| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id$";
| 3 |
#endif
| 4 |
| 5 |
* gensurf.c - program to generate functional surfaces
| 6 |
| 7 |
* Parametric functions x(s,t), y(s,t) and z(s,t)
| 8 |
* specify the surface, which is tesselated into an m by n
| 9 |
* array of paired triangles.
| 10 |
* The surface normal is defined by the right hand
| 11 |
* rule applied to (s,t).
| 12 |
| 13 |
* 4/3/87
| 14 |
| 15 |
* 4/16/02 Added conditional vertex output
| 16 |
| 17 |
| 18 |
#include "standard.h"
| 19 |
| 20 |
char XNAME[] = "X`SYS"; /* x function name */
| 21 |
char YNAME[] = "Y`SYS"; /* y function name */
| 22 |
char ZNAME[] = "Z`SYS"; /* z function name */
| 23 |
| 24 |
char VNAME[] = "valid"; /* valid vertex name */
| 25 |
| 26 |
#define ABS(x) ((x)>=0 ? (x) : -(x))
| 27 |
| 28 |
#define ZEROVECT(v) (DOT(v,v) <= FTINY*FTINY)
| 29 |
| 30 |
#define pvect(p) printf(vformat, (p)[0], (p)[1], (p)[2])
| 31 |
| 32 |
char vformat[] = "%15.9g %15.9g %15.9g\n";
| 33 |
char tsargs[] = "4 surf_dx surf_dy surf_dz surf.cal\n";
| 34 |
char texname[] = "Phong";
| 35 |
| 36 |
int smooth = 0; /* apply smoothing? */
| 37 |
int objout = 0; /* output .OBJ format? */
| 38 |
| 39 |
char *modname, *surfname;
| 40 |
| 41 |
/* recorded data flags */
| 42 |
#define HASBORDER 01
| 43 |
#define TRIPLETS 02
| 44 |
/* a data structure */
| 45 |
struct {
| 46 |
int flags; /* data type */
| 47 |
short m, n; /* number of s and t values */
| 48 |
FLOAT *data; /* the data itself, s major sort */
| 49 |
} datarec; /* our recorded data */
| 50 |
| 51 |
double l_hermite(), l_bezier(), l_bspline(), l_dataval();
| 52 |
extern double funvalue(), argument();
| 53 |
| 54 |
typedef struct {
| 55 |
int valid; /* point is valid (vertex number) */
| 56 |
FVECT p; /* vertex position */
| 57 |
FVECT n; /* average normal */
| 58 |
FLOAT uv[2]; /* (u,v) position */
| 59 |
} POINT;
| 60 |
| 61 |
| 62 |
main(argc, argv)
| 63 |
int argc;
| 64 |
char *argv[];
| 65 |
| 66 |
extern long eclock;
| 67 |
POINT *row0, *row1, *row2, *rp;
| 68 |
int i, j, m, n;
| 69 |
char stmp[256];
| 70 |
| 71 |
varset("PI", ':', PI);
| 72 |
funset("hermite", 5, ':', l_hermite);
| 73 |
funset("bezier", 5, ':', l_bezier);
| 74 |
funset("bspline", 5, ':', l_bspline);
| 75 |
| 76 |
if (argc < 8)
| 77 |
goto userror;
| 78 |
| 79 |
for (i = 8; i < argc; i++)
| 80 |
if (!strcmp(argv[i], "-e"))
| 81 |
scompile(argv[++i], NULL, 0);
| 82 |
else if (!strcmp(argv[i], "-f"))
| 83 |
fcompile(argv[++i]);
| 84 |
else if (!strcmp(argv[i], "-s"))
| 85 |
smooth++;
| 86 |
else if (!strcmp(argv[i], "-o"))
| 87 |
objout++;
| 88 |
else
| 89 |
goto userror;
| 90 |
| 91 |
modname = argv[1];
| 92 |
surfname = argv[2];
| 93 |
m = atoi(argv[6]);
| 94 |
n = atoi(argv[7]);
| 95 |
if (m <= 0 || n <= 0)
| 96 |
