--- ray/src/gen/gensurf.c 1989/09/10 16:45:16 1.2 +++ ray/src/gen/gensurf.c 1990/03/07 11:14:36 1.7 @@ -1,9 +1,9 @@ -/* Copyright (c) 1989 Regents of the University of California */ - #ifndef lint static char SCCSid[] = "$SunId$ LBL"; #endif +/* Copyright (c) 1989 Regents of the University of California */ + /* * gensurf.c - program to generate functional surfaces * @@ -16,38 +16,44 @@ static char SCCSid[] = "$SunId$ LBL"; * 4/3/87 */ -#include +#include "standard.h" #define XNAME "X_" /* x function name */ #define YNAME "Y_" /* y function name */ #define ZNAME "Z_" /* z function name */ -#define PI 3.14159265358979323846 +#define ABS(x) ((x)>=0 ? (x) : -(x)) -#define FTINY 1e-7 +#define pvect(p) printf(vformat, (p)[0], (p)[1], (p)[2]) -#define vertex(p) printf(vformat, (p)[0], (p)[1], (p)[2]) - char vformat[] = "%15.9g %15.9g %15.9g\n"; +char tsargs[] = "4 surf_dx surf_dy surf_dz surf.cal\n"; +char texname[] = "Phong"; -double funvalue(), dist2(), fdot(), l_hermite(), argument(); +int smooth = 0; /* apply smoothing? */ +char *modname, *surfname; +double funvalue(), l_hermite(), l_bezier(), l_bspline(), argument(); + +typedef struct { + FVECT p; /* vertex position */ + FVECT n; /* average normal */ +} POINT; + + main(argc, argv) int argc; char *argv[]; { - static double *xyz[4]; - double *row0, *row1, *dp; - double v1[3], v2[3], vc1[3], vc2[3]; - double a1, a2; + POINT *row0, *row1, *row2, *rp; int i, j, m, n; char stmp[256]; - double d; - register int k; varset("PI", PI); funset("hermite", 5, l_hermite); + funset("bezier", 5, l_bezier); + funset("bspline", 5, l_bspline); if (argc < 8) goto userror; @@ -57,9 +63,13 @@ char *argv[]; scompile(NULL, argv[++i]); else if (!strcmp(argv[i], "-f")) fcompile(argv[++i]); + else if (!strcmp(argv[i], "-s")) + smooth++; else goto userror; + modname = argv[1]; + surfname = argv[2]; sprintf(stmp, "%s(s,t)=%s;", XNAME, argv[3]); scompile(NULL, stmp); sprintf(stmp, "%s(s,t)=%s;", YNAME, argv[4]); @@ -71,85 +81,39 @@ char *argv[]; if (m <= 0 || n <= 0) goto userror; - row0 = (double *)malloc((n+1)*3*sizeof(double)); - row1 = (double *)malloc((n+1)*3*sizeof(double)); - if (row0 == NULL || row1 == NULL) { + row0 = (POINT *)malloc((n+3)*sizeof(POINT)); + row1 = (POINT *)malloc((n+3)*sizeof(POINT)); + row2 = (POINT *)malloc((n+3)*sizeof(POINT)); + if (row0 == NULL || row1 == NULL || row2 == NULL) { fprintf(stderr, "%s: out of memory\n", argv[0]); quit(1); } - + row0++; row1++; row2++; + /* print header */ printhead(argc, argv); - - comprow(0.0, row1, n); /* compute zeroeth row */ - + /* initialize */ + comprow(-1.0/m, row0, n); + comprow(0.0, row1, n); + comprow(1.0/m, row2, n); + compnorms(row0, row1, row2, n); + /* for each row */ for (i = 0; i < m; i++) { /* compute next row */ - dp = row0; + rp = row0; row0 = row1; - row1 = dp; - comprow((double)(i+1)/m, row1, n); + row1 = row2; + row2 = rp; + comprow((double)(i+2)/m, row2, n); + compnorms(row0, row1, row2, n); for (j = 0; j < n; j++) { - /* get vertices */ - xyz[0] = row0 + 3*j; - xyz[1] = row1 + 3*j; - xyz[2] = xyz[0] + 3; - xyz[3] = xyz[1] + 3; - /* rotate vertices */ - if (dist2(xyz[0],xyz[3]) < dist2(xyz[1],xyz[2])-FTINY) { - dp = xyz[0]; - xyz[0] = xyz[1]; - xyz[1] = xyz[3]; - xyz[3] = xyz[2]; - xyz[2] = dp; - } - /* get normals */ - for (k = 0; k < 3; k++) { - v1[k] = xyz[1][k] - xyz[0][k]; - v2[k] = xyz[2][k] - xyz[0][k]; - } - fcross(vc1, v1, v2); - a1 = fdot(vc1, vc1); - for (k = 0; k < 3; k++) { - v1[k] = xyz[2][k] - xyz[3][k]; - v2[k] = xyz[1][k] - xyz[3][k]; - } - fcross(vc2, v1, v2); - a2 = fdot(vc2, vc2); - /* check coplanar */ - if (a1 > FTINY*FTINY && a2 > FTINY*FTINY) { - d = fdot(vc1, vc2); - if (d*d/a1/a2 >= 1.0-FTINY*FTINY) { - if (d > 0.0) { /* coplanar */ - printf( - "\n%s polygon %s.%d.%d\n", - argv[1], argv[2], i+1, j+1); - printf("0\n0\n12\n"); - vertex(xyz[0]); - vertex(xyz[1]); - vertex(xyz[3]); - vertex(xyz[2]); - } /* else overlapped */ - continue; - } /* else bent */ - } - /* check triangles */ - if (a1 > FTINY*FTINY) { - printf("\n%s polygon %s.%da%d\n", - argv[1], argv[2], i+1, j+1); - printf("0\n0\n9\n"); - vertex(xyz[0]); - vertex(xyz[1]); - vertex(xyz[2]); - } - if (a2 > FTINY*FTINY) { - printf("\n%s polygon %s.%db%d\n", - argv[1], argv[2], i+1, j+1); - printf("0\n0\n9\n"); - vertex(xyz[2]); - vertex(xyz[1]); - vertex(xyz[3]); - } + /* put polygons */ + if ((i+j) & 1) + putsquare(&row0[j], &row1[j], + &row0[j+1], &row1[j+1]); + else + putsquare(&row1[j], &row1[j+1], + &row0[j], &row0[j+1]); } } @@ -157,30 +121,259 @@ char *argv[]; userror: fprintf(stderr, "Usage: %s material name ", argv[0]); - fprintf(stderr, "x(s,t) y(s,t) z(s,t) m n [-e expr] [-f file]\n"); + fprintf(stderr, "x(s,t) y(s,t) z(s,t) m n [-s][-e expr][-f file]\n"); quit(1); } +putsquare(p0, p1, p2, p3) /* put out a square */ +POINT *p0, *p1, *p2, *p3; +{ + static int nout = 0; + FVECT norm[4]; + int axis; + FVECT v1, v2, vc1, vc2; + int ok1, ok2; + /* compute exact normals */ + fvsum(v1, p1->p, p0->p, -1.0); + fvsum(v2, p2->p, p0->p, -1.0); + fcross(vc1, v1, v2); + ok1 = normalize(vc1) != 0.0; + fvsum(v1, p2->p, p3->p, -1.0); + fvsum(v2, p1->p, p3->p, -1.0); + fcross(vc2, v1, v2); + ok2 = normalize(vc2) != 0.0; + if (!(ok1 | ok2)) + return; + /* compute normal interpolation */ + axis = norminterp(norm, p0, p1, p2, p3); + + /* put out quadrilateral? */ + if (ok1 & ok2 && fdot(vc1,vc2) >= 1.0-FTINY*FTINY) { + printf("\n%s ", modname); + if (axis != -1) { + printf("texfunc %s\n", texname); + printf(tsargs); + printf("0\n13\t%d\n", axis); + pvect(norm[0]); + pvect(norm[1]); + pvect(norm[2]); + fvsum(v1, norm[3], vc1, -0.5); + fvsum(v1, v1, vc2, -0.5); + pvect(v1); + printf("\n%s ", texname); + } + printf("polygon %s.