root/Development/ray/src/gen/glaze.csh
Revision: 2.5
Committed: Wed Aug 25 19:13:30 2004 UTC (21 years, 2 months ago) by greg
Content type: application/x-csh
CVS Tags: rad3R8, rad3R7P2, rad3R7P1, rad3R6P1, rad3R6
Changes since 2.4: +9 -4 lines
Fixed another bug in addition of -f option
1 #!/bin/csh -f
2 # RCSid: $Id: glaze.csh,v 2.4 2004/08/25 01:40:12 greg Exp $
3 #
4 # Complex glazing model (goes with glaze1.cal and glaze2.cal)
5 #
6 # Oct. 2002 Greg Ward
7 # Aug. 2004 GW (added -f option to read glazings from file)
8 # Funding for this development generously provided by Visarc, Inc.
9 # (http://www.visarc.com)
10 #
11
12 #################################################################
13 #
14 # The general assumption is that one surface is uncoated, and
15 # reflectances and transmittances are computed from this fact.
16 # If the user tries to enter two coated surfaces on the same
17 # pane, the script complains and exits.
18 #
19 # Supported surface types:
20 #
21 set sn_arr=("clear glass" "VE1-2M low-E coating" "PVB laminated" "V-175 white frit" "V-933 warm gray frit")
22 # Glass-side hemispherical reflectances for each surface type:
23 set rg_r_arr=(0.074 0.065 .11 0.33 0.15)
24 set rg_g_arr=(0.077 0.058 .11 0.33 0.15)
25 set rg_b_arr=(0.079 0.067 .11 0.33 0.15)
26 # Coating-side hemispherical reflectance for each surface type:
27 set rc_r_arr=(0.074 0.042 .11 0.59 0.21)
28 set rc_g_arr=(0.077 0.049 .11 0.59 0.21)
29 set rc_b_arr=(0.079 0.043 .11 0.59 0.21)
30 # Hemispherical (normal) transmittance for each surface type:
31 set tn_r_arr=(0.862 0.756 0.63 0.21 0.09)
32 set tn_g_arr=(0.890 0.808 0.63 0.21 0.09)
33 set tn_b_arr=(0.886 0.744 0.63 0.21 0.09)
34 # Boolean whether coatings can have partial coverage:
35 set part_arr=(0 0 0 1 1)
36
37 while ($#argv > 0)
38 set header="Surface Tr Tg Tb Rcr Rcg Rcb Rgr Rgg Rgb Part"
39 if ($#argv < 2 || "$argv[1]" != '-f') then
40 echo "Usage: $0 [-f glazing.dat ..]"
41 exit 1
42 endif
43 shift argv
44 set gf="$argv[1]"
45 shift argv
46 if ("`sed -n 1p $gf:q`" != "$header") then
47 echo "Bad header in $gf -- Expected: $header"
48 exit 1
49 endif
50 echo "Adding glazing types from file $gf :"
51 set nl=`wc -l < $gf:q`
52 @ i=2
53 while ($i <= $nl)
54 set ln=(`sed -n ${i}p $gf:q`)
55 if ($#ln != 11) then
56 echo "Expected 11 words in line: $ln"
57 exit 1
58 endif
59 echo $ln[1]
60 set sn_arr=($sn_arr:q $ln[1])
61 set tn_r_arr=($tn_r_arr $ln[2])
62 set tn_g_arr=($tn_g_arr $ln[3])
63 set tn_b_arr=($tn_b_arr $ln[4])
64 set rc_r_arr=($rc_r_arr $ln[5])
65 set rc_g_arr=($rc_g_arr $ln[6])
66 set rc_b_arr=($rc_b_arr $ln[7])
67 set rg_r_arr=($rg_r_arr $ln[8])
68 set rg_g_arr=($rg_g_arr $ln[9])
69 set rg_b_arr=($rg_b_arr $ln[10])
70 set part_arr=($part_arr $ln[11])
71 @ i++
72 end
73 end
74