goto userror;
| 97 |
if (!strcmp(argv[5], "-") || access(argv[5], 4) == 0) { /* file? */
| 98 |
funset(ZNAME, 2, ':', l_dataval);
| 99 |
if (!strcmp(argv[5],argv[3]) && !strcmp(argv[5],argv[4])) {
| 100 |
loaddata(argv[5], m, n, 3);
| 101 |
funset(XNAME, 2, ':', l_dataval);
| 102 |
funset(YNAME, 2, ':', l_dataval);
| 103 |
} else {
| 104 |
loaddata(argv[5], m, n, 1);
| 105 |
sprintf(stmp, "%s(s,t)=%s;", XNAME, argv[3]);
| 106 |
scompile(stmp, NULL, 0);
| 107 |
sprintf(stmp, "%s(s,t)=%s;", YNAME, argv[4]);
| 108 |
| 109 |
| 110 |
} else {
| 111 |
| 112 |
| 113 |
| 114 |
| 115 |
sprintf(stmp, "%s(s,t)=%s;", ZNAME, argv[5]);
| 116 |
| 117 |
| 118 |
row0 = (POINT *)malloc((n+3)*sizeof(POINT));
| 119 |
row1 = (POINT *)malloc((n+3)*sizeof(POINT));
| 120 |
row2 = (POINT *)malloc((n+3)*sizeof(POINT));
| 121 |
if (row0 == NULL || row1 == NULL || row2 == NULL) {
| 122 |
fprintf(stderr, "%s: out of memory\n", argv[0]);
| 123 |
quit(1);
| 124 |
| 125 |
row0++; row1++; row2++;
| 126 |
/* print header */
| 127 |
printhead(argc, argv);
| 128 |
eclock = 0;
| 129 |
/* initialize */
| 130 |
comprow(-1.0/m, row0, n);
| 131 |
comprow(0.0, row1, n);
| 132 |
comprow(1.0/m, row2, n);
| 133 |
compnorms(row0, row1, row2, n);
| 134 |
if (objout) {
| 135 |
printf("\nusemtl %s\n\n", modname);
| 136 |
putobjrow(row1, n);
| 137 |
| 138 |
/* for each row */
| 139 |
for (i = 0; i < m; i++) {
| 140 |
/* compute next row */
| 141 |
rp = row0;
| 142 |
row0 = row1;
| 143 |
row1 = row2;
| 144 |
row2 = rp;
| 145 |
comprow((double)(i+2)/m, row2, n);
| 146 |
| 147 |
if (objout)
| 148 |
putobjrow(row1, n);
| 149 |
| 150 |
for (j = 0; j < n; j++) {
| 151 |
int orient = (j & 1);
| 152 |
/* put polygons */
| 153 |
if (!(row0[j].valid && row1[j+1].valid))
| 154 |
orient = 1;
| 155 |
else if (!(row1[j].valid && row0[j+1].valid))
| 156 |
orient = 0;
| 157 |
if (orient)
| 158 |
putsquare(&row0[j], &row1[j],
| 159 |
&row0[j+1], &row1[j+1]);
| 160 |
else
| 161 |
putsquare(&row1[j], &row1[j+1],
| 162 |
&row0[j], &row0[j+1]);
| 163 |
| 164 |
| 165 |
| 166 |
quit(0);
| 167 |
| 168 |
userror:
| 169 |
fprintf(stderr, "Usage: %s material name ", argv[0]);
| 170 |
fprintf(stderr, "x(s,t) y(s,t) z(s,t) m n [-s][-e expr][-f file]\n");
| 171 |
quit(1);
| 172 |
| 173 |
| 174 |
| 175 |
loaddata(file, m, n, pointsize) /* load point data from file */
| 176 |
char *file;
| 177 |
int m, n;
| 178 |
int pointsize;
| 179 |
| 180 |
FILE *fp;
| 181 |
char word[64];
| 182 |
register int size;
| 183 |
register FLOAT *dp;
| 184 |
| 185 |
datarec.flags = HASBORDER; /* assume border values */
| 186 |
datarec.m = m+1;
| 187 |
datarec.n = n+1;
| 188 |
size = datarec.m*datarec.n*pointsize;
| 189 |
if (pointsize == 3)
| 190 |
datarec.flags |= TRIPLETS;
| 191 |
dp = (FLOAT *)malloc(size*sizeof(FLOAT));
