root/Development/ray/src/gen/genwindow.csh
Revision: 2.2
Committed: Sat Feb 22 02:07:23 2003 UTC (22 years, 8 months ago) by greg
Content type: application/x-csh
CVS Tags: rad5R4, rad5R2, rad5R3, rad5R0, rad5R1, rad4R2, rad3R7P2, rad3R7P1, rad6R0, rad4R1, rad4R0, rad3R5, rad3R6, rad3R6P1, rad3R8, rad3R9, rad4R2P1, rad4R2P2, HEAD
# User Rev Content
1 greg 1.1 #!/bin/csh -f
2 greg 2.2 # RCSid: $Id$
3 greg 1.1 #
4     # Generate source description for window with venetian blinds.
5     #
6     # 1/11/88 Greg Ward
7     #
8     # Usage: genwindow shellfile
9     #
10     # Takes as input the following shell variables from file $1:
11     #
12     # worient Window orientation (degrees from south)
13     # wwidth Window width
14     # wheight Window height
15     # wtrans Window transmission
16     # bdepth Blind depth
17     # bspac Blind vertical spacing
18     # gap Gap between blinds and window
19     # brcurv Blind curvature radius (negative upward, zero none)
20     # bangle Blind inclination (degrees from horizontal, up and out)
21     # material Blind material type (metal or plastic)
22     # ucolor Blind up side color ("red green blue")
23     # uspec Blind up side specularity (0 to 1)
24     # urough Blind up side roughness (0 to .2)
25     # dcolor Blind down side color (opt)
26     # dspec Blind down side specularity (opt)
27     # drough Blind down side roughness (opt)
28     # lat Site latitude (degrees)
29     # long Site longitude (degrees)
30     # mer Site standard meridian (degrees)
31     # hour Hour (standard 24hr time)
32     # day Day (of month)
33     # month Month (of year)
34     # grefl Ground plane reflectance
35     # sky Sky conditions (sunny, clear, cloudy)
36     # nsources Number of sources to divide window
37     #
38     # Creates the following output files:
39     #
40     # stdout Window description for Radiance
41     # $1.d$$ Window output distribution
42     #
43
44     if ( $#argv != 1 ) then
45     echo Usage: $0 input
46     exit 1
47     endif
48
49     # Set input and output files
50     set input = $1
51     set distrib = $1.d$$
52     set tmpdir = /tmp
53     set descrip = $tmpdir/gw$$.des
54     set distoct = $tmpdir/gw$$.oct
55     set skydesc = $tmpdir/gw$$.sky
56     set remove = ( $distoct $skydesc $descrip )
57     set removerr = ( $remove $distrib )
58     onintr error
59
60     # Set default values
61     set worient = 0.
62     set wtrans = ( .96 .96 .96 )
63     set bdepth = 0.025
64     set bspac = 0.0155
65     set gap = 0.
66     set brcurv = 0.
67     set bangle = 0.
68     set material = plastic
69     set ucolor = ( 0.5 0.5 0.5 )
70     set uspec = 0.
