root/radiance/ray/src/gen/gensurf.c
Revision: 2.22
Committed: Mon Dec 9 22:08:13 2013 UTC (10 years, 6 months ago) by greg
CVS Tags: rad4R2P2, rad5R0, rad4R2, rad4R2P1
Changes since 2.21: +14 -14 lines
Got rid of outdated "register" declarations
# User Rev Content
1 greg 1.1 #ifndef lint
2 greg 2.22 static const char RCSid[] = "$Id: gensurf.c,v 2.21 2012/03/11 22:27:17 greg Exp $";
3 greg 1.1 #endif
4 greg 1.2 /*
5 greg 1.1 * gensurf.c - program to generate functional surfaces
6     *
7     * Parametric functions x(s,t), y(s,t) and z(s,t)
8     * specify the surface, which is tesselated into an m by n
9     * array of paired triangles.
10     * The surface normal is defined by the right hand
11     * rule applied to (s,t).
12     *
13     * 4/3/87
14 greg 2.6 *
15     * 4/16/02 Added conditional vertex output
16 greg 1.1 */
17
18 greg 2.14 #include "standard.h"
19 schorsch 2.15
20     #include "paths.h"
21 greg 2.16 #include "resolu.h"
22     #include "rterror.h"
23 schorsch 2.13 #include "calcomp.h"
24 greg 1.1
25 greg 2.6 char XNAME[] = "X`SYS"; /* x function name */
26     char YNAME[] = "Y`SYS"; /* y function name */
27     char ZNAME[] = "Z`SYS"; /* z function name */
28
29     char VNAME[] = "valid"; /* valid vertex name */
30 greg 1.1
31 greg 1.4 #define ABS(x) ((x)>=0 ? (x) : -(x))
32
33 greg 2.9 #define ZEROVECT(v) (DOT(v,v) <= FTINY*FTINY)
34
35 greg 1.3 #define pvect(p) printf(vformat, (p)[0], (p)[1], (p)[2])
36 greg 1.1
37 greg 2.18 char vformat[] = "%18.12g %18.12g %18.12g\n";
38 greg 2.19 char tsargs[] = "4 surf_dx surf_dy surf_dz surf.cal";
39 greg 1.3 char texname[] = "Phong";
40 greg 1.1
41 greg 1.3 int smooth = 0; /* apply smoothing? */
42 greg 2.7 int objout = 0; /* output .OBJ format? */
43 greg 1.1
44 greg 1.3 char *modname, *surfname;
45 greg 1.1
46 greg 2.2 /* recorded data flags */
47     #define HASBORDER 01
48     #define TRIPLETS 02
49     /* a data structure */
50     struct {
51     int flags; /* data type */
52     short m, n; /* number of s and t values */
53 schorsch 2.11 RREAL *data; /* the data itself, s major sort */
54 greg 2.2 } datarec; /* our recorded data */
55 greg 1.3
56 schorsch 2.13 /* XXX this is redundant with rt/noise3.c, should go to a library */
57 greg 2.2 double l_hermite(), l_bezier(), l_bspline(), l_dataval();
58
59 greg 1.3 typedef struct {
60 greg 2.7 int valid; /* point is valid (vertex number) */
61 greg 2.21 int nvalid; /* normal is valid */
62 greg 1.3 FVECT p; /* vertex position */
63     FVECT n; /* average normal */
64 schorsch 2.11 RREAL uv[2]; /* (u,v) position */
65 greg 1.3 } POINT;
66
67
68 schorsch 2.13 void loaddata(char *file, int m, int n, int pointsize);
69     double l_dataval(char *nam);
70     void putobjrow(POINT *rp, int n);
71     void putsquare(POINT *p0, POINT *p1, POINT *p2, POINT *p3);
72     void comprow(double s, POINT *row, int siz);
73     void compnorms(POINT *r0, POINT *r1, POINT *r2, int siz);
74     int norminterp(FVECT resmat[4], POINT *p0, POINT *p1, POINT *p2, POINT *p3);
75
76
77     int
78 greg 1.1 main(argc, argv)
79     int argc;
80     char *argv[];
81     {
82 greg 1.3 POINT *row0, *row1, *row2, *rp;