| 192 |
if ((datarec.data = dp) == NULL) {
| 193 |
fputs("Out of memory\n", stderr);
| 194 |
exit(1);
| 195 |
| 196 |
if (!strcmp(file, "-")) {
| 197 |
file = "<stdin>";
| 198 |
fp = stdin;
| 199 |
} else if ((fp = fopen(file, "r")) == NULL) {
| 200 |
fputs(file, stderr);
| 201 |
fputs(": cannot open\n", stderr);
| 202 |
exit(1);
| 203 |
| 204 |
while (size > 0 && fgetword(word, sizeof(word), fp) != NULL) {
| 205 |
if (!isflt(word)) {
| 206 |
fprintf(stderr, "%s: garbled data value: %s\n",
| 207 |
file, word);
| 208 |
exit(1);
| 209 |
| 210 |
*dp++ = atof(word);
| 211 |
size--;
| 212 |
| 213 |
if (size == (m+n+1)*pointsize) { /* no border after all */
| 214 |
dp = (FLOAT *)realloc((char *)datarec.data,
| 215 |
m*n*pointsize*sizeof(FLOAT));
| 216 |
if (dp != NULL)
| 217 |
datarec.data = dp;
| 218 |
datarec.flags &= ~HASBORDER;
| 219 |
datarec.m = m;
| 220 |
datarec.n = n;
| 221 |
size = 0;
| 222 |
| 223 |
if (datarec.m < 2 || datarec.n < 2 || size != 0 ||
| 224 |
| 225 |
| 226 |
fputs(": bad number of data points\n", stderr);
| 227 |
exit(1);
| 228 |
| 229 |
fclose(fp);
| 230 |
| 231 |
| 232 |
| 233 |
double
| 234 |
l_dataval(nam) /* return recorded data value */
| 235 |
char *nam;
| 236 |
| 237 |
double u, v;
| 238 |
register int i, j;
| 239 |
register FLOAT *dp;
| 240 |
double d00, d01, d10, d11;
| 241 |
/* compute coordinates */
| 242 |
u = argument(1); v = argument(2);
| 243 |
if (datarec.flags & HASBORDER) {
| 244 |
i = u *= datarec.m-1;
| 245 |
j = v *= datarec.n-1;
| 246 |
} else {
| 247 |
i = u = u*datarec.m - .5;
| 248 |
j = v = v*datarec.n - .5;
| 249 |
| 250 |
if (i < 0) i = 0;
| 251 |
else if (i > datarec.m-2) i = datarec.m-2;
| 252 |
if (j < 0) j = 0;
| 253 |
else if (j > datarec.n-2) j = datarec.n-2;
| 254 |
/* compute value */
| 255 |
if (datarec.flags & TRIPLETS) {
| 256 |
dp = datarec.data + 3*(j*datarec.m + i);
| 257 |
if (nam == ZNAME)
| 258 |
dp += 2;
| 259 |
else if (nam == YNAME)
| 260 |
dp++;
| 261 |
d00 = dp[0]; d01 = dp[3];
| 262 |
dp += 3*datarec.m;
| 263 |
d10 = dp[0]; d11 = dp[3];
| 264 |
} else {
| 265 |
dp = datarec.data + j*datarec.m + i;
| 266 |
d00 = dp[0]; d01 = dp[1];
| 267 |
dp += datarec.m;
| 268 |
d10 = dp[0]; d11 = dp[1];
| 269 |
| 270 |
/* bilinear interpolation */
| 271 |
return((j+1-v)*((i+1-u)*d00+(u-i)*d01)+(v-j)*((i+1-u)*d10+(u-i)*d11));
| 272 |
| 273 |
| 274 |
| 275 |
putobjrow(rp, n) /* output vertex row to .OBJ */
| 276 |
register POINT *rp;
| 277 |
int n;
| 278 |
| 279 |
static int nverts = 0;
| 280 |
| 281 |
for ( ; n-- >= 0; rp++) {
| 282 |
if (!rp->valid)
| 283 |
continue;
| 284 |
fputs("v ", stdout);
| 285 |
pvect(rp->p);
| 286 |
if (smooth && !ZEROVECT(rp->n))
| 287 |
printf("\tvn %.9g %.9g %.9g\n",
| 288 |
rp->n[0], rp->n[1], rp->n[2]);
| 289 |