71     set urough = 0.05
72     set lat = 37.8
73     set long = 122
74     set mer = 120
75     set hour = 12
76     set day = 21
77     set month = 10
78     set grefl = .2
79     set sky = sunny
80     set nsources = 6
81
82     # Get input
83     source $input
84     if ( $status ) goto error
85
86     # Create window
87     cat > $descrip <<_EOF_
88
89     void glass clear_glass
90     0
91     0
92     3 $wtrans
93
94     clear_glass polygon window
95     0
96     0
97     12
98     0 0 0
99     0 0 $wheight
100     $wwidth 0 $wheight
101     $wwidth 0 0
102
103     void $material blind_upmat
104     0
105     0
106     5 $ucolor $uspec $urough
107     _EOF_
108     if ( $status ) goto error
109
110     # Blinds
111     genblinds blind_upmat blind_up $bdepth $wwidth $wheight \
112     `ev "ceil($wheight/$bspac)"` $bangle -r $brcurv \
113     | xform -t $gap -$wwidth 1e-4 -rz 90 >> $descrip
114     if ( $status ) goto error
115     if ( $?dcolor ) then
116     cat >> $descrip <<_EOF_
117
118     void $material blind_dnmat
119     0
120     0
121     5 $dcolor $dspec $drough
122     _EOF_
123     genblinds blind_dnmat blind_down $bdepth $wwidth $wheight \
124     `ev "ceil($wheight/$bspac)"` $bangle -r $brcurv \
125     | xform -t $gap -$wwidth 0 -rz 90 >> $descrip
126     if ( $status ) goto error
127     endif
128
129     # Make sky
130     switch ($sky)
131     case sun*:
132     set skysw = +s
133     breaksw
134     case clear:
135     set skysw = -s
136     breaksw
137     case cloud*:
138     set skysw = -c
139     breaksw
140     endsw
141     dosky:
142     gensky $month $day $hour $skysw -a $lat -o $long -m $mer -g $grefl \
143     | xform -rz `ev "-($worient)"` > $skydesc
144     if ( $skysw == +s ) then
145     if ( `sed -n 13p $skydesc | rcalc -e '$1=if($3,-1,1)'` < 0 ) then
146     set skysw = -s
147     goto dosky
148     endif
149     endif
150     cat >> $skydesc <<_EOF_
151
152     skyfunc glow skyglow
153     0
154     0
155     4 1 1 1 0
156
157     skyglow source sky
158     0
159     0
160     4 0 -1 0 180
161     _EOF_
162
163     # Make distribution
164     oconv $skydesc $descrip > $distoct
165     if ( $status ) goto error
166     echo 2 5 85 9 0 340 18 > $distrib
167     makedist -h -d -x1 0 1 0 -x2 0 0 1 -x3 1 0 0 -alpha 5-85:10 -beta 0-340:20 \
168     -tw $bspac -th $bspac -td `ev "2*($bdepth+$gap)"` \
169     -tc `ev "$wwidth/2" "$bdepth+$gap" "$wheight/2"` \
170     -ab 2 -aa .1 -ad 64 -as 64 \
171     -x 16 -y 16 $distoct >> $distrib
172     if ( $status ) goto error
173
174     set wsgrid = (`ev "floor(sqrt($nsources*$wwidth/$wheight)+.5)" "floor(sqrt($nsources*$wheight/$wwidth)+.5)"`)
175     @ nsources = $wsgrid[1] * $wsgrid[2]
176     # Print header
177     cat <<_EOF_
178     #
179     # Window with venetian blinds
180     # Created from $input `date`
181     #
182     # Window orientation (degrees from south): $worient
183     # Window height: $wheight
184     # Window width: $wwidth
185     # Window transmission: $wtrans
186     # Blind depth: $bdepth
187     # Blind spacing: $bspac
188     # Gap to window: $gap
189     # Blind curvature radius: $brcurv
190     # Blind inclination (degrees altitude): $bangle
191     # Blind material: $material
192     # Up side color: $ucolor
193     # Up side specularity: $uspec
194     # Up side roughness: $urough
195     _EOF_
196     if ( $?dcolor ) then
197     cat <<_EOF_
198     # Down side color: $dcolor
199     # Down side specularity: $dspec
200     # Down side roughness: $drough
201     _EOF_
202     else
203     echo \#\ Down side same as up
204     endif
205     cat <<_EOF_
206     # Latitude (degrees): $lat
207     # Longitude (degrees): $long
208     # Standard Meridian (degrees): $mer
209     # Month Day Hour: $month $day $hour
210     # Ground plane reflectance: $grefl
211     # Sky condition: $sky
212     # Number of window sources: $nsources
213     #
214     _EOF_
215
216     # Send sources
217     xform -e -rz $worient <<_EOF_
218
219     void brightdata wdistrib
220     10 noop $distrib source.cal src_theta src_phi -rx 90 -ry -90 -mx
221     0
222     0
223
224     wdistrib illum willum
225     0
226     0
227     3 1 1 1
228
229     !gensurf willum wsource "$wwidth*t" $bdepth "$wheight*s" $wsgrid[2] $wsgrid[1]
230     _EOF_
231     if ( $status ) goto error
232
233     # Send window
234     xform -rz $worient $descrip
235     if ( $status ) goto error
236
237     # All done, print and exit
238     rm -f $remove
239     exit 0
240
241     # Error exit
242     error:
243     rm -f $removerr
244     exit 1