83 greg 1.1 int i, j, m, n;
84     char stmp[256];
85
86 greg 1.13 varset("PI", ':', PI);
87 greg 1.14 funset("hermite", 5, ':', l_hermite);
88     funset("bezier", 5, ':', l_bezier);
89     funset("bspline", 5, ':', l_bspline);
90 greg 1.1
91     if (argc < 8)
92     goto userror;
93
94     for (i = 8; i < argc; i++)
95     if (!strcmp(argv[i], "-e"))
96 greg 1.10 scompile(argv[++i], NULL, 0);
97 greg 1.1 else if (!strcmp(argv[i], "-f"))
98     fcompile(argv[++i]);
99 greg 1.3 else if (!strcmp(argv[i], "-s"))
100     smooth++;
101 greg 2.7 else if (!strcmp(argv[i], "-o"))
102     objout++;
103 greg 1.1 else
104     goto userror;
105
106 greg 1.3 modname = argv[1];
107     surfname = argv[2];
108 greg 1.1 m = atoi(argv[6]);
109     n = atoi(argv[7]);
110     if (m <= 0 || n <= 0)
111     goto userror;
112 greg 2.2 if (!strcmp(argv[5], "-") || access(argv[5], 4) == 0) { /* file? */
113     funset(ZNAME, 2, ':', l_dataval);
114     if (!strcmp(argv[5],argv[3]) && !strcmp(argv[5],argv[4])) {
115     loaddata(argv[5], m, n, 3);
116     funset(XNAME, 2, ':', l_dataval);
117     funset(YNAME, 2, ':', l_dataval);
118     } else {
119     loaddata(argv[5], m, n, 1);
120     sprintf(stmp, "%s(s,t)=%s;", XNAME, argv[3]);
121     scompile(stmp, NULL, 0);
122     sprintf(stmp, "%s(s,t)=%s;", YNAME, argv[4]);
123     scompile(stmp, NULL, 0);
124     }
125     } else {
126     sprintf(stmp, "%s(s,t)=%s;", XNAME, argv[3]);
127     scompile(stmp, NULL, 0);
128     sprintf(stmp, "%s(s,t)=%s;", YNAME, argv[4]);
129     scompile(stmp, NULL, 0);
130     sprintf(stmp, "%s(s,t)=%s;", ZNAME, argv[5]);
131     scompile(stmp, NULL, 0);
132     }
133 greg 1.4 row0 = (POINT *)malloc((n+3)*sizeof(POINT));
134     row1 = (POINT *)malloc((n+3)*sizeof(POINT));
135     row2 = (POINT *)malloc((n+3)*sizeof(POINT));
136 greg 1.3 if (row0 == NULL || row1 == NULL || row2 == NULL) {
137 greg 1.1 fprintf(stderr, "%s: out of memory\n", argv[0]);
138     quit(1);
139     }
140 greg 1.4 row0++; row1++; row2++;
141 greg 1.3 /* print header */
142 greg 2.16 fputs("# ", stdout);
143     printargs(argc, argv, stdout);
144 greg 1.9 eclock = 0;
145 greg 1.4 /* initialize */
146     comprow(-1.0/m, row0, n);
147 greg 1.3 comprow(0.0, row1, n);
148     comprow(1.0/m, row2, n);
149 greg 1.4 compnorms(row0, row1, row2, n);
150 greg 2.8 if (objout) {
151     printf("\nusemtl %s\n\n", modname);
152 greg 2.7 putobjrow(row1, n);
153 greg 2.8 }
154 greg 1.3 /* for each row */
155 greg 1.1 for (i = 0; i < m; i++) {
156     /* compute next row */
157 greg 1.3 rp = row0;
158 greg 1.1 row0 = row1;
159 greg 1.3 row1 = row2;
160     row2 = rp;
161 greg 1.4 comprow((double)(i+2)/m, row2, n);
162     compnorms(row0, row1, row2, n);
163 greg 2.7 if (objout)
164     putobjrow(row1, n);
165 greg 1.1
166     for (j = 0; j < n; j++) {
167 greg 2.6 int orient = (j & 1);
168 greg 1.3 /* put polygons */
169 greg 2.7 if (!(row0[j].valid && row1[j+1].valid))
170 greg 2.6 orient = 1;
171 greg 2.7 else if (!(row1[j].valid && row0[j+1].valid))
172 greg 2.6 orient = 0;
173     if (orient)
174 greg 1.3 putsquare(&row0[j], &row1[j],
175     &row0[j+1], &row1[j+1]);
176     else