75 #################################################################
76 #
77 # Get user input
78 #
79 echo -n "Enter the number of panes in the system: "
80 set np="$<"
81 if ($np != 1 && $np != 2) then
82 echo "Must be 1 or 2 pane system"
83 exit 1
84 endif
85 echo ""
86 echo "Window normal faces interior"
87 echo ""
88 if ($np == 1) then
89 echo " | |"
90 echo " | |"
91 echo " | |"
92 echo " | |-->"
93 echo " | |"
94 echo " | |"
95 echo " | |"
96 echo " s1 s2"
97 else
98 echo " | | | |"
99 echo " | | | |"
100 echo " | | | |"
101 echo " | | | |-->"
102 echo " | | | |"
103 echo " | | | |"
104 echo " | | | |"
105 echo " s1 s2 s3 s4"
106 endif
107 echo ""
108 echo "Supported surface types are:"
109 set i=1
110 while ($i <= $#sn_arr)
111 echo " " $i - $sn_arr[$i]
112 @ i++
113 end
114 echo ""
115 echo -n "What is the type of s1? "
116 set s1t="$<"
117 echo -n "What is the type of s2? "
118 set s2t="$<"
119 if ($s1t != 1 && $s2t != 1) then
120 echo "One surface of each pane must be $sn_arr[1]"
121 exit 1
122 endif
123 if ($part_arr[$s1t]) then
124 echo -n "Enter fraction coverage for s1 (0-1): "
125 set s1c="$<"
126 endif
127 if ($part_arr[$s2t]) then
128 echo -n "Enter fraction coverage for s2 (0-1): "
129 set s2c="$<"
130 endif
131 if ($np == 2) then
132 echo -n "What is the type of s3? "
133 set s3t="$<"
134 echo -n "What is the type of s4? "
135 set s4t="$<"
136 if ($s3t != 1 && $s4t != 1) then
137 echo "One surface of each pane must be $sn_arr[1]"
138 exit 1
139 endif
140 if ($part_arr[$s3t]) then
141 echo -n "Enter fraction coverage for s3 (0-1): "
142 set s3c="$<"
143 endif
144 if ($part_arr[$s4t]) then
145 echo -n "Enter fraction coverage for s4 (0-1): "
146 set s4c="$<"
147 endif
148 endif
149
150 #################################################################
151 #
152 # Begin material comments
153 #
154 echo ""
155 echo "############################################"
156 echo "# Glazing produced by Radiance glaze script"
157 echo "# `date`"
158 echo "# Material surface normal points to interior"
159 echo "# Number of panes in system: $np"
160
161 if ($np == 2) goto glaze2
162 #################################################################
163 #
164 # Compute single glazing
165 #
166 set sc=1
167 echo "# Exterior surface s1 type: $sn_arr[$s1t]"
168 if ($?s1c) then
169 echo "# s1 coating coverage: $s1c"
170 set sc=$s1c
171 endif
172 echo "# Interior surface s2 type: $sn_arr[$s2t]"
173 if ($?s2c) then
174 echo "# s2 coating coverage: $s2c"
175 set sc=$s2c
176 endif
177 if ($s1t != 1) then
178 set ct=$s1t
179 echo -n "# Exterior normal hemispherical reflectance: "
180 ev ".265*($sc*$rc_r_arr[$ct]+(1-$sc)*$rc_r_arr[1])+.670*($sc*$rc_g_arr[$ct]+(1-$sc)*$rc_g_arr[1])+.065*($sc*$rc_b_arr[$ct]+(1-$sc)*$rc_b_arr[1])"
181 echo -n "# Interior normal hemispherical reflectance: "
