root/radiance/ray/src/gen/gensurf.c
Revision: 2.23
Committed: Sat Jan 28 23:09:24 2017 UTC (7 years, 3 months ago) by greg
Changes since 2.22: +30 -19 lines
Changed to relative vertex indexing, so we can concatenate OBJ output
# User Rev Content
1 greg 1.1 #ifndef lint
2 greg 2.23 static const char RCSid[] = "$Id: gensurf.c,v 2.22 2013/12/09 22:08:13 greg Exp $";
3 greg 1.1 #endif
4 greg 1.2 /*
5 greg 1.1 * gensurf.c - program to generate functional surfaces
6     *
7     * Parametric functions x(s,t), y(s,t) and z(s,t)
8     * specify the surface, which is tesselated into an m by n
9     * array of paired triangles.
10     * The surface normal is defined by the right hand
11     * rule applied to (s,t).
12     *
13     * 4/3/87
14 greg 2.6 *
15     * 4/16/02 Added conditional vertex output
16 greg 1.1 */
17
18 greg 2.14 #include "standard.h"
19 schorsch 2.15
20     #include "paths.h"
21 greg 2.16 #include "resolu.h"
22     #include "rterror.h"
23 schorsch 2.13 #include "calcomp.h"
24 greg 1.1
25 greg 2.6 char XNAME[] = "X`SYS"; /* x function name */
26     char YNAME[] = "Y`SYS"; /* y function name */
27     char ZNAME[] = "Z`SYS"; /* z function name */
28
29     char VNAME[] = "valid"; /* valid vertex name */
30 greg 1.1
31 greg 1.4 #define ABS(x) ((x)>=0 ? (x) : -(x))
32
33 greg 2.9 #define ZEROVECT(v) (DOT(v,v) <= FTINY*FTINY)
34
35 greg 1.3 #define pvect(p) printf(vformat, (p)[0], (p)[1], (p)[2])
36 greg 1.1
37 greg 2.18 char vformat[] = "%18.12g %18.12g %18.12g\n";
38 greg 2.19 char tsargs[] = "4 surf_dx surf_dy surf_dz surf.cal";
39 greg 1.3 char texname[] = "Phong";
40 greg 1.1
41 greg 1.3 int smooth = 0; /* apply smoothing? */
42 greg 2.7 int objout = 0; /* output .OBJ format? */
43 greg 1.1
44 greg 1.3 char *modname, *surfname;
45 greg 1.1
46 greg 2.2 /* recorded data flags */
47     #define HASBORDER 01
48     #define TRIPLETS 02
49     /* a data structure */
50     struct {
51     int flags; /* data type */
52     short m, n; /* number of s and t values */
53 schorsch 2.11 RREAL *data; /* the data itself, s major sort */
54 greg 2.2 } datarec; /* our recorded data */
55 greg 1.3
56 schorsch 2.13 /* XXX this is redundant with rt/noise3.c, should go to a library */
57 greg 2.2 double l_hermite(), l_bezier(), l_bspline(), l_dataval();
58
59 greg 1.3 typedef struct {
60 greg 2.7 int valid; /* point is valid (vertex number) */
61 greg 2.21 int nvalid; /* normal is valid */
62 greg 1.3 FVECT p; /* vertex position */
63     FVECT n; /* average normal */
64 schorsch 2.11 RREAL uv[2]; /* (u,v) position */
65 greg 1.3 } POINT;
66
67 greg 2.23 int nverts = 0; /* vertex output count */
68     int nnorms = 0; /* normal output count */
69 greg 1.3
70 schorsch 2.13 void loaddata(char *file, int m, int n, int pointsize);
71     double l_dataval(char *nam);
72     void putobjrow(POINT *rp, int n);
73 greg 2.23 void putobjvert(POINT *p);
74 schorsch 2.13 void putsquare(POINT *p0, POINT *p1, POINT *p2, POINT *p3);
75     void comprow(double s, POINT *row, int siz);
76     void compnorms(POINT *r0, POINT *r1, POINT *r2, int siz);
77     int norminterp(FVECT resmat[4], POINT *p0, POINT *p1, POINT *p2, POINT *p3);
78
79
80     int
