1 |
#!/bin/csh -f |
2 |
# SCCSid "$Id$ LBL" |
3 |
4 |
# Generate source description for window with venetian blinds. |
5 |
6 |
# 1/11/88 Greg Ward |
7 |
8 |
# Usage: genwindow shellfile |
9 |
10 |
# Takes as input the following shell variables from file $1: |
11 |
12 |
# worient Window orientation (degrees from south) |
13 |
# wwidth Window width |
14 |
# wheight Window height |
15 |
# wtrans Window transmission |
16 |
# bdepth Blind depth |
17 |
# bspac Blind vertical spacing |
18 |
# gap Gap between blinds and window |
19 |
# brcurv Blind curvature radius (negative upward, zero none) |
20 |
# bangle Blind inclination (degrees from horizontal, up and out) |
21 |
# material Blind material type (metal or plastic) |
22 |
# ucolor Blind up side color ("red green blue") |
23 |
# uspec Blind up side specularity (0 to 1) |
24 |
# urough Blind up side roughness (0 to .2) |
25 |
# dcolor Blind down side color (opt) |
26 |
# dspec Blind down side specularity (opt) |
27 |
# drough Blind down side roughness (opt) |
28 |
# lat Site latitude (degrees) |
29 |
# long Site longitude (degrees) |
30 |
# mer Site standard meridian (degrees) |
31 |
# hour Hour (standard 24hr time) |
32 |
# day Day (of month) |
33 |
# month Month (of year) |
34 |
# grefl Ground plane reflectance |
35 |
# sky Sky conditions (sunny, clear, cloudy) |
36 |
# nsources Number of sources to divide window |
37 |
38 |
# Creates the following output files: |
39 |
40 |
# stdout Window description for Radiance |
41 |
# $1.d$$ Window output distribution |
42 |
43 |
44 |
if ( $#argv != 1 ) then |
45 |
echo Usage: $0 input |
46 |
exit 1 |
47 |
endif |
48 |
49 |
# Set input and output files |
50 |
set input = $1 |
51 |
set distrib = $1.d$$ |
52 |
set tmpdir = /tmp |
53 |
set descrip = $tmpdir/gw$$.des |
54 |
set distoct = $tmpdir/gw$$.oct |
55 |
set skydesc = $tmpdir/gw$$.sky |
56 |
set remove = ( $distoct $skydesc $descrip ) |
57 |
set removerr = ( $remove $distrib ) |
58 |
onintr error |
59 |
60 |
# Set default values |
61 |
set worient = 0. |
62 |
set wtrans = ( .96 .96 .96 ) |
63 |
set bdepth = 0.025 |
64 |
set bspac = 0.0155 |
65 |
set gap = 0. |
66 |
set brcurv = 0. |
67 |
set bangle = 0. |
68 |
set material = plastic |
69 |
set ucolor = ( 0.5 0.5 0.5 ) |
70 |
set uspec = 0. |
71 |
set urough = 0.05 |
72 |
set lat = 37.8 |
73 |
set long = 122 |
74 |
set mer = 120 |
75 |
set hour = 12 |
76 |
set day = 21 |
77 |
set month = 10 |
78 |
set grefl = .2 |
79 |
set sky = sunny |
80 |
set nsources = 6 |
81 |
82 |
# Get input |
83 |
source $input |
84 |
if ( $status ) goto error |
85 |
86 |
# Create window |
87 |
cat > $descrip <<_EOF_ |
88 |
89 |
void glass clear_glass |
90 |
0 |
91 |
0 |
92 |
3 $wtrans |
93 |
94 |
clear_glass polygon window |
95 |
0 |
96 |
0 |
97 |
12 |
98 |
0 0 0 |
99 |
0 0 $wheight |
100 |
$wwidth 0 $wheight |
101 |
$wwidth 0 0 |
102 |
103 |
void $material blind_upmat |
104 |
0 |
105 |
0 |
106 |
5 $ucolor $uspec $urough |
107 |
_EOF_ |
108 |
109 |
110 |
# Blinds |
111 |
genblinds blind_upmat blind_up $bdepth $wwidth $wheight \ |
112 |
`ev "ceil($wheight/$bspac)"` $bangle -r $brcurv \ |
113 |
| xform -t $gap -$wwidth 1e-4 -rz 90 >> $descrip |
114 |
115 |
if ( $?dcolor ) then |
116 |
cat >> $descrip <<_EOF_ |
117 |
118 |
void $material blind_dnmat |
119 |
0 |
120 |
0 |
121 |
