root/Development/ray/src/gen/gensurf.c
Wed Apr 23 01:57:04 2025 UTC (6 months, 2 weeks ago) by greg
CVS Tags: HEAD, rad6R0
Changes since 2.32: +3 -2 lines
Diff to previous 2.32 , to selected 2.20
fix: Functio prototypes and other fixes to reduce compiler warnings
Fri Apr 18 23:02:53 2025 UTC (6 months, 3 weeks ago) by greg
Changes since 2.31: +3 -2 lines
Diff to previous 2.31 , to selected 2.20
perf(gensurf,genrev,genworm): Added call to doptimize() for expressions
Tue Jan 21 01:56:27 2025 UTC (9 months, 2 weeks ago) by greg
Changes since 2.30: +12 -2 lines
Diff to previous 2.30 , to selected 2.20
feat(gensurf): Added gensurf -i option to reverse surface normals
Tue Dec 10 17:22:39 2024 UTC (11 months ago) by greg
Diff to previous 2.29 , to selected 2.20
perf(gensurf,genrev,genworm): Fixed setting of eclock that was out-of-date with change from 90's
Thu Apr 1 14:52:55 2021 UTC (4 years, 7 months ago) by greg
Changes since 2.28: +13 -7 lines
Diff to previous 2.28 , to selected 2.20
perf(gensurf): .OBJ output now re-uses identical subsequent normal IDs
Sat Nov 14 00:29:51 2020 UTC (4 years, 11 months ago) by greg
Changes since 2.27: +3 -4 lines
Diff to previous 2.27 , to selected 2.20
feat(gensurf): added surface name output to OBJ
Sun Jun 14 03:54:23 2020 UTC (5 years, 4 months ago) by greg
Changes since 2.26: +5 -4 lines
Diff to previous 2.26 , to selected 2.20
Fixed bug with valid() function and surface normals
Sat Dec 7 02:21:42 2019 UTC (5 years, 11 months ago) by greg
Diff to previous 2.25 , to selected 2.20
Changed gen{worm,surf,rev} to accept expressions for number of segments
Fri May 4 23:56:49 2018 UTC (7 years, 6 months ago) by greg
Changes since 2.24: +10 -4 lines
Fri Jan 12 00:50:17 2018 UTC (7 years, 10 months ago) by greg
Changes since 2.23: +3 -1 lines
Added missing esupport settings for constant expression reduction
Sat Jan 28 23:09:24 2017 UTC (8 years, 9 months ago) by greg
Changes since 2.22: +30 -19 lines
Changed to relative vertex indexing, so we can concatenate OBJ output
Mon Dec 9 22:08:13 2013 UTC (11 years, 11 months ago) by greg
Changes since 2.21: +14 -14 lines
Got rid of outdated "register" declarations
Sun Mar 11 22:27:17 2012 UTC (13 years, 8 months ago) by greg
Changes since 2.20: +17 -23 lines
Diff to previous 2.20
Fixed bug in .OBJ output for degenerate normals
Mon Aug 15 19:48:06 2011 UTC (14 years, 2 months ago) by greg
Diff to previous 2.19
Wed Dec 8 21:37:51 2010 UTC (14 years, 11 months ago) by greg
Changes since 2.18: +5 -8 lines
Eliminated compiler warnings
Thu Oct 18 03:59:54 2007 UTC (18 years ago) by greg
CVS Tags: rad3R9, rad4R0
Increased vertex output accuracy
Tue Oct 9 04:44:54 2007 UTC (18 years, 1 month ago) by greg
Added missing -o option from Usage
Sat Aug 21 11:54:06 2004 UTC (21 years, 2 months ago) by greg
Changes since 2.15: +5 -42 lines
Fri Mar 26 21:30:12 2004 UTC (21 years, 7 months ago) by schorsch
Added "paths.h" for access().