182 ev ".265*($sc*$rg_r_arr[$ct]+(1-$sc)*$rg_r_arr[1])+.670*($sc*$rg_g_arr[$ct]+(1-$sc)*$rg_g_arr[1])+.065*($sc*$rg_b_arr[$ct]+(1-$sc)*$rg_b_arr[1])"
183 else
184 set ct=$s2t
185 echo -n "# Exterior normal hemispherical reflectance: "
186 ev ".265*($sc*$rg_r_arr[$ct]+(1-$sc)*$rg_r_arr[1])+.670*($sc*$rg_g_arr[$ct]+(1-$sc)*$rg_g_arr[1])+.065*($sc*$rg_b_arr[$ct]+(1-$sc)*$rg_b_arr[1])"
187 echo -n "# Interior normal hemispherical reflectance: "
188 ev ".265*($sc*$rc_r_arr[$ct]+(1-$sc)*$rc_r_arr[1])+.670*($sc*$rc_g_arr[$ct]+(1-$sc)*$rc_g_arr[1])+.065*($sc*$rc_b_arr[$ct]+(1-$sc)*$rc_b_arr[1])"
189 endif
190 echo -n "# Normal hemispherical transmittance: "
191 ev ".265*($sc*$tn_r_arr[$ct]+(1-$sc)*$tn_r_arr[1])+.670*($sc*$tn_g_arr[$ct]+(1-$sc)*$tn_g_arr[1])+.065*($sc*$tn_b_arr[$ct]+(1-$sc)*$tn_b_arr[1])"
192 echo "#"
193 echo "void BRTDfunc glaze1_unnamed"
194 if ($part_arr[$s1t] || $part_arr[$s2t]) then
195 ### Frit glazing
196 echo "10"
197 echo " sr_frit_r sr_frit_g sr_frit_b"
198 echo " st_frit_r st_frit_g st_frit_b"
199 echo " 0 0 0"
200 echo " glaze1.cal"
201 echo "0"
202 echo "11"
203 if ($s2t == 1) then
204 ev "$s1c*($rg_r_arr[$s1t]-$rg_r_arr[1])" \
205 "$s1c*($rg_g_arr[$s1t]-$rg_g_arr[1])" \
206 "$s1c*($rg_b_arr[$s1t]-$rg_b_arr[1])"
207 ev "$s1c*$rc_r_arr[$s1t]" "$s1c*$rc_g_arr[$s1t]" "$s1c*$rc_b_arr[$s1t]"
208 ev "$s1c*$tn_r_arr[$s1t]" "$s1c*$tn_g_arr[$s1t]" "$s1c*$tn_b_arr[$s1t]"
209 echo " 1 $s1c"
210 else
211 ev "$s2c*$rc_r_arr[$s2t]" "$s2c*$rc_g_arr[$s2t]" "$s2c*$rc_b_arr[$s2t]"
212 ev "$s2c*($rg_r_arr[$s2t]-$rg_r_arr[1])" \
213 "$s2c*($rg_g_arr[$s2t]-$rg_g_arr[1])" \
214 "$s2c*($rg_b_arr[$s2t]-$rg_b_arr[1])"
215 ev "$s2c*$tn_r_arr[$s2t]" "$s2c*$tn_g_arr[$s2t]" "$s2c*$tn_b_arr[$s2t]"
216 echo " -1 $s2c"
217 endif
218 else
219 ### Low-E glazing
220 echo "10"
221 echo " sr_lowE_r sr_lowE_g sr_lowE_b"
222 echo " st_lowE_r st_lowE_g st_lowE_b"
223 echo " 0 0 0"
224 echo " glaze1.cal"
225 echo "0"
226 echo "19"
227 echo " 0 0 0"
228 echo " 0 0 0"
229 echo " 0 0 0"
230 if ($s2t == 1) then
231 echo " 1"
232 set st=$s1t
233 else
234 echo " -1"
235 set st=$s2t
236 endif
237 echo " $rg_r_arr[$st] $rg_g_arr[$st] $rg_b_arr[$st]"
238 echo " $rc_r_arr[$st] $rc_g_arr[$st] $rc_b_arr[$st]"
239 echo " $tn_r_arr[$st] $tn_g_arr[$st] $tn_b_arr[$st]"
240 endif
241 echo ""
242 exit 0
243
244 glaze2:
245 #################################################################
246 #
247 # Compute double glazing
248 #
249 if ($s2t != 1) then
250 set s2r_rgb=($rc_r_arr[$s2t] $rc_g_arr[$s2t] $rc_b_arr[$s2t])
251 set s1r_rgb=($rg_r_arr[$s2t] $rg_g_arr[$s2t] $rg_b_arr[$s2t])
252 set s12t_rgb=($tn_r_arr[$s2t] $tn_g_arr[$s2t] $tn_b_arr[$s2t])
253 else
254 set s2r_rgb=($rg_r_arr[$s1t] $rg_g_arr[$s1t] $rg_b_arr[$s1t])
255 set s1r_rgb=($rc_r_arr[$s1t] $rc_g_arr[$s1t] $rc_b_arr[$s1t])
