root/radiance/ray/src/gen/glaze.csh
Revision: 2.7
Committed: Mon Feb 11 19:18:25 2008 UTC (16 years, 4 months ago) by greg
Content type: application/x-csh
Changed naming of specular component
1 #!/bin/csh -f
2 # RCSid: $Id: glaze.csh,v 2.6 2008/02/11 19:13:05 greg Exp $
3 #
4 # Complex glazing model (goes with glaze1.cal and glaze2.cal)
5 #
6 # Oct. 2002 Greg Ward
7 # Aug. 2004 GW (added -f option to read glazings from file)
8 # Funding for this development generously provided by Visarc, Inc.
9 # (http://www.visarc.com)
10 #
11
12 #################################################################
13 #
14 # The general assumption is that one surface is uncoated, and
15 # reflectances and transmittances are computed from this fact.
16 # If the user tries to enter two coated surfaces on the same
17 # pane, the script complains and exits.
18 #
19 # Supported surface types:
20 #
21 set sn_arr=("clear glass" "VE1-2M low-E coating" "PVB laminated" "V-175 white frit" "V-933 warm gray frit")
22 # Glass-side hemispherical reflectances for each surface type:
23 set rg_r_arr=(0.074 0.065 .11 0.33 0.15)
24 set rg_g_arr=(0.077 0.058 .11 0.33 0.15)
25 set rg_b_arr=(0.079 0.067 .11 0.33 0.15)
26 # Coating-side hemispherical reflectance for each surface type:
27 set rc_r_arr=(0.074 0.042 .11 0.59 0.21)
28 set rc_g_arr=(0.077 0.049 .11 0.59 0.21)
29 set rc_b_arr=(0.079 0.043 .11 0.59 0.21)
30 # Hemispherical (normal) transmittance for each surface type:
31 set tn_r_arr=(0.862 0.756 0.63 0.21 0.09)
32 set tn_g_arr=(0.890 0.808 0.63 0.21 0.09)
33 set tn_b_arr=(0.886 0.744 0.63 0.21 0.09)
34 # Boolean whether coatings can have partial coverage:
35 set part_arr=(0 0 0 1 1)
36
37 set gfiles=()
38 while ($#argv > 0)
39 set header="Surface Tr Tg Tb Rcr Rcg Rcb Rgr Rgg Rgb Part"
40 if ($#argv < 2 || "$argv[1]" != '-f') then
41 echo "Usage: $0 [-f glazing.dat ..]"
42 exit 1
43 endif
44 shift argv
45 set gf="$argv[1]"
46 shift argv
47 set gfiles=($gfiles:q $gf:q)
48 if ("`sed -n 1p $gf:q`" != "$header") then
49 echo "Bad header in $gf -- Expected: $header"
50 exit 1
51 endif
52 echo "Adding glazing types from file $gf :"
53 set nl=`wc -l < $gf:q`
54 @ i=2
55 while ($i <= $nl)
56 set ln=(`sed -n ${i}p $gf:q`)
57 if ($#ln != 11) then
58 echo "Expected 11 words in line: $ln"
59 exit 1
60 endif
61 echo $ln[1]
62 set sn_arr=($sn_arr:q $ln[1])