printf("\tvt %.9g %.9g\n", rp->uv[0], rp->uv[1]);
| 290 |
rp->valid = ++nverts;
| 291 |
| 292 |
| 293 |
| 294 |
| 295 |
putsquare(p0, p1, p2, p3) /* put out a square */
| 296 |
POINT *p0, *p1, *p2, *p3;
| 297 |
| 298 |
static int nout = 0;
| 299 |
FVECT norm[4];
| 300 |
int axis;
| 301 |
FVECT v1, v2, vc1, vc2;
| 302 |
int ok1, ok2;
| 303 |
/* compute exact normals */
| 304 |
ok1 = (p0->valid && p1->valid && p2->valid);
| 305 |
if (ok1) {
| 306 |
VSUB(v1, p1->p, p0->p);
| 307 |
VSUB(v2, p2->p, p0->p);
| 308 |
fcross(vc1, v1, v2);
| 309 |
ok1 = (normalize(vc1) != 0.0);
| 310 |
| 311 |
ok2 = (p1->valid && p2->valid && p3->valid);
| 312 |
if (ok2) {
| 313 |
VSUB(v1, p2->p, p3->p);
| 314 |
VSUB(v2, p1->p, p3->p);
| 315 |
fcross(vc2, v1, v2);
| 316 |
ok2 = (normalize(vc2) != 0.0);
| 317 |
| 318 |
if (!(ok1 | ok2))
| 319 |
return;
| 320 |
if (objout) { /* output .OBJ faces */
| 321 |
int p0n=0, p1n=0, p2n=0, p3n=0;
| 322 |
if (smooth) {
| 323 |
if (!ZEROVECT(p0->n))
| 324 |
p0n = p0->valid;
| 325 |
if (!ZEROVECT(p1->n))
| 326 |
p1n = p1->valid;
| 327 |
if (!ZEROVECT(p2->n))
| 328 |
p2n = p2->valid;
| 329 |
if (!ZEROVECT(p3->n))
| 330 |
p3n = p3->valid;
| 331 |
| 332 |
if (ok1 & ok2 && fdot(vc1,vc2) >= 1.0-FTINY*FTINY) {
| 333 |
printf("f %d/%d/%d %d/%d/%d %d/%d/%d %d/%d/%d\n",
| 334 |
p0->valid, p0->valid, p0n,
| 335 |
p1->valid, p1->valid, p1n,
| 336 |
p3->valid, p3->valid, p3n,
| 337 |
p2->valid, p2->valid, p2n);
| 338 |
return;
| 339 |
| 340 |
if (ok1)
| 341 |
printf("f %d/%d/%d %d/%d/%d %d/%d/%d\n",
| 342 |
| 343 |
| 344 |
| 345 |
if (ok2)
| 346 |
| 347 |
p2->valid, p2->valid, p2n,
| 348 |
| 349 |
p3->valid, p3->valid, p3n);
| 350 |
return;
| 351 |
| 352 |
/* compute normal interpolation */
| 353 |
axis = norminterp(norm, p0, p1, p2, p3);
| 354 |
| 355 |
/* put out quadrilateral? */
| 356 |
| 357 |
printf("\n%s ", modname);
| 358 |
if (axis != -1) {
| 359 |
printf("texfunc %s\n", texname);
| 360 |
printf(tsargs);
| 361 |
printf("0\n13\t%d\n", axis);
| 362 |
pvect(norm[0]);
| 363 |
pvect(norm[1]);
| 364 |
pvect(norm[2]);
| 365 |
fvsum(v1, norm[3], vc1, -0.5);
| 366 |
fvsum(v1, v1, vc2, -0.5);
| 367 |
pvect(v1);
| 368 |
printf("\n%s ", texname);
| 369 |
| 370 |
printf("polygon %s.%d\n", surfname, ++nout);
| 371 |
printf("0\n0\n12\n");
| 372 |
pvect(p0->p);
| 373 |
pvect(p1->p);
| 374 |
pvect(p3->p);
| 375 |
pvect(p2->p);
| 376 |
return;
| 377 |
| 378 |
/* put out triangles? */
| 379 |
if (ok1) {
| 380 |
| 381 |
if (axis != -1) {
| 382 |
| 383 |
printf(tsargs);
| 384 |
| 385 |
pvect(norm[0]);
| 386 |
pvect(norm[1]);
| 387 |
pvect(norm[2]);
| 388 |
fvsum(v1, norm[3], vc1, -1.0);
| 389 |
pvect(v1);
| 390 |
| 391 |
| 392 |
| 393 |
printf("0\n0\n9\n");
| 394 |
pvect(p0->p);
| 395 |
pvect(p1->p);
| 396 |
pvect(p2->p);
| 397 |
| 398 |
if (ok2) {
| 399 |
