root/radiance/ray/src/gen/genwindow.csh
Revision: 2.2
Committed: Sat Feb 22 02:07:23 2003 UTC (22 years, 3 months ago) by greg
Content type: application/x-csh
CVS Tags: rad5R4, rad5R2, rad4R2P2, rad5R0, rad5R1, rad3R7P2, rad3R7P1, rad4R2, rad4R1, rad4R0, rad3R5, rad3R6, rad3R6P1, rad3R8, rad3R9, rad4R2P1, rad5R3, HEAD
1 #!/bin/csh -f
2 # RCSid: $Id$
3 #
4 # Generate source description for window with venetian blinds.
5 #
6 # 1/11/88 Greg Ward
7 #
8 # Usage: genwindow shellfile
9 #
10 # Takes as input the following shell variables from file $1:
11 #
12 # worient Window orientation (degrees from south)
13 # wwidth Window width
14 # wheight Window height
15 # wtrans Window transmission
16 # bdepth Blind depth
17 # bspac Blind vertical spacing
18 # gap Gap between blinds and window
19 # brcurv Blind curvature radius (negative upward, zero none)
20 # bangle Blind inclination (degrees from horizontal, up and out)
21 # material Blind material type (metal or plastic)
22 # ucolor Blind up side color ("red green blue")
23 # uspec Blind up side specularity (0 to 1)
24 # urough Blind up side roughness (0 to .2)
25 # dcolor Blind down side color (opt)
26 # dspec Blind down side specularity (opt)
27 # drough Blind down side roughness (opt)
28 # lat Site latitude (degrees)
29 # long Site longitude (degrees)
30 # mer Site standard meridian (degrees)
31 # hour Hour (standard 24hr time)
32 # day Day (of month)
33 # month Month (of year)
34 # grefl Ground plane reflectance
35 # sky Sky conditions (sunny, clear, cloudy)
36 # nsources Number of sources to divide window
37 #
38 # Creates the following output files:
39 #
40 # stdout Window description for Radiance
41 # $1.d$$ Window output distribution
42 #
43
44 if ( $#argv != 1 ) then
45 echo Usage: $0 input
46 exit 1
47 endif
48
49 # Set input and output files
50 set input = $1
51 set distrib = $1.d$$
52 set tmpdir = /tmp
53 set descrip = $tmpdir/gw$$.des
54 set distoct = $tmpdir/gw$$.oct
55 set skydesc = $tmpdir/gw$$.sky
56 set remove = ( $distoct $skydesc $descrip )
57 set removerr = ( $remove $distrib )
58 onintr error
59
60 # Set default values
61 set worient = 0.
62 set wtrans = ( .96 .96 .96 )
63 set bdepth = 0.025
64 set bspac = 0.0155
65 set gap = 0.
66 set brcurv = 0.
67 set bangle = 0.
68 set material = plastic
69 set ucolor = ( 0.5 0.5 0.5 )
70 set uspec = 0.
71 set urough = 0.05
72 set lat = 37.8
73 set long = 122
74 set mer = 120
75 set hour = 12
76 set day = 21
77 set month = 10
78 set grefl = .2
79 set sky = sunny
80 set nsources = 6
81
82 # Get input
83 source $input
84 if ( $status ) goto error
85
86 # Create window
87 cat > $descrip <<_EOF_
88
89 void glass clear_glass
90 0
91 0
92 3 $wtrans
93
94 clear_glass polygon window
95 0
96 0
97 12
98 0 0 0
99 0 0 $wheight
100 $wwidth 0 $wheight
101 $wwidth 0 0
102
103 void $material blind_upmat
104 0
105 0
106 5 $ucolor $uspec $urough
107 _EOF_
108 if ( $status ) goto error
109
110 # Blinds
111 genblinds blind_upmat blind_up $bdepth $wwidth $wheight \
112 `ev "ceil($wheight/$bspac)"` $bangle -r $brcurv \
113 | xform -t $gap -$wwidth 1e-4 -rz 90 >> $descrip
114 if ( $status ) goto error
115 if ( $?dcolor ) then
