--- ray/src/gen/genworm.c 1991/04/23 13:05:03 1.7 +++ ray/src/gen/genworm.c 2003/11/16 10:29:38 2.7 @@ -1,9 +1,6 @@ #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: genworm.c,v 2.7 2003/11/16 10:29:38 schorsch Exp $"; #endif - -/* Copyright (c) 1989 Regents of the University of California */ - /* * genworm.c - program to generate worms (strings with varying thickness). * @@ -14,39 +11,45 @@ static char SCCSid[] = "$SunId$ LBL"; * 9/24/87 */ +#include #include +#include +#include +#include "calcomp.h" #include "fvect.h" -#define XNAME "X_" /* x function name */ -#define YNAME "Y_" /* y function name */ -#define ZNAME "Z_" /* z function name */ -#define RNAME "R_" /* r function name */ +#define XNAME "X`SYS`" /* x function name */ +#define YNAME "Y`SYS`" /* y function name */ +#define ZNAME "Z`SYS`" /* z function name */ +#define RNAME "R`SYS`" /* r function name */ #define PI 3.14159265358979323846 -#define FTINY 1e-7 - #define max(a,b) ((a) > (b) ? (a) : (b)) -double funvalue(), l_hermite(), l_bezier(), l_bspline(), argument(); +/* XXX redundant, move to library */ +double l_hermite(char *), l_bezier(char *), l_bspline(char *); +static void printhead(int ac, char **av); + + +int main(argc, argv) int argc; char *argv[]; { - extern long eclock; char stmp[256]; - double t, f, lastr, r; + double t, f, lastr = 0, r; FVECT lastp, p; int i, nseg; varset("PI", ':', PI); - funset("hermite", 5, l_hermite); - funset("bezier", 5, l_bezier); - funset("bspline", 5, l_bspline); + funset("hermite", 5, ':', l_hermite); + funset("bezier", 5, ':', l_bezier); + funset("bspline", 5, ':', l_bspline); if (argc < 8) goto userror; @@ -80,7 +83,7 @@ char *argv[]; p[1] = funvalue(YNAME, 1, &t); p[2] = funvalue(ZNAME, 1, &t); r = funvalue(RNAME, 1, &t); - if (i) + if (i) { if (lastr <= r+FTINY && lastr >= r-FTINY) { printf("\n%s cylinder %s.c%d\n", argv[1], argv[2], i); @@ -107,22 +110,24 @@ char *argv[]; f = f <= 0.0 ? 0.0 : sqrt(f); printf("%18.12g %18.12g\n", f*lastr, f*r); } + } printf("\n%s sphere %s.s%d\n", argv[1], argv[2], i); printf("0\n0\n4 %18.12g %18.12g %18.12g %18.12g\n", p[0], p[1], p[2], r); VCOPY(lastp, p); lastr = r; } - quit(0); + return 0; userror: fprintf(stderr, "Usage: %s material name x(t) y(t) z(t) r(t) nseg [-e expr] [-f file]\n", argv[0]); - quit(1); + return 1; } +void eputs(msg) char *msg; { @@ -130,6 +135,7 @@ char *msg; } +void wputs(msg) char *msg; { @@ -137,15 +143,19 @@ char *msg; } +void quit(code) +int code; { exit(code); } -printhead(ac, av) /* print command header */ -register int ac; -register char **av; +void +printhead( /* print command header */ + register int ac, + register char **av +) { putchar('#'); while (ac--) { @@ -157,7 +167,7 @@ register char **av; double -l_hermite() +l_hermite(char *nm) { double t; @@ -170,7 +180,7 @@ l_hermite() double -l_bezier() +l_bezier(char *nm) { double t; @@ -183,7 +193,7 @@ l_bezier() double -l_bspline() +l_bspline(char *nm) { double t;