81 greg 1.1 main(argc, argv)
82     int argc;
83     char *argv[];
84     {
85 greg 1.3 POINT *row0, *row1, *row2, *rp;
86 greg 1.1 int i, j, m, n;
87     char stmp[256];
88
89 greg 1.13 varset("PI", ':', PI);
90 greg 1.14 funset("hermite", 5, ':', l_hermite);
91     funset("bezier", 5, ':', l_bezier);
92     funset("bspline", 5, ':', l_bspline);
93 greg 1.1
94     if (argc < 8)
95     goto userror;
96
97     for (i = 8; i < argc; i++)
98     if (!strcmp(argv[i], "-e"))
99 greg 1.10 scompile(argv[++i], NULL, 0);
100 greg 1.1 else if (!strcmp(argv[i], "-f"))
101     fcompile(argv[++i]);
102 greg 1.3 else if (!strcmp(argv[i], "-s"))
103     smooth++;
104 greg 2.7 else if (!strcmp(argv[i], "-o"))
105     objout++;
106 greg 1.1 else
107     goto userror;
108
109 greg 1.3 modname = argv[1];
110     surfname = argv[2];
111 greg 1.1 m = atoi(argv[6]);
112     n = atoi(argv[7]);
113     if (m <= 0 || n <= 0)
114     goto userror;
115 greg 2.2 if (!strcmp(argv[5], "-") || access(argv[5], 4) == 0) { /* file? */
116     funset(ZNAME, 2, ':', l_dataval);
117     if (!strcmp(argv[5],argv[3]) && !strcmp(argv[5],argv[4])) {
118     loaddata(argv[5], m, n, 3);
119     funset(XNAME, 2, ':', l_dataval);
120     funset(YNAME, 2, ':', l_dataval);
121     } else {
122     loaddata(argv[5], m, n, 1);
123     sprintf(stmp, "%s(s,t)=%s;", XNAME, argv[3]);
124     scompile(stmp, NULL, 0);
125     sprintf(stmp, "%s(s,t)=%s;", YNAME, argv[4]);
126     scompile(stmp, NULL, 0);
127     }
128     } else {
129     sprintf(stmp, "%s(s,t)=%s;", XNAME, argv[3]);
130     scompile(stmp, NULL, 0);
131     sprintf(stmp, "%s(s,t)=%s;", YNAME, argv[4]);
132     scompile(stmp, NULL, 0);
133     sprintf(stmp, "%s(s,t)=%s;", ZNAME, argv[5]);
134     scompile(stmp, NULL, 0);
135     }
136 greg 1.4 row0 = (POINT *)malloc((n+3)*sizeof(POINT));
137     row1 = (POINT *)malloc((n+3)*sizeof(POINT));
138     row2 = (POINT *)malloc((n+3)*sizeof(POINT));
139 greg 1.3 if (row0 == NULL || row1 == NULL || row2 == NULL) {
140 greg 1.1 fprintf(stderr, "%s: out of memory\n", argv[0]);
141     quit(1);
142     }
143 greg 1.4 row0++; row1++; row2++;
144 greg 1.3 /* print header */
145 greg 2.16 fputs("# ", stdout);
146     printargs(argc, argv, stdout);
147 greg 1.9 eclock = 0;
148 greg 1.4 /* initialize */
149     comprow(-1.0/m, row0, n);
150 greg 1.3 comprow(0.0, row1, n);
151     comprow(1.0/m, row2, n);
152 greg 1.4 compnorms(row0, row1, row2, n);
153 greg 2.8 if (objout) {
154     printf("\nusemtl %s\n\n", modname);
155 greg 2.7 putobjrow(row1, n);
156 greg 2.8 }
157 greg 1.3 /* for each row */
158 greg 1.1 for (i = 0; i < m; i++) {
159     /* compute next row */
160 greg 1.3 rp = row0;
161 greg 1.1 row0 = row1;
162 greg 1.3 row1 = row2;
163     row2 = rp;
164 greg 1.4 comprow((double)(i+2)/m, row2, n);
165     compnorms(row0, row1, row2, n);
166 greg 2.7 if (objout)
167     putobjrow(row1, n);
168 greg 1.1
169     for (j = 0; j < n; j++) {
170 greg 2.6 int orient = (j & 1);
171 greg 1.3 /* put polygons */
172 greg 2.7 if (!(row0[j].valid && row1[j+1].valid))
173 greg 2.6 orient = 1;
174 greg 2.7 else if (!(row1[j].valid && row0[j+1].valid))
175 greg 2.6 orient = 0;
176     if (orient)