177     putsquare(&row1[j], &row1[j+1],
178     &row0[j], &row0[j+1]);
179 greg 1.1 }
180     }
181
182 schorsch 2.13 return 0;
183 greg 1.1
184     userror:
185     fprintf(stderr, "Usage: %s material name ", argv[0]);
186 greg 2.17 fprintf(stderr, "x(s,t) y(s,t) z(s,t) m n [-s][-o][-e expr][-f file]\n");
187 schorsch 2.13 return 1;
188 greg 2.2 }
189
190
191 schorsch 2.13 void
192     loaddata( /* load point data from file */
193     char *file,
194     int m,
195     int n,
196     int pointsize
197     )
198 greg 2.2 {
199     FILE *fp;
200     char word[64];
201 greg 2.22 int size;
202     RREAL *dp;
203 greg 2.2
204     datarec.flags = HASBORDER; /* assume border values */
205 greg 2.3 datarec.m = m+1;
206     datarec.n = n+1;
207     size = datarec.m*datarec.n*pointsize;
208 greg 2.2 if (pointsize == 3)
209     datarec.flags |= TRIPLETS;
210 schorsch 2.11 dp = (RREAL *)malloc(size*sizeof(RREAL));
211 greg 2.2 if ((datarec.data = dp) == NULL) {
212     fputs("Out of memory\n", stderr);
213     exit(1);
214     }
215     if (!strcmp(file, "-")) {
216     file = "<stdin>";
217     fp = stdin;
218     } else if ((fp = fopen(file, "r")) == NULL) {
219     fputs(file, stderr);
220     fputs(": cannot open\n", stderr);
221     exit(1);
222     }
223     while (size > 0 && fgetword(word, sizeof(word), fp) != NULL) {
224     if (!isflt(word)) {
225     fprintf(stderr, "%s: garbled data value: %s\n",
226     file, word);
227     exit(1);
228     }
229     *dp++ = atof(word);
230     size--;
231     }
232     if (size == (m+n+1)*pointsize) { /* no border after all */
233 greg 2.20 dp = (RREAL *)realloc(datarec.data,
234 schorsch 2.11 m*n*pointsize*sizeof(RREAL));
235 greg 2.2 if (dp != NULL)
236     datarec.data = dp;
237     datarec.flags &= ~HASBORDER;
238 greg 2.3 datarec.m = m;
239     datarec.n = n;
240 greg 2.2 size = 0;
241     }
242 greg 2.3 if (datarec.m < 2 || datarec.n < 2 || size != 0 ||
243     fgetword(word, sizeof(word), fp) != NULL) {
244 greg 2.2 fputs(file, stderr);
245     fputs(": bad number of data points\n", stderr);
246     exit(1);
247     }
248     fclose(fp);
249     }
250
251
252     double
253 schorsch 2.13 l_dataval( /* return recorded data value */
254     char *nam
255     )
256 greg 2.2 {
257     double u, v;
258 greg 2.22 int i, j;
259     RREAL *dp;
260 greg 2.2 double d00, d01, d10, d11;
261     /* compute coordinates */
262     u = argument(1); v = argument(2);
263     if (datarec.flags & HASBORDER) {
264 greg 2.3 i = u *= datarec.m-1;
265     j = v *= datarec.n-1;
266 greg 2.2 } else {
267 greg 2.3 i = u = u*datarec.m - .5;
268     j = v = v*datarec.n - .5;
269 greg 2.2 }
270     if (i < 0) i = 0;
271     else if (i > datarec.m-2) i = datarec.m-2;
272     if (j < 0) j = 0;
273     else if (j > datarec.n-2) j = datarec.n-2;
274     /* compute value */
275     if (datarec.flags & TRIPLETS) {
276 greg 2.3 dp = datarec.data + 3*(j*datarec.m + i);
277     if (nam == ZNAME)
278     dp += 2;
279     else if (nam == YNAME)
280 greg 2.2 dp++;
281     d00 = dp[0]; d01 = dp[3];
282 greg 2.3 dp += 3*datarec.m;
283 greg 2.2 d10 = dp[0]; d11 = dp[3];
284     } else {
285 greg 2.3 dp = datarec.data + j*datarec.m + i;