%d\n", surfname, ++nout); + printf("0\n0\n12\n"); + pvect(p0->p); + pvect(p1->p); + pvect(p3->p); + pvect(p2->p); + return; + } + /* put out triangles? */ + if (ok1) { + printf("\n%s ", modname); + if (axis != -1) { + printf("texfunc %s\n", texname); + printf(tsargs); + printf("0\n13\t%d\n", axis); + pvect(norm[0]); + pvect(norm[1]); + pvect(norm[2]); + fvsum(v1, norm[3], vc1, -1.0); + pvect(v1); + printf("\n%s ", texname); + } + printf("polygon %s.%d\n", surfname, ++nout); + printf("0\n0\n9\n"); + pvect(p0->p); + pvect(p1->p); + pvect(p2->p); + } + if (ok2) { + printf("\n%s ", modname); + if (axis != -1) { + printf("texfunc %s\n", texname); + printf(tsargs); + printf("0\n13\t%d\n", axis); + pvect(norm[0]); + pvect(norm[1]); + pvect(norm[2]); + fvsum(v2, norm[3], vc2, -1.0); + pvect(v2); + printf("\n%s ", texname); + } + printf("polygon %s.%d\n", surfname, ++nout); + printf("0\n0\n9\n"); + pvect(p2->p); + pvect(p1->p); + pvect(p3->p); + } +} + + comprow(s, row, siz) /* compute row of values */ double s; -register double *row; +register POINT *row; int siz; { - double st[2], step; - + double st[2]; + register int i; + /* compute one past each end */ st[0] = s; - st[1] = 0.0; - step = 1.0 / siz; + for (i = -1; i <= siz+1; i++) { + st[1] = (double)i/siz; + row[i].p[0] = funvalue(XNAME, 2, st); + row[i].p[1] = funvalue(YNAME, 2, st); + row[i].p[2] = funvalue(ZNAME, 2, st); + } +} + + +compnorms(r0, r1, r2, siz) /* compute row of averaged normals */ +register POINT *r0, *r1, *r2; +int siz; +{ + FVECT v1, v2, vc; + register int i; + + if (!smooth) /* not needed if no smoothing */ + return; + /* compute middle points */ while (siz-- >= 0) { - *row++ = funvalue(XNAME, 2, st); - *row++ = funvalue(YNAME, 2, st); - *row++ = funvalue(ZNAME, 2, st); - st[1] += step; + fvsum(v1, r2[0].p, r1[0].p, -1.0); + fvsum(v2, r1[1].p, r1[0].p, -1.0); + fcross(r1[0].n, v1, v2); + fvsum(v1, r0[0].p, r1[0].p, -1.0); + fcross(vc, v2, v1); + fvsum(r1[0].n, r1[0].n, vc, 1.0); + fvsum(v2, r1[-1].p, r1[0].p, -1.0); + fcross(vc, v1, v2); + fvsum(r1[0].n, r1[0].n, vc, 1.0); + fvsum(v1, r2[0].p, r1[0].p, -1.0); + fcross(vc, v2, v1); + fvsum(r1[0].n, r1[0].n, vc, 1.0); + normalize(r1[0].n); + r0++; r1++; r2++; } } +int +norminterp(resmat, p0, p1, p2, p3) /* compute normal interpolation */ +register FVECT resmat[4]; +POINT *p0, *p1, *p2, *p3; +{ +#define u ((ax+1)%3) +#define v ((ax+2)%3) + + register int ax; + double eqnmat[4][4]; + FVECT v1; + register int i, j; + + if (!smooth) /* no interpolation if no smoothing */ + return(-1); + /* find dominant axis */ + VCOPY(v1, p0->n); + fvsum(v1, v1, p1->n, 1.0); + fvsum(v1, v1, p2->n, 1.0); + fvsum(v1, v1, p3->n, 1.0); + ax = ABS(v1[0]) > ABS(v1[1]) ? 