177 greg 1.3 putsquare(&row0[j], &row1[j],
178     &row0[j+1], &row1[j+1]);
179     else
180     putsquare(&row1[j], &row1[j+1],
181     &row0[j], &row0[j+1]);
182 greg 1.1 }
183     }
184
185 schorsch 2.13 return 0;
186 greg 1.1
187     userror:
188     fprintf(stderr, "Usage: %s material name ", argv[0]);
189 greg 2.17 fprintf(stderr, "x(s,t) y(s,t) z(s,t) m n [-s][-o][-e expr][-f file]\n");
190 schorsch 2.13 return 1;
191 greg 2.2 }
192
193
194 schorsch 2.13 void
195     loaddata( /* load point data from file */
196     char *file,
197     int m,
198     int n,
199     int pointsize
200     )
201 greg 2.2 {
202     FILE *fp;
203     char word[64];
204 greg 2.22 int size;
205     RREAL *dp;
206 greg 2.2
207     datarec.flags = HASBORDER; /* assume border values */
208 greg 2.3 datarec.m = m+1;
209     datarec.n = n+1;
210     size = datarec.m*datarec.n*pointsize;
211 greg 2.2 if (pointsize == 3)
212     datarec.flags |= TRIPLETS;
213 schorsch 2.11 dp = (RREAL *)malloc(size*sizeof(RREAL));
214 greg 2.2 if ((datarec.data = dp) == NULL) {
215     fputs("Out of memory\n", stderr);
216     exit(1);
217     }
218     if (!strcmp(file, "-")) {
219     file = "<stdin>";
220     fp = stdin;
221     } else if ((fp = fopen(file, "r")) == NULL) {
222     fputs(file, stderr);
223     fputs(": cannot open\n", stderr);
224     exit(1);
225     }
226     while (size > 0 && fgetword(word, sizeof(word), fp) != NULL) {
227     if (!isflt(word)) {
228     fprintf(stderr, "%s: garbled data value: %s\n",
229     file, word);
230     exit(1);
231     }
232     *dp++ = atof(word);
233     size--;
234     }
235     if (size == (m+n+1)*pointsize) { /* no border after all */
236 greg 2.20 dp = (RREAL *)realloc(datarec.data,
237 schorsch 2.11 m*n*pointsize*sizeof(RREAL));
238 greg 2.2 if (dp != NULL)
239     datarec.data = dp;
240     datarec.flags &= ~HASBORDER;
241 greg 2.3 datarec.m = m;
242     datarec.n = n;
243 greg 2.2 size = 0;
244     }
245 greg 2.3 if (datarec.m < 2 || datarec.n < 2 || size != 0 ||
246     fgetword(word, sizeof(word), fp) != NULL) {
247 greg 2.2 fputs(file, stderr);
248     fputs(": bad number of data points\n", stderr);
249     exit(1);
250     }
251     fclose(fp);
252     }
253
254
255     double
256 schorsch 2.13 l_dataval( /* return recorded data value */
257     char *nam
258     )
259 greg 2.2 {
260     double u, v;
261 greg 2.22 int i, j;
262     RREAL *dp;
263 greg 2.2 double d00, d01, d10, d11;
264     /* compute coordinates */
265     u = argument(1); v = argument(2);
266     if (datarec.flags & HASBORDER) {
267 greg 2.3 i = u *= datarec.m-1;
268     j = v *= datarec.n-1;
269 greg 2.2 } else {
270 greg 2.3 i = u = u*datarec.m - .5;
271     j = v = v*datarec.n - .5;
272 greg 2.2 }
273     if (i < 0) i = 0;
274     else if (i > datarec.m-2) i = datarec.m-2;
275     if (j < 0) j = 0;
276     else if (j > datarec.n-2) j = datarec.n-2;
277     /* compute value */
278     if (datarec.flags & TRIPLETS) {
279 greg 2.3 dp = datarec.data + 3*(j*datarec.m + i);
280     if (nam == ZNAME)
281     dp += 2;
282     else if (nam == YNAME)
283 greg 2.2 dp++;
284     d00 = dp[0]; d01 = dp[3];
285 greg 2.3 dp += 3*datarec.m;
286 greg 2.2 d10 = dp[0]; d11 = dp[3];
