -n "# Normal hemispherical transmittance: "
257 ev "$s12t_gry*$s34t_gry"
258 echo "#"
259 echo "void BRTDfunc glaze2_unnamed"
260
261 if ($part_arr[$s3t] || $part_arr[$s4t]) then
262 ### Front pane has frit
263 if ($part_arr[$s1t] || $part_arr[$s2t]) then
264 echo "Only one pane can have frit"
265 exit 1
266 endif
267 if ($?s3c) then
268 set sc=$s3c
269 set s3g=`ev "1-$s3c"`
270 else
271 set s3c=0
272 set s3g=1
273 endif
274 if ($?s4c) then
275 set sc=$s4c
276 set s4g=`ev "1-$s4c"`
277 else
278 set s4c=0
279 set s4g=1
280 endif
281 echo "10"
282 echo "if(Rdot,cr($s4g*rclr,$s3g*$s4g*tclr,fr($s2r_rgb[1])),cr(fr($s1r_rgb[1]),ft($s12t_rgb[1]),$s3g*rclr))"
283 echo "if(Rdot,cr($s4g*rclr,$s3g*$s4g*tclr,fr($s2r_rgb[2])),cr(fr($s1r_rgb[2]),ft($s12t_rgb[2]),$s3g*rclr))"
284 echo "if(Rdot,cr($s4g*rclr,$s3g*$s4g*tclr,fr($s2r_rgb[3])),cr(fr($s1r_rgb[3]),ft($s12t_rgb[3]),$s3g*rclr))"
285 echo "$s3g*$s4g*ft($s12t_rgb[1])*tclr"
286 echo "$s3g*$s4g*ft($s12t_rgb[2])*tclr"
287 echo "$s3g*$s4g*ft($s12t_rgb[3])*tclr"
288 echo " 0 0 0"
289 echo " glaze2.cal"
290 echo "0"
291 echo "9"
292 ev "$sc*$s4r_rgb[1]-$s3c*$rg_r_arr[1]" \
293 "$sc*$s4r_rgb[2]-$s3c*$rg_g_arr[1]" \
294 "$sc*$s4r_rgb[3]-$s3c*$rg_b_arr[1]"
295 ev "$s12t_rgb[1]^2*($sc*$s3r_rgb[1]-$s4c*$rg_r_arr[1])" \
296 "$s12t_rgb[2]^2*($sc*$s3r_rgb[2]-$s4c*$rg_g_arr[1])" \
297 "$s12t_rgb[3]^2*($sc*$s3r_rgb[3]-$s4c*$rg_b_arr[1])"
298 ev "$sc*$s12t_rgb[1]*$s34t_rgb[1]" \
299 "$sc*$s12t_rgb[2]*$s34t_rgb[2]" \
300 "$sc*$s12t_rgb[3]*$s34t_rgb[3]"
301 else if ($part_arr[$s1t] || $part_arr[$s2t]) then
302 ### Back pane has frit
303 if ($?s1c) then
304 set sc=$s1c
305 set s1g=`ev "1-$s1c"`
306 else
307 set s1c=0
308 set s1g=1
309 endif
310 if ($?s2c) then
311 set sc=$s2c
312 set s2g=`ev "1-$s2c"`
313 else
314 set s2c=0
315 set s2g=1
316 endif
317 echo "10"
318 echo "if(Rdot,cr(fr($s4r_rgb[1]),ft($s34t_rgb[1]),$s2g*rclr),cr($s1g*rclr,$s1g*$s2g*tclr,fr($s3r_rgb[1])))"
319 echo "if(Rdot,cr(fr($s4r_rgb[2]),ft($s34t_rgb[2]),$s2g*rclr),cr($s1g*rclr,$s1g*$s2g*tclr,fr($s3r_rgb[2])))"
320 echo "if(Rdot,cr(fr($s4r_rgb[3]),ft($s34t_rgb[3]),$s2g*rclr),cr($s1g*rclr,$s1g*$s2g*tclr,fr($s3r_rgb[3])))"
321 echo "$s1g*$s2g*ft($s34t_rgb[1])*tclr"
322 echo "$s1g*$s2g*ft($s34t_rgb[2])*tclr"
323 echo "$s1g*$s2g*ft($s34t_rgb[3])*tclr"
324 echo " 0 0 0"
325 echo " glaze2.cal"
326 echo "0"
327 echo "9"
328 ev "$s34t_rgb[1]^2*($sc*$s2r_rgb[1]-$s1c*$rg_r_arr[1])" \
329 "$s34t_rgb[2]^2*($sc*$s2r_rgb[2]-$s1c*$rg_g_arr[1])" \
330 "$s34t_rgb[3]^2*($sc*$s2r_rgb[3]-$s1c*$rg_b_arr[1])"
331 ev "$sc*$s1r_rgb[1]-$s2c*$rg_r_arr[1]" \
332 "$sc*$s1r_rgb[2]-$s2c*$rg_g_arr[1]" \
333 "$sc*$s1r_rgb[3]-$s2c*$rg_b_arr[1]"
334 ev "$sc*$s34t_rgb[1]*$s12t_rgb[1]" \
335 "$sc*$s34t_rgb[2]*$s12t_rgb[2]" \
336 "$sc*$s34t_rgb[3]*$s12t_rgb[3]"
337 else
338 ### Low-E and regular glazing only
339 echo "10"
340 echo "if(Rdot,cr(fr($s4r_rgb[1]),ft($s34t_rgb[1]),fr($s2r_rgb[1])),cr(fr($s1r_rgb[1]),ft($s12t_rgb[1]),fr($s3r_rgb[1])))"
341 echo "if(Rdot,cr(fr($s4r_rgb[2]),ft($s34t_rgb[2]),fr($s2r_rgb[2])),cr(fr($s1r_rgb[2]),ft($s12t_rgb[2]),fr($s3r_rgb[2])))"
342 echo "if(Rdot,cr(fr($s4r_rgb[3]),ft($s34t_rgb[3]),fr($s2r_rgb[3])),cr(fr($s1r_rgb[3]),ft($s12t_rgb[3]),fr($s3r_rgb[3])))"
343 echo "ft($s34t_rgb[1])*ft($s12t_rgb[1])"
344 echo "ft($s34t_rgb[2])*ft($s12t_rgb[2])"
345 echo "ft($s34t_rgb[3])*ft($s12t_rgb[3])"
346 echo " 0 0 0"
347 echo " glaze2.cal"
348 echo "0"
349 echo "9"
350 echo " 0 0 0"
351 echo " 0 0 0"
352 echo " 0 0 0"
353 endif
354 echo ""
355 exit 0
