root/radiance/ray/src/gen/genworm.c
Sat Jun 7 05:09:45 2025 UTC (2 months ago) by greg
CVS Tags: HEAD, rad6R0
Diff to previous 2.14
Fri Apr 18 23:02:53 2025 UTC (3 months, 2 weeks ago) by greg
Changes since 2.13: +3 -2 lines
Diff to previous 2.13
perf(gensurf,genrev,genworm): Added call to doptimize() for expressions
Tue Dec 10 17:22:39 2024 UTC (7 months, 3 weeks ago) by greg
perf(gensurf,genrev,genworm): Fixed setting of eclock that was out-of-date with change from 90's
Sat Dec 28 18:05:14 2019 UTC (5 years, 7 months ago) by greg
CVS Tags: rad5R3, rad5R4
Sat Dec 7 02:21:42 2019 UTC (5 years, 8 months ago) by greg
Changed gen{worm,surf,rev} to accept expressions for number of segments
Fri May 4 23:56:49 2018 UTC (7 years, 3 months ago) by greg
Changes since 2.9: +11 -4 lines
Fri Jan 12 00:50:17 2018 UTC (7 years, 6 months ago) by greg
Added missing esupport settings for constant expression reduction
Sat Aug 21 11:54:06 2004 UTC (20 years, 11 months ago) by greg
Changes since 2.7: +5 -44 lines
Sun Nov 16 10:29:38 2003 UTC (21 years, 8 months ago) by schorsch
Changes since 2.6: +17 -8 lines
Mon Aug 4 22:37:53 2003 UTC (22 years ago) by greg
Changes since 2.5: +6 -6 lines
Mon Jul 21 22:30:18 2003 UTC (22 years ago) by schorsch
Changes since 2.4: +3 -2 lines
Sat Feb 22 02:07:23 2003 UTC (22 years, 5 months ago) by greg
Changes since 2.3: +5 -4 lines
Thu Nov 18 09:33:07 1993 UTC (31 years, 8 months ago) by greg
minor compiler warning fixes
Tue Jan 5 10:06:59 1993 UTC (32 years, 7 months ago) by greg
added math.h include
Tue Nov 12 17:04:53 1991 UTC (33 years, 9 months ago) by greg
Diff to previous 1.10 , to selected 2.14
Mon Oct 28 16:13:30 1991 UTC (33 years, 9 months ago) by greg
Changes since 1.9: +0 -2 lines
Diff to previous 1.9 , to selected 2.14
removed redundant definition of FTINY
Tue Aug 13 16:07:12 1991 UTC (34 years ago) by greg
Changes since 1.8: +4 -4 lines
Diff to previous 1.8 , to selected 2.14
changed private variable names with `SYS` context
Tue Apr 23 15:51:15 1991 UTC (34 years, 3 months ago) by greg
Diff to previous 1.7 , to selected 2.14
Tue Apr 23 13:05:03 1991 UTC (34 years, 3 months ago) by greg
Diff to previous 1.6 , to selected 2.14
changed arguments to varset()
Fri Jul 20 14:36:02 1990 UTC (35 years ago) by greg
Changes since 1.5: +5 -5 lines
Diff to previous 1.5 , to selected 2.14
Mon Jul 9 09:55:50 1990 UTC (35 years, 1 month ago) by greg
Diff to previous 1.4 , to selected 2.14
set eclock variable for more efficient computations
Wed Mar 7 11:14:39 1990 UTC (35 years, 5 months ago) by greg
Changes since 1.3: +17 -3 lines
Diff to previous 1.3 , to selected 2.14
added bezier and bspline functions
Fri Mar 2 17:24:05 1990 UTC (35 years, 5 months ago) by greg
Changes since 1.2: +15 -1 lines
Diff to previous 1.2 , to selected 2.14
Added Bezier cubic function
Sun Sep 10 16:45:18 1989 UTC (35 years, 11 months ago) by greg
Diff to previous 1.1 , to selected 2.14
fixed location of SCCSid
Thu Feb 2 11:16:31 1989 UTC (36 years, 6 months ago) by greg
Diff to selected 2.14