287     } else {
288 greg 2.3 dp = datarec.data + j*datarec.m + i;
289 greg 2.2 d00 = dp[0]; d01 = dp[1];
290 greg 2.3 dp += datarec.m;
291 greg 2.2 d10 = dp[0]; d11 = dp[1];
292     }
293     /* bilinear interpolation */
294     return((j+1-v)*((i+1-u)*d00+(u-i)*d01)+(v-j)*((i+1-u)*d10+(u-i)*d11));
295 greg 1.1 }
296
297
298 schorsch 2.13 void
299     putobjrow( /* output vertex row to .OBJ */
300 greg 2.22 POINT *rp,
301 schorsch 2.13 int n
302     )
303 greg 2.7 {
304     for ( ; n-- >= 0; rp++) {
305     if (!rp->valid)
306     continue;
307     fputs("v ", stdout);
308 greg 2.9 pvect(rp->p);
309 greg 2.21 if (smooth && !ZEROVECT(rp->n)) {
310 greg 2.7 printf("\tvn %.9g %.9g %.9g\n",
311     rp->n[0], rp->n[1], rp->n[2]);
312 greg 2.21 rp->nvalid = ++nnorms;
313     } else
314     rp->nvalid = 0;
315 greg 2.7 printf("\tvt %.9g %.9g\n", rp->uv[0], rp->uv[1]);
316     rp->valid = ++nverts;
317     }
318     }
319
320
321 schorsch 2.13 void
322 greg 2.23 putobjvert( /* put out OBJ vertex index triplet */
323     POINT *p
324     )
325     {
326     int pti = p->valid ? p->valid-nverts-1 : 0;
327     int ni = p->nvalid ? p->nvalid-nnorms-1 : 0;
328
329     printf(" %d/%d/%d", pti, pti, ni);
330     }
331
332
333     void
334 schorsch 2.13 putsquare( /* put out a square */
335     POINT *p0,
336     POINT *p1,
337     POINT *p2,
338     POINT *p3
339     )
340 greg 1.3 {
341     static int nout = 0;
342     FVECT norm[4];
343     int axis;
344     FVECT v1, v2, vc1, vc2;
345     int ok1, ok2;
346     /* compute exact normals */
347 greg 2.7 ok1 = (p0->valid && p1->valid && p2->valid);
348 greg 2.6 if (ok1) {
349 greg 2.9 VSUB(v1, p1->p, p0->p);
350     VSUB(v2, p2->p, p0->p);
351 greg 2.6 fcross(vc1, v1, v2);
352     ok1 = (normalize(vc1) != 0.0);
353     }
354 greg 2.7 ok2 = (p1->valid && p2->valid && p3->valid);
355 greg 2.6 if (ok2) {
356 greg 2.9 VSUB(v1, p2->p, p3->p);
357     VSUB(v2, p1->p, p3->p);
358 greg 2.6 fcross(vc2, v1, v2);
359     ok2 = (normalize(vc2) != 0.0);
360     }
361 greg 1.3 if (!(ok1 | ok2))
362     return;
363 greg 2.7 if (objout) { /* output .OBJ faces */
364     if (ok1 & ok2 && fdot(vc1,vc2) >= 1.0-FTINY*FTINY) {
365 greg 2.23 putc('f', stdout);
366     putobjvert(p0); putobjvert(p1);
367     putobjvert(p3); putobjvert(p2);
368     putc('\n', stdout);
369 greg 2.7 return;
370     }
371 greg 2.23 if (ok1) {
372     putc('f', stdout);
373     putobjvert(p0); putobjvert(p1); putobjvert(p2);
374     putc('\n', stdout);
375     }
376     if (ok2) {
377     putc('f', stdout);
378     putobjvert(p2); putobjvert(p1); putobjvert(p3);
379     putc('\n', stdout);
380     }
381 greg 2.7 return;
382     }
383 greg 1.3 /* compute normal interpolation */
384     axis = norminterp(norm, p0, p1, p2, p3);
385
386     /* put out quadrilateral? */
387     if (ok1 & ok2 && fdot(vc1,vc2) >= 1.0-FTINY*FTINY) {
388     printf("\n%s ", modname);
389     if (axis != -1) {
390 greg 2.19 printf("texfunc %s\n%s\n", texname, tsargs);
391 greg 1.3 printf("0\n13\t%d\n", axis);
392     pvect(norm[0]);
393     pvect(norm[1]);
394     pvect(norm[2]);
395     fvsum(v1, norm[3], vc1, -0.5);
396     fvsum(v1, v1, vc2, -0.5);