63 set tn_r_arr=($tn_r_arr $ln[2])
64 set tn_g_arr=($tn_g_arr $ln[3])
65 set tn_b_arr=($tn_b_arr $ln[4])
66 set rc_r_arr=($rc_r_arr $ln[5])
67 set rc_g_arr=($rc_g_arr $ln[6])
68 set rc_b_arr=($rc_b_arr $ln[7])
69 set rg_r_arr=($rg_r_arr $ln[8])
70 set rg_g_arr=($rg_g_arr $ln[9])
71 set rg_b_arr=($rg_b_arr $ln[10])
72 set part_arr=($part_arr $ln[11])
73 @ i++
74 end
75 end
76 if (! $#gfiles) unset gfiles
77
78 #################################################################
79 #
80 # Get user input
81 #
82 echo -n "Enter the number of panes in the system: "
83 set np="$<"
84 if ($np != 1 && $np != 2) then
85 echo "Must be 1 or 2 pane system"
86 exit 1
87 endif
88 echo ""
89 echo "Window normal faces interior"
90 echo ""
91 if ($np == 1) then
92 echo " | |"
93 echo " | |"
94 echo " | |"
95 echo " | |-->"
96 echo " | |"
97 echo " | |"
98 echo " | |"
99 echo " s1 s2"
100 else
101 echo " | | | |"
102 echo " | | | |"
103 echo " | | | |"
104 echo " | | | |-->"
105 echo " | | | |"
106 echo " | | | |"
107 echo " | | | |"
108 echo " s1 s2 s3 s4"
109 endif
110 echo ""
111 echo "Supported surface types are:"
112 set i=1
113 while ($i <= $#sn_arr)
114 echo " " $i - $sn_arr[$i]
115 @ i++
116 end
117 echo ""
118 echo -n "What is the type of s1? "
119 set s1t="$<"
120 echo -n "What is the type of s2? "
121 set s2t="$<"
122 if ($s1t != 1 && $s2t != 1) then
123 echo "One surface of each pane must be $sn_arr[1]"
124 exit 1
125 endif
126 if ($part_arr[$s1t]) then
127 echo -n "Enter fraction coverage for s1 (0-1): "
128 set s1c="$<"
129 endif
130 if ($part_arr[$s2t]) then
131 echo -n "Enter fraction coverage for s2 (0-1): "
132 set s2c="$<"
133 endif
134 if ($np == 2) then
135 echo -n "What is the type of s3? "
136 set s3t="$<"
137 echo -n "What is the type of s4? "
138 set s4t="$<"
139 if ($s3t != 1 && $s4t != 1) then
140 echo "One surface of each pane must be $sn_arr[1]"
141 exit 1
142 endif
143 if ($part_arr[$s3t]) then
144 echo -n "Enter fraction coverage for s3 (0-1): "
145 set s3c="$<"
146 endif
147 if ($part_arr[$s4t]) then
148 echo -n "Enter fraction coverage for s4 (0-1): "
149 set s4c="$<"
150 endif
151 endif
152
153 #################################################################
154 #
155 # Begin material comments
156 #
157 echo ""
158 echo "############################################"
159 echo "# Glazing produced by Radiance glaze script"