5 $dcolor $dspec $drough |
122 |
_EOF_ |
123 |
genblinds blind_dnmat blind_down $bdepth $wwidth $wheight \ |
124 |
125 |
| xform -t $gap -$wwidth 0 -rz 90 >> $descrip |
126 |
127 |
endif |
128 |
129 |
# Make sky |
130 |
switch ($sky) |
131 |
case sun*: |
132 |
set skysw = +s |
133 |
breaksw |
134 |
case clear: |
135 |
set skysw = -s |
136 |
breaksw |
137 |
case cloud*: |
138 |
set skysw = -c |
139 |
breaksw |
140 |
endsw |
141 |
dosky: |
142 |
gensky $month $day $hour $skysw -a $lat -o $long -m $mer -g $grefl \ |
143 |
| xform -rz `ev "-($worient)"` > $skydesc |
144 |
if ( $skysw == +s ) then |
145 |
if ( `sed -n 13p $skydesc | rcalc -e '$1=if($3,-1,1)'` < 0 ) then |
146 |
set skysw = -s |
147 |
goto dosky |
148 |
endif |
149 |
endif |
150 |
cat >> $skydesc <<_EOF_ |
151 |
152 |
skyfunc glow skyglow |
153 |
0 |
154 |
0 |
155 |
4 1 1 1 0 |
156 |
157 |
skyglow source sky |
158 |
0 |
159 |
0 |
160 |
4 0 -1 0 180 |
161 |
_EOF_ |
162 |
163 |
# Make distribution |
164 |
oconv $skydesc $descrip > $distoct |
165 |
166 |
echo 2 5 85 9 0 340 18 > $distrib |
167 |
makedist -h -d -x1 0 1 0 -x2 0 0 1 -x3 1 0 0 -alpha 5-85:10 -beta 0-340:20 \ |
168 |
-tw $bspac -th $bspac -td `ev "2*($bdepth+$gap)"` \ |
169 |
-tc `ev "$wwidth/2" "$bdepth+$gap" "$wheight/2"` \ |
170 |
-ab 2 -aa .1 -ad 64 -as 64 \ |
171 |
-x 16 -y 16 $distoct >> $distrib |
172 |
173 |
174 |
set wsgrid = (`ev "floor(sqrt($nsources*$wwidth/$wheight)+.5)" "floor(sqrt($nsources*$wheight/$wwidth)+.5)"`) |
175 |
@ nsources = $wsgrid[1] * $wsgrid[2] |
176 |
# Print header |
177 |
cat <<_EOF_ |
178 |
179 |
# Window with venetian blinds |
180 |
# Created from $input `date` |
181 |
182 |
# Window orientation (degrees from south): $worient |
183 |
# Window height: $wheight |
184 |
# Window width: $wwidth |
185 |
# Window transmission: $wtrans |
186 |
# Blind depth: $bdepth |
187 |
# Blind spacing: $bspac |
188 |
# Gap to window: $gap |
189 |
# Blind curvature radius: $brcurv |
190 |
# Blind inclination (degrees altitude): $bangle |
191 |
# Blind material: $material |
192 |
# Up side color: $ucolor |
193 |
# Up side specularity: $uspec |
194 |
# Up side roughness: $urough |
195 |
_EOF_ |
196 |
197 |
cat <<_EOF_ |
198 |
# Down side color: $dcolor |
199 |
# Down side specularity: $dspec |
200 |
# Down side roughness: $drough |
201 |
_EOF_ |
202 |
else |
203 |
echo \#\ Down side same as up |
204 |
endif |
205 |
cat <<_EOF_ |
206 |
# Latitude (degrees): $lat |
207 |
# Longitude (degrees): $long |
208 |
# Standard Meridian (degrees): $mer |
209 |
# Month Day Hour: $month $day $hour |
210 |
# Ground plane reflectance: $grefl |
211 |
# Sky condition: $sky |
212 |
# Number of window sources: $nsources |
213 |
214 |
_EOF_ |
215 |
216 |
# Send sources |
217 |
xform -e -rz $worient <<_EOF_ |
218 |
219 |
void brightdata wdistrib |
220 |
10 noop $distrib source.cal src_theta src_phi -rx 90 -ry -90 -mx |
221 |
0 |
222 |
0 |
223 |
224 |
wdistrib illum willum |
225 |
0 |
226 |
0 |
227 |
3 1 1 1 |
228 |
229 |
!gensurf willum wsource "$wwidth*t" $bdepth "$wheight*s" $wsgrid[2] $wsgrid[1] |
230 |
_EOF_ |
231 |
232 |
233 |
# Send window |
234 |
xform -rz $worient $descrip |
235 |
236 |
237 |
# All done, print and exit |
238 |
rm -f $remove |
239 |
exit 0 |
240 |
241 |
# Error exit |
242 |
error: |
243 |
rm -f $removerr |
244 |
exit 1 |