0 : 1; + ax = ABS(v1[ax]) > ABS(v1[2]) ? ax : 2; + /* assign equation matrix */ + eqnmat[0][0] = p0->p[u]*p0->p[v]; + eqnmat[0][1] = p0->p[u]; + eqnmat[0][2] = p0->p[v]; + eqnmat[0][3] = 1.0; + eqnmat[1][0] = p1->p[u]*p1->p[v]; + eqnmat[1][1] = p1->p[u]; + eqnmat[1][2] = p1->p[v]; + eqnmat[1][3] = 1.0; + eqnmat[2][0] = p2->p[u]*p2->p[v]; + eqnmat[2][1] = p2->p[u]; + eqnmat[2][2] = p2->p[v]; + eqnmat[2][3] = 1.0; + eqnmat[3][0] = p3->p[u]*p3->p[v]; + eqnmat[3][1] = p3->p[u]; + eqnmat[3][2] = p3->p[v]; + eqnmat[3][3] = 1.0; + /* invert matrix (solve system) */ + if (!invmat(eqnmat, eqnmat)) + return(-1); /* no solution */ + /* compute result matrix */ + for (j = 0; j < 4; j++) + for (i = 0; i < 3; i++) + resmat[j][i] = eqnmat[j][0]*p0->n[i] + + eqnmat[j][1]*p1->n[i] + + eqnmat[j][2]*p2->n[i] + + eqnmat[j][3]*p3->n[i]; + return(ax); + +#undef u +#undef v +} + + +/* + * invmat - computes the inverse of mat into inverse. Returns 1 + * if there exists an inverse, 0 otherwise. It uses Gaussian Elimination + * method. + */ + +invmat(inverse,mat) +double mat[4][4],inverse[4][4]; +{ +#define SWAP(a,b,t) (t=a,a=b,b=t) + + double m4tmp[4][4]; + register int i,j,k; + register double temp; + + bcopy((char *)mat, (char *)m4tmp, sizeof(m4tmp)); + /* set inverse to identity */ + for (i = 0; i < 4; i++) + for (j = 0; j < 4; j++) + inverse[i][j] = i==j ? 1.0 : 0.0; + + for(i = 0; i < 4; i++) { + /* Look for raw with largest pivot and swap raws */ + temp = FTINY; j = -1; + for(k = i; k < 4; k++) + if(ABS(m4tmp[k][i]) > temp) { + temp = ABS(m4tmp[k][i]); + j = k; + } + if(j == -1) /* No replacing raw -> no inverse */ + return(0); + if (j != i) + for(k = 0; k < 4; k++) { + SWAP(m4tmp[i][k],m4tmp[j][k],temp); + SWAP(inverse[i][k],inverse[j][k],temp); + } + + temp = m4tmp[i][i]; + for(k = 0; k < 4; k++) { + m4tmp[i][k] /= temp; + inverse[i][k] /= temp; + } + for(j = 0; j < 4; j++) { + if(j != i) { + temp = m4tmp[j][i]; + for(k = 0; k < 4; k++) { + m4tmp[j][k] -= m4tmp[i][k]*temp; + inverse[j][k] -= inverse[i][k]*temp; + } + } + } + } + return(1); + +#undef SWAP +} + + eputs(msg) char *msg; { @@ -224,4 +417,30 @@ l_hermite() argument(2)*(-2.0*t+3.0)*t*t + argument(3)*((t-2.0)*t+1.0)*t + argument(4)*(t-1.0)*t*t ); +} + + +double +l_bezier() +{ + double t; + + t = argument(5); + return( argument(1) * (1.+t*(-3.+t*(3.-t))) + + argument(2) * 3.*t*(1.+t*(-2.+t)) + + argument(3) * 3.*t*t*(1.-t) + + argument(4) * t*t*t ); +} + + +double +l_bspline() +{ + double t; + + t = argument(5); + return( argument(1) * (1./6.+t*(-1./2.+t*(1./2.-1./6.*t))) + + argument(2) * (2./3.+t*t*(-1.+1./2.*t)) + + argument(3) * (1./6.+t*(1./2.+t*(1./2.-1./2.*t))) + + argument(4) * (1./6.*t*t*t) ); }