116 cat >> $descrip <<_EOF_
117
118 void $material blind_dnmat
119 0
120 0
121 5 $dcolor $dspec $drough
122 _EOF_
123 genblinds blind_dnmat blind_down $bdepth $wwidth $wheight \
124 `ev "ceil($wheight/$bspac)"` $bangle -r $brcurv \
125 | xform -t $gap -$wwidth 0 -rz 90 >> $descrip
126 if ( $status ) goto error
127 endif
128
129 # Make sky
130 switch ($sky)
131 case sun*:
132 set skysw = +s
133 breaksw
134 case clear:
135 set skysw = -s
136 breaksw
137 case cloud*:
138 set skysw = -c
139 breaksw
140 endsw
141 dosky:
142 gensky $month $day $hour $skysw -a $lat -o $long -m $mer -g $grefl \
143 | xform -rz `ev "-($worient)"` > $skydesc
144 if ( $skysw == +s ) then
145 if ( `sed -n 13p $skydesc | rcalc -e '$1=if($3,-1,1)'` < 0 ) then
146 set skysw = -s
147 goto dosky
148 endif
149 endif
150 cat >> $skydesc <<_EOF_
151
152 skyfunc glow skyglow
153 0
154 0
155 4 1 1 1 0
156
157 skyglow source sky
158 0
159 0
160 4 0 -1 0 180
161 _EOF_
162
163 # Make distribution
164 oconv $skydesc $descrip > $distoct
165 if ( $status ) goto error
166 echo 2 5 85 9 0 340 18 > $distrib
167 makedist -h -d -x1 0 1 0 -x2 0 0 1 -x3 1 0 0 -alpha 5-85:10 -beta 0-340:20 \
168 -tw $bspac -th $bspac -td `ev "2*($bdepth+$gap)"` \
169 -tc `ev "$wwidth/2" "$bdepth+$gap" "$wheight/2"` \
170 -ab 2 -aa .1 -ad 64 -as 64 \
171 -x 16 -y 16 $distoct >> $distrib
172 if ( $status ) goto error
173
174 set wsgrid = (`ev "floor(sqrt($nsources*$wwidth/$wheight)+.5)" "floor(sqrt($nsources*$wheight/$wwidth)+.5)"`)
175 @ nsources = $wsgrid[1] * $wsgrid[2]
176 # Print header
177 cat <<_EOF_
178 #
179 # Window with venetian blinds
180 # Created from $input `date`
181 #
182 # Window orientation (degrees from south): $worient
183 # Window height: $wheight
184 # Window width: $wwidth
185 # Window transmission: $wtrans
186 # Blind depth: $bdepth
187 # Blind spacing: $bspac
188 # Gap to window: $gap
189 # Blind curvature radius: $brcurv
190 # Blind inclination (degrees altitude): $bangle
191 # Blind material: $material
192 # Up side color: $ucolor
193 # Up side specularity: $uspec
194 # Up side roughness: $urough
195 _EOF_
196 if ( $?dcolor ) then
197 cat <<_EOF_
198 # Down side color: $dcolor
199 # Down side specularity: $dspec
200 # Down side roughness: $drough
201 _EOF_
202 else
203 echo \#\ Down side same as up
204 endif
205 cat <<_EOF_
206 # Latitude (degrees): $lat
207 # Longitude (degrees): $long
208 # Standard Meridian (degrees): $mer
209 # Month Day Hour: $month $day $hour
210 # Ground plane reflectance: $grefl
211 # Sky condition: $sky
212 # Number of window sources: $nsources
213 #
214 _EOF_
215
216 # Send sources
217 xform -e -rz $worient <<_EOF_
218
219 void brightdata wdistrib
220 10 noop $distrib source.cal src_theta src_phi -rx 90 -ry -90 -mx
221 0
222 0
223
224 wdistrib illum willum
225 0
226 0
227 3 1 1 1
228
229 !gensurf willum wsource "$wwidth*t" $bdepth "$wheight*s" $wsgrid[2] $wsgrid[1]
230 _EOF_
231 if ( $status ) goto error
232
233 # Send window
234 xform -rz $worient $descrip
235 if ( $status ) goto error
236
237 # All done, print and exit
238 rm -f $remove
239 exit 0
240
241 # Error exit
242 error:
243 rm -f $removerr
244 exit 1