160 echo '# $Revision: 2.6 $'
161 if ($?gfiles) then
162 echo "# Loaded: $gfiles:q"
163 echo "# `date`"
164 endif
165 echo "# Material surface normal points to interior"
166 echo "# Number of panes in system: $np"
167
168 if ($np == 2) goto glaze2
169 #################################################################
170 #
171 # Compute single glazing
172 #
173 set sc=1
174 echo "# Exterior surface s1 type: $sn_arr[$s1t]"
175 if ($?s1c) then
176 echo "# s1 coating coverage: $s1c"
177 set sc=$s1c
178 endif
179 echo "# Interior surface s2 type: $sn_arr[$s2t]"
180 if ($?s2c) then
181 echo "# s2 coating coverage: $s2c"
182 set sc=$s2c
183 endif
184 if ($s1t != 1) then
185 set ct=$s1t
186 echo -n "# Exterior normal hemispherical reflectance: "
187 ev ".265*($sc*$rc_r_arr[$ct]+(1-$sc)*$rc_r_arr[1])+.670*($sc*$rc_g_arr[$ct]+(1-$sc)*$rc_g_arr[1])+.065*($sc*$rc_b_arr[$ct]+(1-$sc)*$rc_b_arr[1])"
188 echo -n "# Interior normal hemispherical reflectance: "
189 ev ".265*($sc*$rg_r_arr[$ct]+(1-$sc)*$rg_r_arr[1])+.670*($sc*$rg_g_arr[$ct]+(1-$sc)*$rg_g_arr[1])+.065*($sc*$rg_b_arr[$ct]+(1-$sc)*$rg_b_arr[1])"
190 else
191 set ct=$s2t
192 echo -n "# Exterior normal hemispherical reflectance: "
193 ev ".265*($sc*$rg_r_arr[$ct]+(1-$sc)*$rg_r_arr[1])+.670*($sc*$rg_g_arr[$ct]+(1-$sc)*$rg_g_arr[1])+.065*($sc*$rg_b_arr[$ct]+(1-$sc)*$rg_b_arr[1])"
194 echo -n "# Interior normal hemispherical reflectance: "
195 ev ".265*($sc*$rc_r_arr[$ct]+(1-$sc)*$rc_r_arr[1])+.670*($sc*$rc_g_arr[$ct]+(1-$sc)*$rc_g_arr[1])+.065*($sc*$rc_b_arr[$ct]+(1-$sc)*$rc_b_arr[1])"
196 endif
197 echo -n "# Normal hemispherical transmittance: "
198 ev ".265*($sc*$tn_r_arr[$ct]+(1-$sc)*$tn_r_arr[1])+.670*($sc*$tn_g_arr[$ct]+(1-$sc)*$tn_g_arr[1])+.065*($sc*$tn_b_arr[$ct]+(1-$sc)*$tn_b_arr[1])"
199 echo "#"
200 echo "void BRTDfunc glaze1_unnamed"
201 if ($part_arr[$s1t] || $part_arr[$s2t]) then
202 ### Frit glazing
203 echo "10"
204 echo " sr_frit_r sr_frit_g sr_frit_b"
205 echo " st_frit_r st_frit_g st_frit_b"
206 echo " 0 0 0"
207 echo " glaze1.cal"
208 echo "0"
209 echo "11"
210 if ($s2t == 1) then
211 ev "$s1c*($rg_r_arr[$s1t]-$rg_r_arr[1])" \
212 "$s1c*($rg_g_arr[$s1t]-$rg_g_arr[1])" \
213 "$s1c*($rg_b_arr[$s1t]-$rg_b_arr[1])"
214 ev "$s1c*$rc_r_arr[$s1t]" "$s1c*$rc_g_arr[$s1t]" "$s1c*$rc_b_arr[$s1t]"
215 ev "$s1c*$tn_r_arr[$s1t]" "$s1c*$tn_g_arr[$s1t]" "$s1c*$tn_b_arr[$s1t]"