397     pvect(v1);
398     printf("\n%s ", texname);
399     }
400     printf("polygon %s.%d\n", surfname, ++nout);
401     printf("0\n0\n12\n");
402     pvect(p0->p);
403     pvect(p1->p);
404     pvect(p3->p);
405     pvect(p2->p);
406     return;
407     }
408     /* put out triangles? */
409     if (ok1) {
410     printf("\n%s ", modname);
411     if (axis != -1) {
412 greg 2.19 printf("texfunc %s\n%s\n", texname, tsargs);
413 greg 1.3 printf("0\n13\t%d\n", axis);
414     pvect(norm[0]);
415     pvect(norm[1]);
416     pvect(norm[2]);
417     fvsum(v1, norm[3], vc1, -1.0);
418     pvect(v1);
419     printf("\n%s ", texname);
420     }
421     printf("polygon %s.%d\n", surfname, ++nout);
422     printf("0\n0\n9\n");
423     pvect(p0->p);
424     pvect(p1->p);
425     pvect(p2->p);
426     }
427     if (ok2) {
428     printf("\n%s ", modname);
429     if (axis != -1) {
430 greg 2.19 printf("texfunc %s\n%s\n", texname, tsargs);
431 greg 1.3 printf("0\n13\t%d\n", axis);
432     pvect(norm[0]);
433     pvect(norm[1]);
434     pvect(norm[2]);
435     fvsum(v2, norm[3], vc2, -1.0);
436     pvect(v2);
437     printf("\n%s ", texname);
438     }
439     printf("polygon %s.%d\n", surfname, ++nout);
440     printf("0\n0\n9\n");
441     pvect(p2->p);
442     pvect(p1->p);
443     pvect(p3->p);
444     }
445     }
446
447
448 schorsch 2.13 void
449     comprow( /* compute row of values */
450     double s,
451 greg 2.22 POINT *row,
452 schorsch 2.13 int siz
453     )
454 greg 1.1 {
455 greg 1.4 double st[2];
456 greg 1.8 int end;
457 greg 2.6 int checkvalid;
458 greg 2.22 int i;
459 greg 1.8
460     if (smooth) {
461     i = -1; /* compute one past each end */
462     end = siz+1;
463     } else {
464     if (s < -FTINY || s > 1.0+FTINY)
465     return;
466     i = 0;
467     end = siz;
468     }
469 greg 1.1 st[0] = s;
470 greg 2.6 checkvalid = (fundefined(VNAME) == 2);
471 greg 1.8 while (i <= end) {
472 greg 1.4 st[1] = (double)i/siz;
473 greg 2.6 if (checkvalid && funvalue(VNAME, 2, st) <= 0.0) {
474     row[i].valid = 0;
475     row[i].p[0] = row[i].p[1] = row[i].p[2] = 0.0;
476 greg 2.7 row[i].uv[0] = row[i].uv[1] = 0.0;
477 greg 2.6 } else {
478     row[i].valid = 1;
479     row[i].p[0] = funvalue(XNAME, 2, st);
480     row[i].p[1] = funvalue(YNAME, 2, st);
481     row[i].p[2] = funvalue(ZNAME, 2, st);
482 greg 2.7 row[i].uv[0] = st[0];
483     row[i].uv[1] = st[1];
484 greg 2.6 }
485 greg 1.8 i++;
486 greg 1.1 }
487 greg 1.3 }
488
489
490 schorsch 2.13 void
491     compnorms( /* compute row of averaged normals */
492 greg 2.22 POINT *r0,
493     POINT *r1,
494     POINT *r2,
495 schorsch 2.13 int siz
496     )
497 greg 1.3 {
498 greg 1.11 FVECT v1, v2;
499 greg 1.3
500     if (!smooth) /* not needed if no smoothing */
501     return;
502 greg 2.6 /* compute row 1 normals */
503 greg 1.4 while (siz-- >= 0) {
504 greg 2.6 if (!r1[0].valid)
505     continue;
506     if (!r0[0].valid) {
507     if (!r2[0].valid) {
508     r1[0].n[0] = r1[0].n[1] = r1[0].n[2] = 0.0;
509     continue;
510     }
511     fvsum(v1, r2[0].p, r1[0].p, -1.0);
512     } else if (!r2[0].valid)
513     fvsum(v1, r1[0].p, r0[0].p, -1.0);
514     else