286 greg 2.2 d00 = dp[0]; d01 = dp[1];
287 greg 2.3 dp += datarec.m;
288 greg 2.2 d10 = dp[0]; d11 = dp[1];
289     }
290     /* bilinear interpolation */
291     return((j+1-v)*((i+1-u)*d00+(u-i)*d01)+(v-j)*((i+1-u)*d10+(u-i)*d11));
292 greg 1.1 }
293
294
295 schorsch 2.13 void
296     putobjrow( /* output vertex row to .OBJ */
297 greg 2.22 POINT *rp,
298 schorsch 2.13 int n
299     )
300 greg 2.7 {
301     static int nverts = 0;
302 greg 2.21 static int nnorms = 0;
303 greg 2.7
304     for ( ; n-- >= 0; rp++) {
305     if (!rp->valid)
306     continue;
307     fputs("v ", stdout);
308 greg 2.9 pvect(rp->p);
309 greg 2.21 if (smooth && !ZEROVECT(rp->n)) {
310 greg 2.7 printf("\tvn %.9g %.9g %.9g\n",
311     rp->n[0], rp->n[1], rp->n[2]);
312 greg 2.21 rp->nvalid = ++nnorms;
313     } else
314     rp->nvalid = 0;
315 greg 2.7 printf("\tvt %.9g %.9g\n", rp->uv[0], rp->uv[1]);
316     rp->valid = ++nverts;
317     }
318     }
319
320
321 schorsch 2.13 void
322     putsquare( /* put out a square */
323     POINT *p0,
324     POINT *p1,
325     POINT *p2,
326     POINT *p3
327     )
328 greg 1.3 {
329     static int nout = 0;
330     FVECT norm[4];
331     int axis;
332     FVECT v1, v2, vc1, vc2;
333     int ok1, ok2;
334     /* compute exact normals */
335 greg 2.7 ok1 = (p0->valid && p1->valid && p2->valid);
336 greg 2.6 if (ok1) {
337 greg 2.9 VSUB(v1, p1->p, p0->p);
338     VSUB(v2, p2->p, p0->p);
339 greg 2.6 fcross(vc1, v1, v2);
340     ok1 = (normalize(vc1) != 0.0);
341     }
342 greg 2.7 ok2 = (p1->valid && p2->valid && p3->valid);
343 greg 2.6 if (ok2) {
344 greg 2.9 VSUB(v1, p2->p, p3->p);
345     VSUB(v2, p1->p, p3->p);
346 greg 2.6 fcross(vc2, v1, v2);
347     ok2 = (normalize(vc2) != 0.0);
348     }
349 greg 1.3 if (!(ok1 | ok2))
350     return;
351 greg 2.7 if (objout) { /* output .OBJ faces */
352     if (ok1 & ok2 && fdot(vc1,vc2) >= 1.0-FTINY*FTINY) {
353     printf("f %d/%d/%d %d/%d/%d %d/%d/%d %d/%d/%d\n",
354 greg 2.21 p0->valid, p0->valid, p0->nvalid,
355     p1->valid, p1->valid, p1->nvalid,
356     p3->valid, p3->valid, p3->nvalid,
357     p2->valid, p2->valid, p2->nvalid);
358 greg 2.7 return;
359     }
360     if (ok1)
361     printf("f %d/%d/%d %d/%d/%d %d/%d/%d\n",
362 greg 2.21 p0->valid, p0->valid, p0->nvalid,
363     p1->valid, p1->valid, p1->nvalid,
364     p2->valid, p2->valid, p2->nvalid);
365 greg 2.7 if (ok2)
366     printf("f %d/%d/%d %d/%d/%d %d/%d/%d\n",
367 greg 2.21 p2->valid, p2->valid, p2->nvalid,
368     p1->valid, p1->valid, p1->nvalid,
369     p3->valid, p3->valid, p3->nvalid);
370 greg 2.7 return;
371     }
372 greg 1.3 /* compute normal interpolation */
373     axis = norminterp(norm, p0, p1, p2, p3);
374
375     /* put out quadrilateral? */
376     if (ok1 & ok2 && fdot(vc1,vc2) >= 1.0-FTINY*FTINY) {
377     printf("\n%s ", modname);
378     if (axis != -1) {
379 greg 2.19 printf("texfunc %s\n%s\n", texname, tsargs);
380 greg 1.3 printf("0\n13\t%d\n", axis);
381     pvect(norm[0]);
382     pvect(norm[1]);
383     pvect(norm[2]);
384     fvsum(v1, norm[3], vc1, -0.5);
385     fvsum(v1, v1, vc2, -0.5);
386     pvect(v1);
387     printf("\n%s ", texname);