216 echo " 1 $s1c"
217 else
218 ev "$s2c*$rc_r_arr[$s2t]" "$s2c*$rc_g_arr[$s2t]" "$s2c*$rc_b_arr[$s2t]"
219 ev "$s2c*($rg_r_arr[$s2t]-$rg_r_arr[1])" \
220 "$s2c*($rg_g_arr[$s2t]-$rg_g_arr[1])" \
221 "$s2c*($rg_b_arr[$s2t]-$rg_b_arr[1])"
222 ev "$s2c*$tn_r_arr[$s2t]" "$s2c*$tn_g_arr[$s2t]" "$s2c*$tn_b_arr[$s2t]"
223 echo " -1 $s2c"
224 endif
225 else
226 ### Low-E glazing
227 echo "10"
228 echo " sr_clear_r sr_clear_g sr_clear_b"
229 echo " st_clear_r st_clear_g st_clear_b"
230 echo " 0 0 0"
231 echo " glaze1.cal"
232 echo "0"
233 echo "19"
234 echo " 0 0 0"
235 echo " 0 0 0"
236 echo " 0 0 0"
237 if ($s2t == 1) then
238 echo " 1"
239 set st=$s1t
240 else
241 echo " -1"
242 set st=$s2t
243 endif
244 echo " $rg_r_arr[$st] $rg_g_arr[$st] $rg_b_arr[$st]"
245 echo " $rc_r_arr[$st] $rc_g_arr[$st] $rc_b_arr[$st]"
246 echo " $tn_r_arr[$st] $tn_g_arr[$st] $tn_b_arr[$st]"
247 endif
248 echo ""
249 exit 0
250
251 glaze2:
252 #################################################################
253 #
254 # Compute double glazing
255 #
256 if ($s2t != 1) then
257 set s2r_rgb=($rc_r_arr[$s2t] $rc_g_arr[$s2t] $rc_b_arr[$s2t])
258 set s1r_rgb=($rg_r_arr[$s2t] $rg_g_arr[$s2t] $rg_b_arr[$s2t])
259 set s12t_rgb=($tn_r_arr[$s2t] $tn_g_arr[$s2t] $tn_b_arr[$s2t])
260 else
261 set s2r_rgb=($rg_r_arr[$s1t] $rg_g_arr[$s1t] $rg_b_arr[$s1t])
262 set s1r_rgb=($rc_r_arr[$s1t] $rc_g_arr[$s1t] $rc_b_arr[$s1t])
263 set s12t_rgb=($tn_r_arr[$s1t] $tn_g_arr[$s1t] $tn_b_arr[$s1t])
264 endif
265 if ($s4t != 1) then
266 set s4r_rgb=($rc_r_arr[$s4t] $rc_g_arr[$s4t] $rc_b_arr[$s4t])
267 set s3r_rgb=($rg_r_arr[$s4t] $rg_g_arr[$s4t] $rg_b_arr[$s4t])
268 set s34t_rgb=($tn_r_arr[$s4t] $tn_g_arr[$s4t] $tn_b_arr[$s4t])
269 else
270 set s4r_rgb=($rg_r_arr[$s3t] $rg_g_arr[$s3t] $rg_b_arr[$s3t])
271 set s3r_rgb=($rc_r_arr[$s3t] $rc_g_arr[$s3t] $rc_b_arr[$s3t])
272 set s34t_rgb=($tn_r_arr[$s3t] $tn_g_arr[$s3t] $tn_b_arr[$s3t])
273 endif
274 set s12c=1
275 echo "# Exterior surface s1 type: $sn_arr[$s1t]"
276 if ($?s1c) then
277 echo "# s1 coating coverage: $s1c"
278 set s12c=$s1c
279 endif
280 echo "# Inner surface s2 type: $sn_arr[$s2t]"
281 if ($?s2c) then
282 echo "# s2 coating coverage: $s2c"
283 set s12c=$s2c
284 endif
285 set s34c=1
286 echo "# Inner surface s3 type: $sn_arr[$s3t]"
287 if ($?s3c) then
288 echo "# s3 coating coverage: $s3c"