256 set s12t_rgb=($tn_r_arr[$s1t] $tn_g_arr[$s1t] $tn_b_arr[$s1t])
257 endif
258 if ($s4t != 1) then
259 set s4r_rgb=($rc_r_arr[$s4t] $rc_g_arr[$s4t] $rc_b_arr[$s4t])
260 set s3r_rgb=($rg_r_arr[$s4t] $rg_g_arr[$s4t] $rg_b_arr[$s4t])
261 set s34t_rgb=($tn_r_arr[$s4t] $tn_g_arr[$s4t] $tn_b_arr[$s4t])
262 else
263 set s4r_rgb=($rg_r_arr[$s3t] $rg_g_arr[$s3t] $rg_b_arr[$s3t])
264 set s3r_rgb=($rc_r_arr[$s3t] $rc_g_arr[$s3t] $rc_b_arr[$s3t])
265 set s34t_rgb=($tn_r_arr[$s3t] $tn_g_arr[$s3t] $tn_b_arr[$s3t])
266 endif
267 set s12c=1
268 echo "# Exterior surface s1 type: $sn_arr[$s1t]"
269 if ($?s1c) then
270 echo "# s1 coating coverage: $s1c"
271 set s12c=$s1c
272 endif
273 echo "# Inner surface s2 type: $sn_arr[$s2t]"
274 if ($?s2c) then
275 echo "# s2 coating coverage: $s2c"
276 set s12c=$s2c
277 endif
278 set s34c=1
279 echo "# Inner surface s3 type: $sn_arr[$s3t]"
280 if ($?s3c) then
281 echo "# s3 coating coverage: $s3c"
282 set s34c=$s3c
283 endif
284 echo "# Interior surface s4 type: $sn_arr[$s4t]"
285 if ($?s4c) then
286 echo "# s4 coating coverage: $s4c"
287 set s34c=$s4c
288 endif
289 # Approximate reflectance and transmittance for comment using gray values
290 set rglass=`ev ".265*$rg_r_arr[1]+.670*$rg_g_arr[1]+.065*$rg_b_arr[1]"`
291 set tglass=`ev ".265*$tn_r_arr[1]+.670*$tn_g_arr[1]+.065*$tn_b_arr[1]"`
292 set s1r_gry=`ev "$s12c*(.265*$s1r_rgb[1]+.670*$s1r_rgb[2]+.065*$s1r_rgb[3])+(1-$s12c)*$rglass"`
293 set s2r_gry=`ev "$s12c*(.265*$s2r_rgb[1]+.670*$s2r_rgb[2]+.065*$s2r_rgb[3])+(1-$s12c)*$rglass"`
294 set s12t_gry=`ev "$s12c*(.265*$s12t_rgb[1]+.670*$s12t_rgb[2]+.065*$s12t_rgb[3])+(1-$s12c)*$tglass"`
295 set s3r_gry=`ev "$s34c*(.265*$s3r_rgb[1]+.670*$s3r_rgb[2]+.065*$s3r_rgb[3])+(1-$s34c)*$rglass"`
296 set s4r_gry=`ev "$s34c*(.265*$s4r_rgb[1]+.670*$s4r_rgb[2]+.065*$s4r_rgb[3])+(1-$s34c)*$rglass"`
297 set s34t_gry=`ev "$s34c*(.265*$s34t_rgb[1]+.670*$s34t_rgb[2]+.065*$s34t_rgb[3])+(1-$s34c)*$tglass"`
298 echo -n "# Exterior normal hemispherical reflectance: "
299 ev "$s1r_gry + $s12t_gry^2*$s3r_gry"
300 echo -n "# Interior normal hemispherical reflectance: "
301 ev "$s4r_gry + $s34t_gry^2*$s2r_gry"
302 echo -n "# Normal hemispherical transmittance: "
303 ev "$s12t_gry*$s34t_gry"
304 echo "#"
305 echo "void BRTDfunc glaze2_unnamed"
306
307 if ($part_arr[$s3t] || $part_arr[$s4t]) then
308 ### Front pane has frit
309 if ($part_arr[$s1t] || $part_arr[$s2t]) then
310 echo "Only one pane can have frit"
311 exit 1
312 endif
313 if ($?s3c) then
314 set sc=$s3c
315 set s3g=`ev "1-$s3c"`
316 else
317 set s3c=0
318 set s3g=1
319 endif
320 if ($?s4c) then
321 set sc=$s4c
322 set s4g=`ev "1-$s4c"`
323 else
324 set s4c=0
325 set s4g=1
326 endif
327 echo "10"
328 echo "if(Rdot,cr($s4g*rclr,$s3g*$s4g*tclr,fr($s2r_rgb[1])),cr(fr($s1r_rgb[1]),ft($s12t_rgb[1]),$s3g*rclr))"
