root/radiance/ray/src/gen/genworm.c
Fri May 4 23:56:49 2018 UTC (6 years, 1 month ago) by greg
Changes since 2.9: +11 -4 lines
Diff to previous 2.9 , to selected 1.9
Fri Jan 12 00:50:17 2018 UTC (6 years, 4 months ago) by greg
Diff to previous 2.8 , to selected 1.9
Added missing esupport settings for constant expression reduction
Sat Aug 21 11:54:06 2004 UTC (19 years, 9 months ago) by greg
Changes since 2.7: +5 -44 lines
Diff to previous 2.7 , to selected 1.9
Changes since 2.6: +17 -8 lines
Diff to previous 2.6 , to selected 1.9
Mon Aug 4 22:37:53 2003 UTC (20 years, 10 months ago) by greg
Changes since 2.5: +6 -6 lines
Diff to previous 2.5 , to selected 1.9
Changes since 2.4: +3 -2 lines
Diff to previous 2.4 , to selected 1.9
Changes since 2.3: +5 -4 lines
Diff to previous 2.3 , to selected 1.9
Thu Nov 18 09:33:07 1993 UTC (30 years, 6 months ago) by greg
Diff to previous 2.2 , to selected 1.9
minor compiler warning fixes
Tue Jan 5 10:06:59 1993 UTC (31 years, 5 months ago) by greg
Diff to previous 2.1 , to selected 1.9
added math.h include
Tue Nov 12 17:04:53 1991 UTC (32 years, 6 months ago) by greg
Diff to previous 1.10 , to selected 1.9
Mon Oct 28 16:13:30 1991 UTC (32 years, 7 months ago) by greg
Changes since 1.9: +0 -2 lines
Diff to previous 1.9
removed redundant definition of FTINY
Revision 1.9 - (view) (download) (annotate) - [selected]
Tue Aug 13 16:07:12 1991 UTC (32 years, 9 months ago) by greg
Changes since 1.8: +4 -4 lines
Diff to previous 1.8
changed private variable names with `SYS` context
Tue Apr 23 15:51:15 1991 UTC (33 years, 1 month ago) by greg
Diff to previous 1.7 , to selected 1.9
Tue Apr 23 13:05:03 1991 UTC (33 years, 1 month ago) by greg
Diff to previous 1.6 , to selected 1.9
changed arguments to varset()
Fri Jul 20 14:36:02 1990 UTC (33 years, 10 months ago) by greg
Changes since 1.5: +5 -5 lines
Diff to previous 1.5 , to selected 1.9
Mon Jul 9 09:55:50 1990 UTC (33 years, 11 months ago) by greg
Diff to previous 1.4 , to selected 1.9
set eclock variable for more efficient computations
Wed Mar 7 11:14:39 1990 UTC (34 years, 3 months ago) by greg
Changes since 1.3: +17 -3 lines
Diff to previous 1.3 , to selected 1.9
added bezier and bspline functions
Fri Mar 2 17:24:05 1990 UTC (34 years, 3 months ago) by greg
Changes since 1.2: +15 -1 lines
Diff to previous 1.2 , to selected 1.9
Added Bezier cubic function
Sun Sep 10 16:45:18 1989 UTC (34 years, 9 months ago) by greg
Diff to previous 1.1 , to selected 1.9
fixed location of SCCSid
Thu Feb 2 11:16:31 1989 UTC (35 years, 4 months ago) by greg
Diff to selected 1.9