289 set s34c=$s3c
290 endif
291 echo "# Interior surface s4 type: $sn_arr[$s4t]"
292 if ($?s4c) then
293 echo "# s4 coating coverage: $s4c"
294 set s34c=$s4c
295 endif
296 # Approximate reflectance and transmittance for comment using gray values
297 set rglass=`ev ".265*$rg_r_arr[1]+.670*$rg_g_arr[1]+.065*$rg_b_arr[1]"`
298 set tglass=`ev ".265*$tn_r_arr[1]+.670*$tn_g_arr[1]+.065*$tn_b_arr[1]"`
299 set s1r_gry=`ev "$s12c*(.265*$s1r_rgb[1]+.670*$s1r_rgb[2]+.065*$s1r_rgb[3])+(1-$s12c)*$rglass"`
300 set s2r_gry=`ev "$s12c*(.265*$s2r_rgb[1]+.670*$s2r_rgb[2]+.065*$s2r_rgb[3])+(1-$s12c)*$rglass"`
301 set s12t_gry=`ev "$s12c*(.265*$s12t_rgb[1]+.670*$s12t_rgb[2]+.065*$s12t_rgb[3])+(1-$s12c)*$tglass"`
302 set s3r_gry=`ev "$s34c*(.265*$s3r_rgb[1]+.670*$s3r_rgb[2]+.065*$s3r_rgb[3])+(1-$s34c)*$rglass"`
303 set s4r_gry=`ev "$s34c*(.265*$s4r_rgb[1]+.670*$s4r_rgb[2]+.065*$s4r_rgb[3])+(1-$s34c)*$rglass"`
304 set s34t_gry=`ev "$s34c*(.265*$s34t_rgb[1]+.670*$s34t_rgb[2]+.065*$s34t_rgb[3])+(1-$s34c)*$tglass"`
305 echo -n "# Exterior normal hemispherical reflectance: "
306 ev "$s1r_gry + $s12t_gry^2*$s3r_gry"
307 echo -n "# Interior normal hemispherical reflectance: "
308 ev "$s4r_gry + $s34t_gry^2*$s2r_gry"
309 echo -n "# Normal hemispherical transmittance: "
310 ev "$s12t_gry*$s34t_gry"
311 echo "#"
312 echo "void BRTDfunc glaze2_unnamed"
313
314 if ($part_arr[$s3t] || $part_arr[$s4t]) then
315 ### Front pane has frit
316 if ($part_arr[$s1t] || $part_arr[$s2t]) then
317 echo "Only one pane can have frit"
318 exit 1
319 endif
320 if ($?s3c) then
321 set sc=$s3c
322 set s3g=`ev "1-$s3c"`
323 else
324 set s3c=0
325 set s3g=1
326 endif
327 if ($?s4c) then
328 set sc=$s4c
329 set s4g=`ev "1-$s4c"`
330 else
331 set s4c=0
332 set s4g=1
333 endif
334 echo "10"
335 echo "if(Rdot,cr($s4g*rclr,$s3g*$s4g*tclr,fr($s2r_rgb[1])),cr(fr($s1r_rgb[1]),ft($s12t_rgb[1]),$s3g*rclr))"
336 echo "if(Rdot,cr($s4g*rclr,$s3g*$s4g*tclr,fr($s2r_rgb[2])),cr(fr($s1r_rgb[2]),ft($s12t_rgb[2]),$s3g*rclr))"
337 echo "if(Rdot,cr($s4g*rclr,$s3g*$s4g*tclr,fr($s2r_rgb[3])),cr(fr($s1r_rgb[3]),ft($s12t_rgb[3]),$s3g*rclr))"
338 echo "$s3g*$s4g*ft($s12t_rgb[1])*tclr"
339 echo "$s3g*$s4g*ft($s12t_rgb[2])*tclr"
340 echo "$s3g*$s4g*ft($s12t_rgb[3])*tclr"
341 echo " 0 0 0"
342 echo " glaze2.cal"
343 echo "0"
344 echo "9"
345 ev "$sc*$s4r_rgb[1]-$s3c*$rg_r_arr[1]" \