329 echo "if(Rdot,cr($s4g*rclr,$s3g*$s4g*tclr,fr($s2r_rgb[2])),cr(fr($s1r_rgb[2]),ft($s12t_rgb[2]),$s3g*rclr))"
330 echo "if(Rdot,cr($s4g*rclr,$s3g*$s4g*tclr,fr($s2r_rgb[3])),cr(fr($s1r_rgb[3]),ft($s12t_rgb[3]),$s3g*rclr))"
331 echo "$s3g*$s4g*ft($s12t_rgb[1])*tclr"
332 echo "$s3g*$s4g*ft($s12t_rgb[2])*tclr"
333 echo "$s3g*$s4g*ft($s12t_rgb[3])*tclr"
334 echo " 0 0 0"
335 echo " glaze2.cal"
336 echo "0"
337 echo "9"
338 ev "$sc*$s4r_rgb[1]-$s3c*$rg_r_arr[1]" \
339 "$sc*$s4r_rgb[2]-$s3c*$rg_g_arr[1]" \
340 "$sc*$s4r_rgb[3]-$s3c*$rg_b_arr[1]"
341 ev "$s12t_rgb[1]^2*($sc*$s3r_rgb[1]-$s4c*$rg_r_arr[1])" \
342 "$s12t_rgb[2]^2*($sc*$s3r_rgb[2]-$s4c*$rg_g_arr[1])" \
343 "$s12t_rgb[3]^2*($sc*$s3r_rgb[3]-$s4c*$rg_b_arr[1])"
344 ev "$sc*$s12t_rgb[1]*$s34t_rgb[1]" \
345 "$sc*$s12t_rgb[2]*$s34t_rgb[2]" \
346 "$sc*$s12t_rgb[3]*$s34t_rgb[3]"
347 else if ($part_arr[$s1t] || $part_arr[$s2t]) then
348 ### Back pane has frit
349 if ($?s1c) then
350 set sc=$s1c
351 set s1g=`ev "1-$s1c"`
352 else
353 set s1c=0
354 set s1g=1
355 endif
356 if ($?s2c) then
357 set sc=$s2c
358 set s2g=`ev "1-$s2c"`
359 else
360 set s2c=0
361 set s2g=1
362 endif
363 echo "10"
364 echo "if(Rdot,cr(fr($s4r_rgb[1]),ft($s34t_rgb[1]),$s2g*rclr),cr($s1g*rclr,$s1g*$s2g*tclr,fr($s3r_rgb[1])))"
365 echo "if(Rdot,cr(fr($s4r_rgb[2]),ft($s34t_rgb[2]),$s2g*rclr),cr($s1g*rclr,$s1g*$s2g*tclr,fr($s3r_rgb[2])))"
366 echo "if(Rdot,cr(fr($s4r_rgb[3]),ft($s34t_rgb[3]),$s2g*rclr),cr($s1g*rclr,$s1g*$s2g*tclr,fr($s3r_rgb[3])))"
367 echo "$s1g*$s2g*ft($s34t_rgb[1])*tclr"
368 echo "$s1g*$s2g*ft($s34t_rgb[2])*tclr"
369 echo "$s1g*$s2g*ft($s34t_rgb[3])*tclr"
370 echo " 0 0 0"
371 echo " glaze2.cal"
372 echo "0"
373 echo "9"
374 ev "$s34t_rgb[1]^2*($sc*$s2r_rgb[1]-$s1c*$rg_r_arr[1])" \
375 "$s34t_rgb[2]^2*($sc*$s2r_rgb[2]-$s1c*$rg_g_arr[1])" \
376 "$s34t_rgb[3]^2*($sc*$s2r_rgb[3]-$s1c*$rg_b_arr[1])"
377 ev "$sc*$s1r_rgb[1]-$s2c*$rg_r_arr[1]" \
378 "$sc*$s1r_rgb[2]-$s2c*$rg_g_arr[1]" \
379 "$sc*$s1r_rgb[3]-$s2c*$rg_b_arr[1]"
380 ev "$sc*$s34t_rgb[1]*$s12t_rgb[1]" \
381 "$sc*$s34t_rgb[2]*$s12t_rgb[2]" \
382 "$sc*$s34t_rgb[3]*$s12t_rgb[3]"
383 else
384 ### Low-E and regular glazing only
385 echo "10"
386 echo "if(Rdot,cr(fr($s4r_rgb[1]),ft($s34t_rgb[1]),fr($s2r_rgb[1])),cr(fr($s1r_rgb[1]),ft($s12t_rgb[1]),fr($s3r_rgb[1])))"
387 echo "if(Rdot,cr(fr($s4r_rgb[2]),ft($s34t_rgb[2]),fr($s2r_rgb[2])),cr(fr($s1r_rgb[2]),ft($s12t_rgb[2]),fr($s3r_rgb[2])))"
388 echo "if(Rdot,cr(fr($s4r_rgb[3]),ft($s34t_rgb[3]),fr($s2r_rgb[3])),cr(fr($s1r_rgb[3]),ft($s12t_rgb[3]),fr($s3r_rgb[3])))"
389 echo "ft($s34t_rgb[1])*ft($s12t_rgb[1])"
390 echo "ft($s34t_rgb[2])*ft($s12t_rgb[2])"
391 echo "ft($s34t_rgb[3])*ft($s12t_rgb[3])"
392 echo " 0 0 0"
393 echo " glaze2.cal"
394 echo "0"
395 echo "9"
396 echo " 0 0 0"
397 echo " 0 0 0"
398 echo " 0 0 0"
399 endif
400 echo ""
401 exit 0
