--- ray/src/gen/gensurf.c 2003/02/22 02:07:23 2.6 +++ ray/src/gen/gensurf.c 2003/03/12 04:59:04 2.9 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: gensurf.c,v 2.6 2003/02/22 02:07:23 greg Exp $"; +static const char RCSid[] = "$Id: gensurf.c,v 2.9 2003/03/12 04:59:04 greg Exp $"; #endif /* * gensurf.c - program to generate functional surfaces @@ -25,6 +25,8 @@ char VNAME[] = "valid"; /* valid vertex name */ #define ABS(x) ((x)>=0 ? (x) : -(x)) +#define ZEROVECT(v) (DOT(v,v) <= FTINY*FTINY) + #define pvect(p) printf(vformat, (p)[0], (p)[1], (p)[2]) char vformat[] = "%15.9g %15.9g %15.9g\n"; @@ -32,6 +34,7 @@ char tsargs[] = "4 surf_dx surf_dy surf_dz surf.cal\n char texname[] = "Phong"; int smooth = 0; /* apply smoothing? */ +int objout = 0; /* output .OBJ format? */ char *modname, *surfname; @@ -49,9 +52,10 @@ double l_hermite(), l_bezier(), l_bspline(), l_datava extern double funvalue(), argument(); typedef struct { - int valid; /* point is valid */ + int valid; /* point is valid (vertex number) */ FVECT p; /* vertex position */ FVECT n; /* average normal */ + FLOAT uv[2]; /* (u,v) position */ } POINT; @@ -79,6 +83,8 @@ char *argv[]; fcompile(argv[++i]); else if (!strcmp(argv[i], "-s")) smooth++; + else if (!strcmp(argv[i], "-o")) + objout++; else goto userror; @@ -125,6 +131,10 @@ char *argv[]; comprow(0.0, row1, n); comprow(1.0/m, row2, n); compnorms(row0, row1, row2, n); + if (objout) { + printf("\nusemtl %s\n\n", modname); + putobjrow(row1, n); + } /* for each row */ for (i = 0; i < m; i++) { /* compute next row */ @@ -134,13 +144,15 @@ char *argv[]; row2 = rp; comprow((double)(i+2)/m, row2, n); compnorms(row0, row1, row2, n); + if (objout) + putobjrow(row1, n); for (j = 0; j < n; j++) { int orient = (j & 1); /* put polygons */ - if (!(row0[j].valid & row1[j+1].valid)) + if (!(row0[j].valid && row1[j+1].valid)) orient = 1; - else if (!(row1[j].valid & row0[j+1].valid)) + else if (!(row1[j].valid && row0[j+1].valid)) orient = 0; if (orient) putsquare(&row0[j], &row1[j], @@ -260,6 +272,26 @@ char *nam; } +putobjrow(rp, n) /* output vertex row to .OBJ */ +register POINT *rp; +int n; +{ + static int nverts = 0; + + for ( ; n-- >= 0; rp++) { + if (!rp->valid) + continue; + fputs("v ", stdout); + pvect(rp->p); + if (smooth && !ZEROVECT(rp->n)) + printf("\tvn %.9g %.9g %.9g\n", + rp->n[0], rp->n[1], rp->n[2]); + printf("\tvt %.9g %.9g\n", rp->uv[0], rp->uv[1]); + rp->valid = ++nverts; + } +} + + putsquare(p0, p1, p2, p3) /* put out a square */ POINT *p0, *p1, *p2, *p3; { @@ -269,22 +301,54 @@ POINT *p0, *p1, *p2, *p3; FVECT v1, v2, vc1, vc2; int ok1, ok2; /* compute exact normals */ - ok1 = (p0->valid & p1->valid & p2->valid); + ok1 = (p0->valid && p1->valid && p2->valid); if (ok1) { - fvsum(v1, p1->p, p0->p, -1.0); - fvsum(v2, p2->p, p0->p, -1.0); + VSUB(v1, p1->p, p0->p); + VSUB(v2, p2->p, p0->p); fcross(vc1, v1, v2); ok1 = (normalize(vc1) != 0.0); } - ok2 = (p1->valid & p2->valid & p3->valid); + ok2 = (p1->valid && p2->valid && p3->valid); if (ok2) { - fvsum(v1, p2->p, p3->p, -1.0); - fvsum(v2, p1->p, p3->p, -1.0); + VSUB(v1, p2->p, p3->p); + VSUB(v2, p1->p, p3->p); fcross(vc2, v1, v2); ok2 = (normalize(vc2) != 0.0); } if (!(ok1 | ok2)) return; + if (objout) { /* output .OBJ faces */ + int p0n=0, p1n=0, p2n=0, p3n=0; + if (smooth) { + if (!ZEROVECT(p0->n)) + p0n = p0->valid; + if (!ZEROVECT(p1->n)) + p1n = p1->valid; + if (!ZEROVECT(p2->n)) + p2n = p2->valid; + if (!ZEROVECT(p3->n)) + p3n = p3->valid; + } + if (ok1 & ok2 && fdot(vc1,vc2) >= 1.0-FTINY*FTINY) { + printf("f %d/%d/%d %d/%d/%d %d/%d/%d %d/%d/%d\n", + p0->valid, p0->valid, p0n, + p1->valid, p1->valid, p1n, + p3->valid, p3->valid, p3n, + p2->valid, p2->valid, p2n); + return; + } + if (ok1) + printf("f %d/%d/%d %d/%d/%d %d/%d/%d\n", + p0->valid, p0->valid, p0n, + p1->valid, p1->valid, p1n, + p2->valid, p2->valid, p2n); + if (ok2) + printf("f %d/%d/%d %d/%d/%d %d/%d/%d\n", + p2->valid, p2->valid, p2n, + p1->valid, p1->valid, p1n, + p3->valid, p3->valid, p3n); + return; + } /* compute normal interpolation */ axis = norminterp(norm, p0, p1, p2, p3); @@ -379,11 +443,14 @@ int siz; if (checkvalid && funvalue(VNAME, 2, st) <= 0.0) { row[i].valid = 0; row[i].p[0] = row[i].p[1] = row[i].p[2] = 0.0; + row[i].uv[0] = row[i].uv[1] = 0.0; } else { row[i].valid = 1; row[i].p[0] = funvalue(XNAME, 2, st); row[i].p[1] = funvalue(YNAME, 2, st); row[i].p[2] = funvalue(ZNAME, 2, st); + row[i].uv[0] = st[0]; + row[i].uv[1] = st[1]; } i++; }