| 400 |
if (axis != -1) {
| 401 |
| 402 |
printf(tsargs);
| 403 |
| 404 |
pvect(norm[0]);
| 405 |
pvect(norm[1]);
| 406 |
pvect(norm[2]);
| 407 |
fvsum(v2, norm[3], vc2, -1.0);
| 408 |
pvect(v2);
| 409 |
| 410 |
| 411 |
| 412 |
| 413 |
pvect(p2->p);
| 414 |
pvect(p1->p);
| 415 |
pvect(p3->p);
| 416 |
| 417 |
| 418 |
| 419 |
| 420 |
comprow(s, row, siz) /* compute row of values */
| 421 |
double s;
| 422 |
register POINT *row;
| 423 |
int siz;
| 424 |
| 425 |
double st[2];
| 426 |
int end;
| 427 |
int checkvalid;
| 428 |
register int i;
| 429 |
| 430 |
if (smooth) {
| 431 |
i = -1; /* compute one past each end */
| 432 |
end = siz+1;
| 433 |
} else {
| 434 |
if (s < -FTINY || s > 1.0+FTINY)
| 435 |
return;
| 436 |
i = 0;
| 437 |
end = siz;
| 438 |
| 439 |
st[0] = s;
| 440 |
checkvalid = (fundefined(VNAME) == 2);
| 441 |
while (i <= end) {
| 442 |
st[1] = (double)i/siz;
| 443 |
if (checkvalid && funvalue(VNAME, 2, st) <= 0.0) {
| 444 |
row[i].valid = 0;
| 445 |
row[i].p[0] = row[i].p[1] = row[i].p[2] = 0.0;
| 446 |
row[i].uv[0] = row[i].uv[1] = 0.0;
| 447 |
} else {
| 448 |
row[i].valid = 1;
| 449 |
row[i].p[0] = funvalue(XNAME, 2, st);
| 450 |
row[i].p[1] = funvalue(YNAME, 2, st);
| 451 |
row[i].p[2] = funvalue(ZNAME, 2, st);
| 452 |
row[i].uv[0] = st[0];
| 453 |
row[i].uv[1] = st[1];
| 454 |
| 455 |
i++;
| 456 |
| 457 |
| 458 |
| 459 |
| 460 |
compnorms(r0, r1, r2, siz) /* compute row of averaged normals */
| 461 |
register POINT *r0, *r1, *r2;
| 462 |
int siz;
| 463 |
| 464 |
FVECT v1, v2;
| 465 |
| 466 |
if (!smooth) /* not needed if no smoothing */
| 467 |
return;
| 468 |
/* compute row 1 normals */
| 469 |
while (siz-- >= 0) {
| 470 |
if (!r1[0].valid)
| 471 |
continue;
| 472 |
if (!r0[0].valid) {
| 473 |
if (!r2[0].valid) {
| 474 |
r1[0].n[0] = r1[0].n[1] = r1[0].n[2] = 0.0;
| 475 |
continue;
| 476 |
| 477 |
fvsum(v1, r2[0].p, r1[0].p, -1.0);
| 478 |
} else if (!r2[0].valid)
| 479 |
fvsum(v1, r1[0].p, r0[0].p, -1.0);
| 480 |
else
| 481 |
fvsum(v1, r2[0].p, r0[0].p, -1.0);
| 482 |
if (!r1[-1].valid) {
| 483 |
if (!r1[1].valid) {
| 484 |
| 485 |
continue;
| 486 |
| 487 |
fvsum(v2, r1[1].p, r1[0].p, -1.0);
| 488 |
} else if (!r1[1].valid)
| 489 |
fvsum(v2, r1[0].p, r1[-1].p, -1.0);
| 490 |
else
| 491 |
fvsum(v2, r1[1].p, r1[-1].p, -1.0);
| 492 |
fcross(r1[0].n, v1, v2);
| 493 |
normalize(r1[0].n);
| 494 |
r0++; r1++; r2++;
| 495 |
| 496 |
| 497 |
| 498 |
| 499 |
int
| 500 |
norminterp(resmat, p0, p1, p2, p3) /* compute normal interpolation */
| 501 |
register FVECT resmat[4];
| 502 |
| 503 |
| 504 |
#define u ((ax+1)%3)
| 505 |
#define v ((ax+2)%3)
| 506 |
| 507 |
register int ax;
| 508 |
MAT4 eqnmat;
| 509 |
FVECT v1;
| 510 |
register int i, j;
| 511 |
| 512 |
if (!smooth) /* no interpolation if no smoothing */
| 513 |