515     fvsum(v1, r2[0].p, r0[0].p, -1.0);
516     if (!r1[-1].valid) {
517     if (!r1[1].valid) {
518     r1[0].n[0] = r1[0].n[1] = r1[0].n[2] = 0.0;
519     continue;
520     }
521     fvsum(v2, r1[1].p, r1[0].p, -1.0);
522     } else if (!r1[1].valid)
523     fvsum(v2, r1[0].p, r1[-1].p, -1.0);
524     else
525     fvsum(v2, r1[1].p, r1[-1].p, -1.0);
526 greg 1.3 fcross(r1[0].n, v1, v2);
527     normalize(r1[0].n);
528     r0++; r1++; r2++;
529     }
530     }
531
532
533     int
534 schorsch 2.13 norminterp( /* compute normal interpolation */
535 greg 2.22 FVECT resmat[4],
536 schorsch 2.13 POINT *p0,
537     POINT *p1,
538     POINT *p2,
539     POINT *p3
540     )
541 greg 1.3 {
542     #define u ((ax+1)%3)
543     #define v ((ax+2)%3)
544
545 greg 2.22 int ax;
546 greg 1.12 MAT4 eqnmat;
547 greg 1.3 FVECT v1;
548 greg 2.22 int i, j;
549 greg 1.3
550     if (!smooth) /* no interpolation if no smoothing */
551     return(-1);
552     /* find dominant axis */
553     VCOPY(v1, p0->n);
554     fvsum(v1, v1, p1->n, 1.0);
555     fvsum(v1, v1, p2->n, 1.0);
556     fvsum(v1, v1, p3->n, 1.0);
557 greg 1.4 ax = ABS(v1[0]) > ABS(v1[1]) ? 0 : 1;
558     ax = ABS(v1[ax]) > ABS(v1[2]) ? ax : 2;
559 greg 1.3 /* assign equation matrix */
560     eqnmat[0][0] = p0->p[u]*p0->p[v];
561     eqnmat[0][1] = p0->p[u];
562     eqnmat[0][2] = p0->p[v];
563     eqnmat[0][3] = 1.0;
564     eqnmat[1][0] = p1->p[u]*p1->p[v];
565     eqnmat[1][1] = p1->p[u];
566     eqnmat[1][2] = p1->p[v];
567     eqnmat[1][3] = 1.0;
568     eqnmat[2][0] = p2->p[u]*p2->p[v];
569     eqnmat[2][1] = p2->p[u];
570     eqnmat[2][2] = p2->p[v];
571     eqnmat[2][3] = 1.0;
572     eqnmat[3][0] = p3->p[u]*p3->p[v];
573     eqnmat[3][1] = p3->p[u];
574     eqnmat[3][2] = p3->p[v];
575     eqnmat[3][3] = 1.0;
576     /* invert matrix (solve system) */
577 greg 2.5 if (!invmat4(eqnmat, eqnmat))
578 greg 1.3 return(-1); /* no solution */
579     /* compute result matrix */
580     for (j = 0; j < 4; j++)
581     for (i = 0; i < 3; i++)
582 greg 1.4 resmat[j][i] = eqnmat[j][0]*p0->n[i] +
583     eqnmat[j][1]*p1->n[i] +
584     eqnmat[j][2]*p2->n[i] +
585     eqnmat[j][3]*p3->n[i];
586 greg 1.3 return(ax);
587
588     #undef u
589     #undef v
590 greg 1.1 }
591
592
593     double
594 greg 2.12 l_hermite(char *nm)
595 greg 1.1 {
596     double t;
597
598     t = argument(5);
599     return( argument(1)*((2.0*t-3.0)*t*t+1.0) +
600     argument(2)*(-2.0*t+3.0)*t*t +
601     argument(3)*((t-2.0)*t+1.0)*t +
602     argument(4)*(t-1.0)*t*t );
603 greg 1.6 }
604
605
606     double
607 greg 2.12 l_bezier(char *nm)
608 greg 1.6 {
609     double t;
610
611     t = argument(5);
612     return( argument(1) * (1.+t*(-3.+t*(3.-t))) +
613     argument(2) * 3.*t*(1.+t*(-2.+t)) +
614     argument(3) * 3.*t*t*(1.-t) +
615     argument(4) * t*t*t );
616 greg 1.7 }
617
618
619     double
620 greg 2.12 l_bspline(char *nm)
621 greg 1.7 {
622     double t;
623
624     t = argument(5);
625     return( argument(1) * (1./6.+t*(-1./2.+t*(1./2.-1./6.*t))) +
626     argument(2) * (2./3.+t*t*(-1.+1./2.*t)) +
627     argument(3) * (1./6.+t*(1./2.+t*(1./2.-1./2.*t))) +
628     argument(4) * (1./6.*t*t*t) );
629 greg 1.1 }