Tue Mar 23 15:18:09 2004 UTC (21 years, 7 months ago) by greg
Changes since 2.13: +2 -4 lines
Fixed missing declaration for atof()
Sun Nov 16 10:29:38 2003 UTC (22 years ago) by schorsch
Changes since 2.12: +66 -30 lines
Mon Aug 4 22:37:53 2003 UTC (22 years, 3 months ago) by greg
Thu Jun 26 00:58:09 2003 UTC (22 years, 4 months ago) by schorsch
Wed Apr 23 00:52:33 2003 UTC (22 years, 6 months ago) by greg
Wed Mar 12 04:59:04 2003 UTC (22 years, 8 months ago) by greg
Changes since 2.8: +26 -20 lines
Tue Mar 11 22:57:45 2003 UTC (22 years, 8 months ago) by greg
Bug fix in output of .OBJ usemtl statement
Tue Mar 11 22:48:20 2003 UTC (22 years, 8 months ago) by greg
Changes since 2.6: +65 -6 lines
Sat Feb 22 02:07:23 2003 UTC (22 years, 8 months ago) by greg
Changes since 2.5: +66 -23 lines
Tue Apr 12 15:16:15 1994 UTC (31 years, 7 months ago) by greg
Changes since 2.4: +1 -59 lines
moved 4x4 matrix inversion routine to library module
Thu Nov 18 09:33:04 1993 UTC (32 years ago) by greg
minor compiler warning fixes
Wed Feb 5 21:05:00 1992 UTC (33 years, 9 months ago) by greg
Changes since 2.2: +18 -13 lines
bug fixes
Thu Jan 30 14:11:39 1992 UTC (33 years, 9 months ago) by greg
Changes since 2.1: +132 -11 lines
added ability to get point values from a file
Tue Nov 12 17:04:49 1991 UTC (34 years ago) by greg
Diff to previous 1.15 , to selected 2.20
Tue Aug 13 16:07:14 1991 UTC (34 years, 3 months ago) by greg
Changes since 1.14: +3 -3 lines
Diff to previous 1.14 , to selected 2.20
changed private variable names with `SYS` context
Tue Apr 23 15:51:11 1991 UTC (34 years, 6 months ago) by greg
Diff to previous 1.13 , to selected 2.20
Tue Apr 23 13:04:58 1991 UTC (34 years, 6 months ago) by greg
Diff to previous 1.12 , to selected 2.20
changed arguments to varset()
Sat Dec 15 15:00:52 1990 UTC (34 years, 11 months ago) by greg
Changes since 1.11: +4 -4 lines
Diff to previous 1.11 , to selected 2.20
added MAT4 type
Thu Aug 2 13:42:56 1990 UTC (35 years, 3 months ago) by greg
Changes since 1.10: +5 -14 lines
Diff to previous 1.10 , to selected 2.20
simplified average normal calculation
Fri Jul 20 14:35:59 1990 UTC (35 years, 4 months ago) by greg
Changes since 1.9: +4 -4 lines
Diff to previous 1.9 , to selected 2.20
Mon Jul 9 09:55:47 1990 UTC (35 years, 4 months ago) by greg
Diff to previous 1.8 , to selected 2.20
set eclock variable for more efficient computations
Sat May 26 19:44:40 1990 UTC (35 years, 5 months ago) by greg
Changes since 1.7: +13 -2 lines
Diff to previous 1.7 , to selected 2.20
eliminated computations outside [0,1] for unsmoothed surfaces
Wed Mar 7 11:14:36 1990 UTC (35 years, 8 months ago) by greg
Changes since 1.6: +17 -3 lines
Diff to previous 1.6 , to selected 2.20
added bezier and bspline functions
Fri Mar 2 17:24:02 1990 UTC (35 years, 8 months ago) by greg
Changes since 1.5: +15 -1 lines
Diff to previous 1.5 , to selected 2.20
Added Bezier cubic function
Fri Jan 19 00:03:08 1990 UTC (35 years, 10 months ago) by greg
Changes since 1.4: +2 -7 lines
Diff to previous 1.4 , to selected 2.20
Wed Oct 18 18:49:09 1989 UTC (36 years, 1 month ago) by greg
Changes since 1.3: +51 -79 lines
Diff to previous 1.3 , to selected 2.20
improved smoothing at edges, improved stability of invmat()
Wed Oct 18 15:01:23 1989 UTC (36 years, 1 month ago) by greg
Changes since 1.2: +307 -83 lines
Diff to previous 1.2 , to selected 2.20
added smoothing option
Sun Sep 10 16:45:16 1989 UTC (36 years, 2 months ago) by greg
Diff to previous 1.1 , to selected 2.20
fixed location of SCCSid
Thu Feb 2 11:16:30 1989 UTC (36 years, 9 months ago) by greg
Diff to selected 2.20
