root/radiance/ray/src/gen/glaze.csh
Thu Nov 5 19:00:50 2009 UTC (15 years, 6 months ago) by greg
CVS Tags: HEAD, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2, rad5R3, rad5R4
Changes since 2.7: +49 -16 lines
Altered -f option behavior to remove default database
Mon Feb 11 19:18:25 2008 UTC (17 years, 3 months ago) by greg
Changed naming of specular component
Mon Feb 11 19:13:05 2008 UTC (17 years, 3 months ago) by greg
Changes since 2.5: +9 -2 lines
Added some header information about loaded files, version
Wed Aug 25 19:13:30 2004 UTC (20 years, 9 months ago) by greg
Changes since 2.4: +9 -4 lines
Fixed another bug in addition of -f option
Wed Aug 25 01:40:12 2004 UTC (20 years, 9 months ago) by greg
Changes since 2.3: +6 -5 lines
Added missing partial boolean (Jack fixed this)
Sat Aug 14 19:36:38 2004 UTC (20 years, 9 months ago) by greg
Changes since 2.2: +39 -1 lines
Added -f option to read glazing types from file
Mon Jun 30 18:12:24 2003 UTC (21 years, 11 months ago) by greg
Diff to previous 2.1
Updated Fresnel approximation
Sat Feb 22 02:07:23 2003 UTC (22 years, 3 months ago) by greg
Links to HEAD: (view) (download) (as text) (annotate) Links to rad4R2P1: (view) (download) (as text) (annotate)