346 "$sc*$s4r_rgb[2]-$s3c*$rg_g_arr[1]" \
347 "$sc*$s4r_rgb[3]-$s3c*$rg_b_arr[1]"
348 ev "$s12t_rgb[1]^2*($sc*$s3r_rgb[1]-$s4c*$rg_r_arr[1])" \
349 "$s12t_rgb[2]^2*($sc*$s3r_rgb[2]-$s4c*$rg_g_arr[1])" \
350 "$s12t_rgb[3]^2*($sc*$s3r_rgb[3]-$s4c*$rg_b_arr[1])"
351 ev "$sc*$s12t_rgb[1]*$s34t_rgb[1]" \
352 "$sc*$s12t_rgb[2]*$s34t_rgb[2]" \
353 "$sc*$s12t_rgb[3]*$s34t_rgb[3]"
354 else if ($part_arr[$s1t] || $part_arr[$s2t]) then
355 ### Back pane has frit
356 if ($?s1c) then
357 set sc=$s1c
358 set s1g=`ev "1-$s1c"`
359 else
360 set s1c=0
361 set s1g=1
362 endif
363 if ($?s2c) then
364 set sc=$s2c
365 set s2g=`ev "1-$s2c"`
366 else
367 set s2c=0
368 set s2g=1
369 endif
370 echo "10"
371 echo "if(Rdot,cr(fr($s4r_rgb[1]),ft($s34t_rgb[1]),$s2g*rclr),cr($s1g*rclr,$s1g*$s2g*tclr,fr($s3r_rgb[1])))"
372 echo "if(Rdot,cr(fr($s4r_rgb[2]),ft($s34t_rgb[2]),$s2g*rclr),cr($s1g*rclr,$s1g*$s2g*tclr,fr($s3r_rgb[2])))"
373 echo "if(Rdot,cr(fr($s4r_rgb[3]),ft($s34t_rgb[3]),$s2g*rclr),cr($s1g*rclr,$s1g*$s2g*tclr,fr($s3r_rgb[3])))"
374 echo "$s1g*$s2g*ft($s34t_rgb[1])*tclr"
375 echo "$s1g*$s2g*ft($s34t_rgb[2])*tclr"
376 echo "$s1g*$s2g*ft($s34t_rgb[3])*tclr"
377 echo " 0 0 0"
378 echo " glaze2.cal"
379 echo "0"
380 echo "9"
381 ev "$s34t_rgb[1]^2*($sc*$s2r_rgb[1]-$s1c*$rg_r_arr[1])" \
382 "$s34t_rgb[2]^2*($sc*$s2r_rgb[2]-$s1c*$rg_g_arr[1])" \
383 "$s34t_rgb[3]^2*($sc*$s2r_rgb[3]-$s1c*$rg_b_arr[1])"
384 ev "$sc*$s1r_rgb[1]-$s2c*$rg_r_arr[1]" \
385 "$sc*$s1r_rgb[2]-$s2c*$rg_g_arr[1]" \
386 "$sc*$s1r_rgb[3]-$s2c*$rg_b_arr[1]"
387 ev "$sc*$s34t_rgb[1]*$s12t_rgb[1]" \
388 "$sc*$s34t_rgb[2]*$s12t_rgb[2]" \
389 "$sc*$s34t_rgb[3]*$s12t_rgb[3]"
390 else
391 ### Low-E and regular glazing only
392 echo "10"
393 echo "if(Rdot,cr(fr($s4r_rgb[1]),ft($s34t_rgb[1]),fr($s2r_rgb[1])),cr(fr($s1r_rgb[1]),ft($s12t_rgb[1]),fr($s3r_rgb[1])))"
394 echo "if(Rdot,cr(fr($s4r_rgb[2]),ft($s34t_rgb[2]),fr($s2r_rgb[2])),cr(fr($s1r_rgb[2]),ft($s12t_rgb[2]),fr($s3r_rgb[2])))"
395 echo "if(Rdot,cr(fr($s4r_rgb[3]),ft($s34t_rgb[3]),fr($s2r_rgb[3])),cr(fr($s1r_rgb[3]),ft($s12t_rgb[3]),fr($s3r_rgb[3])))"
396 echo "ft($s34t_rgb[1])*ft($s12t_rgb[1])"
397 echo "ft($s34t_rgb[2])*ft($s12t_rgb[2])"
398 echo "ft($s34t_rgb[3])*ft($s12t_rgb[3])"
399 echo " 0 0 0"
400 echo " glaze2.cal"
401 echo "0"
402 echo "9"
403 echo " 0 0 0"
404 echo " 0 0 0"
405 echo " 0 0 0"
406 endif
407 echo ""
408 exit 0