388     }
389     printf("polygon %s.%d\n", surfname, ++nout);
390     printf("0\n0\n12\n");
391     pvect(p0->p);
392     pvect(p1->p);
393     pvect(p3->p);
394     pvect(p2->p);
395     return;
396     }
397     /* put out triangles? */
398     if (ok1) {
399     printf("\n%s ", modname);
400     if (axis != -1) {
401 greg 2.19 printf("texfunc %s\n%s\n", texname, tsargs);
402 greg 1.3 printf("0\n13\t%d\n", axis);
403     pvect(norm[0]);
404     pvect(norm[1]);
405     pvect(norm[2]);
406     fvsum(v1, norm[3], vc1, -1.0);
407     pvect(v1);
408     printf("\n%s ", texname);
409     }
410     printf("polygon %s.%d\n", surfname, ++nout);
411     printf("0\n0\n9\n");
412     pvect(p0->p);
413     pvect(p1->p);
414     pvect(p2->p);
415     }
416     if (ok2) {
417     printf("\n%s ", modname);
418     if (axis != -1) {
419 greg 2.19 printf("texfunc %s\n%s\n", texname, tsargs);
420 greg 1.3 printf("0\n13\t%d\n", axis);
421     pvect(norm[0]);
422     pvect(norm[1]);
423     pvect(norm[2]);
424     fvsum(v2, norm[3], vc2, -1.0);
425     pvect(v2);
426     printf("\n%s ", texname);
427     }
428     printf("polygon %s.%d\n", surfname, ++nout);
429     printf("0\n0\n9\n");
430     pvect(p2->p);
431     pvect(p1->p);
432     pvect(p3->p);
433     }
434     }
435
436
437 schorsch 2.13 void
438     comprow( /* compute row of values */
439     double s,
440 greg 2.22 POINT *row,
441 schorsch 2.13 int siz
442     )
443 greg 1.1 {
444 greg 1.4 double st[2];
445 greg 1.8 int end;
446 greg 2.6 int checkvalid;
447 greg 2.22 int i;
448 greg 1.8
449     if (smooth) {
450     i = -1; /* compute one past each end */
451     end = siz+1;
452     } else {
453     if (s < -FTINY || s > 1.0+FTINY)
454     return;
455     i = 0;
456     end = siz;
457     }
458 greg 1.1 st[0] = s;
459 greg 2.6 checkvalid = (fundefined(VNAME) == 2);
460 greg 1.8 while (i <= end) {
461 greg 1.4 st[1] = (double)i/siz;
462 greg 2.6 if (checkvalid && funvalue(VNAME, 2, st) <= 0.0) {
463     row[i].valid = 0;
464     row[i].p[0] = row[i].p[1] = row[i].p[2] = 0.0;
465 greg 2.7 row[i].uv[0] = row[i].uv[1] = 0.0;
466 greg 2.6 } else {
467     row[i].valid = 1;
468     row[i].p[0] = funvalue(XNAME, 2, st);
469     row[i].p[1] = funvalue(YNAME, 2, st);
470     row[i].p[2] = funvalue(ZNAME, 2, st);
471 greg 2.7 row[i].uv[0] = st[0];
472     row[i].uv[1] = st[1];
473 greg 2.6 }
474 greg 1.8 i++;
475 greg 1.1 }
476 greg 1.3 }
477
478
479 schorsch 2.13 void
480     compnorms( /* compute row of averaged normals */
481 greg 2.22 POINT *r0,
482     POINT *r1,
483     POINT *r2,
484 schorsch 2.13 int siz
485     )
486 greg 1.3 {
487 greg 1.11 FVECT v1, v2;
488 greg 1.3
489     if (!smooth) /* not needed if no smoothing */
490     return;
491 greg 2.6 /* compute row 1 normals */
492 greg 1.4 while (siz-- >= 0) {
493 greg 2.6 if (!r1[0].valid)
494     continue;
495     if (!r0[0].valid) {
496     if (!r2[0].valid) {
497     r1[0].n[0] = r1[0].n[1] = r1[0].n[2] = 0.0;
498     continue;
499     }
500     fvsum(v1, r2[0].p, r1[0].p, -1.0);
501     } else if (!r2[0].valid)
502     fvsum(v1, r1[0].p, r0[0].p, -1.0);
503     else
504     fvsum(v1, r2[0].p, r0[0].p, -1.0);