return(-1);
| 514 |
/* find dominant axis */
| 515 |
VCOPY(v1, p0->n);
| 516 |
fvsum(v1, v1, p1->n, 1.0);
| 517 |
fvsum(v1, v1, p2->n, 1.0);
| 518 |
fvsum(v1, v1, p3->n, 1.0);
| 519 |
ax = ABS(v1[0]) > ABS(v1[1]) ? 0 : 1;
| 520 |
ax = ABS(v1[ax]) > ABS(v1[2]) ? ax : 2;
| 521 |
/* assign equation matrix */
| 522 |
eqnmat[0][0] = p0->p[u]*p0->p[v];
| 523 |
eqnmat[0][1] = p0->p[u];
| 524 |
eqnmat[0][2] = p0->p[v];
| 525 |
eqnmat[0][3] = 1.0;
| 526 |
eqnmat[1][0] = p1->p[u]*p1->p[v];
| 527 |
eqnmat[1][1] = p1->p[u];
| 528 |
eqnmat[1][2] = p1->p[v];
| 529 |
eqnmat[1][3] = 1.0;
| 530 |
eqnmat[2][0] = p2->p[u]*p2->p[v];
| 531 |
eqnmat[2][1] = p2->p[u];
| 532 |
eqnmat[2][2] = p2->p[v];
| 533 |
eqnmat[2][3] = 1.0;
| 534 |
eqnmat[3][0] = p3->p[u]*p3->p[v];
| 535 |
eqnmat[3][1] = p3->p[u];
| 536 |
eqnmat[3][2] = p3->p[v];
| 537 |
eqnmat[3][3] = 1.0;
| 538 |
/* invert matrix (solve system) */
| 539 |
if (!invmat4(eqnmat, eqnmat))
| 540 |
return(-1); /* no solution */
| 541 |
/* compute result matrix */
| 542 |
for (j = 0; j < 4; j++)
| 543 |
for (i = 0; i < 3; i++)
| 544 |
resmat[j][i] = eqnmat[j][0]*p0->n[i] +
| 545 |
eqnmat[j][1]*p1->n[i] +
| 546 |
eqnmat[j][2]*p2->n[i] +
| 547 |
eqnmat[j][3]*p3->n[i];
| 548 |
return(ax);
| 549 |
| 550 |
#undef u
| 551 |
#undef v
| 552 |
| 553 |
| 554 |
| 555 |
void
| 556 |
eputs(msg)
| 557 |
char *msg;
| 558 |
| 559 |
fputs(msg, stderr);
| 560 |
| 561 |
| 562 |
| 563 |
void
| 564 |
wputs(msg)
| 565 |
char *msg;
| 566 |
| 567 |
eputs(msg);
| 568 |
| 569 |
| 570 |
| 571 |
void
| 572 |
quit(code)
| 573 |
int code;
| 574 |
| 575 |
exit(code);
| 576 |
| 577 |
| 578 |
| 579 |
printhead(ac, av) /* print command header */
| 580 |
register int ac;
| 581 |
register char **av;
| 582 |
| 583 |
putchar('#');
| 584 |
while (ac--) {
| 585 |
putchar(' ');
| 586 |
fputs(*av++, stdout);
| 587 |
| 588 |
putchar('\n');
| 589 |
| 590 |
| 591 |
| 592 |
double
| 593 |
l_hermite()
| 594 |
| 595 |
double t;
| 596 |
| 597 |
t = argument(5);
| 598 |
return( argument(1)*((2.0*t-3.0)*t*t+1.0) +
| 599 |
argument(2)*(-2.0*t+3.0)*t*t +
| 600 |
argument(3)*((t-2.0)*t+1.0)*t +
| 601 |
argument(4)*(t-1.0)*t*t );
| 602 |
| 603 |
| 604 |
| 605 |
double
| 606 |
l_bezier()
| 607 |
| 608 |
double t;
| 609 |
| 610 |
t = argument(5);
| 611 |
return( argument(1) * (1.+t*(-3.+t*(3.-t))) +
| 612 |
argument(2) * 3.*t*(1.+t*(-2.+t)) +
| 613 |
argument(3) * 3.*t*t*(1.-t) +
| 614 |
argument(4) * t*t*t );
| 615 |
| 616 |
| 617 |
| 618 |
double
| 619 |
l_bspline()
| 620 |
| 621 |
double t;
| 622 |
| 623 |
t = argument(5);
| 624 |
return( argument(1) * (1./6.+t*(-1./2.+t*(1./2.-1./6.*t))) +
| 625 |
argument(2) * (2./3.+t*t*(-1.+1./2.*t)) +
| 626 |
argument(3) * (1./6.+t*(1./2.+t*(1./2.-1./2.*t))) +
| 627 |
argument(4) * (1./6.*t*t*t) );
| 628 |