505     if (!r1[-1].valid) {
506     if (!r1[1].valid) {
507     r1[0].n[0] = r1[0].n[1] = r1[0].n[2] = 0.0;
508     continue;
509     }
510     fvsum(v2, r1[1].p, r1[0].p, -1.0);
511     } else if (!r1[1].valid)
512     fvsum(v2, r1[0].p, r1[-1].p, -1.0);
513     else
514     fvsum(v2, r1[1].p, r1[-1].p, -1.0);
515 greg 1.3 fcross(r1[0].n, v1, v2);
516     normalize(r1[0].n);
517     r0++; r1++; r2++;
518     }
519     }
520
521
522     int
523 schorsch 2.13 norminterp( /* compute normal interpolation */
524 greg 2.22 FVECT resmat[4],
525 schorsch 2.13 POINT *p0,
526     POINT *p1,
527     POINT *p2,
528     POINT *p3
529     )
530 greg 1.3 {
531     #define u ((ax+1)%3)
532     #define v ((ax+2)%3)
533
534 greg 2.22 int ax;
535 greg 1.12 MAT4 eqnmat;
536 greg 1.3 FVECT v1;
537 greg 2.22 int i, j;
538 greg 1.3
539     if (!smooth) /* no interpolation if no smoothing */
540     return(-1);
541     /* find dominant axis */
542     VCOPY(v1, p0->n);
543     fvsum(v1, v1, p1->n, 1.0);
544     fvsum(v1, v1, p2->n, 1.0);
545     fvsum(v1, v1, p3->n, 1.0);
546 greg 1.4 ax = ABS(v1[0]) > ABS(v1[1]) ? 0 : 1;
547     ax = ABS(v1[ax]) > ABS(v1[2]) ? ax : 2;
548 greg 1.3 /* assign equation matrix */
549     eqnmat[0][0] = p0->p[u]*p0->p[v];
550     eqnmat[0][1] = p0->p[u];
551     eqnmat[0][2] = p0->p[v];
552     eqnmat[0][3] = 1.0;
553     eqnmat[1][0] = p1->p[u]*p1->p[v];
554     eqnmat[1][1] = p1->p[u];
555     eqnmat[1][2] = p1->p[v];
556     eqnmat[1][3] = 1.0;
557     eqnmat[2][0] = p2->p[u]*p2->p[v];
558     eqnmat[2][1] = p2->p[u];
559     eqnmat[2][2] = p2->p[v];
560     eqnmat[2][3] = 1.0;
561     eqnmat[3][0] = p3->p[u]*p3->p[v];
562     eqnmat[3][1] = p3->p[u];
563     eqnmat[3][2] = p3->p[v];
564     eqnmat[3][3] = 1.0;
565     /* invert matrix (solve system) */
566 greg 2.5 if (!invmat4(eqnmat, eqnmat))
567 greg 1.3 return(-1); /* no solution */
568     /* compute result matrix */
569     for (j = 0; j < 4; j++)
570     for (i = 0; i < 3; i++)
571 greg 1.4 resmat[j][i] = eqnmat[j][0]*p0->n[i] +
572     eqnmat[j][1]*p1->n[i] +
573     eqnmat[j][2]*p2->n[i] +
574     eqnmat[j][3]*p3->n[i];
575 greg 1.3 return(ax);
576
577     #undef u
578     #undef v
579 greg 1.1 }
580
581
582     double
583 greg 2.12 l_hermite(char *nm)
584 greg 1.1 {
585     double t;
586
587     t = argument(5);
588     return( argument(1)*((2.0*t-3.0)*t*t+1.0) +
589     argument(2)*(-2.0*t+3.0)*t*t +
590     argument(3)*((t-2.0)*t+1.0)*t +
591     argument(4)*(t-1.0)*t*t );
592 greg 1.6 }
593
594
595     double
596 greg 2.12 l_bezier(char *nm)
597 greg 1.6 {
598     double t;
599
600     t = argument(5);
601     return( argument(1) * (1.+t*(-3.+t*(3.-t))) +
602     argument(2) * 3.*t*(1.+t*(-2.+t)) +
603     argument(3) * 3.*t*t*(1.-t) +
604     argument(4) * t*t*t );
605 greg 1.7 }
606
607
608     double
609 greg 2.12 l_bspline(char *nm)
610 greg 1.7 {
611     double t;
612
613     t = argument(5);
614     return( argument(1) * (1./6.+t*(-1./2.+t*(1./2.-1./6.*t))) +
615     argument(2) * (2./3.+t*t*(-1.+1./2.*t)) +
616     argument(3) * (1./6.+t*(1./2.+t*(1./2.-1./2.*t))) +
617     argument(4) * (1./6.*t*t*t) );
618 greg 1.1 }
